path: root/include/net/netlink.h
2011-02-01netfilter: NFNL_SUBSYS_IPSET id and NLA_PUT_NET* macrosJozsef Kadlecsik
The patch adds the NFNL_SUBSYS_IPSET id and NLA_PUT_NET* macros to the vanilla kernel. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-11-16netlink: let nlmsg and nla functions take pointer-to-const argsJan Engelhardt
The changed functions do not modify the NL messages and/or attributes at all. They should use const (similar to strchr), so that callers which have a const nlmsg/nlattr around can make use of them without casting. While at it, constify a data array. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-04netlink: Make nlmsg_find_attr take a const nlmsghdr*.Nelson Elhage
This will let us use it on a nlmsghdr stored inside a netlink_callback. Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-23net: Fix a typo in netlink.hJustin P. Mattock
Fix a typo in include/net/netlink.h should be finalize instead of finanlize Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-19netlink: fix unaligned access in nla_get_be64()Pablo Neira Ayuso
This patch fixes a unaligned access in nla_get_be64() that was introduced by myself in a17c859849402315613a0015ac8fbf101acf0cc1. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18const: struct nla_policyAlexey Dobriyan
Make remaining netlink policies as const. Fixup coding style where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-25netlink: constify nlmsghdr argumentsPatrick McHardy
Consitfy nlmsghdr arguments to a couple of functions as preparation for the next patch, which will constify the netlink message data in all nfnetlink users. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-05-27netfilter: conntrack: add support for DCCP handshake sequence to ctnetlinkPablo Neira Ayuso
This patch adds CTA_PROTOINFO_DCCP_HANDSHAKE_SEQ that exposes the u64 handshake sequence number to user-space. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-25netlink: add nla_policy_len()Holger Eitzenberger
It calculates the max. length of a Netlink policy, which is usefull for allocating Netlink buffers roughly the size of the actual message. Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-12-25netlink: fix (theoretical) overrun in message iterationVegard Nossum
See commit 1045b03e07d85f3545118510a587035536030c1c ("netlink: fix overrun in attribute iteration") for a detailed explanation of why this patch is necessary. In short, nlmsg_next() can make "remaining" go negative, and the remaining >= sizeof(...) comparison will promote "remaining" to an unsigned type, which means that the expression will evaluate to true for negative numbers, even though it was not intended. I put "theoretical" in the title because I have no evidence that this can actually happen, but I suspect that a crafted netlink packet can trigger some badness. Note that the last test, which seemingly has the exact same problem (also true for nla_ok()), is perfectly OK, since we already know that remaining is positive. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28netlink: constify struct nlattr * arg to parsing functionsPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath9k/core.c drivers/net/wireless/ath9k/main.c net/core/dev.c
2008-09-11netlink: fix overrun in attribute iterationVegard Nossum
kmemcheck reported this: kmemcheck: Caught 16-bit read from uninitialized memory (f6c1ba30) 0500110001508abf050010000500000002017300140000006f72672e66726565 i i i i i i i i i i i i i u u u u u u u u u u u u u u u u u u u ^ Pid: 3462, comm: wpa_supplicant Not tainted (2.6.27-rc3-00054-g6397ab9-dirty #13) EIP: 0060:[<c05de64a>] EFLAGS: 00010296 CPU: 0 EIP is at nla_parse+0x5a/0xf0 EAX: 00000008 EBX: fffffffd ECX: c06f16c0 EDX: 00000005 ESI: 00000010 EDI: f6c1ba30 EBP: f6367c6c ESP: c0a11e88 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 CR0: 8005003b CR2: f781cc84 CR3: 3632f000 CR4: 000006d0 DR0: c0ead9bc DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff4ff0 DR7: 00000400 [<c05d4b23>] rtnl_setlink+0x63/0x130 [<c05d5f75>] rtnetlink_rcv_msg+0x165/0x200 [<c05ddf66>] netlink_rcv_skb+0x76/0xa0 [<c05d5dfe>] rtnetlink_rcv+0x1e/0x30 [<c05dda21>] netlink_unicast+0x281/0x290 [<c05ddbe9>] netlink_sendmsg+0x1b9/0x2b0 [<c05beef2>] sock_sendmsg+0xd2/0x100 [<c05bf945>] sys_sendto+0xa5/0xd0 [<c05bf9a6>] sys_send+0x36/0x40 [<c05c03d6>] sys_socketcall+0x1e6/0x2c0 [<c020353b>] sysenter_do_call+0x12/0x3f [<ffffffff>] 0xffffffff This is the line in nla_ok(): /** * nla_ok - check if the netlink attribute fits into the remaining bytes * @nla: netlink attribute * @remaining: number of bytes remaining in attribute stream */ static inline int nla_ok(const struct nlattr *nla, int remaining) { return remaining >= sizeof(*nla) && nla->nla_len >= sizeof(*nla) && nla->nla_len <= remaining; } It turns out that remaining can become negative due to alignment in nla_next(). But GCC promotes "remaining" to unsigned in the test against sizeof(*nla) above. Therefore the test succeeds, and the nla_for_each_attr() may access memory outside the received buffer. A short example illustrating this point is here: #include <stdio.h> main(void) { printf("%d\n", -1 >= sizeof(int)); } ...which prints "1". This patch adds a cast in front of the sizeof so that GCC will make a signed comparison and fix the illegal memory dereference. With the patch applied, there is no kmemcheck report. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-02netlink: Remove compat API for nested attributesThomas Graf
Removes all _nested_compat() functions from the API. The prio qdisc no longer requires them and netem has its own format anyway. Their existance is only confusing. Resend: Also remove the wrapper macro. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-21netlink: add NLA_PUT_BE64 macroKrzysztof Piotr Oledzki
Add NLA_PUT_BE64 macro required for 64bit counters in netfilter Signed-off-by: Krzysztof Piotr Oledzki <ole@ans.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03netlink: Improve returned error codesThomas Graf
Make nlmsg_trim(), nlmsg_cancel(), genlmsg_cancel(), and nla_nest_cancel() void functions. Return -EMSGSIZE instead of -1 if the provided message buffer is not big enough. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-22netlink: Fix nla_parse_nested_compat() to call nla_parse() directlyThomas Graf
The purpose of nla_parse_nested_compat() is to parse attributes which contain a struct followed by a stream of nested attributes. So far, it called nla_parse_nested() to parse the stream of nested attributes which was wrong, as nla_parse_nested() expects a container attribute as data which holds the attribute stream. It needs to call nla_parse() directly while pointing at the next possible alignment point after the struct in the beginning of the attribute. With this patch, I can no longer reproduce the reported leftover warnings. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETLINK]: Add nla_append()Patrick McHardy
Used to append data to a message without a header or padding. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns to nl_info structure.Denis V. Lunev
nl_info is used to track the end-user destination of routing change notification. This is a natural object to hold a namespace on. Place it there and utilize the context in the appropriate places. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETLINK]: Add NLA_PUT_BE16/nla_get_be16()Patrick McHardy
2008-01-28[NETLINK]: Mark attribute construction exception unlikelyPatrick McHardy
2007-10-10[NET]: make netlink user -> kernel interface synchroniousDenis V. Lunev
This patch make processing netlink user -> kernel messages synchronious. This change was inspired by the talk with Alexey Kuznetsov about current netlink messages processing. He says that he was badly wrong when introduced asynchronious user -> kernel communication. The call netlink_unicast is the only path to send message to the kernel netlink socket. But, unfortunately, it is also used to send data to the user. Before this change the user message has been attached to the socket queue and sk->sk_data_ready was called. The process has been blocked until all pending messages were processed. The bad thing is that this processing may occur in the arbitrary process context. This patch changes nlk->data_ready callback to get 1 skb and force packet processing right in the netlink_unicast. Kernel -> user path in netlink_unicast remains untouched. EINTR processing for in netlink_run_queue was changed. It forces rtnl_lock drop, but the process remains in the cycle until the message will be fully processed. So, there is no need to use this kludges now. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETLINK]: Fix typos in comments in netlink.hPierre Ynard
This patch fixes a few typos in comments in include/net/netlink.h Signed-off-by: Pierre Ynard <linkfanel@yahoo.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETLINK]: Avoid pointer in netlink_run_queueHerbert Xu
I was looking at Patrick's fix to inet_diag and it occured to me that we're using a pointer argument to return values unnecessarily in netlink_run_queue. Changing it to return the value will allow the compiler to generate better code since the value won't have to be memory-backed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETLINK]: Introduce nested and byteorder flag to netlink attributeThomas Graf
This change allows the generic attribute interface to be used within the netfilter subsystem where this flag was initially introduced. The byte-order flag is yet unused, it's intended use is to allow automatic byte order convertions for all atomic types. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETLINK]: attr: add nested compat attribute typePatrick McHardy
Add a nested compat attribute type that can be used to convert attributes that contain a structure to nested attributes in a backwards compatible way. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[NETLINK]: Mark netlink policies constPatrick McHardy
2007-04-26[NETLINK]: Possible cleanups.Adrian Bunk
- make the following needlessly global variables static: - core/rtnetlink.c: struct rtnl_msg_handlers[] - netfilter/nf_conntrack_proto.c: struct nf_ct_protos[] - make the following needlessly global functions static: - core/rtnetlink.c: rtnl_dump_all() - netlink/af_netlink.c: netlink_queue_skip() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: introduce NLA_BINARY typeJohannes Berg
This patch introduces a new NLA_BINARY attribute policy type with the verification of simply checking the maximum length of the payload. It also fixes a small typo in the example. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Remove error pointer from netlink message handlerThomas Graf
The error pointer argument in netlink message handlers is used to signal the special case where processing has to be interrupted because a dump was started but no error happened. Instead it is simpler and more clear to return -EINTR and have netlink_run_queue() deal with getting the queue right. nfnetlink passed on this error pointer to its subsystem handlers but only uses it to signal the start of a netlink dump. Therefore it can be removed there as well. This patch also cleans up the error handling in the affected message handlers to be consistent since it had to be touched anyway. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04[PATCH] severing skbuff.h -> mm.hAl Viro
2006-12-02[DECNET] address: Convert to new netlink interfaceThomas Graf
Extends the netlink interface to support the __le16 type and converts address addition, deletion and, dumping to use the new netlink interface. Fixes multiple occasions of possible illegal memory references due to not validated netlink attributes. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETLINK]: Do precise netlink message allocations where possibleThomas Graf
Account for the netlink message header size directly in nlmsg_new() instead of relying on the caller calculate it correctly. Replaces error handling of message construction functions when constructing notifications with bug traps since a failure implies a bug in calculating the size of the skb. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: introduce nla_get_be32()/NLA_PUT_BE32()Al Viro
net-endian counterparts of nla_get_u32()/NLA_PUT_U32() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[Netlink]: add nla_validate_nested()Paul Moore
Add a new function, nla_validate_nested(), to validate nested Netlink attributes. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[NETLINK]: add nla_for_each_nested() to the interface listPaul Moore
At the top of include/net/netlink.h is a list of Netlink interfaces, however, the nla_for_each_nested() macro was not listed. This patch adds this interface to the list at the top of the header file. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETLINK]: Improve string attribute validationThomas Graf
Introduces a new attribute type NLA_NUL_STRING to support NUL terminated strings. Attributes of this kind require to carry a terminating NUL within the maximum specified in the policy. The `old' NLA_STRING which is not required to be NUL terminated is extended to provide means to specify a maximum length of the string. Aims at easing the pain with using nla_strlcpy() on temporary buffers. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETLINK]: remove third bogus argument from NLA_PUT_FLAGJohannes Berg
This patch removes the 'value' argument from NLA_PUT_FLAG which is unused anyway. The documentation comment was already correct so it doesn't need an update :) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPv4]: FIB configuration using struct fib_configThomas Graf
Introduces struct fib_config replacing the ugly struct kern_rta prone to ordering issues. Avoids creating faked netlink messages for auto generated routes or requests via ioctl. A new interface net/nexthop.h is added to help navigate through nexthop configuration arrays. A new struct nl_info will be used to carry the necessary netlink information to be used for notifications later on. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[RTNETLINK]: Add rtnetlink notification interfaceThomas Graf
Adds rtnl_notify() to send rtnetlink notification messages and rtnl_set_sk_err() to report notification errors as socket errors in order to indicate the need of a resync due to loss of events. nlmsg_report() is added to properly document the meaning of NLM_F_ECHO. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETLINK]: Add notification message sending interfaceThomas Graf
Adds nlmsg_notify() implementing proper notification logic. The message is multicasted to all listeners in the group. The applications the requests orignates from can request a unicast back report in which case said socket will be excluded from the multicast to avoid duplicated notifications. nlmsg_multicast() is extended to take allocation flags to allow notification in atomic contexts. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETLINK]: Extend netlink messaging interfaceThomas Graf
Adds: nlmsg_get_pos() return current position in message nlmsg_trim() trim part of message nla_reserve_nohdr(skb, len) reserve room for an attribute w/o hdr nla_put_nohdr(skb, len, data) add attribute w/o hdr nla_find_nested() find attribute in nested attributes Fixes nlmsg_new() to take allocation flags and consider size. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Generic netlink receive queue processorThomas Graf
Introduces netlink_run_queue() to handle the receive queue of a netlink socket in a generic way. Processes as much as there was in the queue upon entry and invokes a callback function for each netlink message found. The callback function may refuse a message by returning a negative error code but setting the error pointer to 0 in which case netlink_run_queue() will return with a qlen != 0. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Type-safe netlink messages/attributes interfaceThomas Graf
Introduces a new type-safe interface for netlink message and attributes handling. The interface is fully binary compatible with the old interface towards userspace. Besides type safety, this interface features attribute validation capabilities, simplified message contstruction, and documentation. The resulting netlink code should be smaller, less error prone and easier to understand. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
