path: root/include/net/dn_route.h
2006-03-20[DECnet]: Endian annotation and fixes for DECnet.Steven Whitehouse
The typedef for dn_address has been removed in favour of using __le16 or __u16 directly as appropriate. All the DECnet header files are updated accordingly. The byte ordering of dn_eth2dn() and dn_dn2eth() are both changed since just about all their callers wanted network order rather than host order, so the conversion is now done in the functions themselves. Several missed endianess conversions have been picked up during the conversion process. The nh_gw field in struct dn_fib_info has been changed from a 32 bit field to 16 bits as it ought to be. One or two cases of using htons rather than dn_htons in the routing code have been found and fixed. There are still a few warnings to fix, but this patch deals with the important cases. Signed-off-by: Steven Whitehouse <steve@chygwyn.com> Signed-off-by: Patrick Caulfield <patrick@tykepenguin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[DECNET]: fix sparse gfp nocast warningsRandy Dunlap
Fix implicit nocast warnings in decnet code: net/decnet/af_decnet.c:458:40: warning: implicit cast to nocast type net/decnet/dn_nsp_out.c:125:35: warning: implicit cast to nocast type net/decnet/dn_nsp_out.c:219:29: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
