A subsequent patch will add a new multipath hash policy where the packet
fields used for multipath hash calculation are determined by user space.
This patch adds a sysctl that allows user space to set these fields.
The packet fields are represented using a bitmask and are common between
IPv4 and IPv6 to allow user space to use the same numbering across both
protocols. For example, to hash based on standard 5-tuple:
# sysctl -w net.ipv6.fib_multipath_hash_fields=0x0037
net.ipv6.fib_multipath_hash_fields = 0x0037
To avoid introducing holes in 'struct netns_sysctl_ipv6', move the
'bindv6only' field after the multipath hash fields.
The kernel rejects unknown fields, for example:
# sysctl -w net.ipv6.fib_multipath_hash_fields=0x1000
sysctl: setting key "net.ipv6.fib_multipath_hash_fields": Invalid argument
Signed-off-by: Ido Schimmel <idosch@nvidia.com>
Reviewed-by: David Ahern <dsahern@kernel.org>
No longer needed, table pointer arg is now passed via netfilter core.
ip6_dst_ops have cache line alignement.
Moving it at beginning of netns_ipv6
removes a 48 byte hole, and shrinks netns_ipv6
from 12 to 11 cache lines.
Convert most sysctls that can fit in a byte.
After installing a route to the kernel, user space receives an
acknowledgment, which means the route was installed in the kernel,
but not necessarily in hardware.
The asynchronous nature of route installation in hardware can lead
to a routing daemon advertising a route before it was actually installed in
hardware. This can result in packet loss or mis-routed packets until the
route is installed in hardware.
It is also possible for a route already installed in hardware to change
its action and therefore its flags. For example, a host route that is
trapping packets can be "promoted" to perform decapsulation following
the installation of an IPinIP/VXLAN tunnel.
Emit RTM_NEWROUTE notifications whenever RTM_F_OFFLOAD/RTM_F_TRAP flags
are changed. The aim is to provide an indication to user-space
(e.g., routing daemons) about the state of the route in hardware.
Introduce a sysctl that controls this behavior.
Keep the default value at 0 (i.e., do not emit notifications) for several
reasons:
- Multiple RTM_NEWROUTE notification per-route might confuse existing
routing daemons.
- Convergence reasons in routing daemons.
- The extra notifications will negatively impact the insertion rate.
- Not all users are interested in these notifications.
Move fib6_info_hw_flags_set() to C file because it is no longer a short
function.
Signed-off-by: Amit Cohen <amcohen@nvidia.com>
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
Use a per namespace counter, increment it on successful creation
of any route using the source address, decrement it on deletion
of such routes.
This allows us to check easily if the routing decision in the
current namespace depends on the packet source. Will be used
by the next patch.
Suggested-by: David Ahern <dsahern@gmail.com>
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Reviewed-by: David Ahern <dsahern@gmail.com>
Following patch will add rcu grace period before fqdir
rhashtable destruction, so we need to dynamically allocate
fqdir structures to not force expensive synchronize_rcu() calls
in netns dismantle path.
Rename the @frags fields from structs netns_ipv4, netns_ipv6,
netns_nf_frag and netns_ieee802154_lowpan to @fqdir
1) struct netns_frags is renamed to struct fqdir
This structure is really holding many frag queues in a hash table.
2) (struct inet_frag_queue)->net field is renamed to fqdir
since net is generally associated to a 'struct net' pointer
in networking stack.
To make ICMPv6 closer to ICMPv4, add ratemask parameter. Since the ICMP
message types use larger numeric values, a simple bitmask doesn't fit.
I use large bitmap. The input and output are the in form of list of
ranges. Set the default to rate limit all error messages but Packet Too
Big. For Packet Too Big, use ratemask instead of hard-coded.
There are functions where icmpv6_xrlim_allow() and icmpv6_global_allow()
aren't called. This patch only adds them to icmpv6_echo_reply().
Rate limiting error messages is mandated by RFC 4443 but RFC 4890 says
that it is also acceptable to rate limit informational messages. Thus,
I removed the current hard-coded behavior of icmpv6_mask_allow() that
doesn't rate limit informational messages.
v2: Add dummy function proc_do_large_bitmap() if CONFIG_PROC_SYSCTL
isn't defined, expand the description in ip-sysctl.txt and remove
unnecessary conditional before kfree().
v3: Inline the bitmap instead of dynamically allocated. Still is a
pointer to it is needed because of the way proc_do_large_bitmap work.
Signed-off-by: Stephen Suryaputra <ssuryaextr@gmail.com>
In addition to icmp_echo_ignore_multicast, there is a need to also
prevent responding to pings to anycast addresses for security.
IPv4 has icmp_echo_ignore_broadcast to prevent responding to broadcast pings.
IPv6 needs a similar mechanism.
v1->v2:
- Remove NET_IPV6_ICMP_ECHO_IGNORE_MULTICAST.
Use percpu allocation for the ipv6.icmp_sk.
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Another difference between IPv4 and IPv6 is the generation of RTM_DELROUTE
notifications when a device is taken down (admin down) or deleted. IPv4
does not generate a message for routes evicted by the down or delete;
IPv6 does. A NOS at scale really needs to avoid these messages and have
IPv4 and IPv6 behave similarly, relying on userspace to handle link
notifications and evict the routes.
At this point existing user behavior needs to be preserved. Since
notifications are a global action (not per app) the only way to preserve
existing behavior and allow the messages to be skipped is to add a new
sysctl (net/ipv6/route/skip_notify_on_dev_down) which can be set to
disable the notificatioons.
IPv6 route code already supports the option to skip the message (it is
used for multipath routes for example). Besides the new sysctl we need
to pass the skip_notify setting through the generic fib6_clean and
fib6_walk functions to fib6_clean_node and to set skip_notify on calls
to __ip_del_rt for the addrconf_ifdown path.
Signed-off-by: David Ahern <dsahern@gmail.com>
Preventing the kernel from responding to ICMP Echo Requests messages
can be useful in several ways. The sysctl parameter
'icmp_echo_ignore_all' can be used to prevent the kernel from
responding to IPv4 ICMP echo requests. For IPv6 pings, such
a sysctl kernel parameter did not exist.
Add the ability to prevent the kernel from responding to IPv6
ICMP echo requests through the use of the following sysctl
parameter : /proc/sys/net/ipv6/icmp/echo_ignore_all.
Update the documentation to reflect this change.
Signed-off-by: Virgile Jarry <virgile@acceis.fr>
It is a waste of memory to use a full "struct netns_sysctl_ipv6"
while only one pointer is really used, considering netns_sysctl_ipv6
keeps growing.
Also, since "struct netns_frags" has cache line alignment,
it is better to move the frags_hdr pointer outside, otherwise
we spend a full cache line for this pointer.
This saves 192 bytes of memory per netns.
Fixes: c038a767cd69 ("ipv6: add a new namespace for nf_conntrack_reasm")
ECMP (equal-cost multipath) hashes are typically computed on the packets'
5-tuple(src IP, dst IP, src port, dst port, L4 proto).
For encapsulated packets, the L4 data is not readily available and ECMP
hashing will often revert to (src IP, dst IP). This will lead to traffic
polarization on a single ECMP path, causing congestion and waste of network
capacity.
In IPv6, the 20-bit flow label field is also used as part of the ECMP hash.
In the lack of L4 data, the hashing will be on (src IP, dst IP, flow
label). Having a non-zero flow label is thus important for proper traffic
load balancing when L4 data is unavailable (i.e., when packets are
encapsulated).
Currently, the seg6_do_srh_encap() function extracts the original packet's
flow label and set it as the outer IPv6 flow label. There are two issues
with this behaviour:
a) There is no guarantee that the inner flow label is set by the source.
b) If the original packet is not IPv6, the flow label will be set to
zero (e.g., IPv4 or L2 encap).
This patch adds a function, named seg6_make_flowlabel(), that computes a
flow label from a given skb. It supports IPv6, IPv4 and L2 payloads, and
leverages the per namespace 'seg6_flowlabel" sysctl value.
The currently support behaviours are as follows:
-1 set flowlabel to zero.
0 copy flowlabel from Inner paceket in case of Inner IPv6
(Set flowlabel to 0 in case IPv4/L2)
1 Compute the flowlabel using seg6_make_flowlabel()
This patch has been tested for IPv6, IPv4, and L2 traffic.
Signed-off-by: Ahmed Abdelsalam <amsalam20@gmail.com>
Acked-by: David Lebrun <dlebrun@google.com>
Convert all code paths referencing a FIB entry from
rt6_info to fib6_info.
ip6_null_entry will stay a dst based return for lookups that fail to
match an entry.
Add a new fib6_null_entry which constitutes the root node and leafs
for fibs. Replace existing references to ip6_null_entry with the
new fib6_null_entry when dealing with FIBs.
In similar fashion to ipmr, support fib notifications for ip6mr mfc and
vif related events. This would later allow drivers to react to said
notifications and offload the IPv6 mroutes.
Signed-off-by: Yuval Mintz <yuvalm@mellanox.com>
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Some operators prefer IPv6 path selection to use a standard 5-tuple
hash rather than just an L3 hash with the flow the label. To that end
add support to IPv6 for multipath hash policy similar to bf4e0a3db97eb
("net: ipv4: add support for ECMP hash policy choice"). The default
is still L3 which covers source and destination addresses along with
flow label and IPv6 protocol.
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
Tested-by: Ido Schimmel <idosch@mellanox.com>
Reviewed-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Following previous changes to ip6mr, mr_table and mr6_table are
basically the same [up to mr6_table having additional '6' suffixes to
its variable names].
Move the common structure definition into a common header; This
requires renaming all references in ip6mr to variables that had the
distinct suffix.
Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Dissect flow in fwd path if fib rules require it. Controlled by
a flag to avoid penatly for the common case. Flag is set when fib
rules with sport, dport and proto match that require flow dissect
are installed. Also passes the dissected hash keys to the multipath
hash function when applicable to avoid dissecting the flow again.
icmp packets will continue to use inner header for hash
calculations.
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Acked-by: Paolo Abeni <pabeni@redhat.com>
Files removed in 'net-next' had their license header updated
in 'net'. We take the remove from 'net-next'.
RFC 8200 (IPv6) defines Hop-by-Hop options and Destination options
extension headers. Both of these carry a list of TLVs which is
only limited by the maximum length of the extension header (2048
bytes). By the spec a host must process all the TLVs in these
options, however these could be used as a fairly obvious
denial of service attack. I think this could in fact be
a significant DOS vector on the Internet, one mitigating
factor might be that many FWs drop all packets with EH (and
obviously this is only IPv6) so an Internet wide attack might not
be so effective (yet!).
By my calculation, the worse case packet with TLVs in a standard
1500 byte MTU packet that would be processed by the stack contains
1282 invidual TLVs (including pad TLVS) or 724 two byte TLVs. I
wrote a quick test program that floods a whole bunch of these
packets to a host and sure enough there is substantial time spent
in ip6_parse_tlv. These packets contain nothing but unknown TLVS
(that are ignored), TLV padding, and bogus UDP header with zero
payload length.
25.38% [kernel] [k] __fib6_clean_all
21.63% [kernel] [k] ip6_parse_tlv
4.21% [kernel] [k] __local_bh_enable_ip
2.18% [kernel] [k] ip6_pol_route.isra.39
1.98% [kernel] [k] fib6_walk_continue
1.88% [kernel] [k] _raw_write_lock_bh
1.65% [kernel] [k] dst_release
This patch adds configurable limits to Destination and Hop-by-Hop
options. There are three limits that may be set:
- Limit the number of options in a Hop-by-Hop or Destination options
extension header.
- Limit the byte length of a Hop-by-Hop or Destination options
extension header.
- Disallow unrecognized options in a Hop-by-Hop or Destination
options extension header.
The limits are set in corresponding sysctls:
ipv6.sysctl.max_dst_opts_cnt
ipv6.sysctl.max_hbh_opts_cnt
ipv6.sysctl.max_dst_opts_len
ipv6.sysctl.max_hbh_opts_len
If a max_*_opts_cnt is less than zero then unknown TLVs are disallowed.
The number of known TLVs that are allowed is the absolute value of
this number.
If a limit is exceeded when processing an extension header the packet is
dropped.
Default values are set to 8 for options counts, and set to INT_MAX
for maximum length. Note the choice to limit options to 8 is an
arbitrary guess (roughly based on the fact that the stack supports
three HBH options and just one destination option).
These limits have being proposed in draft-ietf-6man-rfc6434-bis.
Tested (by Martin Lau)
I tested out 1 thread (i.e. one raw_udp process).
I changed the net.ipv6.max_dst_(opts|hbh)_number between 8 to 2048.
With sysctls setting to 2048, the softirq% is packed to 100%.
With 8, the softirq% is almost unnoticable from mpstat.
v2;
- Code and documention cleanup.
- Change references of RFC2460 to be RFC8200.
- Add reference to RFC6434-bis where the limits will be in standard.
Signed-off-by: Tom Herbert <tom@quantonium.net>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Having a global list of labels do not scale to thousands of
netns in the cloud era. This causes quadratic behavior on
netns creation and deletion.
This is time having a per netns list of ~10 labels.
Tested:
$ time perf record (for f in `seq 1 3000` ; do ip netns add tast$f; done)
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 3.637 MB perf.data (~158898 samples) ]
real 0m20.837s # instead of 0m24.227s
user 0m0.328s
sys 0m20.338s # instead of 0m23.753s
16.17% ip [kernel.kallsyms] [k] netlink_broadcast_filtered
12.30% ip [kernel.kallsyms] [k] netlink_has_listeners
6.76% ip [kernel.kallsyms] [k] _raw_spin_lock_irqsave
5.78% ip [kernel.kallsyms] [k] memset_erms
5.77% ip [kernel.kallsyms] [k] kobject_uevent_env
5.18% ip [kernel.kallsyms] [k] refcount_sub_and_test
4.96% ip [kernel.kallsyms] [k] _raw_read_lock
3.82% ip [kernel.kallsyms] [k] refcount_inc_not_zero
3.33% ip [kernel.kallsyms] [k] _raw_spin_unlock_irqrestore
2.11% ip [kernel.kallsyms] [k] unmap_page_range
1.77% ip [kernel.kallsyms] [k] __wake_up
1.69% ip [kernel.kallsyms] [k] strlen
1.17% ip [kernel.kallsyms] [k] __wake_up_common
1.09% ip [kernel.kallsyms] [k] insert_header
1.04% ip [kernel.kallsyms] [k] page_remove_rmap
1.01% ip [kernel.kallsyms] [k] consume_skb
0.98% ip [kernel.kallsyms] [k] netlink_trim
0.51% ip [kernel.kallsyms] [k] kernfs_link_sibling
0.51% ip [kernel.kallsyms] [k] filemap_map_pages
0.46% ip [kernel.kallsyms] [k] memcpy_erms
Reflecting IPv6 Flow Label at server nodes is useful in environments
that employ multipath routing to load balance the requests. As "IPv6
Flow Label Reflection" standard draft [1] points out - ICMPv6 PTB error
messages generated in response to a downstream packets from the server
can be routed by a load balancer back to the original server without
looking at transport headers, if the server applies the flow label
reflection. This enables the Path MTU Discovery past the ECMP router in
load-balance or anycast environments where each server node is reachable
by only one path.
Introduce a sysctl to enable flow label reflection per net namespace for
all newly created sockets. Same could be earlier achieved only per
socket by setting the IPV6_FL_F_REFLECT flag for the IPV6_FLOWLABEL_MGR
socket option.
[1] https://tools.ietf.org/html/draft-wang-6man-flow-label-reflection-01
Signed-off-by: Jakub Sitnicki <jkbs@redhat.com>
If the user hasn't installed any custom rules, don't go through the
whole FIB rules layer. This is pretty similar to f4530fa574df (ipv4:
Avoid overhead when no custom FIB rules are installed).
Using a micro-benchmark module [1], timing ip6_route_output() with
get_cycles(), with 40,000 routes in the main routing table, before this
patch:
min=606 max=12911 count=627 average=1959 95th=4903 90th=3747 50th=1602 mad=821
table=254 avgdepth=21.8 maxdepth=39
value │ ┊ count
600 │▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ 199
880 │▒▒▒░░░░░░░░░░░░░░░░ 43
1160 │▒▒▒░░░░░░░░░░░░░░░░░░░░ 48
1440 │▒▒▒░░░░░░░░░░░░░░░░░░░░░░░ 43
1720 │▒▒▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░░ 59
2000 │▒▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 50
2280 │▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 26
2560 │▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 31
2840 │▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 28
3120 │▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 17
3400 │▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 17
3680 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 8
3960 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 11
4240 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 6
4520 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 6
4800 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 9
After:
min=544 max=11687 count=627 average=1776 95th=4546 90th=3585 50th=1227 mad=565
value │ ┊ count
540 │▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ 201
800 │▒▒▒▒▒░░░░░░░░░░░░░░░░ 63
1060 │▒▒▒▒▒░░░░░░░░░░░░░░░░░░░░░ 68
1320 │▒▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░ 39
1580 │▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 32
1840 │▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 32
2100 │▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 34
2360 │▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 33
2620 │▒▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 26
2880 │▒░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 22
3140 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 9
3400 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 8
3660 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 9
3920 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 8
4180 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 8
4440 │░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 8
At the frequency of the host during the bench (~ 3.7 GHz), this is
about a 100 ns difference on the median value.
A next step would be to collapse local and main tables, as in
0ddcf43d5d4a (ipv4: FIB Local/MAIN table collapse).
[1]: https://github.com/vincentbernat/network-lab/blob/master/lab-routes-ipv6/kbench_mod.c
Signed-off-by: Vincent Bernat <vincent@bernat.im>
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
Acked-by: David Ahern <dsahern@gmail.com>
We're about to add IPv6 FIB offload support, so implement the necessary
callbacks in IPv6 code, which will later allow us to add routes and
rules notifications.
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
This patch adds the necessary hooks and structures to provide support
for SR-IPv6 control plane, essentially the Generic Netlink commands
that will be used for userspace control over the Segment Routing
kernel structures.
The genetlink commands provide control over two different structures:
tunnel source and HMAC data. The tunnel source is the source address
that will be used by default when encapsulating packets into an
outer IPv6 header + SRH. If the tunnel source is set to :: then an
address of the outgoing interface will be selected as the source.
The HMAC commands currently just return ENOTSUPP and will be implemented
in a future patch.
Signed-off-by: David Lebrun <david.lebrun@uclouvain.be>
One of our customers observed issues with FIB6 garbage collectors
running in different network namespaces blocking each other, resulting
in soft lockups (fib6_run_gc() initiated from timer runs always in
forced mode).
Now that FIB6 walkers are separated per namespace, there is no more need
for instances of fib6_run_gc() in different namespaces blocking each
other. There is still a call to icmp6_dst_gc() which operates on shared
data but this function is protected by its own shared lock.
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com>
The IPv6 FIB data structures are separated per network namespace but
there is still only one global walkers list and one global walker list
lock. This means changes in one namespace unnecessarily interfere with
walkers in other namespaces.
Replace the global list with per-netns lists (and give each its own
lock).
Add support to allow non-local binds similar to how this was done for IPv4.
Non-local binds are very useful in emulating the Internet in a box, etc.
This add the ip_nonlocal_bind sysctl under ipv6.
Testing:
Set up nonlocal binding and receive routing on a host, e.g.:
ip -6 rule add from ::/0 iif eth0 lookup 200
ip -6 route add local 2001:0:0:1::/64 dev lo proto kernel scope host table 200
sysctl -w net.ipv6.ip_nonlocal_bind=1
Set up routing to 2001:0:0:1::/64 on peer to go to first host
ping6 -I 2001:0:0:1::1 peer-address -- to verify
Signed-off-by: Tom Herbert <tom@herbertland.com>
This patch divides the IPv6 flow label space into two ranges:
0-7ffff is reserved for flow label manager, 80000-fffff will be
used for creating auto flow labels (per RFC6438). This only affects how
labels are set on transmit, it does not affect receive. This range split
can be disbaled by systcl.
Background:
IPv6 flow labels have been an unmitigated disappointment thus far
in the lifetime of IPv6. Support in HW devices to use them for ECMP
is lacking, and OSes don't turn them on by default. If we had these
we could get much better hashing in IPv6 networks without resorting
to DPI, possibly eliminating some of the motivations to to define new
encaps in UDP just for getting ECMP.
Unfortunately, the initial specfications of IPv6 did not clarify
how they are to be used. There has always been a vague concept that
these can be used for ECMP, flow hashing, etc. and we do now have a
good standard how to this in RFC6438. The problem is that flow labels
can be either stateful or stateless (as in RFC6438), and we are
presented with the possibility that a stateless label may collide
with a stateful one. Attempts to split the flow label space were
rejected in IETF. When we added support in Linux for RFC6438, we
could not turn on flow labels by default due to this conflict.
This patch splits the flow label space and should give us
a path to enabling auto flow labels by default for all IPv6 packets.
This is an API change so we need to consider compatibility with
existing deployment. The stateful range is chosen to be the lower
values in hopes that most uses would have chosen small numbers.
Once we resolve the stateless/stateful issue, we can proceed to
look at enabling RFC6438 flow labels by default (starting with
scaled testing).
This is specified by RFC 7217.
Cc: Erik Kline <ek@google.com>
Cc: Fernando Gont <fgont@si6networks.com>
Cc: Lorenzo Colitti <lorenzo@google.com>
Cc: YOSHIFUJI Hideaki/吉藤英明 <hideaki.yoshifuji@miraclelinux.com>
Joining multicast group on ethernet level via "ip maddr" command would
not work if we have an Ethernet switch that does igmp snooping since
the switch would not replicate multicast packets on ports that did not
have IGMP reports for the multicast addresses.
Linux vxlan interfaces created via "ip link add vxlan" have the group option
that enables then to do the required join.
By extending ip address command with option "autojoin" we can get similar
functionality for openvswitch vxlan interfaces as well as other tunneling
mechanisms that need to receive multicast traffic. The kernel code is
structured similar to how the vxlan driver does a group join / leave.
example:
ip address add 224.1.1.10/24 dev eth5 autojoin
ip address del 224.1.1.10/24 dev eth5
Signed-off-by: Madhu Challa <challa@noironetworks.com>
Try to reduce number of possible fn_sernum mutation by constraining them
to their namespace.
Also remove rt_genid which I forgot to remove in 705f1c869d577c ("ipv6:
remove rt6i_genid").
Cc: YOSHIFUJI Hideaki <hideaki@yoshifuji.org>
Cc: Martin Lau <kafai@fb.com>
Automatically generate flow labels for IPv6 packets on transmit.
The flow label is computed based on skb_get_hash. The flow label will
only automatically be set when it is zero otherwise (i.e. flow label
manager hasn't set one). This supports the transmit side functionality
of RFC 6438.
Added an IPv6 sysctl auto_flowlabels to enable/disable this behavior
system wide, and added IPV6_AUTOFLOWLABEL socket option to enable this
functionality per socket.
By default, auto flowlabels are disabled to avoid possible conflicts
with flow label manager, however if this feature proves useful we
may want to enable it by default.
It should also be noted that FreeBSD has already implemented automatic
flow labels (including the sysctl and socket option). In FreeBSD,
automatic flow labels default to enabled.
Performance impact:
Running super_netperf with 200 flows for TCP_RR and UDP_RR for
IPv6. Note that in UDP case, __skb_get_hash will be called for
every packet with explains slight regression. In the TCP case
the hash is saved in the socket so there is no regression.
Automatic flow labels disabled:
TCP_RR:
86.53% CPU utilization
127/195/322 90/95/99% latencies
1.40498e+06 tps
UDP_RR:
90.70% CPU utilization
118/168/243 90/95/99% latencies
1.50309e+06 tps
Automatic flow labels enabled:
TCP_RR:
85.90% CPU utilization
128/199/337 90/95/99% latencies
1.40051e+06
UDP_RR
92.61% CPU utilization
115/164/236 90/95/99% latencies
1.4687e+06
Signed-off-by: Tom Herbert <therbert@google.com>
Kernel-originated IP packets that have no user socket associated
with them (e.g., ICMP errors and echo replies, TCP RSTs, etc.)
are emitted with a mark of zero. Add a sysctl to make them have
the same mark as the packet they are replying to.
This allows an administrator that wishes to do so to use
mark-based routing, firewalling, etc. for these replies by
marking the original packets inbound.
Tested using user-mode linux:
- ICMP/ICMPv6 echo replies and errors.
- TCP RST packets (IPv4 and IPv6).
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
With the introduction of IPV6_FL_F_REFLECT, there is no guarantee of
flow label unicity. This patch introduces a new sysctl to protect the old
behaviour, enable by default.
Changelog of V3:
* rename ip6_flowlabel_consistency to flowlabel_consistency
* use net_info_ratelimited()
* checkpatch cleanups
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
This change move anycast_src_echo_reply sysctl with other ipv6 sysctls.
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Francois-Xavier Le Bail <fx.lebail@yahoo.com>
This change allows to follow a recommandation of RFC4942.
- Add "anycast_src_echo_reply" sysctl to control the use of anycast addresses
as source addresses for ICMPv6 echo reply. This sysctl is false by default
to preserve existing behavior.
- Add inline check ipv6_anycast_destination().
- Use them in icmpv6_echo_reply().
Reference:
RFC4942 - IPv6 Transition/Coexistence Security Considerations
(http://tools.ietf.org/html/rfc4942#section-2.1.6)
2.1.6. Anycast Traffic Identification and Security
To avoid exposing knowledge about the internal structure of the
network, it is recommended that anycast servers now take advantage of
the ability to return responses with the anycast address as the
source address if possible.
Current net name space has only one genid for both IPv4 and IPv6, it has below
drawbacks:
- Add/delete an IPv4 address will invalidate all IPv6 routing table entries.
- Insert/remove XFRM policy will also invalidate both IPv4/IPv6 routing table
entries even when the policy is only applied for one address family.
Thus, this patch attempt to split one genid for two to cater for IPv4 and IPv6
separately in a fine granularity.
Signed-off-by: Fan Du <fan.du@windriver.com>
This patch adds a dev_addr_genid for IPv6. The goal is to use it, combined with
dev_base_seq to check if a change occurs during a netlink dump.
If a change is detected, the flag NLM_F_DUMP_INTR is set in the first message
after the dump was interrupted.
Note that only dump of unicast addresses is checked (multicast and anycast are
not checked).
Reported-by: Junwei Zhang <junwei.zhang@6wind.com>
Reported-by: Hongjun Li <hongjun.li@6wind.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
The xfrm gc threshold can be configured via xfrm{4,6}_gc_thresh
sysctl but currently only in init_net, other namespaces always
use the default value. This can substantially limit the number
of IPsec tunnels that can be effectively used.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
As pointed by Michal, it is necessary to add a new
namespace for nf_conntrack_reasm code, this prepares
for the second patch.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Michal Kubeček <mkubecek@suse.cz>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: netfilter-devel@vger.kernel.org
Signed-off-by: Cong Wang <amwang@redhat.com>
now inetpeer doesn't support namespace,the information will
be leaking across namespace.
this patch move the global vars v4_peers and v6_peers to
netns_ipv4 and netns_ipv6 as a field peers.
add struct pernet_operations inetpeer_ops to initial pernet
inetpeer data.
and change family_to_base and inet_getpeer to support namespace.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
The sysctl core no longer natively understands sysctl tables
with .child entries.
Split the ipv6_table to remove the .child entries.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
