path: root/include/net/llc_conn.h
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[LLC]: fix llc_ui_recvmsg, making it behave like tcp_recvmsgArnaldo Carvalho de Melo
In fact it is an exact copy of the parts that makes sense to LLC :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-22[LLC]: Fix sparse warningsArnaldo Carvalho de Melo
2005-09-22[LLC]: Use refcounting with struct llc_sapArnaldo Carvalho de Melo
Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-22[LLC]: Add sysctl support for the LLC timeoutsArnaldo Carvalho de Melo
