Once rfkill-input is disabled, the "global" states will only be used as
default initial states.
Since the states will always be the same after resume, we shouldn't
generate events on resume.
Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
rfkill_set_global_sw_state() (previously rfkill_set_default()) will no
longer be exported by the rewritten rfkill core.
Instead, platform drivers which can provide persistent soft-rfkill state
across power-down/reboot should indicate their initial state by calling
rfkill_set_sw_state() before registration. Otherwise, they will be
initialized to a default value during registration by a set_block call.
We remove existing calls to rfkill_set_sw_state() which happen before
registration, since these had no effect in the old model. If these
drivers do have persistent state, the calls can be put back (subject
to testing :-). This affects hp-wmi and acer-wmi.
Drivers with persistent state will affect the global state only if
rfkill-input is enabled. This is required, otherwise booting with
wireless soft-blocked and pressing the wireless-toggle key once would
have no apparent effect. This special case will be removed in future
along with rfkill-input, in favour of a more flexible userspace daemon
(see Documentation/feature-removal-schedule.txt).
Now rfkill_global_states[n].def is only used to preserve global states
over EPO, it is renamed to ".sav".
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
In order to handle powersave frames properly we had needed
to pass these out to the device queues again, and introduce
the skb->requeue bit. This, however, also has unnecessary
overhead by needing to 'clean up' already tried frames, and
this clean-up code is also buggy when software encryption
is used.
Instead of sending the frames via the master netdev queue
again, simply put them into the pending queue. This also
fixes a problem where frames for that particular station
could be reordered when some were still on the software
queues and older ones are re-injected into the software
queue after them.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
This removes the dependency on GPIO framework and lets the SPI host
driver handle the chip select. The SPI host driver is required to keep
the CS active for the entire message unless cs_change says otherwise.
This patch collects the two/three single SPI transfers into a message.
Also the delay in read path in case use_dummy_writes are not used is
moved into the SPI host driver.
Tested-by: Mike Rapoport <mike@compulab.co.il>
Tested-by: Andrey Yurovsky <andrey@cozybit.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Dan Williams <dcbw@redhat.com>
Since we use ERR_PTR and similar macros, we need to include
linux/err.h.
Ethtool is a standard way of getting information about
ethernet interfaces. We enhance ethtool kernel interface
& e1000e to make the MDI-X status readable via ethtool in
userspace.
Signed-off-by: Chaitanya Lala <clala@riverbed.com>
Signed-off-by: Arthur Jones <ajones@riverbed.com>
Add a netlink interface for configuration of IEEE 802.15.4 device. Also this
interface specifies events notification sent by devices towards higher layers.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
IEEE 802.15.4 stack requires several constants to be defined/adjusted.
With the hope that these can be used to eliminate direct
references to the frag list implementation.
Change the name of the Kernel CAPI exported function capi_ctr_reseted()
to something representing its purpose better.
Impact: renaming, no functional change
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
skb_dma_unmap() is quite expensive for small packets,
because we use two different cache lines from skb_shared_info.
One to access nr_frags, one to access dma_maps[0]
Instead of dma_maps being an array of MAX_SKB_FRAGS + 1 elements,
let dma_head alone in a new dma_head field, close to nr_frags,
to reduce cache lines misses.
Tested on my dev machine (bnx2 & tg3 adapters), nice speedup !
Get rid of num_dma_maps in struct skb_shared_info, as it seems unused.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
This patch removes the forcedeth device ids from pci_ids.h
The forcedeth driver uses the device id constants directly in its source
file.
[ Need to keep PCI_DEVICE_ID_NVIDIA_NVENET_15 in order to keep
drivers/pci/quirks.c building -DaveM ]
Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/vxy/lksctp-dev
As it stands skb fraglists can get past the check in dev_queue_xmit
if the skb is marked as GSO. In particular, if the packet doesn't
have the proper checksums for GSO, but can otherwise be handled by
the underlying device, we will not perform the fraglist check on it
at all.
If the underlying device cannot handle fraglists, then this will
break.
The fix is as simple as moving the fraglist check from the device
check into skb_gso_ok.
This has caused crashes with Xen when used together with GRO which
can generate GSO packets with fraglists.
Sometimes it is necessary to know how the state is,
and it is easier to query rfkill than keep track of
it somewhere else, so add a function for that. This
could later be expanded to return hard/soft block,
but so far that isn't necessary.
The new code added by this patch will make rfkill create
a misc character device /dev/rfkill that userspace can use
to control rfkill soft blocks and get status of devices as
well as events when the status changes.
Using it is very simple -- when you open it you can read
a number of times to get the initial state, and every
further read blocks (you can poll) on getting the next
event from the kernel. The same structure you read is
also used when writing to it to change the soft block of
a given device, all devices of a given type, or all
devices.
This also makes CONFIG_RFKILL_INPUT selectable again in
order to be able to test without it present since its
functionality can now be replaced by userspace entirely
and distros and users may not want the input part of
rfkill interfering with their userspace code. We will
also write a userspace daemon to handle all that and
consequently add the input code to the feature removal
schedule.
In order to have rfkilld support both kernels with and
without CONFIG_RFKILL_INPUT (or new kernels after its
eventual removal) we also add an ioctl (that only exists
if rfkill-input is present) to disable rfkill-input.
It is not very efficient, but at least gives the correct
behaviour in all cases.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
This patch completely rewrites the rfkill core to address
the following deficiencies:
* all rfkill drivers need to implement polling where necessary
rather than having one central implementation
* updating the rfkill state cannot be done from arbitrary
contexts, forcing drivers to use schedule_work and requiring
lots of code
* rfkill drivers need to keep track of soft/hard blocked
internally -- the core should do this
* the rfkill API has many unexpected quirks, for example being
asymmetric wrt. alloc/free and register/unregister
* rfkill can call back into a driver from within a function the
driver called -- this is prone to deadlocks and generally
should be avoided
* rfkill-input pointlessly is a separate module
* drivers need to #ifdef rfkill functions (unless they want to
depend on or select RFKILL) -- rfkill should provide inlines
that do nothing if it isn't compiled in
* the rfkill structure is not opaque -- drivers need to initialise
it correctly (lots of sanity checking code required) -- instead
force drivers to pass the right variables to rfkill_alloc()
* the documentation is hard to read because it always assumes the
reader is completely clueless and contains way TOO MANY CAPS
* the rfkill code needlessly uses a lot of locks and atomic
operations in locked sections
* fix LED trigger to actually change the LED when the radio state
changes -- this wasn't done before
Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> [thinkpad]
NETDEV_UP is called after the device is set UP, but sometimes
it is useful to be able to veto the device UP. Introduce a
new NETDEV_PRE_UP notifier that can be used for exactly this.
The first use case will be cfg80211 denying interfaces to be
set UP if the device is known to be rfkill'ed.
Instead of hardcoding the key length for validation, use the
constants Zhu Yi recently added and add one for AES_CMAC too.
RFC5061 had changed the error cause codes for Dynamic Address
Reconfiguration As the following:
Cause Code
Value Cause Code
0x00A0 Request to Delete Last Remaining IP Address
0x00A1 Operation Refused Due to Resource Shortage
0x00A2 Request to Delete Source IP Address
0x00A3 Association Aborted Due to Illegal ASCONF-ACK
0x00A4 Request Refused - No Authorization
This patch fix the error cause codes.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Can remove anonymous union now it has one field.
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
Define skb_rtable(const struct sk_buff *skb) accessor to get rtable from skb
Delete skb->rtable field
Setting rtable is not allowed, just set dst instead as rtable is an alias.
struct sk_buff uses one union to define dst and rtable fields.
We want to replace direct access to these pointers by accessors.
First patch adds a new "unsigned long _skb_dst;" opaque field
in this union.
drivers/net/forcedeth.c
After some discussion offline with Christoph Lameter and David Stevens
regarding multicast behaviour in Linux, I'm submitting a slightly
modified patch from the one Christoph submitted earlier.
This patch provides a new socket option IP_MULTICAST_ALL.
In this case, default behaviour is _unchanged_ from the current
Linux standard. The socket option is set by default to provide
original behaviour. Sockets wishing to receive data only from
multicast groups they join explicitly will need to clear this
socket option.
Signed-off-by: Nivedita Singhvi <niv@us.ibm.com>
Signed-off-by: Christoph Lameter<cl@linux.com>
Acked-by: David Stevens <dlstevens@us.ibm.com>
Add 'autoconf' and 'disable_ipv6' parameters to the IPv6 module.
The first controls if IPv6 addresses are autoconfigured from
prefixes received in Router Advertisements. The IPv6 loopback
(::1) and link-local addresses are still configured.
The second controls if IPv6 addresses are desired at all. No
IPv6 addresses will be added to any interfaces.
Signed-off-by: Brian Haley <brian.haley@hp.com>
This patch adds a generic driver for SJA1000 chips on the OpenFirmware
platform bus found on embedded PowerPC systems. You need a SJA1000 node
definition in your flattened device tree source (DTS) file similar to:
can@3,100 {
compatible = "nxp,sja1000";
reg = <3 0x100 0x80>;
interrupts = <2 0>;
interrupt-parent = <&mpic>;
nxp,external-clock-frequency = <16000000>;
See also Documentation/powerpc/dts-bindings/can/sja1000.txt.
CC: devicetree-discuss@ozlabs.org
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
This patch converts unicast address list to standard list_head using
previously introduced struct netdev_hw_addr. It also relaxes the
locking. Original spinlock (still used for multicast addresses) is not
needed and is no longer used for a protection of this list. All
reading and writing takes place under rtnl (with no changes).
I also removed a possibility to specify the length of the address
while adding or deleting unicast address. It's always dev->addr_len.
The convertion touched especially e1000 and ixgbe codes when the
change is not so trivial.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
drivers/net/bnx2.c | 13 +--
drivers/net/e1000/e1000_main.c | 24 +++--
drivers/net/ixgbe/ixgbe_common.c | 14 ++--
drivers/net/ixgbe/ixgbe_common.h | 4 +-
drivers/net/ixgbe/ixgbe_main.c | 6 +-
drivers/net/ixgbe/ixgbe_type.h | 4 +-
drivers/net/macvlan.c | 11 +-
drivers/net/mv643xx_eth.c | 11 +-
drivers/net/niu.c | 7 +-
drivers/net/virtio_net.c | 7 +-
drivers/s390/net/qeth_l2_main.c | 6 +-
drivers/scsi/fcoe/fcoe.c | 16 ++--
include/linux/netdevice.h | 18 ++--
net/8021q/vlan.c | 4 +-
net/8021q/vlan_dev.c | 10 +-
net/core/dev.c | 195 +++++++++++++++++++++++++++-----------
net/dsa/slave.c | 10 +-
net/packet/af_packet.c | 4 +-
18 files changed, 227 insertions(+), 137 deletions(-)
[PATCH net-next] bonding: allow bond in mode balance-alb to work properly in bridge -try4.3
(updated)
changes v4.2 -> v4.3
- memcpy the address always, not just in case it differs from master->dev_addr
- compare_ether_addr_64bits() is not used so there is no direct need to make new
header file (I think it would be good to have bond stuff in separate file
anyway).
changes v4.1 -> v4.2
- use skb->pkt_type == PACKET_HOST compare rather then comparing skb dest addr
against skb->dev->dev_addr
The problem is described in following bugzilla:
https://bugzilla.redhat.com/show_bug.cgi?id=487763
Basically here's what's going on. In every mode, bonding interface uses the same
mac address for all enslaved devices (except fail_over_mac). Only balance-alb
will simultaneously use multiple MAC addresses across different slaves. When you
put this kind of bond device into a bridge it will only add one of mac adresses
into a hash list of mac addresses, say X. This mac address is marked as local.
But this bonding interface also has mac address Y. Now then packet arrives with
destination address Y, this address is not marked as local and the packed looks
like it needs to be forwarded. This packet is then lost which is wrong.
Notice that interfaces can be added and removed from bond while it is in bridge.
When the multiple addresses for bridge port approach failed to solve this issue
due to STP I started to think other way to solve this. I returned to previous
solution but tweaked one.
This patch solves the situation in the bonding without touching bridge code.
For every incoming frame to bonding the destination address is compared to
current address of the slave device from which tha packet came. If these two
match destination address is replaced by mac address of the master. This address
is known by bridge so it is delivered properly. Note that the comparsion is not
made directly, it's used skb->pkt_type == PACKET_HOST instead. This is "set"
previously in eth_type_trans().
I experimentally tried that this works as good as searching through the slave
list (v4 of this patch).
Jirka
Signed-off-by: Andy Gospodarek <andy@greyhouse.net>
git://git.kernel.org/pub/scm/linux/kernel/git/inaky/wimax
As the 'state_get' API call was added, we need to increase the minor
protocol version number so applications that depend on the can check
it's presence.
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
wimax connection manager / daemon has to know what is current
state of the device. Previously it was only possible to get
notification whet state has changed.
Note:
By mistake, the new generic netlink's number for
WIMAX_GNL_OP_STATE_GET was declared inserting into the existing list
of API calls, not appending; thus, it'd break existing API.
Fixed by Inaky Perez-Gonzalez <inaky@linux.intel.com> by moving to
the tail, where we add to the interface, not modify the interface.
Thanks to Stephen Hemminger <shemminger@vyatta.com> for catching this.
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
Use ALIGN() and PTR_ALIGN() macros instead of handcoding them.
Get rid of NETDEV_ALIGN_CONST ugly define
For the overwhelming majority of cases, skb_gro_header's return
value cannot be NULL. Yet we must check it because of its current
form. This patch splits it up into multiple functions in order
to avoid this.
By caching frag0_len, we can avoid checking both frag0 and the
length separately in skb_gro_header. This helps as skb_gro_header
is called four times per packet which amounts to a few million
times at 10Gb/s.
Currently skb_gro_header is used for packets which put the hardware
header in skb->data with the rest in frags. Since the drivers that
need this optimisation all provide completely non-linear packets,
we can gain extra optimisations by only performing the frag0
optimisation for completely non-linear packets.
In particular, we can simply test frag0 (instead of skb_headlen)
to see whether the optimisation is in force.
The function skb_gro_header is called four times per packet which
quickly adds up at 10Gb/s. This patch inlines it to allow better
optimisations.
Some architectures perform multiplication for page_address, which
is done by each skb_gro_header invocation. This patch caches that
value in skb->cb to avoid the unnecessary multiplications.
Just use the constant 20 to keep things working.
If someone is so motivated, this can be converted over to
dynamic strings. I tried and it's a lot of work.
But for now this is good enough.
We would like to get rid of netdev->trans_start = jiffies; that about all net
drivers have to use in their start_xmit() function, and use txq->trans_start
instead.
This can be done generically in core network, as suggested by David.
Some devices, (particularly loopback) dont need trans_start update, because
they dont have transmit watchdog. We could add a new device flag, or rely
on fact that txq->tran_start can be updated is txq->xmit_lock_owner is
different than -1. Use a helper function to hide our choice.
Robert L Mathews discovered that some clients send evil TCP RST segments,
which are accepted by netfilter conntrack but discarded by the
destination. Thus the conntrack entry is destroyed but the destination
retransmits data until timeout.
The same technique, i.e. sending properly crafted RST segments, can easily
be used to bypass connlimit/connbytes based restrictions (the sample
script written by Robert can be found in the netfilter mailing list
archives).
The patch below adds a new flag and new field to struct ip_ct_tcp_state so
that checking RST segments can be made more strict and thus TCP conntrack
can catch the invalid ones: the RST segment is accepted only if its
sequence number higher than or equal to the highest ack we seen from the
other direction. (The last_ack field cannot be reused because it is used
to catch resent packets.)
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
All drivers are already converted to new net_device_ops API
and nobody uses old API anymore.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
The new ID is validated by Cologne Chip.
LEDs control is also supported.
Signed-off-by: Andreas Eversberg <andreas@eversberg.eu>
Signed-off-by: Karsten Keil <keil@b1-systems.de>
This patch make debug printk's KERN_DEBUG and also fix some
codestyle issues.
new id for HFC-8S
