path: root/include/net/route.h
2008-10-01ipv4: Conditionally enable transparent flow flag when connectingKOVACS Krisztian
Set FLOWI_FLAG_ANYSRC in flowi->flags if the socket has the transparent socket option set. This way we selectively enable certain connections with non-local source addresses to be routed. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Make inet_sock.h independent of route.hKOVACS Krisztian
inet_iif() in inet_sock.h requires route.h. Since users of inet_iif() usually require other route.h functionality anyway this patch moves inet_iif() to route.h. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-27missing bits of net-namespace / sysctlAl Viro
Piss-poor sysctl registration API strikes again, film at 11... What we really need is _pathname_ required to be present in already registered table, so that kernel could warn about bad order. That's the next target for sysctl stuff (and generally saner and more explicit order of initialization of ipv[46] internals wouldn't hurt either). For the time being, here are full fixups required by ..._rotable() stuff; we make per-net sysctl sets descendents of "ro" one and make sure that sufficient skeleton is there before we start registering per-net sysctls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-05netns: add namespace parameter to rt_cache_flushDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29ipv4: Update MTU to all related cache entries in ip_rt_frag_needed()Timo Teras
Add struct net_device parameter to ip_rt_frag_needed() and update MTU to cache entries where ifindex is specified. This is similar to what is already done in ip_rt_redirect(). Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-23[NET]: include/net/route.h - remove duplicate includeJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPV4] route cache: Introduce rt_genid for smooth cache invalidationEric Dumazet
Current ip route cache implementation is not suited to large caches. We can consume a lot of CPU when cache must be invalidated, since we currently need to evict all cache entries, and this eviction is sometimes asynchronous. min_delay & max_delay can somewhat control this asynchronism behavior, but whole thing is a kludge, regularly triggering infamous soft lockup messages. When entries are still in use, this also consumes a lot of ram, filling dst_garbage.list. A better scheme is to use a generation identifier on each entry, so that cache invalidation can be performed by changing the table identifier, without having to scan all entries. No more delayed flushing, no more stalling when secret_interval expires. Invalidated entries will then be freed at GC time (controled by ip_rt_gc_timeout or stress), or when an invalidated entry is found in a chain when an insert is done. Thus we keep a normal equilibrium. This patch : - renames rt_hash_rnd to rt_genid (and makes it an atomic_t) - Adds a new rt_genid field to 'struct rtable' (filling a hole on 64bit) - Checks entry->rt_genid at appropriate places :
2008-01-31[NET]: Introducing socket mark socket option.Laszlo Attila Toth
A userspace program may wish to set the mark for each packets its send without using the netfilter MARK target. Changing the mark can be used for mark based routing without netfilter or for packet filtering. It requires CAP_NET_ADMIN capability. Signed-off-by: Laszlo Attila Toth <panther@balabit.hu> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Routing cache virtualization.Denis V. Lunev
Basically, this piece looks relatively easy. Namespace is already available on the dst entry via device and the device is safe to dereferrence. Compare it with one of a searcher and skip entry if appropriate. The only exception is ip_rt_frag_needed. So, add namespace parameter to it. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Correct namespace for connect-time routing.Denis V. Lunev
ip_route_connect and ip_route_newports are a part of routing API presented to the socket layer. The namespace is available inside them through a socket. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to ip_route_output_key.Denis V. Lunev
Needed to propagate it down to the ip_route_output_flow. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to ip_route_output_flow.Denis V. Lunev
Needed to propagate it down to the __ip_route_output_key. Signed_off_by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to __ip_route_output_key.Denis V. Lunev
This is only required to propagate it down to the ip_route_output_slow. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Pass namespace through ip_rt_ioctl.Denis V. Lunev
... up to rtentry_to_fib_config Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to inet_(dev_)add_type.Eric W. Biederman
The patch extends the inet_addr_type and inet_dev_addr_type with the network namespace pointer. That allows to access the different tables relatively to the network namespace. The modification of the signature function is reported in all the callers of the inet_addr_type using the pointer to the well known init_net. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Add inet_dev_addr_type()Laszlo Attila Toth
Address type search can be limited to an interface by inet_dev_addr_type function. Signed-off-by: Laszlo Attila Toth <panther@balabit.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-07[IPV4]: Remove prototype of ip_rt_adviceDenis V. Lunev
ip_rt_advice has been gone, so no need to keep prototype and debug message. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV4]: Make ip_tos2prio const.Philippe De Muyter
Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV4]: The scheduled removal of multipath cached routing support.David S. Miller
With help from Chris Wedgwood. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[IPV4]: Convert ipv4 route to use the new dst_entry 'next' pointerEric Dumazet
This patch removes the rt_next pointer from 'struct rtable.u' union, and renames u.rt_next to u.dst_rt_next. It also moves 'struct flowi' right after 'struct dst_entry' to prepare the gain on lookups. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[IPV4/IPV6]: Always wait for IPSEC SA resolution in socket contexts.David S. Miller
Do this even for non-blocking sockets. This avoids the silly -EAGAIN that applications can see now, even for non-blocking sockets in some cases (f.e. connect()). With help from Venkat Tekkirala. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: route.h annotationsAl Viro
ip_route_connect(), ip_route_newports() get port numbers net-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: inet_addr_type() annotationsAl Viro
argument and inferred net-endian variables in callers annotated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: ip_route_connect() ipv4 address arguments annotatedAl Viro
annotated address arguments (port number left alone for now); ditto for inferred net-endian variables in callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate ipv4 addresses in struct rtable and struct flowiAl Viro
2006-09-28[IPV4]: ip_rt_redirect() annotationsAl Viro
The first 4 arguments of ip_rt_redirect() are net-endian. Annotated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: ip_route_input() annotationsAl Viro
ip_route_input() takes net-endian source and destination address. * Annotated as such. * arguments of its invocations annotated where needed. * local helpers getting the same values passed to by it (ip_route_input_mc(), ip_route_input_slow(), ip_handle_martian_source(), ip_mkroute_input(), ip_mkroute_input_def(), __mkroute_input()) annotated Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[MLSXFRM]: Add flow labelingVenkat Yekkirala
This labels the flows that could utilize IPSec xfrms at the points the flows are defined so that IPSec policy and SAs at the right label can be used. The following protos are currently not handled, but they should continue to be able to use single-labeled IPSec like they currently do. ipmr ip_gre ipip igmp sit sctp ip6_tunnel (IPv6 over IPv6 tunnel device) decnet Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-25[IPV4]: Aggregate route entries with different TOS valuesIlia Sotnikov
When we get an ICMP need-to-frag message, the original TOS value in the ICMP payload cannot be used as a key to look up the routes to update. This is because the TOS field may have been modified by routers on the way. Similarly, ip_rt_redirect should also ignore the TOS as the router that gave us the message may have modified the TOS value. The patch achieves this objective by aggregating entries with different TOS values (but are otherwise identical) into the same bucket. This makes it easy to update them at the same time when an ICMP message is received. In future we should use a twin-hashing scheme where teh aggregation occurs at the entry level. That is, the TOS goes back into the hash for normal lookups while ICMP lookups will end up with a node that gives us a list that contains all other route entries that differ only by TOS. Signed-off-by: Ilia Sotnikov <hostcc@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-31[IPV4]: Always set fl.proto in ip_route_newportsPatrick McHardy
ip_route_newports uses the struct flowi from the struct rtable returned by ip_route_connect for the new route lookup and just replaces the port numbers if they have changed. If an IPsec policy exists which doesn't match port 0 the struct flowi won't have the proto field set and no xfrm lookup is done for the changed ports. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-22[IPV4]: Fix secondary IP addresses after promotionJamal Hadi Salim
This patch fixes the problem with promoting aliases when: a) a single primary and > 1 secondary addresses b) multiple primary addresses each with at least one secondary address Based on earlier efforts from Brian Pomerantz <bapper@piratehaven.org>, Patrick McHardy <kaber@trash.net> and Thomas Graf <tgraf@suug.ch> Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV4]: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global function: - xfrm4_state.c: xfrm4_state_fini - remove the following unneeded EXPORT_SYMBOL's: - ip_output.c: ip_finish_output - ip_output.c: sysctl_ip_default_ttl - fib_frontend.c: ip_dev_find - inetpeer.c: inet_peer_idlock - ip_options.c: ip_options_compile - ip_options.c: ip_options_undo - net/core/request_sock.c: sysctl_max_syn_backlog Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[PATCH] smp_processor_id() cleanupIngo Molnar
This patch implements a number of smp_processor_id() cleanup ideas that Arjan van de Ven and I came up with. The previous __smp_processor_id/_smp_processor_id/smp_processor_id API spaghetti was hard to follow both on the implementational and on the usage side. Some of the complexity arose from picking wrong names, some of the complexity comes from the fact that not all architectures defined __smp_processor_id. In the new code, there are two externally visible symbols: - smp_processor_id(): debug variant. - raw_smp_processor_id(): nondebug variant. Replaces all existing uses of _smp_processor_id() and __smp_processor_id(). Defined by every SMP architecture in include/asm-*/smp.h. There is one new internal symbol, dependent on DEBUG_PREEMPT: - debug_smp_processor_id(): internal debug variant, mapped to smp_processor_id(). Also, i moved debug_smp_processor_id() from lib/kernel_lock.c into a new lib/smp_processor_id.c file. All related comments got updated and/or clarified. I have build/boot tested the following 8 .config combinations on x86: {SMP,UP} x {PREEMPT,!PREEMPT} x {DEBUG_PREEMPT,!DEBUG_PREEMPT} I have also build/boot tested x64 on UP/PREEMPT/DEBUG_PREEMPT. (Other architectures are untested, but should work just fine.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-29[IPV4]: Kill MULTIPATHHOLDROUTE flag.Pravin B. Shelar
It cannot work properly, so just ignore it in drr and rr multipath algorithms just like the random multipath algorithm does. Suggested by Herbert Xu. Signed-off by: Pravin B. Shelar <pravins@calsoftinc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
