path: root/include/linux
2011-03-10drbd: Rename enum drbd_state_ret_codes to enum drbd_state_rvAndreas Gruenbacher
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-03-10drbd: Rename enum drbd_ret_codes to enum drbd_ret_codeAndreas Gruenbacher
2011-03-10drbd: --force option for disconnectPhilipp Reisner
As the network connection can be lost at any time, a --force option for disconnect is just a matter of completeness. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-03-10drbd: add packet_type 27 (return_code_only) to netlink apiLars Ellenberg
In case we ever should add an other packet type, we must not reuse 27, as that currently used for "empty" return code only replies. Document it as such. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-03-10drbd: New packet for Ahead/Behind mode: P_OUT_OF_SYNCPhilipp Reisner
2011-03-10drbd: Implemented two new connection states Ahead/BehindPhilipp Reisner
In this connection mode, the ahead node no longer replicates application IO. The behind's disk becomes out dated. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-03-10drbd: New configuration parameters for dealing with network congestionPhilipp Reisner
net { on_congestion {block|pull-ahead|disconnect}; congestion-fill {sectors}; congestion-extents {al-extents}; } Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: initial patch for on-stack per-task pluggingJens Axboe
This patch adds support for creating a queuing context outside of the queue itself. This enables us to batch up pieces of IO before grabbing the block device queue lock and submitting them to the IO scheduler. The context is created on the stack of the process and assigned in the task structure, so that we can auto-unplug it if we hit a schedule event. The current queue plugging happens implicitly if IO is submitted to an empty device, yet callers have to remember to unplug that IO when they are going to wait for it. This is an ugly API and has caused bugs in the past. Additionally, it requires hacks in the vm (->sync_page() callback) to handle that logic. By switching to an explicit plugging scheme we make the API a lot nicer and can get rid of the ->sync_page() hack in the vm. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: add API for delaying work/request_fn a little bitJens Axboe
Currently we use plugging for that, but as plugging is going away, we need an alternative mechanism. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-08block: biovec_slab vs. CONFIG_BLK_DEV_INTEGRITYMartin K. Petersen
The block integrity subsystem no longer uses the bio_vec slabs so this code can safely be compiled in. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-04Merge branch 'for-linus' of ../linux-2.6-block into block-for-2.6.39/coreTejun Heo
This merge creates two set of conflicts. One is simple context conflicts caused by removal of throtl_scheduled_delayed_work() in for-linus and removal of throtl_shutdown_timer_wq() in for-2.6.39/core. The other is caused by commit 255bb490c8 (block: blk-flush shouldn't call directly into q->request_fn() __blk_run_queue()) in for-linus crashing with FLUSH reimplementation in for-2.6.39/core. The conflict isn't trivial but the resolution is straight-forward. * __blk_run_queue() calls in flush_end_io() and flush_data_end_io() should be called with @force_kblockd set to %true. * elv_insert() in blk_kick_flush() should use %ELEVATOR_INSERT_REQUEUE. Both changes are to avoid invoking ->request_fn() directly from request completion path and closely match the changes in the commit 255bb490c8. Signed-off-by: Tejun Heo <tj@kernel.org>
2011-03-03blktrace: Remove blk_fill_rwbs_rq.Tao Ma
If we enable trace events to trace block actions, We use blk_fill_rwbs_rq to analyze the corresponding actions in request's cmd_flags, but we only choose the minor 2 bits from it, so most of other flags(e.g, REQ_SYNC) are missing. For example, with a sync write we get: write_test-2409 [001] 160.013869: block_rq_insert: 3,64 W 0 () 258135 + = 8 [write_test] Since now we have integrated the flags of both bio and request, it is safe to pass rq->cmd_flags directly to blk_fill_rwbs and blk_fill_rwbs_rq isn't needed any more. With this patch, after a sync write we get: write_test-2417 [000] 226.603878: block_rq_insert: 3,64 WS 0 () 258135 += 8 [write_test] Signed-off-by: Tao Ma <boyu.mt@taobao.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-02block: Move blk_throtl_exit() call to blk_cleanup_queue()Vivek Goyal
Move blk_throtl_exit() in blk_cleanup_queue() as blk_throtl_exit() is written in such a way that it needs queue lock. In blk_release_queue() there is no gurantee that ->queue_lock is still around. Initially blk_throtl_exit() was in blk_cleanup_queue() but Ingo reported one problem. https://lkml.org/lkml/2010/10/23/86 And a quick fix moved blk_throtl_exit() to blk_release_queue(). commit 7ad58c028652753814054f4e3ac58f925e7343f4 Author: Jens Axboe <jaxboe@fusionio.com> Date: Sat Oct 23 20:40:26 2010 +0200 block: fix use-after-free bug in blk throttle code This patch reverts above change and does not try to shutdown the throtl work in blk_sync_queue(). By avoiding call to throtl_shutdown_timer_wq() from blk_sync_queue(), we should also avoid the problem reported by Ingo. blk_sync_queue() seems to be used only by md driver and it seems to be using it to make sure q->unplug_fn is not called as md registers its own unplug functions and it is about to free up the data structures used by unplug_fn(). Block throttle does not call back into unplug_fn() or into md. So there is no need to cancel blk throttle work. In fact I think cancelling block throttle work is bad because it might happen that some bios are throttled and scheduled to be dispatched later with the help of pending work and if work is cancelled, these bios might never be dispatched. Block layer also uses blk_sync_queue() during blk_cleanup_queue() and blk_release_queue() time. That should be safe as we are also calling blk_throtl_exit() which should make sure all the throttling related data structures are cleaned up. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-02block: add @force_kblockd to __blk_run_queue()Tejun Heo
__blk_run_queue() automatically either calls q->request_fn() directly or schedules kblockd depending on whether the function is recursed. blk-flush implementation needs to be able to explicitly choose kblockd. Add @force_kblockd. All the current users are converted to specify %false for the parameter and this patch doesn't introduce any behavior change. stable: This is prerequisite for fixing ide oops caused by the new blk-flush implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-01Merge commit 'v2.6.38-rc6' into for-2.6.39/coreJens Axboe
Conflicts: block/cfq-iosched.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-01blk-throttle: Do not use kblockd workqueue for throtl workVivek Goyal
o Dominik Klein reported a system hang issue while doing some blkio throttling testing. https://lkml.org/lkml/2011/2/24/173 o Some tracing revealed that CFQ was not dispatching any more jobs as queue unplug was not happening. And queue unplug was not happening because unplug work was not being called as there was one throttling work on same cpu which as not finished yet. And throttling work had not finished as it was tyring to dispatch a bio to CFQ but all the request descriptors were consume to it was put to sleep. o So basically it is a cyclic dependecny between CFQ unplug work and throtl dispatch work. Tejun suggested that use separate workqueue for such cases. o This patch uses a separate workqueue for throttle related work and does not rely on kblockd workqueue anymore. Cc: stable@kernel.org Reported-by: Dominik Klein <dk@in-telegence.net> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-28ACPI: Fix build for CONFIG_NET unsetRafael J. Wysocki
Several ACPI drivers fail to build if CONFIG_NET is unset, because they refer to things depending on CONFIG_THERMAL that in turn depends on CONFIG_NET. However, CONFIG_THERMAL doesn't really need to depend on CONFIG_NET, because the only part of it requiring CONFIG_NET is the netlink interface in thermal_sys.c. Put the netlink interface in thermal_sys.c under #ifdef CONFIG_NET and remove the dependency of CONFIG_THERMAL on CONFIG_NET from drivers/thermal/Kconfig. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Len Brown <lenb@kernel.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Luming Yu <luming.yu@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: Make ACPI wakeup from S5 work again when CONFIG_PM_SLEEP is unset
2011-02-25rapidio: fix sysfs config attribute to access 16MB of maint spaceAlexandre Bounine
Fixes sysfs config attribute to allow access to entire 16MB maintenance space of RapidIO devices. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: Fix - again - partition detection when array becomes active Fix over-zealous flush_disk when changing device size. md: avoid spinlock problem in blk_throtl_exit md: correctly handle probe of an 'mdp' device. md: don't set_capacity before array is active. md: Fix raid1->raid0 takeover
2011-02-24PM: Make ACPI wakeup from S5 work again when CONFIG_PM_SLEEP is unsetRafael J. Wysocki
Commit 074037e (PM / Wakeup: Introduce wakeup source objects and event statistics (v3)) caused ACPI wakeup to only work if CONFIG_PM_SLEEP is set, but it also worked for CONFIG_PM_SLEEP unset before. This can be fixed by making device_set_wakeup_enable(), device_init_wakeup() and device_may_wakeup() work in the same way as before commit 074037e when CONFIG_PM_SLEEP is unset. Reported-and-tested-by: Justin Maggard <jmaggard10@gmail.com> Cc: stable@kernel.org Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-24Fix over-zealous flush_disk when changing device size.NeilBrown
There are two cases when we call flush_disk. In one, the device has disappeared (check_disk_change) so any data will hold becomes irrelevant. In the oter, the device has changed size (check_disk_size_change) so data we hold may be irrelevant. In both cases it makes sense to discard any 'clean' buffers, so they will be read back from the device if needed. In the former case it makes sense to discard 'dirty' buffers as there will never be anywhere safe to write the data. In the second case it *does*not* make sense to discard dirty buffers as that will lead to file system corruption when you simply enlarge the containing devices. flush_disk calls __invalidate_devices. __invalidate_device calls both invalidate_inodes and invalidate_bdev. invalidate_inodes *does* discard I_DIRTY inodes and this does lead to fs corruption. invalidate_bev *does*not* discard dirty pages, but I don't really care about that at present. So this patch adds a flag to __invalidate_device (calling it __invalidate_device2) to indicate whether dirty buffers should be killed, and this is passed to invalidate_inodes which can choose to skip dirty inodes. flusk_disk then passes true from check_disk_change and false from check_disk_size_change. dm avoids tripping over this problem by calling i_size_write directly rathher than using check_disk_size_change. md does use check_disk_size_change and so is affected. This regression was introduced by commit 608aeef17a which causes check_disk_size_change to call flush_disk, so it is suitable for any kernel since 2.6.27. Cc: stable@kernel.org Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Andrew Patterson <andrew.patterson@hp.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: NeilBrown <neilb@suse.de>
2011-02-23mm: prevent concurrent unmap_mapping_range() on the same inodeMiklos Szeredi
Michael Leun reported that running parallel opens on a fuse filesystem can trigger a "kernel BUG at mm/truncate.c:475" Gurudas Pai reported the same bug on NFS. The reason is, unmap_mapping_range() is not prepared for more than one concurrent invocation per inode. For example: thread1: going through a big range, stops in the middle of a vma and stores the restart address in vm_truncate_count. thread2: comes in with a small (e.g. single page) unmap request on the same vma, somewhere before restart_address, finds that the vma was already unmapped up to the restart address and happily returns without doing anything. Another scenario would be two big unmap requests, both having to restart the unmapping and each one setting vm_truncate_count to its own value. This could go on forever without any of them being able to finish. Truncate and hole punching already serialize with i_mutex. Other callers of unmap_mapping_range() do not, and it's difficult to get i_mutex protection for all callers. In particular ->d_revalidate(), which calls invalidate_inode_pages2_range() in fuse, may be called with or without i_mutex. This patch adds a new mutex to 'struct address_space' to prevent running multiple concurrent unmap_mapping_range() on the same mapping. [ We'll hopefully get rid of all this with the upcoming mm preemptibility series by Peter Zijlstra, the "mm: Remove i_mmap_mutex lockbreak" patch in particular. But that is for 2.6.39 ] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reported-by: Michael Leun <lkml20101129@newton.leun.net> Reported-by: Gurudas Pai <gurudas.pai@oracle.com> Tested-by: Gurudas Pai <gurudas.pai@oracle.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits) Added support for usb ethernet (0x0fe6, 0x9700) r8169: fix RTL8168DP power off issue. r8169: correct settings of rtl8102e. r8169: fix incorrect args to oob notify. DM9000B: Fix PHY power for network down/up DM9000B: Fix reg_save after spin_lock in dm9000_timeout net_sched: long word align struct qdisc_skb_cb data sfc: lower stack usage in efx_ethtool_self_test bridge: Use IPv6 link-local address for multicast listener queries bridge: Fix MLD queries' ethernet source address bridge: Allow mcast snooping for transient link local addresses too ipv6: Add IPv6 multicast address flag defines bridge: Add missing ntohs()s for MLDv2 report parsing bridge: Fix IPv6 multicast snooping by correcting offset in MLDv2 report bridge: Fix IPv6 multicast snooping by storing correct protocol type p54pci: update receive dma buffers before and after processing fix cfg80211_wext_siwfreq lock ordering... rt2x00: Fix WPA TKIP Michael MIC failures. ath5k: Fix fast channel switching tcp: undo_retrans counter fixes ...
2011-02-21module: explicitly align module_version_attribute structureDmitry Torokhov
We force particular alignment when we generate attribute structures when generation MODULE_VERSION() data and we need to make sure that this alignment is followed when we iterate over these structures, otherwise we may crash on platforms whose natural alignment is not sizeof(void *), such as m68k. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Dmitry Torokhov <dtor@vmware.com> [ There are more issues here, but the fixes are incredibly ugly - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-19net: dcb: match dcb_app protocol field with 802.1Qaz specJohn Fastabend
The dcb_app protocol field is a __u32 however the 802.1Qaz specification defines it as a 16 bit field. This patch brings the structure inline with the spec making it a __u16. CC: Shmulik Ravid <shmulikr@broadcom.com> Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-18Merge branch 'rtc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'rtc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: RTC: Re-enable UIE timer/polling emulation RTC: Revert UIE emulation removal RTC: Release mutex in error path of rtc_alarm_irq_enable
2011-02-18Merge branch 'fixes-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq * 'fixes-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: make sure MAYDAY_INITIAL_TIMEOUT is at least 2 jiffies long workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable' workqueue: wake up a worker when a rescuer is leaving a gcwq
2011-02-18Expand CONFIG_DEBUG_LIST to several other list operationsLinus Torvalds
When list debugging is enabled, we aim to readably show list corruption errors, and the basic list_add/list_del operations end up having extra debugging code in them to do some basic validation of the list entries. However, "list_del_init()" and "list_move[_tail]()" ended up avoiding the debug code due to how they were written. This fixes that. So the _next_ time we have list_move() problems with stale list entries, we'll hopefully have an easier time finding them.. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-17RTC: Re-enable UIE timer/polling emulationJohn Stultz
This patch re-enables UIE timer/polling emulation for rtc devices that do not support alarm irqs. CC: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> CC: Thomas Gleixner <tglx@linutronix.de> Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-17RTC: Revert UIE emulation removalJohn Stultz
Uwe pointed out that my alarm based UIE emulation is not sufficient to replace the older timer/polling based UIE emulation on devices where there is no alarm irq. This causes rtc devices without alarms to return -EINVAL to UIE ioctls. The fix is to re-instate the old timer/polling method for devices without alarm irqs. This patch reverts the following commits: 042620a018afcfba1d678062b62e46 - Remove UIE emulation 1daeddd5962acad1bea55e524fc0fa - Cleanup removed UIE emulation declaration b5cc8ca1c9c3a37eaddf709b2fd3e1 - Remove Kconfig symbol for UIE emulation The emulation mode will still need to be wired-in with a following patch before it will work. CC: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> CC: Thomas Gleixner <tglx@linutronix.de> Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-16workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable'Tejun Heo
There are two spellings in use for 'freeze' + 'able' - 'freezable' and 'freezeable'. The former is the more prominent one. The latter is mostly used by workqueue and in a few other odd places. Unify the spelling to 'freezable'. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alex Dubov <oakad@yahoo.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Steven Whitehouse <swhiteho@redhat.com>
2011-02-15thp: prevent hugepages during args/env copying into the user stackAndrea Arcangeli
Transparent hugepages can only be created if rmap is fully functional. So we must prevent hugepages to be created while is_vma_temporary_stack() is true. This also optmizes away some harmless but unnecessary setting of khugepaged_scan.address and it switches some BUG_ON to VM_BUG_ON. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-15Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix text_poke_smp_batch() deadlock perf tools: Fix thread_map event synthesizing in top and record watchdog, nmi: Lower the severity of error messages ARM: oprofile: Fix backtraces in timer mode oprofile: Fix usage of CONFIG_HW_PERF_EVENTS for oprofile_perf_init and friends
2011-02-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: matrix_keypad - increase the limit of rows and columns Input: wacom - fix error path in wacom_probe() Input: ads7846 - check proper condition when freeing gpio Revert "Input: do not pass injected events back to the originating handler" Input: sysrq - rework re-inject logic Input: serio - clear pending rescans after sysfs driver rebind Input: rotary_encoder - use proper irqflags Input: wacom_w8001 - report resolution to userland
2011-02-15Merge branch 'urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/urgent
2011-02-13klist: Fix object alignment on 64-bit.David Miller
Commit c0e69a5bbc6f ("klist.c: bit 0 in pointer can't be used as flag") intended to make sure that all klist objects were at least pointer size aligned, but used the constant "4" which only works on 32-bit. Use "sizeof(void *)" which is correct in all cases. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: stable <stable@kernel.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-11block: share request flush fields with elevator_privateMike Snitzer
Flush requests are never put on the IO scheduler. Convert request structure's elevator_private* into an array and have the flush fields share a union with it. Reclaim the space lost in 'struct request' by moving 'completion_data' back in the union with 'rb_node'. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-11Input: matrix_keypad - increase the limit of rows and columnsTrilok Soni
Some keyboard controllers support more than 16 columns and rows. Increase the limit to 32. Signed-off-by: Trilok Soni <tsoni@codeaurora.org> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-02-11security: add cred argument to security_capable()Chris Wright
Expand security_capable() to include cred, so that it can be usable in a wider range of call sites. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-02-10Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (21 commits) USB: cdc-acm: Adding second ACM channel support for Nokia N8 USB, Mass Storage, composite, gadget: Fix build failure and memset of a struct USB: Fix trout build failure with ci13xxx_msm gadget USB: EHCI: fix scheduling while atomic during suspend USB: usb-storage: unusual_devs entry for Coby MP3 player USB: ftdi_sio: Add VID=0x0647, PID=0x0100 for Acton Research spectrograph USB: fix race between root-hub resume and wakeup requests USB: prevent buggy hubs from crashing the USB stack usb: r8a66597-udc: Fixed bufnum of Bulk USB: ftdi_sio: add ST Micro Connect Lite uart support USB: Storage: Add unusual_devs entry for VTech Kidizoom USB SL811HS HCD: Fix memory leak in sl811h_urb_enqueue() USB: ti_usb: fix module removal USB: io_edgeport: fix the reported firmware major and minor usb: ehci-omap: Show fatal probing time errors to end user usb: musb: introduce api for dma code to check compatibility with usb request usb: musb: maintain three states for buffer mappings instead of two usb: musb: disable double buffering when it's broken usb: musb: hsdma: change back to use musb_read/writew usb: musb: core: fix IRQ check ...
2011-02-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) virtio_net: Add schedule check to napi_enable call x25: Do not reference freed memory. pch_can: fix tseg1/tseg2 setting issue isdn: hysdn: Kill (partially buggy) CVS regision log reporting. can: softing_cs needs slab.h pch_gbe: Fix the issue which a driver locks when rx offload is set by ethtool netfilter: nf_conntrack: set conntrack templates again if we return NF_REPEAT pch_can: fix module reload issue with MSI pch_can: fix rmmod issue pch_can: fix 800k comms issue net: Fix lockdep regression caused by initializing netdev queues too early. net/caif: Fix dangling list pointer in freed object on error. USB CDC NCM errata updates for cdc_ncm host driver CDC NCM errata updates for cdc.h ixgbe: update version string ixgbe: cleanup variable initialization ixgbe: limit VF access to network traffic ixgbe: fix for 82599 erratum on Header Splitting ixgbe: fix variable set but not used warnings by gcc 4.6 e1000: add support for Marvell Alaska M88E1118R PHY ...
2011-02-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: virtio: console: Update Copyright virtio: console: Wake up outvq on host notifications
2011-02-08CDC NCM errata updates for cdc.hAlexey Orishko
Changes are based on the following documents: - CDC NCM errata: http://www.usb.org/developers/devclass_docs/NCM10_012011.zip - CDC and WMC errata link: http://www.usb.org/developers/devclass_docs/CDC1.2_WMC1.1_012011.zip Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-09virtio: console: Update CopyrightAmit Shah
Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-02-06Merge branch 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: m32r: Fixup last __do_IRQ leftover genirq: Add missing status flags to modification mask
2011-02-06Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf stat: Fix aggreate counter reading accounting tracing: Replace syscall_meta_data struct array with pointer array tracepoints: Fix section alignment using pointer array tracing: Replace trace_event struct array with pointer array
