This patch adds a set of MMCIF functions for the romImage
boot loader that allows the kernel to be booted directly
from an MMC card.
Thanks to Jeremy Baker for the initial prototype.
Signed-off-by: Magnus Damm <damm@opensource.se>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Update the MMCIF driver to include register information
and register access functions in the header file.
The MMCIF boot code builds on top of this.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'slub/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
SLUB: Allow full duplication of kmalloc array for 390
slub: move kmem_cache_node into it's own cacheline
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
mm: export generic_pipe_buf_*() to modules
fuse: support splice() reading from fuse device
fuse: allow splice to move pages
mm: export remove_from_page_cache() to modules
mm: export lru_cache_add_*() to modules
fuse: support splice() writing to fuse device
fuse: get page reference for readpages
fuse: use get_user_pages_fast()
fuse: remove unneeded variable
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (47 commits)
mfd: Rename twl5031 sih modules
mfd: Storage class for timberdale should be before const qualifier
mfd: Remove unneeded and dangerous clearing of clientdata
mfd: New AB8500 driver
gpio: Fix inverted rdc321x gpio data out registers
mfd: Change rdc321x resources flags to IORESOURCE_IO
mfd: Move pcf50633 irq related functions to its own file.
mfd: Use threaded irq for pcf50633
mfd: pcf50633-adc: Fix potential race in pcf50633_adc_sync_read
mfd: Fix pcf50633 bitfield logic in interrupt handler
gpio: rdc321x needs to select MFD_CORE
mfd: Use menuconfig for quicker config editing
ARM: AB3550 board configuration and irq for U300
mfd: AB3550 core driver
mfd: AB3100 register access change to abx500 API
mfd: Renamed ab3100.h to abx500.h
gpio: Add TC35892 GPIO driver
mfd: Add Toshiba's TC35892 MFD core
mfd: Delay to mask tsc irq in max8925
mfd: Remove incorrect wm8350 kfree
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
DMAENGINE: DMA40 U8500 platform configuration
DMA: PL330: Add dma api driver
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
quota: Convert quota statistics to generic percpu_counter
ext3 uses rb_node = NULL; to zero rb_root.
quota: Fixup dquot_transfer
reiserfs: Fix resuming of quotas on remount read-write
pohmelfs: Remove dead quota code
ufs: Remove dead quota code
udf: Remove dead quota code
quota: rename default quotactl methods to dquot_
quota: explicitly set ->dq_op and ->s_qcop
quota: drop remount argument to ->quota_on and ->quota_off
quota: move unmount handling into the filesystem
quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers
quota: move remount handling into the filesystem
ocfs2: Fix use after free on remount read-only
Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
Fix a bunch of new rapidio kernel-doc warnings:
Warning(include/linux/rio.h:123): No description found for parameter 'comp_tag'
Warning(include/linux/rio.h:123): No description found for parameter 'phys_efptr'
Warning(include/linux/rio.h:123): No description found for parameter 'em_efptr'
Warning(include/linux/rio.h:123): No description found for parameter 'pwcback'
Warning(include/linux/rio.h:247): No description found for parameter 'set_domain'
Warning(include/linux/rio.h:247): No description found for parameter 'get_domain'
Warning(drivers/rapidio/rio-scan.c:1133): No description found for parameter 'rdev'
Warning(drivers/rapidio/rio-scan.c:1133): Excess function parameter 'port' description in 'rio_init_em'
Warning(drivers/rapidio/rio.c:349): No description found for parameter 'rdev'
Warning(drivers/rapidio/rio.c:349): Excess function parameter 'mport' description in 'rio_request_inb_pwrite'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'port'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'local'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'destid'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'hopcount'
Warning(drivers/rapidio/rio.c:393): Excess function parameter 'rdev' description in 'rio_mport_get_physefb'
Warning(drivers/rapidio/rio.c:845): Excess function parameter 'local' description in 'rio_std_route_clr_table'
Cc: Alexandre Bounine <alexandre.bounine@idt.com>
This reverts commit 0ac0c0d0f837c499afd02a802f9cf52d3027fa3b, which
caused cross-architecture build problems for all the wrong reasons.
IA64 already added its own version of __node_random(), but the fact is,
there is nothing architectural about the function, and the original
commit was just badly done. Revert it, since no fix is forthcoming.
Requested-by: Stephen Rothwell <sfr@canb.auug.org.au>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: clean up on forwarded aborted mds request
ceph: fix leak of osd authorizer
ceph: close out mds, osd connections before stopping auth
ceph: make lease code DN specific
fs/ceph: Use ERR_CAST
ceph: renew auth tickets before they expire
ceph: do not resend mon requests on auth ticket renewal
ceph: removed duplicated #includes
ceph: avoid possible null dereference
ceph: make mds requests killable, not interruptible
sched: add wait_for_completion_killable_timeout
Commit 756dee75872a2a764b478e18076360b8a4ec9045 ("SLUB: Get rid of dynamic DMA
kmalloc cache allocation") makes S390 run out of kmalloc caches. Increase the
number of kmalloc caches to a safe size.
Cc: <stable@kernel.org> [ .33 and .34 ]
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Tested-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits)
ALSA: snd-usb-caiaq: Bump version number to 1.3.21
ALSA: Revert "ALSA: snd-usb-caiaq: Set default input mode of A4DJ"
ALSA: snd-usb-caiaq: Simplify single case to an 'if'
ALSA: snd-usb-caiaq: Restore 'Control vinyl' input mode on A4DJ
ALSA: hda: Use LPIB for a Shuttle device
ALSA: hda: Add support for another Lenovo ThinkPad Edge in conexant codec
ALSA: hda: Use LPIB for Sony VPCS11V9E
ALSA: usb-audio: fix feature unit parser for UAC2
ALSA: asihpi - Minor code cleanup
ALSA: asihpi - Add support for new ASI8800 family
ALSA: asihpi - Fix bug preventing outstream_write preload from happening
ALSA: asihpi - Fix imbalanced lock path in hw_message
ALSA: asihpi - Remove support for old ASI8800 family
ALSA: asihpi - Add hd radio blend functions
ALSA: asihpi - Remove unused io map functions
ALSA: usb-audio: add support for UAC2 pitch control
ALSA: usb-audio: parse UAC2 endpoint descriptors correctly
ALSA: usb-audio: fix return values
ALSA: usb-audio: parse more format descriptors with structs
sound: Add missing spin_unlock
Add missing _killable_timeout variant for wait_for_completion that will
return when a timeout expires or the task is killed.
CC: Ingo Molnar <mingo@elte.hu>
CC: Andreas Herrmann <andreas.herrmann3@amd.com>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Mike Galbraith <efault@gmx.de>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Signed-off-by: Sage Weil <sage@newdream.net>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
intel_idle: native hardware cpuidle driver for latest Intel processors
ACPI: acpi_idle: touch TS_POLLING only in the non-MWAIT case
acpi_pad: uses MONITOR/MWAIT, so it doesn't need to clear TS_POLLING
sched: clarify commment for TS_POLLING
ACPI: allow a native cpuidle driver to displace ACPI
cpuidle: make cpuidle_curr_driver static
cpuidle: add cpuidle_unregister_driver() error check
cpuidle: fail to register if !CONFIG_CPU_IDLE
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits)
ACPI: Don't let acpi_pad needlessly mark TSC unstable
drivers/acpi/sleep.h: Checkpatch cleanup
ACPI: Minor cleanup eliminating redundant PMTIMER_TICKS to NS conversion
ACPI: delete unused c-state promotion/demotion data strucutures
ACPI: video: fix acpi_backlight=video
ACPI: EC: Use kmemdup
drivers/acpi: use kasprintf
ACPI, APEI, EINJ injection parameters support
Add x64 support to debugfs
ACPI, APEI, Use ERST for persistent storage of MCE
ACPI, APEI, Error Record Serialization Table (ERST) support
ACPI, APEI, Generic Hardware Error Source memory error support
ACPI, APEI, UEFI Common Platform Error Record (CPER) header
Unified UUID/GUID definition
ACPI Hardware Error Device (PNP0C33) support
ACPI, APEI, PCIE AER, use general HEST table parsing in AER firmware_first setup
ACPI, APEI, Document for APEI
ACPI, APEI, EINJ support
ACPI, APEI, HEST table parsing
ACPI, APEI, APEI supporting infrastructure
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
remove detritus left by "mm: make read_cache_page synchronous"
fix fs/sysv s_dirt handling
fat: convert to use the new truncate convention.
ext2: convert to use the new truncate convention.
tmpfs: convert to use the new truncate convention
fs: convert simple fs to new truncate
kill spurious reference to vmtruncate
fs: introduce new truncate sequence
fs/super: fix kernel-doc warning
fs/minix: bugfix, number of indirect block ptrs per block depends on block size
rename the generic fsync implementations
drop unused dentry argument to ->fsync
fs: Add missing mutex_unlock
Fix racy use of anon_inode_getfd() in perf_event.c
get rid of the magic around f_count in aio
VFS: fix recent breakage of FS_REVAL_DOT
Revert "anon_inode: set S_IFREG on the anon_inode"
Introduce a new truncate calling sequence into fs/mm subsystems. Rather than
setattr > vmtruncate > truncate, have filesystems call their truncate sequence
from ->setattr if filesystem specific operations are required. vmtruncate is
deprecated, and truncate_pagecache and inode_newsize_ok helpers introduced
previously should be used.
simple_setattr is introduced for simple in-ram filesystems to implement
the new truncate sequence. Eventually all filesystems should be converted
to implement a setattr, and the default code in notify_change should go
away.
simple_setsize is also introduced to perform just the ATTR_SIZE portion
of simple_setattr (ie. changing i_size and trimming pagecache).
To implement the new truncate sequence:
- filesystem specific manipulations (eg freeing blocks) must be done in
the setattr method rather than ->truncate.
- vmtruncate can not be used by core code to trim blocks past i_size in
the event of write failure after allocation, so this must be performed
in the fs code.
- convert usage of helpers block_write_begin, nobh_write_begin,
cont_write_begin, and *blockdev_direct_IO* to use _newtrunc postfixed
variants. These avoid calling vmtruncate to trim blocks (see previous).
- inode_setattr should not be used. generic_setattr is a new function
to be used to copy simple attributes into the generic inode.
- make use of the better opportunity to handle errors with the new sequence.
Big problem with the previous calling sequence: the filesystem is not called
until i_size has already changed. This means it is not allowed to fail the
call, and also it does not know what the previous i_size was. Also, generic
code calling vmtruncate to truncate allocated blocks in case of error had
no good way to return a meaningful error (or, for example, atomically handle
block deallocation).
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Nick Piggin <npiggin@suse.de>
We don't name our generic fsync implementations very well currently.
The no-op implementation for in-memory filesystems currently is called
simple_sync_file which doesn't make too much sense to start with,
the the generic one for simple filesystems is called simple_fsync
which can lead to some confusion.
This patch renames the generic file fsync method to generic_file_fsync
to match the other generic_file_* routines it is supposed to be used
with, and the no-op implementation to noop_fsync to make it obvious
what to expect. In addition add some documentation for both methods.
__aio_put_req() plays sick games with file refcount. What
it wants is fput() from atomic context; it's almost always
done with f_count > 1, so they only have to deal with delayed
work in rare cases when their reference happens to be the
last one. Current code decrements f_count and if it hasn't
hit 0, everything is fine. Otherwise it keeps a pointer
to struct file (with zero f_count!) around and has delayed
work do __fput() on it.
Better way to do it: use atomic_long_add_unless( , -1, 1)
instead of !atomic_long_dec_and_test(). IOW, decrement it
only if it's not the last reference, leave refcount alone
if it was. And use normal fput() in delayed work.
I've made that atomic_long_add_unless call a new helper -
fput_atomic(). Drops a reference to file if it's safe to
do in atomic (i.e. if that's not the last one), tells if
it had been able to do that. aio.c converted to it, __fput()
use is gone. req->ki_file *always* contributes to refcount
now. And __fput() became static.
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: implement dump_id force param
libata: disable ATAPI AN by default
libata-sff: make BMDMA optional
libata-sff: kill dummy BMDMA ops from sata_qstor and pata_octeon_cf
libata-sff: separate out BMDMA init
libata-sff: separate out BMDMA irq handler
libata-sff: ata_sff_irq_clear() is BMDMA specific
sata_mv: drop unncessary EH callback resetting
cpuidle_register_driver() sets cpuidle_curr_driver
cpuidle_unregister_driver() clears cpuidle_curr_driver
We should't expose cpuidle_curr_driver to
potential modification except via these interfaces.
So make it static and create cpuidle_get_driver() to observe it.
Signed-off-by: Len Brown <len.brown@intel.com>
Add a new driver to support the AB8500 Power Management chip, replacing
the current AB4500. The new driver replaces the old one, instead of an
incremental modification, because this is a substantial overhaul
including:
- Split of the driver into -core and -spi portions, to allow another
interface layer to be added
- Addition of interrupt support
- Switch to MFD core API for handling subdevices
- Simplification of the APIs to remove a redundant block parameter
- Rename of the APIs and macros from ab4500_* to ab8500_*
- Rename of the files from ab4500* to ab8500*
- Change of the driver name from ab4500 to ab8500
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
The interface for the AB3100 is changed to make way for the
ABX500 family of chips: AB3550, AB5500 and future ST-Ericsson
Analog Baseband chips. The register access functions are moved
out to a separate struct abx500_ops. In this way the interface
is moved from the implementation and the sub functionality drivers
can keep their interface intact when chip infrastructure and
communication mechanisms changes. We also define the AB3550
device IDs and the AB3550 platform data struct and convert
the catenated 32bit event to an array of 3 x 8bits.
Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
The goal here is to make way for a more general interface for the
analog baseband chips ab3100 ab3550 ab550 and future chips.
This patch have been divided into two parts since both changing name
and content of a file is not recommended in git.
The TC35892 I/O Expander provides 24 GPIOs, a keypad controller, timers,
and a rotator wheel interface. This patch adds the MFD core.
The charger interrupts on the WM831x are unconditionally a wake source
for the system. If the power driver is not able to monitor them (for
example, due to the IRQ line not having been wired up on the system)
then any charger interrupt will prevent the system suspending for any
meaningful amount of time since nothing will ack them.
Avoid this issue by manually acknowledging these interrupts when we
suspend the WM831x core device if they are masked. If software is
actually using the interrupts then they will be unmasked and this
change will have no effect.
Add touch screen input driver for TPS6507x family of multi-function
chips. Uses the TPS6507x MFD driver. No interrupt support due to
testing limitations of current hardware.
Signed-off-by: Todd Fischer <todd.fischer@ridgerun.com>
TPS6507x are multi function (PM, touchscreen) chipsets from TI.
This commit also changes the corresponding regulator driver from being
standalone to an MFD subdevice.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Add mfd structure which refrences sub-driver initialization data. For example,
for a giving hardware implementation, the voltage regulator sub-driver
initialization data provides the mapping betten a voltage regulator and what
the output voltage is being used for.
Other sub-drivers for the TPS6507x chip will need to use register
definition so move it out of the source file and into a header file.
The Janz CMOD-IO PCI MODULbus carrier board is a PCI to MODULbus bridge,
which may host many different types of MODULbus daughterboards, including
CAN and GPIO controllers.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
Reviewed-by: Wolfgang Grandegger <wg@grandegger.com>
This patch fixes three section mismatches.
WARNING: drivers/mfd/88pm860x.o(.text+0x12): Section mismatch in
reference from the function pm860x_device_exit() to the function
.devexit.text:device_irq_exit()
The function pm860x_device_exit() references a function in an exit
section.
Often the function device_irq_exit() has valid usage outside the exit
section
and the fix is to remove the __devexit annotation of device_irq_exit.
WARNING: drivers/mfd/88pm860x.o(.text+0xb0): Section mismatch in
reference from the function pm860x_device_init() to the function
.devinit.text:device_8606_init()
The function pm860x_device_init() references
the function __devinit device_8606_init().
This is often because pm860x_device_init lacks a __devinit
annotation or the annotation of device_8606_init is wrong.
WARNING: drivers/mfd/88pm860x.o(.text+0xbe): Section mismatch in
.devinit.text:device_8607_init()
the function __devinit device_8607_init().
annotation or the annotation of device_8607_init is wrong.
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de>
This patch adds a new MFD driver for the RDC321x southbridge. This southbridge
is always present in the RDC321x System-on-a-Chip and provides access to some
GPIOs as well as a watchdog. Access to these two functions is done using the
southbridge PCI device configuration space.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (61 commits)
tracing: Add __used annotation to event variable
perf, trace: Fix !x86 build bug
perf report: Support multiple events on the TUI
perf annotate: Fix up usage of the build id cache
x86/mmiotrace: Remove redundant instruction prefix checks
perf annotate: Add TUI interface
perf tui: Remove annotate from popup menu after failure
perf report: Don't start the TUI if -D is used
perf: Fix getline undeclared
perf: Optimize perf_tp_event_match()
perf: Remove more code from the fastpath
perf: Optimize the !vmalloc backed buffer
perf: Optimize perf_output_copy()
perf: Fix wakeup storm for RO mmap()s
perf-record: Share per-cpu buffers
perf-record: Remove -M
perf: Ensure that IOC_OUTPUT isn't used to create multi-writer buffers
perf, trace: Optimize tracepoints by using per-tracepoint-per-cpu hlist to track events
perf, trace: Optimize tracepoints by removing IRQ-disable from perf/tracepoint interaction
perf tui: Allow disabling the TUI on a per command basis in ~/.perfconfig
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight:
gta02: Use pcf50633 backlight driver instead of platform backlight driver.
backlight: pcf50633: Register a pcf50633-backlight device in pcf50633 core driver.
backlight: Add pcf50633 backlight driver
backlight: 88pm860x_bl: fix error handling in pm860x_backlight_probe
backlight: max8925_bl: Fix error handling path
backlight: l4f00242t03: fix error handling in l4f00242t03_probe
backlight: add S6E63M0 AMOLED LCD Panel driver
backlight: adp8860: add support for ADP8861 & ADP8863
backlight: mbp_nvidia_bl - Fix DMI_SYS_VENDOR for MacBook1,1
backlight: Add Cirrus EP93xx backlight driver
backlight: l4f00242t03: Fix regulators handling code in remove function
backlight: fix adp8860_bl build errors
backlight: new driver for the ADP8860 backlight parts
backlight: 88pm860x_bl - potential memory leak
backlight: mbp_nvidia_bl - add support for older MacBookPro and MacBook 6,1.
backlight: Kconfig cleanup
backlight: backlight_device_register() return ERR_PTR()
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds:
leds: Add mx31moboard MC13783 led support
leds: Add mc13783 LED support
leds: leds-ss4200: fix led_classdev_unregister twice in error handling
leds: leds-lp3944: properly handle lp3944_configure fail in lp3944_probe
leds: led-class: set permissions on max_brightness file to 0444
leds: leds-gpio: Change blink_set callback to be able to turn off blinking
leds: Add LED driver for the Soekris net5501 board
leds: 88pm860x - fix checking in probe function
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (23 commits)
hwmon: (lm75) Add support for the Texas Instruments TMP105
hwmon: (ltc4245) Read only one GPIO pin
hwmon: (dme1737) Add SCH5127 support
hwmon: (tmp102) Don't always stop chip at exit
hwmon: (tmp102) Fix suspend and resume functions
hwmon: (tmp102) Various fixes
hwmon: Driver for TI TMP102 temperature sensor
hwmon: EMC1403 thermal sensor support
hwmon: (applesmc) Add temperature sensor labels to sysfs interface
hwmon: (applesmc) Add generic support for MacBook Pro 7
hwmon: (applesmc) Add generic support for MacBook Pro 6
hwmon: (applesmc) Add support for MacBook Pro 5,3 and 5,4
hwmon: (tmp401) Reorganize code to get rid of static forward declarations
hwmon: (tmp401) Use constants for sysfs file permissions
hwmon: (adm1031) Allow setting update rate
hwmon: Add description of the update_rate sysfs attribute
hwmon: (lm90) Use programmed update rate
hwmon: (f71882fg) Acquire I/O regions while we're working with them
hwmon: (f71882fg) Code cleanup
hwmon: (f71882fg) Use strict_stro(l|ul) instead of simple_strto$1
When the user passes the kernel parameter acpi_enforce_resources=lax,
the ACPI resources are no longer protected, so a native driver can
make use of them. In that case, we do not want the asus_atk0110 to be
loaded. Unfortunately, this driver loads automatically due to its
MODULE_DEVICE_TABLE, so the user ends up with two drivers loaded for
the same device - this is bad.
So I suggest that we prevent the asus_atk0110 driver from loading if
acpi_enforce_resources=lax.
Acked-by: Luca Tettamanti <kronos.it@gmail.com>
Cc: Len Brown <lenb@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6
* 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6:
SFI: add sysfs interface for SFI tables.
SFI: add support for v0.81 spec
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (27 commits)
Btrfs: add more error checking to btrfs_dirty_inode
Btrfs: allow unaligned DIO
Btrfs: drop verbose enospc printk
Btrfs: Fix block generation verification race
Btrfs: fix preallocation and nodatacow checks in O_DIRECT
Btrfs: avoid ENOSPC errors in btrfs_dirty_inode
Btrfs: move O_DIRECT space reservation to btrfs_direct_IO
Btrfs: rework O_DIRECT enospc handling
Btrfs: use async helpers for DIO write checksumming
Btrfs: don't walk around with task->state != TASK_RUNNING
Btrfs: do aio_write instead of write
Btrfs: add basic DIO read/write support
direct-io: do not merge logically non-contiguous requests
direct-io: add a hook for the fs to provide its own submit_bio function
fs: allow short direct-io reads to be completed via buffered IO
Btrfs: Metadata ENOSPC handling for balance
Btrfs: Pre-allocate space for data relocation
Btrfs: Metadata ENOSPC handling for tree log
Btrfs: Metadata reservation for orphan inodes
Btrfs: Introduce global metadata reservation
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (40 commits)
ext4: Make fsync sync new parent directories in no-journal mode
ext4: Drop whitespace at end of lines
ext4: Fix compat EXT4_IOC_ADD_GROUP
ext4: Conditionally define compat ioctl numbers
tracing: Convert more ext4 events to DEFINE_EVENT
ext4: Add new tracepoints to track mballoc's buddy bitmap loads
ext4: Add a missing trace hook
ext4: restart ext4_ext_remove_space() after transaction restart
ext4: Clear the EXT4_EOFBLOCKS_FL flag only when warranted
ext4: Avoid crashing on NULL ptr dereference on a filesystem error
ext4: Use bitops to read/modify i_flags in struct ext4_inode_info
ext4: Convert calls of ext4_error() to EXT4_ERROR_INODE()
ext4: Convert callers of ext4_get_blocks() to use ext4_map_blocks()
ext4: Add new abstraction ext4_map_blocks() underneath ext4_get_blocks()
ext4: Use our own write_cache_pages()
ext4: Show journal_checksum option
ext4: Fix for ext4_mb_collect_stats()
ext4: check for a good block group before loading buddy pages
ext4: Prevent creation of files larger than RLIMIT_FSIZE using fallocate
ext4: Remove extraneous newlines in ext4_msg() calls
Fixed up trivial conflict in fs/ext4/fsync.c
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
ieee1394: schedule for removal
firewire: core: use separate timeout for each transaction
firewire: core: Fix tlabel exhaustion problem
firewire: core: make transaction label allocation more robust
firewire: core: clean up config ROM related defined constants
ieee1394: mark char device files as not seekable
firewire: cdev: mark char device files as not seekable
firewire: ohci: cleanups and fix for nonstandard build without debug facility
firewire: ohci: wait for PHY register accesses to complete
firewire: ohci: fix up configuration of TI chips
firewire: ohci: enable 1394a enhancements
firewire: ohci: do not clear PHY interrupt status inadvertently
firewire: ohci: add a function for reading PHY registers
Trivial conflicts in Documentation/feature-removal-schedule.txt
Generic per-cpu counter has some memory overhead but it is negligible for
modern systems and embedded systems compile without quota support. And code
reuse is a good thing. This patch should fix complain from preemptive kernels
which was introduced by dde9588853b1bde.
[Jan Kara: Fixed patch to work on 32-bit archs as well]
Reported-by: Rafael J. Wysocki <rjw@sisk.pl>
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: usbtouchscreen - support bigger iNexio touchscreens
Input: ads7846 - return error on regulator_get() failure
Input: twl4030-vibra - correct the power down sequence
Input: enable onkey driver of max8925
Input: use ABS_CNT rather than (ABS_MAX + 1)
Introduce numa_mem_id(), based on generic percpu variable infrastructure
to track "nearest node with memory" for archs that support memoryless
nodes.
Define API in <linux/topology.h> when CONFIG_HAVE_MEMORYLESS_NODES
defined, else stubs. Architectures will define HAVE_MEMORYLESS_NODES
if/when they support them.
Archs can override definitions of:
numa_mem_id() - returns node number of "local memory" node
set_numa_mem() - initialize [this cpus'] per cpu variable 'numa_mem'
cpu_to_mem() - return numa_mem for specified cpu; may be used as lvalue
Generic initialization of 'numa_mem' occurs in __build_all_zonelists().
This will initialize the boot cpu at boot time, and all cpus on change of
numa_zonelist_order, or when node or memory hot-plug requires zonelist
rebuild. Archs that support memoryless nodes will need to initialize
'numa_mem' for secondary cpus as they're brought on-line.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Eric Whitney <eric.whitney@hp.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: <linux-arch@vger.kernel.org>
Rework the generic version of the numa_node_id() function to use the new
generic percpu variable infrastructure.
Guard the new implementation with a new config option:
CONFIG_USE_PERCPU_NUMA_NODE_ID.
Archs which support this new implemention will default this option to 'y'
when NUMA is configured. This config option could be removed if/when all
archs switch over to the generic percpu implementation of numa_node_id().
Arch support involves:
1) converting any existing per cpu variable implementations to use
this implementation. x86_64 is an instance of such an arch.
2) archs that don't use a per cpu variable for numa_node_id() will
need to initialize the new per cpu variable "numa_node" as cpus
are brought on-line. ia64 is an example.
3) Defining USE_PERCPU_NUMA_NODE_ID in arch dependent Kconfig--e.g.,
when NUMA is configured. This is required because I have
retained the old implementation by default to allow archs to
be modified incrementally, as desired.
Subsequent patches will convert x86_64 and ia64 to use this implemenation.
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
This is an implementation of ->llseek useable for the rare special case
when userspace expects the seek to succeed but the (device) file is
actually not able to perform the seek. In this case you use noop_llseek()
instead of falling back to the default implementation of ->llseek.
Signed-off-by: Jan Blunck <jblunck@suse.de>
