path: root/include/net/checksum.h
2016-03-13csum: Update csum_block_add to use rotate instead of byteswapAlexander Duyck
The code for csum_block_add was doing a funky byteswap to swap the even and odd bytes of the checksum if the offset was odd. Instead of doing this we can save ourselves some trouble and just shift by 8 as this should have the same effect in terms of the final checksum value and only requires one instruction. In addition we can update csum_block_sub to just use csum_block_add with a inverse value for csum2. This way we follow the same code path as csum_block_add without having to duplicate it. Signed-off-by: Alexander Duyck <aduyck@mirantis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-08bpf: allow bpf_csum_diff to feed bpf_l3_csum_replace as wellDaniel Borkmann
Commit 7d672345ed29 ("bpf: add generic bpf_csum_diff helper") added a generic checksum diff helper that can feed bpf_l4_csum_replace() with a target __wsum diff that is to be applied to the L4 checksum. This facility is very flexible, can be cascaded, allows for adding, removing, or diffing data, or for calculating the pseudo header checksum from scratch, but it can also be reused for working with the IPv4 header checksum. Thus, analogous to bpf_l4_csum_replace(), add a case for header field value of 0 to change the checksum at a given offset through a new helper csum_replace_by_diff(). Also, in addition to that, this provides an easy to use interface for feeding precalculated diffs f.e. coming from a map. It nicely complements bpf_l3_csum_replace() that currently allows only for csum updates of 2 and 4 byte diffs. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-13rco: Clean up casting errorsTom Herbert
Fixe a couple of cast errors found by sparse. Signed-off-by: Tom Herbert <tom@herbertland.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-17net: Add inet_proto_csum_replace_by_diff utility functionTom Herbert
This function updates a checksum field value and skb->csum based on a value which is the difference between the old and new checksum. Signed-off-by: Tom Herbert <tom@herbertland.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-17net: Change pseudohdr argument of inet_proto_csum_replace* to be a boolTom Herbert
inet_proto_csum_replace4,2,16 take a pseudohdr argument which indicates the checksum field carries a pseudo header. This argument should be a boolean instead of an int. Signed-off-by: Tom Herbert <tom@herbertland.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-17net: fix sparse error in csum_replace4()Eric Dumazet
make C=2 CF=-D__CHECK_ENDIAN__ net/ipv4/netfilter/nf_nat_l3proto_ipv4.o CHECK net/ipv4/netfilter/nf_nat_l3proto_ipv4.c include/net/checksum.h:125:64: warning: incorrect type in argument 2 (different base types) include/net/checksum.h:125:64: expected restricted __wsum [usertype] addend include/net/checksum.h:125:64: got restricted __be32 [usertype] from include/net/checksum.h:125:71: warning: incorrect type in argument 2 (different base types) include/net/checksum.h:125:71: expected restricted __wsum [usertype] addend include/net/checksum.h:125:71: got restricted __be32 [usertype] to include/net/checksum.h:125:64: warning: incorrect type in argument 2 (different base types) include/net/checksum.h:125:64: expected restricted __wsum [usertype] addend include/net/checksum.h:125:64: got restricted __be32 [usertype] from include/net/checksum.h:125:71: warning: incorrect type in argument 2 (different base types) include/net/checksum.h:125:71: expected restricted __wsum [usertype] addend include/net/checksum.h:125:71: got restricted __be32 [usertype] to Fixes: 4565af0d406b ("net: optimise csum_replace4()") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-11net: Fix remcsum in GRO path to not change packetTom Herbert
Remote checksum offload processing is currently the same for both the GRO and non-GRO path. When the remote checksum offload option is encountered, the checksum field referred to is modified in the packet. So in the GRO case, the packet is modified in the GRO path and then the operation is skipped when the packet goes through the normal path based on skb->remcsum_offload. There is a problem in that the packet may be modified in the GRO path, but then forwarded off host still containing the remote checksum option. A remote host will again perform RCO but now the checksum verification will fail since GRO RCO already modified the checksum. To fix this, we ensure that GRO restores a packet to it's original state before returning. In this model, when GRO processes a remote checksum option it still changes the checksum per the algorithm but on return from lower layer processing the checksum is restored to its original value. In this patch we add define gro_remcsum structure which is passed to skb_gro_remcsum_process to save offset and delta for the checksum being changed. After lower layer processing, skb_gro_remcsum_cleanup is called to restore the checksum before returning from GRO. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26net: Add remcsum_adjust as common function for remote checksum offloadTom Herbert
This function does the work to update a checksum field as part of remote checksum offload. remcsum_adjust does the following: 1) Subtract out the calculated checksum from the beginning of the packet (ptr arg) to the start offset. 2) Adjust the checksum field indicated by offset based on the modified checksum value from above step. 3) Return the difference in the old checksum field value and the new one. The caller will use this to update skb->csum and NAPI csum. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-26net: optimise csum_replace4()LEROY Christophe
csum_partial() is a generic function which is not optimised for small fixed length calculations, and its use requires to store "from" and "to" values in memory while we already have them available in registers. This also has impact, especially on RISC processors. In the same spirit as the change done by Eric Dumazet on csum_replace2(), this patch rewrites inet_proto_csum_replace4() taking into account RFC1624. I spotted during a NATted tcp transfert that csum_partial() is one of top 5 consuming functions (around 8%), and the second user of csum_partial() is inet_proto_csum_replace4(). I have proposed the same modification to inet_proto_csum_replace4() in another patch. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-05net: Allow csum_add to be provided in archTom Herbert
csum_add is really nothing more then add-with-carry which can be implemented efficiently in some architectures. Allow architecture to define this protected by HAVE_ARCH_CSUM_ADD. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24net: optimize csum_replace2()Eric Dumazet
When changing one 16bit value by another in IP header, we can adjust the IP checksum by doing a simple operation described in RFC 1624, as reminded by David. csum_partial() is a complex function on x86_64, not really suited for small number of checksummed bytes. I spotted csum_partial() being in the top 20 most consuming functions (more than 1 %) in a GRO workload, which was rather unexpected. The caller was inet_gro_complete() doing a csum_replace2() when building the new IP header for the GRO packet. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-04net: checksum: fix warning in skb_checksumDaniel Borkmann
This patch fixes a build warning in skb_checksum() by wrapping the csum_partial() usage in skb_checksum(). The problem is that on a few architectures, csum_partial is used with prefix asmlinkage whereas on most architectures it's not. So fix this up generically as we did with csum_block_add_ext() to match the signature. Introduced by 2817a336d4d ("net: skb_checksum: allow custom update/combine for walking skb"). Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-03net: skb_checksum: allow custom update/combine for walking skbDaniel Borkmann
Currently, skb_checksum walks over 1) linearized, 2) frags[], and 3) frag_list data and calculats the one's complement, a 32 bit result suitable for feeding into itself or csum_tcpudp_magic(), but unsuitable for SCTP as we're calculating CRC32c there. Hence, in order to not re-implement the very same function in SCTP (and maybe other protocols) over and over again, use an update() + combine() callback internally to allow for walking over the skb with different algorithms. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-31checksum: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30net: core: add function for incremental IPv6 pseudo header checksum updatesPatrick McHardy
Add inet_proto_csum_replace16 for incrementally updating IPv6 pseudo header checksums for IPv6 NAT. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: David S. Miller <davem@davemloft.net>
2008-11-19include/net net/ - csum_partial - remove unnecessary castsJoe Perches
The first argument to csum_partial is const void * casts to char/u8 * are not necessary Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Move netfilter checksum helpers to net/core/utils.cPatrick McHardy
This allows to get rid of the CONFIG_NETFILTER dependency of NET_ACT_NAT. This patch redefines the old names to keep the noise low, the next patch converts all users. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Make mangling a checksum (0 -> 0xffff on the wire) explicit.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Generic checksum annotations and cleanups.Al Viro
