path: root/include/media
2006-08-08V4L/DVB (4340): Videodev.h should be included also when V4L1_COMPAT is selected.Mauro Carvalho Chehab
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-07-29V4L/DVB (4316): Check __must_check warningsMichael Krufky
Check __must_check warnings for class_device_register and class_device_create_file video_device_create_file was declared as a void, but instead should return the int value of class_device_create_file. Move the check from bttv-driver.c into v4l2-dev.h, because all other callers of video_device_create_file must also be checked. Replace the call to class_device_create_file in videodev.c with video_device_create_file, as defined in v4l2-dev.h, so that the return value of class_device_create_file will be checked. Check the return value of class_device_register in videodev.c and pvrusb2-sysfs.c Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-30V4L/DVB (4270): Add tda9887-specific tuner configurationHans Verkuil
Many tda9887 settings depend on the chosen tuner. Expand the tuner parameters to include these tda9887 settings. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-27V4L/DVB (4259): Pass an explicit log prefix to cx2341x_log_statusHans Verkuil
A card number is not unique enough. Instead, let the caller specify the prefix of the status messages. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-27V4L/DVB (4257): Fix 64-bit compile warnings.Hans Verkuil
2006-06-26[PATCH] devfs: Remove the videodevice devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26V4L/DVB (4223): Add V4L2_CID_MPEG_STREAM_VBI_FMT controlHans Verkuil
V4L2_CID_MPEG_STREAM_VBI_FMT controls if and how VBI data is embedded in an MPEG stream. Currently only one format is supported: the format designed for the ivtv driver. This should be extended with new standard formats (such as defined for DVB) in the future. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4205): Merge tda9887 module into tuner.Mauro Carvalho Chehab
Most uses a tda988[5/6/7] IF demodulator as part of the device. Having this as a separate stuff makes harder to configure it, since there are some tda9887 options that are tuner-dependent and should be bound into tuner-types structures. This patch merges tda9887 module into tuner. More work is required to make tuner-types to properly use it. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4203): Explicitly set the enum values.Hans Verkuil
It's better to use explicit enums. It reduces the chance of someone inserting new enums in the middle which would break things. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4202): allow selecting CX2341x port modeHans Verkuil
CX2341X port was always set to 'memory', but 'streaming' is also possible ivtv uses the memory (DMA) interface with the CX2341X, while pvrusb2 and cx88-blackbird use the streaming interface. This setting is now selectable by the driver. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4199): Add cx2341x-specific control array to cx2341x.cHans Verkuil
2006-06-25V4L/DVB (4191): Add CX2341X MPEG encoder module.Hans Verkuil
Adds the cx2341x.c module that handles the programming of the Conexant cx23415/6 MPEG encoder chip used by cx88-blackbird, pvrusb2 and ivtv. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4190): Add helper functions for control processing to v4l2-common.Hans Verkuil
Control processing is often duplicated in the various drivers. Unfortunately, simple things like the names of controls are often different between drivers, even though it is the same controls. Adding in the new extended controls and the need for having control helper functions became apparent. Several functions have now been added to v4l2-common to do things like filling the v4l2_queryctrl and v4l2_querymenu structs, to check for valid control input and to move to the next control when enumerating over all controls. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4189): Add videodev support for VIDIOC_S/G/TRY_EXT_CTRLS.Hans Verkuil
videodev.c copies the control list specified in struct v4l2_ext_controls to kernel space. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4068): Removed all references to kernel stuff from videodev.h and ↵Mauro Carvalho Chehab
videodev2.h The videodev.h and videodev2.h describe the public API for V4L and V4L2. It shouldn't have there any kernel-specific stuff. Those were moved to v4l2-dev.h. This patch removes some uneeded headers and include v4l2-common.h on all V4L driver. This header includes device implementation of V4L2 API provided on v4l2-dev.h as well as V4L2 internal ioctls that provides connections between master driver and its i2c devices. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4065): Several improvements at videodev.cMauro Carvalho Chehab
Videodev now is capable of better handling V4L2 api, by processing V4L2 ioctls and using callbacks to the driver. The drivers should be migrated to the newer way and the older one will be obsoleted soon. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4038): New cx88 card #50: NPG Tech RealTVRicardo Cerqueira
Added support for a new cx88 card, including it's remote Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4023): Subject: Pinnacle PCTV grey remote control supportSylvain Pasche
This adds support for the older (?) Pinnacle PCTV remotes (with all buttons colored in grey). There's no autodetection for the type of remote, though; saa7134 defaults to the colored one, to use the grey remote the "pinnacle_remote=1" option must be passed to the saa7134 module Signed-off-by: Sylvain Pasche <sylvain.pasche@gmail.com> Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4005): Add support for the cx25836/7 video decoder.Hans Verkuil
Signed-off-by: Scott Alfter <salfter@ssai.us> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3809c): Added cx2341x header fileMauro Carvalho Chehab
Date: There are several drivers now using those cx2341x registers. This patch creates a separate header for those registers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3919): V4l: rename TUNER_LG_TDVS_H062F to TUNER_LG_TDVS_H06XFMichael Krufky
2006-06-25V4L/DVB (3835): [PATCH] update pwc driverLuc Saillard
Add v4l2 compatibility Include the decompressor (legal problem has been resolv by Alan Cox) Faster decoder and easier to maintain, optimize, ... Can export to userland compressed stream Support more cameras, lot of bugs are fixed. Signed-off-by: Luc Saillard <luc@saillard.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3814): Add support for Samsung TCPG 6121P30A PAL tuner.Hans Verkuil
2006-06-25V4L/DVB (3762): Add sysfs device links to dvb devicesAndrew de Quincey
Currently in /sys/class/dvb/dvbX.demuxY/ we have: dev uevent With the patch, we have (for a PCI DVB device): dev device -> ../../../devices/pci0000:00/0000:00:1e.0/0000:03:0d.0 uevent So userspace tools can (finally) work out which physical device a DVB adapter refers to. Previously you had to kinda look through dmesg and hope that it hadn't been dumped out of the buffer. This makes debugging a lot easier if the system has been up for a long time! This is done by adding an extra 'struct device *' parameter to dvb_register_adapter(). It will work with any kind of standard linux 'device'. Additionally, if someone has an embedded system which does things differently, they can simply supply 'NULL' and the behaviour will be as before - the link will simply not appear. Ack'd-by: Manu Abraham <manu@linuxtv.org> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3712): Fix video input setting of em28xx, use _INT_S_VIDEO_ROUTING ↵Hans Verkuil
in tvp5150 - Use new routing input defines in em28xx-cards.c - Fix S-Video settings for tvp5150-based cards (input was copied from saa7115 based cards and worked only because S-Video was selected in the default: case) - Replace VIDIOC_S_INPUT by VIDIOC_INT_S_VIDEO_ROUTING in em28xx-video.c - Remove the now obsolete VIDIOC_S_INPUT handler in saa7115.c - Add VIDIOC_INT_G/S_VIDEO_ROUTING in tvp5150.c - Add new media/tvp5150.h with the routing defines. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3711): Add support for VIDIOC_INT_S_CRYSTAL_FREQ internal command.Hans Verkuil
Some saa7115-based cards use a different crystal frequency and a different audio clock generation. Add a new VIDIOC_INT_S_CRYSTAL_FREQ command to be able to set these values. Also change the default APLL setting to 0. It makes no sense to have the audio clock independent from the video clock, this can lead to audio/video synchronization problems. Setting this to 0 is also consistent with the old saa7114.c source and the way the Hauppauge Windows driver sets it. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-04-02V4L/DVB (3702): Make msp3400 routing defines more consistentHans Verkuil
Renamed various msp3400 routing defines to be more consistent and less confusing. Esp. the MSP_DSP_OUT defines were confusing since it is really a DSP input. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-04-02V4L/DVB (3666): Remove trailing newlinesHans Verkuil
2006-04-02V4L/DVB (3665): Add new NEC uPD64031A and uPD64083 i2c driversHans Verkuil
- Add support for the uPD64031A NEC Electronics Ghost Reduction i2c device - Add support for the uPD6408x NEC Electronics 3-Dimensional Y/C separation i2c device. Signed-off-by: Takahiro Adachi <tadachi@tadachi-net.com> Signed-off-by: Takeru Komoriya <komoriya@paken.org> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-04-02V4L/DVB (3610): Added the new routing commands to cx25840.Hans Verkuil
2006-04-02V4L/DVB (3608): Implement new routing commands in saa7127.cHans Verkuil
2006-04-02V4L/DVB (3607): Implement routing command for saa7115.cHans Verkuil
2006-03-24V4L/DVB (3599): Implement new routing commands for wm8775 and cs53l32a.Hans Verkuil
2006-03-24V4L/DVB (3582): Implement correct msp3400 input/output routingHans Verkuil
- implement VIDIOC_INT_S_AUDIO_ROUTING for msp3400 and tvaudio - use the new command in bttv, pvrusb2 and em28xx. - remove the now obsolete MSP_SET_MATRIX from msp3400 (yeah!) - remove the obsolete VIDIOC_S_AUDIO from msp3400. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3581): Add new media/msp3400.h header containing the routing macrosHans Verkuil
Moved msp3400.h to msp3400-driver.h. Created media/msp3400.h with the new routing defines and lots of comments. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3577): Cleanup audio input handlingHans Verkuil
Cleanup audio input handling in bttv and tvaudio: - inputs were specified that were never used - mute was handled as a special input which led to confusing code - confusing naming made it difficult to see if the setting was for i2c or gpio. The old audiochip.h input names moved to tvaudio.h. Currently this is used both by tvaudio and msp3400 until the msp3400 implements the new msp3400-specific inputs. Detect in bttv the tvaudio and msp3400 i2c clients and use these client pointers to set the inputs directly instead of broadcasting the command. Removed AUDC_SET_INPUT. Now replaced by VIDIOC_S_AUDIO. This will be replaced again later by the new ROUTING commands. Removed VIDIOC_G_AUDIO implementations in i2c drivers: this command is a user level command and not to be used internally. It wasn't called at all anyway. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3548): Renamed I2C_foo addresses to I2C_ADDR_fooMauro Carvalho Chehab
I2C_foo were used for some i2c addresses. Bad, since those constants could mean other i2c chip things. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3547): Tvaudio.h are just i2c addresses. Merged into i2c-addr.hMauro Carvalho Chehab
2006-03-24V4L/DVB (3546): Fix Compilation after moving bttv codeMauro Carvalho Chehab
- Missing a Makefile for bt8xx - rds.h were at wrong directory, since it is a global header for an internal interface - tda7432 and tda9875 were dependent from bttv.h - bttv.h were holding i2c addresses Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3516): Make video_buf more genericMauro Carvalho Chehab
Video_buf were concerned to allow PCI devices to be used as video capture devices. This patch extends video_buf features by virtualizing pci-dependent functions and allowing other type of devices to use it. It is still DMA centric, although it may be used also by devices that emulates scatter/gather behavior or a DMA device Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3513): Remove saa711x driverMauro Carvalho Chehab
Now, em28xx uses saa7115 instead of saa711x. saa7115 driver is capable of handling saa 7113, 7114 and 7115. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3445): LG TALN series: add PAL / SECAM supportMichael Krufky
- added tuner_lg_taln_pal_secam_ranges - renamed tuner 66 from TUNER_LG_NTSC_TALN_MINI to TUNER_LG_TALN - updated FlyTV mini Asus Digimatrix with new tuner Thanks-to: Rickard Osser <ricky@osser.se> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-08V4L/DVB (3411): FE6600 is a Thomson tunerMichael Krufky
- The tuner used in DViCO FusionHDTV DVB-T hybrid is made by Thomson - renamed tuner and dvb_pll structs accordingly Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-08V4L/DVB (3408): DViCO FusionHDTV DVB-T Hybrid and ZL10353-based FusionHDTV ↵Chris Pascoe
DVB-T Plus support Add support for the FE6600 tuner used on the DVB-T Hybrid board. Add support for the Zarlink ZL10353 DVB-T demodulator, which supersedes the MT352, used on the DViCO FusionHDTV DVB-T Hybrid and later model Plus boards. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-27V4L/DVB (3371): Add debug to ioctl arguments.Mauro Carvalho Chehab
Added a new function that allows printing ioctl arguments. This makes easier to include debug code under v4l ioctl handling. Also fixed some declarations on internal ioctl. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-27V4L/DVB (3291): Added support for xc3028 analogue tuner (Hauppauge HVR900, ↵Markus Rechberger
Terratec Hybrid XS) Added support for xc3028 to v4l which adds support for: * Terratec Hybrid XS (analogue) * Hauppauge HVR 900 (analogue) Signed-off-by: Markus Rechberger <mrechberger@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-07V4L/DVB (3318b): sem2mutex: drivers/media/, #2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-06V4L/DVB (3265): Add count to tunertype structMichael Krufky
The tuner_params element is an array of undefined length, with each array member being a set of parameters for each video standard type. The number of members in the tuner_params array will be stored in tuners[]->count Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-23V4L/DVB (3436): move config byte from tuner_params to tuner_range struct.Michael Krufky
- Move config byte from tuner_params to tuner_range struct. - dvb tuners must be able to set different config byte for each range. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
