path: root/include/media/v4l2-common.h
2013-11-18Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c changes from Wolfram Sang: - new drivers for exynos5, bcm kona, and st micro - bigger overhauls for drivers mxs and rcar - typical driver bugfixes, cleanups, improvements - got rid of the superfluous 'driver' member in i2c_client struct This touches a few drivers in other subsystems. All acked. * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits) i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe() i2c: i2c-eg20t: do not print error message in syslog if no ACK received i2c: bcm-kona: Introduce Broadcom I2C Driver i2c: cbus-gpio: Fix device tree binding i2c: wmt: add missing clk_disable_unprepare() on error i2c: designware: add new ACPI IDs i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCH i2c: exynos5: Remove incorrect clk_disable_unprepare i2c: i2c-st: Add ST I2C controller i2c: exynos5: add High Speed I2C controller driver i2c: rcar: fixup rcar type naming i2c: scmi: remove some bogus NULL checks i2c: sh_mobile & rcar: Enable the driver on all ARM platforms i2c: sh_mobile: Convert to clk_prepare/unprepare i2c: mux: gpio: use reg value for i2c_add_mux_adapter i2c: mux: gpio: use gpio_set_value_cansleep() i2c: Include linux/of.h header i2c: mxs: Fix PIO mode on i.MX23 i2c: mxs: Rework the PIO mode operation i2c: mxs: distinguish i.MX23 and i.MX28 based I2C controller ...
2013-10-17[media] v4l2-ctrls: Correct v4l2_ctrl_get_int_menu() function's return typeSylwester Nawrocki
Remove the redundant 'const' qualifiers from the function signature and from the qmenu_int arrays' declarations. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-10-03media: core: Don't use i2c_client->driverLars-Peter Clausen
The 'driver' field of the i2c_client struct is redundant and is going to be removed. The results of the expressions 'client->driver.driver->field' and 'client->dev.driver->field' are identical, so replace all occurrences of the former with the later. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-08-18v4l2-common: warning fix (W=1): add a missed function prototypeMauro Carvalho Chehab
changeset d1e9b7c12 added a new ancilliary function to API, but forgot to add it to the corresponding header file. drivers/media/v4l2-core/v4l2-ctrls.c:568:18: warning: no previous prototype for 'v4l2_ctrl_get_int_menu' [-Wmissing-prototypes] const s64 const *v4l2_ctrl_get_int_menu(u32 id, u32 *len) Cc: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-08-18[media] v4l2: move dv-timings related code to v4l2-dv-timings.cHans Verkuil
v4l2-common.c contained a bunch of dv-timings related functions. Move that to the new v4l2-dv-timings.c which is a more appropriate place for them. There aren't many drivers that do HDTV, so it is a good idea to separate common code related to that into a module of its own. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-06-21[media] v4l2-common: remove unused v4l2_chip_match/ident_i2c_client functionsHans Verkuil
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-06-21[media] v4l2: remove obsolete v4l2_chip_match_host()Hans Verkuil
This function is no longer needed since it is now the responsibility of the v4l2 core to check if the DBG_G/S_REGISTER and DBG_G_CHIP_INFO ioctls are called for the bridge driver or not. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-24[media] v4l2-common: remove obsolete v4l_fill_dv_preset_infoHans Verkuil
It's no longer used, so it can now be removed. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-21[media] v4l: Helper function for obtaining timestampsSakari Ailus
v4l2_get_timestamp() produces a monotonic timestamp but unlike ktime_get_ts(), it uses struct timeval instead of struct timespec, saving the drivers the conversion job when getting timestamps for v4l2_buffer's timestamp field. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-13[media] v4l2-common: add CVT and GTF detection functionsHans Verkuil
These two helper functions detect whether the analog video timings detected by the video receiver match the VESA CVT or GTF standards. They basically do the inverse of the CVT and GTF modeline calculations. This patch also adds a helper function that will determine the aspect ratio based on the provided EDID values. This aspect ratio can be given to the GTF helper function. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-13[media] v4l2-common: add v4l_match_dv_timingsHans Verkuil
Add the v4l_match_dv_timings function that can be used to compare two v4l2_dv_timings structs. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-11[media] v4l2: typosMichael Jones
[mchehab@redhat.com: fix a merge conflict at Documentation/video4linux/v4l2-framework.txt] Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l2_prio: move from v4l2-common to v4l2-devHans Verkuil
We are going to move priority handling into the v4l2 core. As a consequence the v4l2_prio helper functions need to be moved into the core videodev module as well to prevent circular dependencies. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-19[media] v4l2-subdev: remove core.s_config and v4l2_i2c_new_subdev_cfg()Hans Verkuil
The core.s_config op was meant for legacy drivers that needed to work with old pre-2.6.26 kernels. This is no longer relevant. Unfortunately, this op was incorrectly called from several drivers. Replace those occurences with proper i2c_board_info structs and call v4l2_i2c_new_subdev_board. After these changes v4l2_i2c_new_subdev_cfg() was no longer used, so remove that function as well. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-30[media] v4l2-ctrls: use const char * const * for the menu arraysHans Verkuil
This prevents checkpatch warnings generated when defining 'static const char *foo[]' arrays. It makes sense to use const char * const * anyway since the pointers in the array are indeed const. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-11-22[media] v4l: Remove module_name argument to the v4l2_i2c_new_subdev* functionsLaurent Pinchart
The argument isn't used anymore by the functions, remove it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: v4l2-common: Move v4l2_find_nearest_format from videodev2.h to ↵Hans Verkuil
v4l2-common.h This function is an internal API and belongs in v4l2-common.h, not videodev.h. The return pointer and probe argument should be const as well. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: v4l2-common: simplify prio utility functionsHans Verkuil
v4l2_prio_init/open/close returned an int when in fact they would always return 0. Make these void functions. v4l2_prio_close and v4l2_prio_check pass an enum v4l2_priority as a pointer for no good reason. Replace with a normal enum v4l2_priority argument. These changes will simplify the work of moving priority handling into the v4l core. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: Add SPI support to V4L2Dmitri Belimov
Add support SPI bus to v4l2. Useful for control some device with SPI bus like hardware MPEG2 encoders and etc. Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13618): v4l2: Adding helper function to get dv preset descriptionMuralidharan Karicheri
This patch adds a helper function to get description of a digital video preset added by the video timing API. This will be useful for drivers implementing the above API. Signed-off-by: Muralidharan Karicheri <m-karicheri2@ti.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12540): v4l: simplify v4l2_i2c_new_subdev and friendsHans Verkuil
Rewrite v4l2_i2c_new_subdev as a simplified version of v4l2_i2c_new_subdev_cfg and remove v4l2_i2c_new_probed_subdev and v4l2_i2c_new_probed_subdev_addr. This simplifies this API substantially. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-23V4L/DVB (11901): v4l2: Create helper function for bounding and aligning imagesTrent Piepho
Most hardware has limits on minimum and maximum image dimensions and also requirements about alignment. For example, image width must be even or a multiple of four. Some hardware has requirements that the total image size (width * height) be a multiple of some power of two. v4l_bound_align_image() will enforce min and max width and height, power of two alignment on width and height, and power of two alignment on total image size. It uses an efficient algorithm that will try to find the "closest" image size that meets the requirements. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-23V4L/DVB (12125): v4l2: add new s_config subdev ops and ↵Hans Verkuil
v4l2_i2c_new_subdev_cfg/board calls Add a new s_config core ops call: this is called with the irq and platform data to be used to initialize the subdev. Added new v4l2_i2c_new_subdev_cfg and v4l2_i2c_new_subdev_board calls that allows you to pass these new arguments. The existing v4l2_i2c_new_subdev functions were modified to also call s_config. In the future the existing v4l2_i2c_new_subdev functions will be replaced by a single v4l2_i2c_new_subdev function similar to v4l2_i2c_new_subdev_cfg but without the irq and platform_data arguments. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11381): ivtv/cx18: remove VIDIOC_INT_S_AUDIO_ROUTING debug support.Hans Verkuil
Remove support for the debug call VIDIOC_INT_S_AUDIO_ROUTING from cx18 and ivtv. These internal ioctls shouldn't be exposed. These were only used through the cx18-ctl and ivtv-ctl utilities, and only when testing a new card variant. This cleanup allows the removal of this ioctl from v4l2-common.h. Cc: Andy Walls <awalls@radix.net> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11373): v4l2-common: add explicit v4l2_device pointer as first arg ↵Hans Verkuil
to new_(probed)_subdev The functions v4l2_i2c_new_subdev and v4l2_i2c_new_probed_subdev relied on i2c_get_adapdata to return the v4l2_device. However, this is not always possible on embedded platforms. So modify the API to pass the v4l2_device pointer explicitly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11374): v4l2-common: add v4l2_i2c_new_probed_subdev_addrHans Verkuil
Add utility function to probe for a single address, rather than a list of addresses. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11367): v4l2-common: remove legacy codeHans Verkuil
Now that all drivers are converted to v4l2_subdev we can remove legacy code in v4l2-common. Also move the documentation of the internal API to v4l2-subdev.h where it really belongs. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10698): v4l2-common: remove v4l2_ctrl_query_fill_stdHans Verkuil
The v4l2_ctrl_query_fill_std() function wasn't one the best idea I ever had. It doesn't add anything valuable that cannot be expressed equally well with v4l2_ctrl_query_fill and only adds overhead. Replace it with v4l2_ctrl_query_fill() everywhere it is used and remove it from v4l2_common.c. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10691): v4l2-common: add v4l2_i2c_subdev_addr()Hans Verkuil
Add small function to retrieve the i2c address from a v4l2_subdev pointer. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10544): v4l2-common: add comments warning that about the sort orderHans Verkuil
Control arrays as are used with v4l2_ctrl_next must be sorted from low to high. Add a comment at the top of all such arrays to warn about this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10542): v4l2-subdev: add querystd and g_input_statusHans Verkuil
In order to convert the v4l1 zoran and vino i2c drivers to v4l2 these extra ops are required. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10249): v4l2-common: added v4l2_i2c_tuner_addrs()Hans Verkuil
Add v4l2_i2c_tuner_addrs() to obtain the various I2C tuner addresses. This will be used in several drivers, so make this a common function as we do not want to have these I2C addresses all over the place. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9821): v4l2-common: add i2c helper functionsHans Verkuil
Add helper functions to load i2c sub-devices, integrating them into the v4l2-framework. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8940): saa7115: fix saa7111(a) supportHans Verkuil
The saa7111 support in saa7115.c was missing some features and did not properly take some of the differences into account. With this patch saa7115 can be used in the mxb driver instead of saa7111.c. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8637): v4l2: add v4l2_ctrl_query_menu_valid_items support functionHans Verkuil
v4l2_ctrl_query_menu_valid_items() makes it easy to handle control menus that have a lot of invalid 'holes'. For example, many MPEG encoders only support a limited subset of audio bitrates. In that case a driver can specify an array listing the set of valid bitrates and pass that to this function. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8636): v4l2: add v4l2_ctrl_get_name control support function.Hans Verkuil
Add function that returns the control name. Allows this to be used in places where the normal v4l2_ctrl_query_fill() function cannot be used (e.g. uvc). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-23V4L/DVB (8434): Fix x86_64 compilation and move some macros to v4l2-ioctl.hMauro Carvalho Chehab
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-23V4L/DVB (8430): videodev: move some functions from v4l2-dev.h to ↵Hans Verkuil
v4l2-common.h or v4l2-ioctl.h The functions in a header should not belong to another module. The prio functions belong to v4l2-common.c, so move them to v4l2-common.h. The ioctl functions belong to v4l2-ioctl.c, so create a new v4l2-ioctl.h header and move those functions to it. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-02-18V4L/DVB (7133): Fix Kconfig dependenciesMauro Carvalho Chehab
As pointed by Adrian Bunk, with I2C=m and VIDEO_DEV=y, videodev brokes. This patch moves the functions that videodev needs from v4l2-common. It also fixes some Kconfig changes. After this patch, I2C=m / VIDEO_DEV=y will make v4l2 core statically linked into kernel. v4l2-common will be m, and all V4L drivers will also be m. This approach is very conservative, since it is possible to have V4L drivers that don't need I2C or v4l2-common. The better is to map what drivers really need v4l2-common, making them to select v4l2-common, and allowing the others to be 'y', 'm' and 'n'. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6451): v4l2: add support for bus-based I2C driversHans Verkuil
Two new headers were added: one for I2C drivers that are only used by V4L2 drivers converted to the new bus-based I2C API, and one that can be used by both converted and unconverted drivers (at the expense of some additional overhead). To support the legacy I2C API a helper function was added to v4l2-common.c. These headers take care of all the 'boilerplate' code that all V4L2 I2C drivers have in common and will automatically support the bus-based I2C API introduced in kernel 2.6.22. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6384): Replace TDA9887_SET_CONFIG by TUNER_SET_CONFIGMauro Carvalho Chehab
Currently, the only tuner-specific device that allows special configurations is tda9887. However, tea5767 also may require some special configurations (for example, to specify a different Xtal freq). This patch replaces TDA9887_SET_CONFIG by a more generic internal ioctl (TUNER_SET_CONFIG). The newer one allows specifying what tuner is appliable to a configuration set, and allows an arbitrary configuration struct. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5306): Add support for VIDIOC_G_CHIP_IDENTHans Verkuil
VIDIOC_G_CHIP_IDENT improves debugging of card problems: it can be used to detect which chips are on the board and based on that information selected register dumps can be made, making it easy to debug complicated media chips containing tens or hundreds of registers. This ioctl replaces the internal VIDIOC_INT_G_CHIP_IDENT ioctl. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5290): Add support for VIDIOC_INT_G/S_STD_OUTPUTHans Verkuil
Added VIDIOC_INT_G_STD_OUTPUT and VIDIOC_INT_S_STD_OUTPUT to allow drivers to set the TV standard for video output separately from the video capture. This is needed for cx23415 support where the decoder is separate from the encoder and can have a different TV standard. Modified the saa7127 module to listen to VIDIOC_INT_G/S_STD_OUTPUT instead of VIDIOC_G/S_STD. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5304): Improve chip matching in v4l2_registerHans Verkuil
The chip matching in struct v4l2_register for VIDIOC_DBG_G/S_REGISTER was rather primitive. It could not be extended to other busses besides i2c and it lacked a way to. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5200): V4l_printk_ioctl_arg() is no longer used.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5146): Make VIDIOC_INT_[SG]_REGISTER ioctls no longer internal onlyTrent Piepho
The direct register access ioctls were defined as kernel internal only, but they are very useful for debugging hardware from userspace and are used as such. Officially export them. VIDIOC_INT_[SG]_REGISTER is renamed to VIDIOC_DBG_[SG]_REGISTER Definition of ioctl and struct v4l2_register is moved from v4l2-common.h to videodev2.h. Types used in struct v4l2_register are changed to the userspace exportable versions (u32 -> __u32, etc). Use of VIDIOC_DBG_S_REGISTER requires CAP_SYS_ADMIN permission, so move the check into the video_ioctl2() dispatcher so it doesn't need to be duplicated in each driver's call-back function. CAP_SYS_ADMIN check is added to pvrusb2 (which doesn't use video_ioctl2). Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4798): OmniVision OV7670 driverJonathan Corbet
This patch adds a V4L2 driver for the OmniVision OV7670 camera. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4796): A couple of V4L2 defines needed by Cafe Camara driverJonathan Corbet
Two defines for V4L2, needed by the Cafe camera driver: 1) Add the RGB444 image format 2) Add the "init" internal command which is separate from "reset". Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
