path: root/include/media/rc-map.h
2017-12-14media: lirc: implement scancode sendingSean Young
This introduces a new lirc mode: scancode. Any device which can send raw IR can now also send scancodes. int main() { int mode, fd = open("/dev/lirc0", O_RDWR); mode = LIRC_MODE_SCANCODE; if (ioctl(fd, LIRC_SET_SEND_MODE, &mode)) { // kernel too old or lirc does not support transmit } struct lirc_scancode scancode = { .scancode = 0x1e3d, .rc_proto = RC_PROTO_RC5, }; write(fd, &scancode, sizeof(scancode)); close(fd); } The other fields of lirc_scancode must be set to 0. Note that toggle (rc5, rc6) and repeats (nec) are not implemented. Nor is there a method for holding down a key for a period. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-10-31media: rc: Add Astrometa T2hybrid keymap moduleOleh Kravchenko
Add the keymap module for Astrometa T2hybrid remote control commands. Signed-off-by: Oleh Kravchenko <oleg@kaa.org.ua> Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-10-27media: rc/keymaps: add support for RC of hisilicon poplar boardYounian Wang
This is a NEC protocol type remote controller distributed with 96boards poplar@tocoding board. Signed-off-by: Younian Wang <wangyounian@hisilicon.com> Signed-off-by: Jiancheng Xue <xuejiancheng@hisilicon.com> Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2017-10-27media: rc/keymaps: add support for RC of hisilicon TV demo boardsYounian Wang
This is a NEC protocol type remote controller distributed with hisilicon TV demo boards. Signed-off-by: Younian Wang <wangyounian@hisilicon.com> Signed-off-by: Jiancheng Xue <xuejiancheng@hisilicon.com> Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2017-10-11media: rc: Add tango keymapMarc Gonzalez
Add a keymap for the Sigma Designs Vantage (dev board) remote control. Signed-off-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com> Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-08-20media: rc: rename RC_TYPE_* to RC_PROTO_* and RC_BIT_* to RC_PROTO_BIT_*Sean Young
RC_TYPE is confusing and it's just the protocol. So rename it. Suggested-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Sean Young <sean@mess.org> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-08-20media: rc: add zx-irdec remote control driverShawn Guo
It adds the remote control driver and corresponding keymap file for IRDEC block found on ZTE ZX family SoCs. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-03-24[media] mce_kbd: add encoderSean Young
Split the protocol into two variants, one for keyboard and one for mouse data. Note that the mce_kbd protocol cannot be used on the igorplugusb, since the IR is too long. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-03-24[media] rc: lirc keymap no longer makes any senseSean Young
The lirc keymap existed once upon a time to select the lirc protocol. Since '275ddb4 [media] rc-core: remove the LIRC "protocol"', IR is always passed to the lirc decoder so this keymap is no longer needed. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-01-31[media] rc/keymaps: add a keytable for the GeekBox remote controlMartin Blumenstingl
The GeekBox ships with a 12 button remote control which seems to use the NEC protocol. The button keycodes were captured with the "ir-keytable" tool (ir-keytable -p $PROTOCOL -t; human_button_pusher). Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com> Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-01-30[media] rc: rc-core: Add support for encode_wakeup driversJames Hogan
Add support in rc-core for drivers which implement the wakeup scancode filter by encoding the scancode using the raw IR encoders. This is by way of rc_dev::encode_wakeup which should be set to true and rc_dev::allowed_wakeup_protocols should be set to the raw IR encoders. We also do not permit the mask to be set as we cannot generate IR which would match that. Signed-off-by: James Hogan <james@albanarts.com> Signed-off-by: Antti Seppälä <a.seppala@gmail.com> Signed-off-by: Sean Young <sean@mess.org> Cc: David Härdeman <david@hardeman.nu> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-01-30[media] rc: raw IR drivers cannot handle cec, unknown or otherSean Young
unknown and other are for IR protocols for which we have no decoder, so the raw IR drivers have no chance of generating them. cec is not an IR protocol. Signed-off-by: Sean Young <sean@mess.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Benjamin Tissoires <benjamin.tissoires@redhat.com> Cc: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-01-30[media] rc5x: document that this is the 20 bit variantSean Young
There are many variants of extended rc5. This implements the 20 bit version. Signed-off-by: Sean Young <sean@mess.org> Cc: David Härdeman <david@hardeman.nu> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-01-30[media] cxusb: port to rc-coreSean Young
The d680_dmb keymap has some new new mappings. Tested-by: Vincent McIntyre <vincent.mcintyre@gmail.com> Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-09-22[media] rc: split nec protocol into its three variantsSean Young
Currently we do not know what variant (bit length) of the nec protocol is used, other than from guessing from the length of the scancode. Now nec will be handled the same way as the sony protocol or the rc6 protocol; one variant per bit length. In the future we might want to expose the rc protocol type to userspace and we don't want to be introducing this world of pain into userspace too. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-09-09[media] rc-map.h: fix a Sphinx warningMauro Carvalho Chehab
./include/media/rc-map.h:121: WARNING: Inline emphasis start-string without end-string. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-09-09[media] rc-map.h: document structs/enums on itMauro Carvalho Chehab
There are some structs/enums that aren't documented via kernel-doc markup. Add documentation for them. Fix those warnings: ./include/media/rc-map.h:103: WARNING: c:type reference target not found: rc_map_list ./include/media/rc-map.h:110: WARNING: c:type reference target not found: rc_map_list ./include/media/rc-map.h:117: WARNING: c:type reference target not found: rc_map Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-07-23Merge branch 'patchwork' into topic/docs-nextMauro Carvalho Chehab
* patchwork: (1492 commits) [media] cec: always check all_device_types and features [media] cec: poll should check if there is room in the tx queue [media] vivid: support monitor all mode [media] cec: fix test for unconfigured adapter in main message loop [media] cec: limit the size of the transmit queue [media] cec: zero unused msg part after msg->len [media] cec: don't set fh to NULL in CEC_TRANSMIT [media] cec: clear all status fields before transmit and always fill in sequence [media] cec: CEC_RECEIVE overwrote the timeout field [media] cxd2841er: Reading SNR for DVB-C added [media] cxd2841er: Reading BER and UCB for DVB-C added [media] cxd2841er: fix switch-case for DVB-C [media] cxd2841er: fix signal strength scale for ISDB-T [media] cxd2841er: adjust the dB scale for DVB-C [media] cxd2841er: provide signal strength for DVB-C [media] cxd2841er: fix BER report via DVBv5 stats API [media] mb86a20s: apply mask to val after checking for read failure [media] airspy: fix error logic during device register [media] s5p-cec/TODO: add TODO item [media] cec/TODO: drop comment about sphinx documentation ... Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-07-17[media] doc-rst: Fix issues with RC documentationMauro Carvalho Chehab
The kernel-doc script is now broken if it doesn't find all exported symbols documented. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-07-09[media] Convert Wideview WT220 DVB USB driver to rc-coreJonathan McDowell
Converts the dtt200u DVB USB driver over to the rc-core infrastructure for its handling of IR remotes. This device can receive generic NEC / NEC Extended signals and the switch to the newer core enables the easy use of tools such as ir-keytable to modify the active key map. Signed-off-by: Jonathan McDowell <noodles@earth.li> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-06-22[media] rc: Add HDMI CEC protocol handlingKamil Debski
Add handling of remote control events coming from the HDMI CEC bus and the new protocol required for that. Signed-off-by: Kamil Debski <kamil@wypas.org> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2015-11-19[media] media: rc: improve RC_BIT_ constant definitionHeiner Kallweit
The RC_BIT_ constants are used in 64-bit bitmaps. In case of > 32 RC_BIT_ constants the current code will fail on 32-bit systems. Therefore define the RC_BIT_ constants as unsigned long long. Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-07-06[media] rc-core: remove the LIRC "protocol"David Härdeman
The LIRC protocol was always a bad fit and if we're ever going to expose protocol numbers in a user-space API, it'd be better to get rid of the LIRC "protocol" first. The sysfs API is kept backwards compatible by always listing the lirc protocol as present and enabled. Signed-off-by: David Härdeman <david@hardeman.nu> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-06-10[media] rc/keymaps: add keytable for Twinhan DTV CAB CIJan Klötzke
This RC map was taken from Christoph Pinkl's patch (http://patchwork.linuxtv.org/patch/7217/). It is used solely by the respective mantis based card because the encoding is not known. Signed-off-by: Jan Klötzke <jan@kloetzke.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-06-10[media] rc/keymaps: add keytable for Terratec Cinergy S2 HDJan Klötzke
2015-06-10[media] rc/keymaps: add keytable for Terratec Cinergy C PCIJan Klötzke
2015-06-10[media] rc/keymaps: add RC keytable for TechniSat TS35Jan Klötzke
The TS35 remote is distributed with TechniSat CableStar HD2 cards (mantis chipset). The exact protocol type is unknown, making this rc map probably only usable by mantis cards. Signed-off-by: Jan Klötzke <jan@kloetzke.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-09-23[media] rc: add dvbsky rc keymap macronibble.max
This RC will be used by DVBSky driver, added on the next patch. Signed-off-by: Nibble Max <nibble.max@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-07-26[media] rc: Add support for decoding XMP protocolMarcel J.E. Mol
This protocol is found on Dreambox remotes [m.chehab@samsung.com: CodingStyle fixes and conflict fix] Signed-off-by: Marcel Mol <marcel@mesa.nl> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-23[media] rc-core: improve ir-kbd-i2c get_key functionsDavid Härdeman
The arguments used for ir-kbd-i2c's get_key() functions are not really suited for rc-core and the ir_raw/ir_key distinction is just confusing. Convert all of them to return a protocol/scancode/toggle triple instead. Signed-off-by: David Härdeman <david@hardeman.nu> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-07[media, edac] Change my email addressMauro Carvalho Chehab
There are several left overs with my old email address. Remove their occurrences and add myself at CREDITS, to allow people to be able to reach me on my new addresses. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] media: rc: add Sharp infrared protocolJames Hogan
Add Sharp infrared protocol constants RC_TYPE_SHARP and RC_BIT_SHARP. Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-12-10[media] dw2102: Use RC Core instead of the legacy RC (second edition)Evgeny Plehov
Use RC Core instead of the legacy RC. DVBWorld, TBS, TeVii, Prof hardware decode only NEC remotes (one byte code). Geniatech hardware decode only RC5 (two bytes). + New keymap for Geniatech HDStar (SU3000). Signed-off-by: Evgeny Plehov <EvgenyPlehov@ukr.net> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-05-21[media] rc: Add rc-delock-61959Jakob Haufe
This adds the keytable for the remote that comes with the Delock 61959. NEC protocol with address 0x866b. Signed-off-by: Jakob Haufe <sur5r@sur5r.net> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-04-14[media] rc: add rc-reddoAntti Palosaari
It is very similar than rc-msi-digivox-iii but new keytable is needed as there is one existing scancode mapped to different button. Also that one has less buttons. NEC extended protocol with address 0x61d6. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-23[media] rc/keymaps: add RC keytable for MyGica X8507Alfredo Jesús Delaiti
Add RC-5 remote keytable definition for MyGica X8507. [mchehab@redhat.com: fixed whitespacing - it seems that Alfredo's emailer mangled it] Signed-off-by: Alfredo J. Delaiti <alfredodelaiti@netscape.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-27[media] rc-core: add separate defines for protocol bitmaps and numbersDavid Härdeman
The RC_TYPE_* defines are currently used both where a single protocol is expected and where a bitmap of protocols is expected. Functions like rc_keydown() and functions which add/remove entries to the keytable want a single protocol. Future userspace APIs would also benefit from numeric protocols (rather than bitmap ones). Keytables are smaller if they can use a small(ish) integer rather than a bitmap. Other functions or struct members (e.g. allowed_protos, enabled_protocols, etc) accept multiple protocols and need a bitmap. Using different types reduces the risk of programmer error. Using a protocol enum whereever possible also makes for a more future-proof user-space API as we don't need to worry about a sufficient number of bits being available (e.g. in structs used for ioctl() calls). The use of both a number and a corresponding bit is dalso one in e.g. the input subsystem as well (see all the references to set/clear bit when changing keytables for example). This patch separate the different usages in preparation for upcoming patches. Where a single protocol is expected, enum rc_type is used; where one or more protocol(s) are expected, something like u64 is used. The patch has been rewritten so that the format of the sysfs "protocols" file is no longer altered (at the loss of some detail). The file itself should probably be deprecated in the future though. Signed-off-by: David Härdeman <david@hardeman.nu> Cc: Andy Walls <awalls@md.metrocast.net> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Antti Palosaari <crope@iki.fi> Cc: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-20[media] patch for Asus My Cinema PS3-100 (1043:48cd)remi schwartz
Signed-off-by: Remi Schwartz <remi.schwartz@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-20[media] ati_remote: add keymap for Medion X10 OR2x remotesAnssi Hannula
Add another Medion X10 remote keymap. This is for the Medion OR2x remotes with the Windows MCE button. The receiver shipped with this remote has the same USB ID as the other Medion receivers, but the name is different and is therefore used to detect this variant. Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-11[media] ati_remote: add support for Medion X10 Digitainer remoteAnssi Hannula
Add support for another Medion X10 remote. This was apparently originally used with the Medion Digitainer box, but is now sold separately without any Digitainer labeling. A peculiarity of this remote is a scrollwheel in place of up/down buttons. Each direction is mapped to 8 different scancodes, each corresponding to 1..8 notches, allowing multiple notches to the same direction to be transmitted in a single scancode. The driver transforms the multi-notch scancodes to multiple events of the single-notch scancode. (0x70..0x77 = 1..8 notches down, 0x78..0x7f = 1..8 notches up) Since the scrollwheel scancodes are the same that are used for mouse on some other X10 (ati_remote) remotes, the driver will now check whether the active keymap has a keycode defined for the single-notch scancode when a mouse/scrollwheel scancode (0x70..0x7f) is received. If set, scrollwheel is assumed, otherwise mouse is assumed. This remote ships with a different receiver than the already supported Medion X10 remote, but they share the same USB ID. The only difference in the USB descriptors is that the Digitainer receiver has the Remote Wakeup bit set in bmAttributes of the Configuration Descriptor. Therefore that is used to select the default keymap. Thanks to Stephan Raue from OpenELEC (www.openelec.tv) for providing me both a Medion X10 Digitainer remote+receiver and an already supported Medion X10 remote+receiver. Thanks to Martin Beyss for providing some useful information about the remote (including the "Digitainer" name). This patch has been tested by both of them and myself. Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Tested-by: Stephan Raue <stephan@openelec.tv> Tested-by: Martin Beyss <Martin.Beyss@rwth-aachen.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-08[media] Add support for KWorld PC150-U ATSC hybrid tuner cardKyle Strickland
[mchehab@redhat.com: CodingStyle fixes] Signed-off-by: Kyle Strickland <kyle@kyle.strickland.name> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-02-14[media] IT913X Version 1 and Version 2 keymapsMalcolm Priestley
IT913X V1 V2 keymaps Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-10[media] rc-videomate-m1f.c Rename to match remote controler nameSamuel Rakitnican
This remote was added with support for card Compro VideoMate M1F. This remote is shipped with various Compro cards, not this one only. Furthermore this remote can be bought separately under name Compro VideoMate K100. http://compro.com.tw/en/product/k100/k100.html So give it a proper name. [mchehab@redhat.com: Fix the Makefile] Signed-off-by: Samuel Rakitničan <samuel.rakitnican@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-23[media] rc: Add support for decoding Sanyo protocolMauro Carvalho Chehab
This protocol is found on Sanyo/Aiwa remotes. Tested with an Aiwa RC-7AS06 remote control. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-22[media] ati_remote: add support for SnapStream Firefly remoteAnssi Hannula
The protocol differs by having two toggle bits in the scancode. Since one of the bits is otherwise unused, we can safely handle the bits unconditionally. [mchehab@redhat.com: Fix some bad whitespacing] Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-22[media] ati_remote: add keymap for Medion X10 RF remoteAnssi Hannula
2011-09-22[media] ati_remote: migrate to the rc subsystemAnssi Hannula
The keycode mangling algorithm is kept the same, so the new external keymap has the same values as the old static table. [mchehab@redhat.com: Fix some bad whitespacing] Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] rc-core support for Microsoft IR keyboard/mouseJarod Wilson
This is a custom IR protocol decoder, for the RC-6-ish protocol used by the Microsoft Remote Keyboard, apparently developed internally at Microsoft, and officially dubbed MCIR-2, per their March 2011 remote and transceiver requirements and specifications document, which also touches on this IR keyboard/mouse device. Its a standard keyboard with embedded thumb stick mouse pointer and mouse buttons, along with a number of media keys. The media keys are standard RC-6, identical to the signals from the stock MCE remotes, and will be handled as such. The keyboard and mouse signals will be decoded and delivered to the system by an input device registered specifically by this driver. Successfully tested with multiple mceusb-driven transceivers, as well as with fintek-cir and redrat3 hardware. Essentially, any raw IR hardware with enough sampling resolution should be able to use this decoder, nothing about it is at all receiver-hardware-specific. This work is inspired by lirc_mod_mce: The documentation there and code aided in understanding and decoding the protocol, but the bulk of the code is actually borrowed more from the existing in-kernel decoders than anything. I did recycle the keyboard keycode table, a few defines, and some of the keyboard and mouse data parsing bits from lirc_mod_mce though. Special thanks to James Meyer for providing the hardware, and being patient with me as I took forever to get around to writing this. callback routine to ensure we don't get any stuck keys, and used symbolic names for the keytable. Also cc'ing Florian this time, who I believe is the original mod-mce author... CC: Florian Demski <fdemski@users.sourceforge.net> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] rc: add tivo/nero liquidtv keymapJarod Wilson
2011-03-22[media] rc/keymaps: Rename Hauppauge table as rc-hauppaugeMauro Carvalho Chehab
There are two "hauppauge-new" keymaps, one with protocol unknown, and the other with the protocol marked accordingly. However, both tables are miss-named. Also, the old rc-hauppauge-new is broken, as it mixes three different controllers as if they were just one. This patch solves half of the problem by renaming the correct keycode table as just rc-hauppauge. This table contains the codes for the four different types of remote controllers found on Hauppauge cards, properly mapped with their different addresses. create mode 100644 drivers/media/rc/keymaps/rc-hauppauge.c delete mode 100644 drivers/media/rc/keymaps/rc-rc5-hauppauge-new.c [Jarod: fix up RC_MAP_HAUPPAUGE defines] Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Jarod Wilson <jarod@redhat.com>
