path: root/include/net/genetlink.h
2007-07-18[GENETLINK]: Dynamic multicast groups.Johannes Berg
Introduce API to dynamically register and unregister multicast groups. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Patrick McHardy <kaber@trash.net> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[NETLINK]: Mark netlink policies constPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[GENETLINK]: Add cmd dump completion.Jamal Hadi Salim
Remove assumption that generic netlink commands cannot have dump completion callbacks. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[GENL]: Add genlmsg_put_reply() to simplify building reply headersThomas Graf
By modyfing genlmsg_put() to take a genl_family and by adding genlmsg_put_reply() the process of constructing the netlink and generic netlink headers is simplified. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[GENL]: Add genlmsg_reply() to simply unicast replies to requestsThomas Graf
A generic netlink user has no interest in knowing how to address the source of the original request. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[GENL]: Add genlmsg_new() to allocate generic netlink messagesThomas Graf
2006-10-01[PATCH] Add genetlink utilities for payload length calculationBalbir Singh
Add two utility helper functions genlmsg_msg_size() and genlmsg_total_size(). These functions are derived from their netlink counterparts. Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jamal Hadi <hadi@cyberus.ca> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Thomas Graf <tgraf@suug.ch> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[GENL]: Provide more information to userspace about registered genl familiesThomas Graf
Additionaly exports the following information when providing the list of registered generic netlink families: - protocol version - header size - maximum number of attributes - list of available operations including - id - flags - avaiability of policy and doit/dumpit function libnl HEAD provides a utility to read this new information: 0x0010 nlctrl version 1 hdrsize 0 maxattr 6 op GETFAMILY (0x03) [POLICY,DOIT,DUMPIT] 0x0011 NLBL_MGMT version 1 hdrsize 0 maxattr 0 op unknown (0x02) [DOIT] op unknown (0x03) [DOIT] .... Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETLINK]: Add notification message sending interfaceThomas Graf
Adds nlmsg_notify() implementing proper notification logic. The message is multicasted to all listeners in the group. The applications the requests orignates from can request a unicast back report in which case said socket will be excluded from the multicast to avoid duplicated notifications. nlmsg_multicast() is extended to take allocation flags to allow notification in atomic contexts. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-14[PATCH] per-task-delay-accounting: utilities for genetlink usageBalbir Singh
Two utilities for simplifying usage of NETLINK_GENERIC interface. Signed-off-by: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-13[PATCH] genetlink: don't touch module ref countPer Liden
Increasing the module ref count at registration will block the module from ever being unloaded. In fact, genetlink should not care about the owner at all. This patch removes the owner field from the struct registered with genetlink. Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NETLINK] genetlink: fix cmd type in genl_ops to be consistent to u8Per Liden
Signed-off-by: Per Liden <per.liden@ericsson.com> ACKed-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Generic netlink familyThomas Graf
The generic netlink family builds on top of netlink and provides simplifies access for the less demanding netlink users. It solves the problem of protocol numbers running out by introducing a so called controller taking care of id management and name resolving. Generic netlink modules register themself after filling out their id card (struct genl_family), after successful registration the modules are able to register callbacks to command numbers by filling out a struct genl_ops and calling genl_register_op(). The registered callbacks are invoked with attributes parsed making life of simple modules a lot easier. Although generic netlink modules can request static identifiers, it is recommended to use GENL_ID_GENERATE and to let the controller assign a unique identifier to the module. Userspace applications will then ask the controller and lookup the idenfier by the module name. Due to the current multicast implementation of netlink, the number of generic netlink modules is restricted to 1024 to avoid wasting memory for the per socket multiacst subscription bitmask. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
