path: root/include/net/iucv
2009-04-23af_iucv: New socket option for setting IUCV MSGLIMITsHendrik Brueckner
The SO_MSGLIMIT socket option modifies the message limit for new IUCV communication paths. The message limit specifies the maximum number of outstanding messages that are allowed for connections. This setting can be lowered by z/VM when an IUCV connection is established. Expects an integer value in the range of 1 to 65535. The default value is 65535. The message limit must be set before calling connect() or listen() for sockets. If sockets are already connected or in state listen, changing the message limit is not supported. For reading the message limit value, unconnected sockets return the limit that has been set or the default limit. For connected sockets, the actual message limit is returned. The actual message limit is assigned by z/VM for each connection and it depends on IUCV MSGLIMIT authorizations specified for the z/VM guest virtual machine. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-23af_iucv: Modify iucv msg target class using control msghdrHendrik Brueckner
Allow 'classification' of socket data that is sent or received over an af_iucv socket. For classification of data, the target class of an (native) iucv message is used. This patch provides the cmsg interface for iucv_sock_recvmsg() and iucv_sock_sendmsg(). Applications can use the msg_control field of struct msghdr to set or get the target class as a "socket control message" (SCM/CMSG). Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-23af_iucv: add sockopt() to enable/disable use of IPRM_DATA msgsHendrik Brueckner
Provide the socket operations getsocktopt() and setsockopt() to enable/disable sending of data in the parameter list of IUCV messages. The patch sets respective flag only. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25[S390] iucv: Locking free version of iucv_message_(receive|send)Hendrik Brueckner
Provide a locking free version of iucv_message_receive and iucv_message_send that do not call local_bh_enable in a spin_lock_(bh|irqsave)() context. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
2007-10-10[AF_IUCV]: postpone receival of iucv-packetsUrsula Braun
AF_IUCV socket programs may waste Linux storage, because af_iucv allocates an skb whenever posted by the receive callback routine and receives the message immediately. Message receival is now postponed if data from previous callbacks has not yet been transferred to the receiving socket program. Instead a message handle is saved in a message queue as a reminder. Once messages could be given to the receiving socket program, there is an additional checking for entries in the message queue, followed by skb allocation and message receival if applicable. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[AF_IUCV]: remove static declarations from header file.Heiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[AF_IUCV]: Add lock when updating accept_qUrsula Braun
The accept_queue of an af_iucv socket will be corrupted, if adding and deleting of entries in this queue occurs at the same time (connect request from one client, while accept call is processed for another client). Solution: add locking when updating accept_q Signed-off-by: Ursula Braun <braunu@de.ibm.com> Acked-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[AF_IUCV]: Implementation of a skb backlog queueJennifer Hunt
With the inital implementation we missed to implement a skb backlog queue . The result is that socket receive processing tossed packets. Since AF_IUCV connections are working synchronously it leads to connection hangs. Problems with read, close and select also occured. Using a skb backlog queue is fixing all of these problems . Signed-off-by: Jennifer Hunt <jenhunt@us.ibm.com> Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-28[AF_IUCV/IUCV]: smp_call_function deadlockMartin Schwidefsky
Calling smp_call_function can lead to a deadlock if it is called from tasklet context. Fixing this deadlock requires to move the smp_call_function from the tasklet context to a work queue. To do that queue the path pending interrupts to a separate list and move the path cleanup out of iucv_path_sever to iucv_path_connect and iucv_path_pending. This creates a new requirement for iucv_path_connect: it may not be called from tasklet context anymore. Also fixed compile problem for CONFIG_HOTPLUG_CPU=n and another one when walking the cpu_online mask. When doing this, we must disable cpu hotplug. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[S390]: Add AF_IUCV socket supportJennifer Hunt
From: Jennifer Hunt <jenhunt@us.ibm.com> This patch adds AF_IUCV socket support. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[S390]: Rewrite of the IUCV base code, part 2Martin Schwidefsky
Add rewritten IUCV base code to net/iucv. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
