path: root/include/media
2015-07-01Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem updates from Bryan Wu: "In this cycle, we finished to merge patches for LED Flash class driver. Other than that we have some bug fixes and new drivers for LED controllers" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (33 commits) leds:lp55xx: fix firmware loading error leds: fix max77693-led build errors leds: fix aat1290 build errors leds: aat1290: pass flags parameter to devm_gpiod_get leds: ktd2692: pass flags parameter to devm_gpiod_get drivers/leds: don't use module_init in non-modular leds-cobalt-raq.c leds: aat1290: add support for V4L2 Flash sub-device DT: aat1290: Document handling external strobe sources leds: max77693: add support for V4L2 Flash sub-device media: Add registration helpers for V4L2 flash sub-devices v4l: async: Add a pointer to of_node to struct v4l2_subdev, match it Documentation: leds: Add description of v4l2-flash sub-device leds: add BCM6358 LED driver leds: add DT binding for BCM6358 LED controller leds: fix brightness changing when software blinking is active Documentation: leds-lp5523: describe master fader attributes leds: lp5523: add master_fader support leds: leds-gpio: Allow compile test if !GPIOLIB leds: leds-gpio: Add missing #include <linux/of.h> gpiolib: Add missing dummies for the unified device properties interface ...
2015-06-22media: Add registration helpers for V4L2 flash sub-devicesJacek Anaszewski
This patch adds helper functions for registering/unregistering LED Flash class devices as V4L2 sub-devices. The functions should be called from the LED subsystem device driver. In case the support for V4L2 Flash sub-devices is disabled in the kernel config the functions' empty versions will be used. Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Sakari Ailus <sakari.ailus@iki.fi> Cc: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2015-06-15v4l: async: Add a pointer to of_node to struct v4l2_subdev, match itSakari Ailus
V4L2 async sub-devices are currently matched (OF case) based on the struct device_node pointer in struct device. LED devices may have more than one LED, and in that case the OF node to match is not directly the device's node, but a LED's node. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2015-06-10[media] rc/keymaps: add keytable for Twinhan DTV CAB CIJan Klötzke
This RC map was taken from Christoph Pinkl's patch (http://patchwork.linuxtv.org/patch/7217/). It is used solely by the respective mantis based card because the encoding is not known. Signed-off-by: Jan Klötzke <jan@kloetzke.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-06-10[media] rc/keymaps: add keytable for Terratec Cinergy S2 HDJan Klötzke
2015-06-10[media] rc/keymaps: add keytable for Terratec Cinergy C PCIJan Klötzke
2015-06-10[media] rc/keymaps: add RC keytable for TechniSat TS35Jan Klötzke
The TS35 remote is distributed with TechniSat CableStar HD2 cards (mantis chipset). The exact protocol type is unknown, making this rc map probably only usable by mantis cards. Signed-off-by: Jan Klötzke <jan@kloetzke.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-06-09[media] v4l2-dv-timings: add interlace support in detect cvt/gtfPrashant Laddha
Extend detect_cvt/gtf API to indicate the format type (interlaced or progressive). In case of interlaced, the vertical front and back porch and vsync values for both (odd,even) fields are considered to derive image height. Populated vsync, vertical front, back porch values in bt timing structure for even and odd fields and updated the flags appropriately. Also modified the functions calling the detect_cvt/gtf(). As of now these functions are calling detect_cvt/gtf() with interlaced flag set to false. Cc: Martin Bugge <marbugge@cisco.com> Cc: Mats Randgaard <matrandg@cisco.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Prashant Laddha <prladdha@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-06-09[media] adv7511: log the currently set infoframesHans Verkuil
The adv7511 sets up InfoFrames that are used when transmitting video. Log the contents of those InfoFrames so it is possible to see exactly what the transmitter is sending. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-06-09[media] adv7842: replace uintX_t by uX for consistencyHans Verkuil
Currently this driver mixes u8/u32 and uint8_t/uint32_t. Standardize on u8/u32. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-06-09[media] adv7511: replace uintX_t by uX for consistencyHans Verkuil
Currently this driver mixes u8/u16 and uint8_t/uint16_t. Standardize on u8/u16. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-06-09[media] v4l2-mem2mem: add support for prepare_bufHans Verkuil
This was never added for some reason, so add it now. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-06-05[media] videodev2.h: add support for transfer functionsHans Verkuil
In the past the transfer function was implied by the colorspace. However, it is an independent entity in its own right. Add support for explicitly choosing the transfer function. This change will allow us to represent linear RGB (as is used by openGL), and it will make it easier to work with decoded video material since most codecs store the transfer function as a separate property as well. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-06-05[media] rc: set IR_MAX_DURATION to 500 msMauro Carvalho Chehab
The current definition is weird, and produce lots of sparse warnings: drivers/media/i2c/cx25840/cx25840-ir.c:448 txclk_tx_s_max_pulse_width() warn: impossible condition '(ns > 4294967295) => (0-u32max > u32max)' drivers/media/i2c/cx25840/cx25840-ir.c:461 rxclk_rx_s_max_pulse_width() warn: impossible condition '(ns > 4294967295) => (0-u32max > u32max)' drivers/media/i2c/cx25840/cx25840-ir.c:706 cx25840_ir_rx_read() warn: impossible condition '(v > 4294967295) => (0-u32max > u32max)' drivers/media/pci/ivtv/ivtv-queue.c:145 ivtv_queue_move() error: we previously assumed 'steal' could be null (see line 138) drivers/media/rc/streamzap.c:155 sz_push_full_pulse() warn: impossible condition '(rawir.duration > 4294967295) => (0-u32max > u32max)' drivers/media/rc/streamzap.c:169 sz_push_full_pulse() warn: impossible condition '(rawir.duration > 4294967295) => (0-u32max > u32max)' drivers/media/rc/redrat3.c:325 redrat3_us_to_len() warn: impossible condition '(microsec > 4294967295) => (0-u32max > u32max)' drivers/media/rc/redrat3.c:383 redrat3_process_ir_data() warn: impossible condition '(rawir.duration > 4294967295) => (0-u32max > u32max)' drivers/media/usb/pvrusb2/pvrusb2-hdw.c:3676 pvr2_send_request_ex() error: we previously assumed 'write_data' could be null (see line 3648) drivers/media/usb/pvrusb2/pvrusb2-hdw.c:3829 pvr2_send_request_ex() error: we previously assumed 'read_data' could be null (see line 3649) drivers/media/pci/cx23885/cx23888-ir.c:463 txclk_tx_s_max_pulse_width() warn: impossible condition '(ns > 4294967295) => (0-u32max > u32max)' drivers/media/pci/cx23885/cx23888-ir.c:476 rxclk_rx_s_max_pulse_width() warn: impossible condition '(ns > 4294967295) => (0-u32max > u32max)' drivers/media/pci/cx23885/cx23888-ir.c:696 cx23888_ir_rx_read() warn: impossible condition '(v > 4294967295) => (0-u32max > u32max)' Use a more realistic value for it. Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-20[media] adv7604/adv7842: replace FMT_CHANGED by V4L2_DEVICE_NOTIFY_EVENTHans Verkuil
This makes it easier for the bridge driver to just passthrough such events to the corresponding device node. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-20[media] v4l2-subdev: allow subdev to send an event to the v4l2_device notify ↵jean-michel.hautbois@vodalys.com
function All drivers use custom notifications, in particular when source changes. The bridge only has to map the subdev that sends it to whatever video node it is connected to. Signed-off-by: Jean-Michel Hautbois <jean-michel.hautbois@vodalys.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-20[media] adv7842: Make output format configurable through pad format operationsHans Verkuil
Replace the dummy video format operations by pad format operations that configure the output format. Copied from the adv7604 driver. Note: while arch/blackfin/mach-bf609/boards/ezkit.c uses adv7842_platform_data this source has not been updated because it is broken since the very beginning. It depends on a struct adv7842_output_format that does not exist. And besides that gcc has no support for bf609 so nobody can compile it except by installing a toolchain from ADI. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-14[media] rc: nuvoton-cir: Add support for writing wakeup samples via sysfs ↵Antti Seppälä
filter callback Nuvoton-cir utilizes the encoding capabilities of rc-core to convert scancodes from user space to pulse/space format understood by the underlying hardware. Converted samples are then written to the wakeup fifo along with other necessary configuration to enable wake up functionality. Signed-off-by: Antti Seppälä <a.seppala@gmail.com> Signed-off-by: James Hogan <james@albanarts.com> Cc: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-14[media] rc: rc-core: Add support for encode_wakeup driversJames Hogan
Add support in rc-core for drivers which implement the wakeup scancode filter by encoding the scancode using the raw IR encoders. This is by way of rc_dev::encode_wakeup which should be set to true to make the allowed wakeup protocols the same as the set of raw IR encoders. As well as updating the sysfs interface to know which wakeup protocols are allowed for encode_wakeup drivers, also ensure that the IR decoders/encoders are loaded when an encode_wakeup driver is registered. Signed-off-by: James Hogan <james@albanarts.com> Signed-off-by: Antti Seppälä <a.seppala@gmail.com> Cc: David Härdeman <david@hardeman.nu> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-14[media] rc: rc-ir-raw: Add scancode encoder callbackJames Hogan
Add a callback to raw ir handlers for encoding and modulating a scancode to a set of raw events. This could be used for transmit, or for converting a wakeup scancode filter to a form that is more suitable for raw hardware wake up filters. Signed-off-by: James Hogan <james@albanarts.com> Signed-off-by: Antti Seppälä <a.seppala@gmail.com> Cc: David Härdeman <david@hardeman.nu> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-12[media] videobuf2: return -EPIPE from DQBUF after the last bufferPhilipp Zabel
If the last buffer was dequeued from a capture queue, let poll return immediately and let DQBUF return -EPIPE to signal there will no more buffers to dequeue until STREAMOFF. The driver signals the last buffer by setting the V4L2_BUF_FLAG_LAST. To reenable dequeuing on the capture queue, the driver must explicitly call vb2_clear_last_buffer_queued. The last buffer queued flag is cleared automatically during STREAMOFF. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-01[media] v4l2: replace s_mbus_fmt by set_fmt in bridge driversHans Verkuil
Replace all calls to s_mbus_fmt in bridge drivers by calls to the set_fmt pad op. Remove the old try/s_mbus_fmt video ops since they are now no longer used. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Acked-by: Scott Jiang <scott.jiang.linux@gmail.com> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-01[media] v4l2: replace video op g_mbus_fmt by pad op get_fmtHans Verkuil
The g_mbus_fmt video op is a duplicate of the pad op. Replace all uses by the get_fmt pad op and remove the video op. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Kamil Debski <k.debski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-01[media] v4l2: replace enum_mbus_fmt by enum_mbus_codeHans Verkuil
Replace all calls to the enum_mbus_fmt video op by the pad enum_mbus_code op and remove the duplicate video op. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Scott Jiang <scott.jiang.linux@gmail.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Kamil Debski <k.debski@samsung.com> Acked-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-28[media] v4l2-of: fix compiler errors if CONFIG_OF is undefinedHans Verkuil
You must use static inline otherwise you get these errors if CONFIG_OF is not defined: In file included from drivers/media/platform/soc_camera/soc_camera.c:39:0: include/media/v4l2-of.h:112:13: warning: 'v4l2_of_free_endpoint' defined but not used [-Wunused-function] static void v4l2_of_free_endpoint(struct v4l2_of_endpoint *endpoint) ^ In file included from drivers/media/platform/soc_camera/atmel-isi.c:28:0: include/media/v4l2-of.h:112:13: warning: 'v4l2_of_free_endpoint' defined but not used [-Wunused-function] static void v4l2_of_free_endpoint(struct v4l2_of_endpoint *endpoint) ^ In file included from drivers/media/platform/soc_camera/rcar_vin.c:36:0: include/media/v4l2-of.h:112:13: warning: 'v4l2_of_free_endpoint' defined but not used [-Wunused-function] static void v4l2_of_free_endpoint(struct v4l2_of_endpoint *endpoint) ^ Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-27[media] media: i2c/adp1653: Devicetree support for adp1653Pavel Machek
Add device tree support for adp1653 flash LED driver. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-27[media] v4l: of: Parse variable length properties --- link-frequenciesSakari Ailus
The link-frequencies property is a variable length array of link frequencies in an endpoint. The array is needed by an increasing number of drivers, so it makes sense to add it to struct v4l2_of_endpoint. However, the length of the array is variable and the size of struct v4l2_of_endpoint is fixed since it is allocated by the caller. The options here are 1. to define a fixed maximum limit of link frequencies that has to be the global maximum of all boards. This is seen as problematic since the maximum could be largish, and everyone hitting the problem would need to submit a patch to fix it, or 2. parse the property in every driver. This doesn't sound appealing as two of the three implementations submitted to linux-media were wrong, and one of them was even merged before this was noticed, or 3. change the interface so that allocating and releasing memory according to the size of the array is possible. This is what the patch does. v4l2_of_alloc_parse_endpoint() is just like v4l2_of_parse_endpoint(), but it will allocate the memory resources needed to store struct v4l2_of_endpoint and the additional arrays pointed to by this struct. A corresponding release function v4l2_of_free_endpoint() is provided to release the memory allocated by v4l2_of_alloc_parse_endpoint(). In addition to this, the link-frequencies property is parsed as well, and the result is stored to struct v4l2_of_endpoint field link_frequencies. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Tested-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-27[media] v4l: of: Instead of zeroing bus_type and bus field separately, unify ↵Sakari Ailus
this Zero the entire struct starting from bus_type. As more fields are added, no changes will be needed in the function to reset their value explicitly. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-27[media] v4l: of: Remove the head field in struct v4l2_of_endpointSakari Ailus
The field is unused. Remove it. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-21Merge branch 'patchwork' into v4l_for_linusMauro Carvalho Chehab
* patchwork: (404 commits) [media] uvcvideo: add support for VIDIOC_QUERY_EXT_CTRL [media] uvcvideo: fix cropcap v4l2-compliance failure [media] media: omap3isp: remove unused clkdev [media] coda: Add tracing support [media] coda: drop dma_sync_single_for_device in coda_bitstream_queue [media] coda: fix fill bitstream errors in nonstreaming case [media] coda: call SEQ_END when the first queue is stopped [media] coda: fail to start streaming if userspace set invalid formats [media] coda: remove duplicate error messages for buffer allocations [media] coda: move parameter buffer in together with context buffer allocation [media] coda: allocate bitstream buffer from REQBUFS, size depends on the format [media] coda: allocate per-context buffers from REQBUFS [media] coda: use strlcpy instead of snprintf [media] coda: bitstream payload is unsigned [media] coda: fix double call to debugfs_remove [media] coda: check kasprintf return value in coda_open [media] coda: bitrate can only be set in kbps steps [media] v4l2-mem2mem: no need to initialize b in v4l2_m2m_next_buf and v4l2_m2m_buf_remove [media] s5p-mfc: set allow_zero_bytesused flag for vb2_queue_init [media] coda: set allow_zero_bytesused flag for vb2_queue_init ...
2015-04-10[media] media: omap3isp: remove unused clkdevRussell King
No merged platform supplies xclks via platform data. As we want to slightly change the clkdev interface, rather than fixing this unused code, remove it instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-10[media] vb2: add allow_zero_bytesused flag to the vb2_queue structKamil Debski
The vb2: fix bytesused == 0 handling (8a75ffb) patch changed the behavior of __fill_vb2_buffer function, so that if bytesused is 0 it is set to the size of the buffer. However, bytesused set to 0 is used by older codec drivers as as indication used to mark the end of stream. To keep backward compatibility, this patch adds a flag passed to the vb2_queue_init function - allow_zero_bytesused. If the flag is set upon initialization of the queue, the videobuf2 keeps the value of bytesused intact in the OUTPUT queue and passes it to the driver. Reported-by: Nicolas Dufresne <nicolas.dufresne@collabora.com> Signed-off-by: Kamil Debski <k.debski@samsung.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-10[media] vb2: split the io_flags member of vb2_queue into a bit fieldKamil Debski
This patch splits the io_flags member of vb2_queue into a bit field. Instead of an enum with flags separate bit fields were introduced. Signed-off-by: Kamil Debski <k.debski@samsung.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-03[media] v4l: of: Add v4l2_of_parse_link() functionLaurent Pinchart
The function fills a link data structure with the device node and port number at both the local and remote ends of a link defined by one of its endpoint nodes. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-03[media] media: entity: Document the media_entity_ops structureLaurent Pinchart
Currently, there's no documentation for the structure. Add a kernel-doc nano documentation to it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-02[media] media: davinci: vpfe_capture: embed video_deviceLad, Prabhakar
Embed the video_device struct to simplify the error handling and in order to (eventually) get rid of video_device_alloc/release. Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-02[media] saa7146: embed video_deviceHans Verkuil
Embed the video_device struct to simplify the error handling and in order to (eventually) get rid of video_device_alloc/release. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-02[media] media: i2c: add support for omnivision's ov2659 sensorBenoit Parrot
this patch adds support for omnivision's ov2659 sensor, the driver supports following features: 1: Asynchronous probing 2: DT support 3: Media controller support Signed-off-by: Benoit Parrot <bparrot@ti.com> Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-02[media] v4l: mt9p031: Convert to the gpiod APILaurent Pinchart
This simplifies platform data and DT integration. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Reviewed-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-02[media] V4L: add CCF support to the v4l2_clk APIGuennadi Liakhovetski
V4L2 clocks, e.g. used by camera sensors for their master clock, do not have to be supplied by a different V4L2 driver, they can also be supplied by an independent source. In this case the standart kernel clock API should be used to handle such clocks. This patch adds support for such cases. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Tested-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-02[media] V4L: remove clock name from v4l2_clk APIGuennadi Liakhovetski
All uses of the v4l2_clk API so far only register one clock with a fixed name. This allows us to get rid of it, which also will make CCF and DT integration easier. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Tested-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-02[media] v4l: of: Read lane-polarities endpoint propertySakari Ailus
Add lane_polarities field to struct v4l2_of_bus_mipi_csi2 and write the contents of the lane-polarities property to it. The field tells the polarity of the physical lanes starting from the first one. Any unused lanes are ignored, i.e. only the polarity of the used lanes is specified. Also rework reading the "data-lanes" property a little. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-02[media] omap3isp: Calculate vpclk_div for CSI-2Sakari Ailus
The video port clock is l3_ick divided by vpclk_div. This clock must be high enough for the external pixel rate. The video port requires two clock cycles to process a pixel. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-02[media] omap3isp: Refactor device configuration structs for Device TreeSakari Ailus
Make omap3isp configuration data structures more suitable for consumption by the DT by separating the I2C bus information of all the sub-devices in a group and the ISP bus information from each other. The ISP bus information is made a pointer instead of being directly embedded in the struct. In the case of the DT only the sensor specific information on the ISP bus configuration is retained. The structs are renamed to reflect that. After this change the structs needed to describe device configuration can be allocated and accessed separately without those needed only in the case of platform data. The platform data related structs can be later removed once the support for platform data can be removed. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Igor Grinberg <grinberg@compulab.co.il> (for cm-t35) Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-03-23[media] v4l2-subdev: remove enum_framesizes/intervalsHans Verkuil
The video and pad ops are duplicates, so get rid of the more limited video op. The whole point of the subdev API is to allow reuse of subdev drivers by bridge drivers. Having duplicate ops makes that much harder. We should never have allowed duplicate ops in the first place. A lesson for the future. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-03-23[media] v4l2-subdev: replace v4l2_subdev_fh by v4l2_subdev_pad_configHans Verkuil
If a subdevice pad op is called from a bridge driver, then there is no v4l2_subdev_fh struct that can be passed to the subdevice. This made it hard to use such subdevs from a bridge driver. This patch replaces the v4l2_subdev_fh pointer by a v4l2_subdev_pad_config pointer in the pad ops. This allows bridge drivers to use the various try_ pad ops by creating a v4l2_subdev_pad_config struct and passing it along to the pad op. The v4l2_subdev_get_try_* macros had to be changed because of this, so I also took the opportunity to use the full name of the v4l2_subdev_get_try_* functions in the __V4L2_SUBDEV_MK_GET_TRY macro arguments: if you now do 'git grep v4l2_subdev_get_try_format' you will actually find the header where it is defined. One remark regarding the drivers/staging/media/davinci_vpfe patches: the *_init_formats() functions assumed that fh could be NULL. However, that's not true for this driver, it's always set. This is almost certainly a copy and paste from the omap3isp driver. I've updated the code to reflect the fact that fh is never NULL. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Tested-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-03-02[media] v4l2-core: drop g/s_priority opsHans Verkuil
The handling of VIDIOC_G/S_PRIORITY is now entirely done by the V4L2 core, so we can drop the g/s_priority ioctl ops. We do have to make sure though that when S_PRIORITY is called we check that the driver used struct v4l2_fh. This check can be removed once all drivers are converted to that structure. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-03-02[media] v4l2-core: remove the old .ioctl BKL replacementHans Verkuil
To keep V4L2 drivers that did not yet convert to unlocked_ioctl happy, the v4l2 core had a .ioctl file operation that took a V4L2 lock. The last drivers are now converted to unlocked_ioctl, so all this old code can now be removed. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-03-02[media] media: i2c: ADV7604: Rename adv7604 prefixesPablo Anton
It is confusing which parts of the driver are adv7604 specific, adv7611 specific or common for both. This patch renames any adv7604 prefixes (both for functions and defines) to adv76xx whenever they are common. Signed-off-by: Pablo Anton <pablo.anton@vodalys-labs.com> Signed-off-by: Jean-Michel Hautbois <jean-michel.hautbois@vodalys.com> [hans.verkuil@cisco.com: rebased and renamed ADV76xx_fsc to ADV76XX_FSC] [hans.verkuil@cisco.com: kept the existing adv7604 driver name] Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-03-02[media] media: atmel-isi: increase the burst length to improve the performanceJosh Wu
The burst length could be BEATS_4/8/16. Before this patch, isi use default value BEATS_4. To imporve the performance we could set it to BEATS_16. Otherwise sometime it would cause the ISI overflow error. Reported-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
