The v4l2_video_std_fps function has been removed by Adrian Bunk in 2004
but then its prototype re-appeared in include/media/v4l2-dev.h. Remove it.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Added default vidioc handler for other private ioctls
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
As pointed by Adrian Bunk, with I2C=m and VIDEO_DEV=y, videodev brokes.
This patch moves the functions that videodev needs from v4l2-common. It also
fixes some Kconfig changes.
After this patch, I2C=m / VIDEO_DEV=y will make v4l2 core statically linked
into kernel. v4l2-common will be m, and all V4L drivers will also be m.
This approach is very conservative, since it is possible to have V4L drivers
that don't need I2C or v4l2-common. The better is to map what drivers really
need v4l2-common, making them to select v4l2-common, and allowing the others to
be 'y', 'm' and 'n'.
Remove the obsolete VIDIOC_G_MPEGCOMP and VIDIOC_S_MPEGCOMP ioctls from
the V4L2 API as per the removal schedule (October 2007).
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
struct video_device used to define a .hardware field. While
initialized on severl drivers, this field is never used inside V4L.
However, drivers using it need to include the old V4L1 header.
This seems to cause compilation troubles with some random configs.
Better just to remove it from all drivers.
The currently used "struct class_device" will be removed from the
kernel. Here is a patch that converts all users in drivers/media/video/
to struct device.
Reviewed-by: Thierry Merle <thierry.merle@free.fr>
Reviewed-by: Mike Isely <isely@pobox.com>
Reviewed-by: Luca Risolia <luca.risolia@studio.unibo.it>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This patch cleans up duplicate includes in
include/media/
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
VIDIOC_G_CHIP_IDENT improves debugging of card problems: it can be
used to detect which chips are on the board and based on that information
selected register dumps can be made, making it easy to debug complicated
media chips containing tens or hundreds of registers.
This ioctl replaces the internal VIDIOC_INT_G_CHIP_IDENT ioctl.
Add V4L2_BUF_TYPE_VIDEO_OUTPUT_OVERLAY support.
Also add support for local and global alpha overlays.
Add new field enums V4L2_FIELD_INTERLACED_TB and V4L2_FIELD_INTERLACED_BT.
These changes are needed to support the ivtv On Screen Display features.
Add support for starting, stopping, pausing and resuming an MPEG (or similar
compressed stream) encoder.
The VIDIOC_G_ENC_INDEX ioctl can obtain the MPEG index from an MPEG
encoder.
The direct register access ioctls were defined as kernel internal only,
but they are very useful for debugging hardware from userspace and are
used as such. Officially export them.
VIDIOC_INT_[SG]_REGISTER is renamed to VIDIOC_DBG_[SG]_REGISTER
Definition of ioctl and struct v4l2_register is moved from v4l2-common.h
to videodev2.h.
Types used in struct v4l2_register are changed to the userspace
exportable versions (u32 -> __u32, etc).
Use of VIDIOC_DBG_S_REGISTER requires CAP_SYS_ADMIN permission, so move
the check into the video_ioctl2() dispatcher so it doesn't need to be
duplicated in each driver's call-back function. CAP_SYS_ADMIN check is
added to pvrusb2 (which doesn't use video_ioctl2).
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Add support for these ioctls to the video_ioctl2 system and the cx88
driver.
video_ioctl2 will auto-generate standard entries at ENUM_FMT.
Also, now, a driver may return a subset of the video array at
the return, to be stored as the current_norm.
For example, a driver may ask for V4L2_STD_PAL. At return,
driver may change it to V4L2_STD_PAL_B. This way, a futher call
to G_STD will return the exact detected video std.
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (180 commits)
V4L/DVB (4641): Trivial: use lowercase letters in hex subsystem ids
V4L/DVB (4639): Cx88: add autodetection for alternate revision of Leadtek PVR
V4L/DVB (4638): Basic DVB-T and analog TV support for the HVR1300.
V4L/DVB (4637): Add a default method for VIDIOC_G_PARM
V4L/DVB (4635): Extend bttv and saa7134 to check for both AGP and PCI PCI failure case
V4L/DVB (4634): Zr36120: implement pcipci checks
V4L/DVB (4632): Zoran: Implement pcipci failure check
V4L/DVB (4631): Av7110: remove V4L2_CAP_VBI_CAPTURE flag
V4L/DVB (4630): Av7110: FW_LOADER depemdency fixed
V4L/DVB (4629): Saa7134: add card support for Proteus Pro 2309
V4L/DVB (4628): Fix VIDIOC_ENUMSTD ioctl in videodev.c
V4L/DVB (4627): Vivi crashes with mplayer
V4L/DVB (4626): On saa7111/7113, LUMA_CTRL need a different value
V4L/DVB (4624): Tvaudio: Replaced kernel_thread() with kthread_run()
V4L/DVB (4622): Copy-paste bug in videodev.c
V4L/DVB (4620): Fix AGC configuration for MOD3000P-based boards
V4L/DVB (4619): Fixes some I2C dependencies on V4L devices
V4L/DVB (4617): Problem with dibusb-mb.c USB IDs
V4L/DVB (4616): [PATCH] Nebula DigiTV USB RC support
V4L/DVB (4614): Export symbol saa7134_tvaudio_setmute from saa7134 for saa7134-alsa
All radio devices use an obsolete mode of opening/release driver.
Since this is not V4L1 core, better to keep the method available for more
time than to rewrite open/release without a radio device to test, since the
newer method is much more complex than the previous one (although providing
support for multiple opens and multiple devices).
We get hundreds of these:
include/media/v4l2-dev.h:348: warning: ignoring return value of 'class_device_create_file', declared with attribute warn_unused_result
Handle it, and propagate the __must_check back a level.
V4L1 support should be disabled when no CONFIG_VIDEO_V4L1_COMPAT is defined,
to allow checking for broken V4L2 ports. This is very important during the
migration phase for V4L2 API.
However, userspace apps should be capable of using both APIs, since they need
to test at runtime, via VIDIOCGCAP ioctl, if V4L1 is supported. So, when
__KERNEL__ is not defined, those ioctls and corresponding structs should be
visible.
This patch also removes the obsolete defines HAVE_V4L1 and HAVE_V4L2, that
where causing some confusion, and were replaced by CONFIG_VIDEO_V4L1_COMPAT
and CONFIG_VIDEO_V4L2.
Check __must_check warnings for class_device_register and class_device_create_file
video_device_create_file was declared as a void, but instead should
return the int value of class_device_create_file.
Move the check from bttv-driver.c into v4l2-dev.h, because all other
callers of video_device_create_file must also be checked.
Replace the call to class_device_create_file in videodev.c with
video_device_create_file, as defined in v4l2-dev.h, so that the
return value of class_device_create_file will be checked.
Check the return value of class_device_register in videodev.c and
pvrusb2-sysfs.c
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Also fixes all drivers that set this field.
videodev.c copies the control list specified in struct v4l2_ext_controls
to kernel space.
videodev2.h
The videodev.h and videodev2.h describe the public API for V4L and V4L2.
It shouldn't have there any kernel-specific stuff. Those were moved to
v4l2-dev.h.
This patch removes some uneeded headers and include v4l2-common.h on all
V4L driver. This header includes device implementation of V4L2 API provided
on v4l2-dev.h as well as V4L2 internal ioctls that provides connections
between master driver and its i2c devices.
Videodev now is capable of better handling V4L2 api, by
processing V4L2 ioctls and using callbacks to the driver.
The drivers should be migrated to the newer way and the older
one will be obsoleted soon.
