commit d81a5d1956731c453b85c141458d4ff5d6cc5366 upstream.
A lot of Broadcom Bluetooth devices provides vendor specific interface
class and we are getting flooded by patches adding new device support.
This change will help us enable support for any other Broadcom with vendor
specific device that arrives in the future.
Only the product id changes for those devices, so this macro would be
perfect for us:
{ USB_VENDOR_AND_INTERFACE_INFO(0x0a5c, 0xff, 0x01, 0x01) }
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Acked-by: Henrik Rydberg <rydberg@bitmath.se>
commit d796c52ef0b71a988364f6109aeb63d79c5b116b upstream.
After we transfer set the EXT4_ERROR_FS bit in the file system
superblock, it's not enough to call jbd2_journal_clear_err() to clear
the error indication from journal superblock --- we need to call
jbd2_journal_update_sb_errno() as well. Otherwise, when the root file
system is mounted read-only, the journal is replayed, and the error
indicator is transferred to the superblock --- but the s_errno field
in the jbd2 superblock is left set (since although we cleared it in
memory, we never flushed it out to disk).
This can end up confusing e2fsck. We should make e2fsck more robust
in this case, but the kernel shouldn't be leaving things in this
confused state, either.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 4eef6cbfcc03b294d9d334368a851b35b496ce53 upstream.
The EETI touchscreen asserts its IRQ line as soon as it has data in its
internal buffers. The line is automatically deasserted once all data has
been read via I2C. Hence, the driver has to monitor the GPIO line and
cannot simply rely on the interrupt handler reception.
In the current implementation of the driver, irq_to_gpio() is used to
determine the GPIO number from the i2c_client's IRQ value.
As irq_to_gpio() is not available on all platforms, this patch changes
this and makes the driver ignore the passed in IRQ. Instead, a GPIO is
added to the platform_data struct and gpio_to_irq is used to derive the
IRQ from that GPIO. If this fails, bail out. The driver is only able to
work in environments where the touchscreen GPIO can be mapped to an
IRQ.
Without this patch, building raumfeld_defconfig results in:
drivers/input/touchscreen/eeti_ts.c: In function 'eeti_ts_irq_active':
drivers/input/touchscreen/eeti_ts.c:65:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration]
Signed-off-by: Daniel Mack <zonque@gmail.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Sven Neumann <s.neumann@raumfeld.com>
Cc: linux-input@vger.kernel.org
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
commit 9d8dad742ad1c74d7e7210ee05d0b44961d5ea16 upstream.
The higher ptrace restriction levels should be blocking even
PTRACE_TRACEME requests. The comments in the LSM documentation are
misleading about when the checks happen (the parent does not go through
security_ptrace_access_check() on a PTRACE_TRACEME call).
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 59ee93a528b94ef4e81a08db252b0326feff171f upstream.
The irq_to_gpio function was removed from the pxa platform
in linux-3.2, and this driver has been broken since.
There is actually no in-tree user of this driver that adds
this platform device, but the driver can and does get enabled
on some platforms.
Without this patch, building ezx_defconfig results in:
drivers/mfd/ezx-pcap.c: In function 'pcap_isr_work':
drivers/mfd/ezx-pcap.c:205:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration]
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream.
With the new interrupt sampling system, we are no longer using the
timer_rand_state structure in the irq descriptor, so we can stop
initializing it now.
[ Merged in fixes from Sedat to find some last missing references to
rand_initialize_irq() ]
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
commit c2557a303ab6712bb6e09447df828c557c710ac9 upstream.
Create a new function, get_random_bytes_arch() which will use the
architecture-specific hardware random number generator if it is
present. Change get_random_bytes() to not use the HW RNG, even if it
is avaiable.
The reason for this is that the hw random number generator is fast (if
it is present), but it requires that we trust the hardware
manufacturer to have not put in a back door. (For example, an
increasing counter encrypted by an AES key known to the NSA.)
It's unlikely that Intel (for example) was paid off by the US
Government to do this, but it's impossible for them to prove otherwise
--- especially since Bull Mountain is documented to use AES as a
whitener. Hence, the output of an evil, trojan-horse version of
RDRAND is statistically indistinguishable from an RDRAND implemented
to the specifications claimed by Intel. Short of using a tunnelling
electronic microscope to reverse engineer an Ivy Bridge chip and
disassembling and analyzing the CPU microcode, there's no way for us
to tell for sure.
Since users of get_random_bytes() in the Linux kernel need to be able
to support hardware systems where the HW RNG is not present, most
time-sensitive users of this interface have already created their own
cryptographic RNG interface which uses get_random_bytes() as a seed.
So it's much better to use the HW RNG to improve the existing random
number generator, by mixing in any entropy returned by the HW RNG into
/dev/random's entropy pool, but to always _use_ /dev/random's entropy
pool.
This way we get almost of the benefits of the HW RNG without any
potential liabilities. The only benefits we forgo is the
speed/performance enhancements --- and generic kernel code can't
depend on depend on get_random_bytes() having the speed of a HW RNG
anyway.
For those places that really want access to the arch-specific HW RNG,
if it is available, we provide get_random_bytes_arch().
commit a2080a67abe9e314f9e9c2cc3a4a176e8a8f8793 upstream.
Add a new interface, add_device_randomness() for adding data to the
random pool that is likely to differ between two devices (or possibly
even per boot). This would be things like MAC addresses or serial
numbers, or the read-out of the RTC. This does *not* add any actual
entropy to the pool, but it initializes the pool to different values
for devices that might otherwise be identical and have very little
entropy available to them (particularly common in the embedded world).
[ Modified by tytso to mix in a timestamp, since there may be some
variability caused by the time needed to detect/configure the hardware
in question. ]
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream.
We've been moving away from add_interrupt_randomness() for various
reasons: it's too expensive to do on every interrupt, and flooding the
CPU with interrupts could theoretically cause bogus floods of entropy
from a somewhat externally controllable source.
This solves both problems by limiting the actual randomness addition
to just once a second or after 64 interrupts, whicever comes first.
During that time, the interrupt cycle data is buffered up in a per-cpu
pool. Also, we make sure the the nonblocking pool used by urandom is
initialized before we start feeding the normal input pool. This
assures that /dev/urandom is returning unpredictable data as soon as
possible.
(Based on an original patch by Linus, but significantly modified by
tytso.)
Tested-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu>
Reported-by: Zakir Durumeric <zakir@umich.edu>
Reported-by: J. Alex Halderman <jhalderm@umich.edu>
commit 8ded2bbc1845e19c771eb55209aab166ef011243 upstream.
Recently, glibc made a change to suppress sign-conversion warnings in
FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the
kernel's definition of __NFDBITS if applications #include
<linux/types.h> after including <sys/select.h>. A build failure would
be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2
flags to gcc.
It was suggested that the kernel should either match the glibc
definition of __NFDBITS or remove that entirely. The current in-kernel
uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no
uses of the related __FDELT and __FDMASK defines. Given that, we'll
continue the cleanup that was started with commit 8b3d1cda4f5f
("posix_types: Remove fd_set macros") and drop the remaining unused
macros.
Additionally, linux/time.h has similar macros defined that expand to
nothing so we'll remove those at the same time.
Reported-by: Jeff Law <law@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
[ .. and fix up whitespace as per akpm ]
commit 6575820221f7a4dd6eadecf7bf83cdd154335eda upstream.
Currently, all workqueue cpu hotplug operations run off
CPU_PRI_WORKQUEUE which is higher than normal notifiers. This is to
ensure that workqueue is up and running while bringing up a CPU before
other notifiers try to use workqueue on the CPU.
Per-cpu workqueues are supposed to remain working and bound to the CPU
for normal CPU_DOWN_PREPARE notifiers. This holds mostly true even
with workqueue offlining running with higher priority because
workqueue CPU_DOWN_PREPARE only creates a bound trustee thread which
runs the per-cpu workqueue without concurrency management without
explicitly detaching the existing workers.
However, if the trustee needs to create new workers, it creates
unbound workers which may wander off to other CPUs while
CPU_DOWN_PREPARE notifiers are in progress. Furthermore, if the CPU
down is cancelled, the per-CPU workqueue may end up with workers which
aren't bound to the CPU.
While reliably reproducible with a convoluted artificial test-case
involving scheduling and flushing CPU burning work items from CPU down
notifiers, this isn't very likely to happen in the wild, and, even
when it happens, the effects are likely to be hidden by the following
successful CPU down.
Fix it by using different priorities for up and down notifiers - high
priority for up operations and low priority for down operations.
Workqueue cpu hotplug operations will soon go through further cleanup.
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
commit b09e786bd1dd66418b69348cb110f3a64764626a upstream.
This patch fixes a crash
tun_chr_close -> netdev_run_todo -> tun_free_netdev -> sk_release_kernel ->
sock_release -> iput(SOCK_INODE(sock))
introduced by commit 1ab5ecb90cb6a3df1476e052f76a6e8f6511cb3d
The problem is that this socket is embedded in struct tun_struct, it has
no inode, iput is called on invalid inode, which modifies invalid memory
and optionally causes a crash.
sock_release also decrements sockets_in_use, this causes a bug that
"sockets: used" field in /proc/*/net/sockstat keeps on decreasing when
creating and closing tun devices.
This patch introduces a flag SOCK_EXTERNALLY_ALLOCATED that instructs
sock_release to not free the inode and not decrement sockets_in_use,
fixing both memory corruption and sockets_in_use underflow.
It should be backported to 3.3 an 3.4 stabke.
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
commit 6751ed65dc6642af64f7b8a440a75563c8aab7ae upstream.
In commit dad1743e5993f1 ("x86/mce: Only restart instruction after machine
check recovery if it is safe") we fixed mce_notify_process() to force a
signal to the current process if it was not restartable (RIPV bit not
set in MCG_STATUS). But doing it here means that the process doesn't
get told the virtual address of the fault via siginfo_t->si_addr. This
would prevent application level recovery from the fault.
Make a new MF_MUST_KILL flag bit for memory_failure() et al. to use so
that we will provide the right information with the signal.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
commit c5c4bdf02e518a281b229ae0891b346919e2d291 upstream.
hub_initiated_lpm_disable_count is not used by any code, so remove it.
This commit should be backported to kernels as old as 3.5, that contain
the commit 8306095fd2c1100e8244c09bf560f97aca5a311d "USB: Disable USB
3.0 LPM in critical sections."
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
The SYSTEM_SUSPEND_DISK system state is never used, so drop it.
Merge emailed kgdb dmesg fixups patches from Anton Vorontsov:
"The dmesg command appears to be broken after the printk rework. The
old logic in the kdb code makes no sense in terms of current
printk/logging storage format, and KDB simply hangs forever upon
entering 'dmesg' command.
The first patch revives the command by switching to kmsg_dumper
iterator. As a side-effect, the code is now much more simpler.
A few changes were needed in the printk.c: we needed unlocked variant
of the kmsg_dumper iterator, but these can surely wait for 3.6.
It's probably too late even for the first patch to go to 3.5, but I'll
try to convince otherwise. :-) Here we go:
- The current code is broken for sure, and has no hope to work at
all. It is a regression
- The new code works for me, and probably works for everyone else;
- If it compiles (and I urge everyone to compile-test it on your
setup), it hardly can make things worse."
* Merge emailed patches from Anton Vorontsov: (4 commits)
kdb: Switch to nolock variants of kmsg_dump functions
printk: Implement some unlocked kmsg_dump functions
printk: Remove kdb_syslog_data
kdb: Revive dmesg command
If used from KDB, the locked variants are prone to deadlocks (suppose we
got to the debugger w/ the logbuf lock held).
So, we have to implement a few routines that grab no logbuf lock.
Yet we don't need these functions in modules, so we don't export them.
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull last minute Ceph fixes from Sage Weil:
"The important one fixes a bug in the socket failure handling behavior
that was turned up in some recent failure injection testing. The
other two are minor bug fixes."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
rbd: endian bug in rbd_req_cb()
rbd: Fix ceph_snap_context size calculation
libceph: fix messenger retry
Commit a7a20d103994 ("sd: limit the scope of the async probe domain")
make the SCSI device probing run device discovery in it's own async
domain.
However, as a result, the partition detection was no longer synchronized
by async_synchronize_full() (which, despite the name, only synchronizes
the global async space, not all of them). Which in turn meant that
"wait_for_device_probe()" would not wait for the SCSI partitions to be
parsed.
And "wait_for_device_probe()" was what the boot time init code relied on
for mounting the root filesystem.
Now, most people never noticed this, because not only is it
timing-dependent, but modern distributions all use initrd. So the root
filesystem isn't actually on a disk at all. And then before they
actually mount the final disk filesystem, they will have loaded the
scsi-wait-scan module, which not only does the expected
wait_for_device_probe(), but also does scsi_complete_async_scans().
[ Side note: scsi_complete_async_scans() had also been partially broken,
but that was fixed in commit 43a8d39d0137 ("fix async probe
regression"), so that same commit a7a20d103994 had actually broken
setups even if you used scsi-wait-scan explicitly ]
Solve this problem by just moving the scsi_complete_async_scans() call
into wait_for_device_probe(). Everybody who wants to wait for device
probing to finish really wants the SCSI probing to complete, so there's
no reason not to do this.
So now "wait_for_device_probe()" really does what the name implies, and
properly waits for device probing to finish. This also removes the now
unnecessary extra calls to scsi_complete_async_scans().
Reported-and-tested-by: Artem S. Tashkinov <t.artem@mailcity.com>
Cc: Dan Williams <dan.j.williams@gmail.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: James Bottomley <jbottomley@parallels.com>
Cc: Borislav Petkov <bp@amd64.org>
Cc: linux-scsi <linux-scsi@vger.kernel.org>
In ancient times, the messenger could both initiate and accept connections.
An artifact if that was data structures to store/process an incoming
ceph_msg_connect request and send an outgoing ceph_msg_connect_reply.
Sadly, the negotiation code was referencing those structures and ignoring
important information (like the peer's connect_seq) from the correct ones.
Among other things, this fixes tight reconnect loops where the server sends
RETRY_SESSION and we (the client) retries with the same connect_seq as last
time. This bug pretty easily triggered by injecting socket failures on the
MDS and running some fs workload like workunits/direct_io/test_sync_io.
Signed-off-by: Sage Weil <sage@inktank.com>
As discussed in
http://thread.gmane.org/gmane.linux.kernel/1249726/focus=1288990,
the capability introduced in 4d7e30d98939a0340022ccd49325a3d70f7e0238
to govern EPOLLWAKEUP seems misnamed: this capability is about governing
the ability to suspend the system, not using a particular API flag
(EPOLLWAKEUP). We should make the name of the capability more general
to encourage reuse in related cases. (Whether or not this capability
should also be used to govern the use of /sys/power/wake_lock is a
question that needs to be separately resolved.)
This patch renames the capability to CAP_BLOCK_SUSPEND. In order to ensure
that the old capability name doesn't make it out into the wild, could you
please apply and push up the tree to ensure that it is incorporated
for the 3.5 release.
Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
Pull RCU, perf, and scheduler fixes from Ingo Molnar.
The RCU fix is a revert for an optimization that could cause deadlocks.
One of the scheduler commits (164c33c6adee "sched: Fix fork() error path
to not crash") is correct but not complete (some architectures like Tile
are not covered yet) - the resulting additional fixes are still WIP and
Ingo did not want to delay these pending fixes. See this thread on
lkml:
[PATCH] fork: fix error handling in dup_task()
The perf fixes are just trivial oneliners.
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Revert "rcu: Move PREEMPT_RCU preemption to switch_to() invocation"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf kvm: Fix segfault with report and mixed guestmount use
perf kvm: Fix regression with guest machine creation
perf script: Fix format regression due to libtraceevent merge
ring-buffer: Fix accounting of entries when removing pages
ring-buffer: Fix crash due to uninitialized new_pages list head
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
MAINTAINERS/sched: Update scheduler file pattern
sched/nohz: Rewrite and fix load-avg computation -- again
sched: Fix fork() error path to not crash
Pull the leap second fixes from Thomas Gleixner:
"It's a rather large series, but well discussed, refined and reviewed.
It got a massive testing by John, Prarit and tip.
In theory we could split it into two parts. The first two patches
f55a6faa3843: hrtimer: Provide clock_was_set_delayed()
4873fa070ae8: timekeeping: Fix leapsecond triggered load spike issue
are merely preventing the stuff loops forever issues, which people
have observed.
But there is no point in delaying the other 4 commits which achieve
full correctness into 3.6 as they are tagged for stable anyway. And I
rather prefer to have the full fixes merged in bulk than a "prevent
the observable wreckage and deal with the hidden fallout later"
approach."
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
hrtimer: Update hrtimer base offsets each hrtimer_interrupt
timekeeping: Provide hrtimer update function
hrtimers: Move lock held region in hrtimer_interrupt()
timekeeping: Maintain ktime_t based offsets for hrtimers
Merge random patches from Andrew Morton.
* Merge emailed patches from Andrew Morton <akpm@linux-foundation.org>: (32 commits)
memblock: free allocated memblock_reserved_regions later
mm: sparse: fix usemap allocation above node descriptor section
mm: sparse: fix section usemap placement calculation
xtensa: fix incorrect memset
shmem: cleanup shmem_add_to_page_cache
shmem: fix negative rss in memcg memory.stat
tmpfs: revert SEEK_DATA and SEEK_HOLE
drivers/rtc/rtc-twl.c: fix threaded IRQ to use IRQF_ONESHOT
fat: fix non-atomic NFS i_pos read
MAINTAINERS: add OMAP CPUfreq driver to OMAP Power Management section
sgi-xp: nested calls to spin_lock_irqsave()
fs: ramfs: file-nommu: add SetPageUptodate()
drivers/rtc/rtc-mxc.c: fix irq enabled interrupts warning
mm/memory_hotplug.c: release memory resources if hotadd_new_pgdat() fails
h8300/uaccess: add mising __clear_user()
h8300/uaccess: remove assignment to __gu_val in unhandled case of get_user()
h8300/time: add missing #include <asm/irq_regs.h>
h8300/signal: fix typo "statis"
h8300/pgtable: add missing #include <asm-generic/pgtable.h>
drivers/rtc/rtc-ab8500.c: ensure correct probing of the AB8500 RTC when Device Tree is enabled
memblock_free_reserved_regions() calls memblock_free(), but
memblock_free() would double reserved.regions too, so we could free the
old range for reserved.regions.
Also tj said there is another bug which could be related to this.
| I don't think we're saving any noticeable
| amount by doing this "free - give it to page allocator - reserve
| again" dancing. We should just allocate regions aligned to page
| boundaries and free them later when memblock is no longer in use.
in that case, when DEBUG_PAGEALLOC, will get panic:
memblock_free: [0x0000102febc080-0x0000102febf080] memblock_free_reserved_regions+0x37/0x39
BUG: unable to handle kernel paging request at ffff88102febd948
IP: [<ffffffff836a5774>] __next_free_mem_range+0x9b/0x155
PGD 4826063 PUD cf67a067 PMD cf7fa067 PTE 800000102febd160
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU 0
Pid: 0, comm: swapper Not tainted 3.5.0-rc2-next-20120614-sasha #447
RIP: 0010:[<ffffffff836a5774>] [<ffffffff836a5774>] __next_free_mem_range+0x9b/0x155
See the discussion at https://lkml.org/lkml/2012/6/13/469
So try to allocate with PAGE_SIZE alignment and free it later.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: <stable@vger.kernel.org>
After commit f5bf18fa22f8 ("bootmem/sparsemem: remove limit constraint
in alloc_bootmem_section"), usemap allocations may easily be placed
outside the optimal section that holds the node descriptor, even if
there is space available in that section. This results in unnecessary
hotplug dependencies that need to have the node unplugged before the
section holding the usemap.
The reason is that the bootmem allocator doesn't guarantee a linear
search starting from the passed allocation goal but may start out at a
much higher address absent an upper limit.
Fix this by trying the allocation with the limit at the section end,
then retry without if that fails. This keeps the fix from f5bf18fa22f8
of not panicking if the allocation does not fit in the section, but
still makes sure to try to stay within the section at first.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: <stable@vger.kernel.org> [3.3.x, 3.4.x]
kswapd_stop() is called to destroy the kswapd work thread when all memory
of a NUMA node has been offlined. But kswapd_stop() only terminates the
work thread without resetting NODE_DATA(nid)->kswapd to NULL. The stale
pointer will prevent kswapd_run() from creating a new work thread when
adding memory to the memory-less NUMA node again. Eventually the stale
pointer may cause invalid memory access.
An example stack dump as below. It's reproduced with 2.6.32, but latest
kernel has the same issue.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81051a94>] exit_creds+0x12/0x78
PGD 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/system/memory/memory391/state
CPU 11
Modules linked in: cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq microcode fuse loop dm_mod tpm_tis rtc_cmos i2c_i801 rtc_core tpm serio_raw pcspkr sg tpm_bios igb i2c_core iTCO_wdt rtc_lib mptctl iTCO_vendor_support button dca bnx2 usbhid hid uhci_hcd ehci_hcd usbcore sd_mod crc_t10dif edd ext3 mbcache jbd fan ide_pci_generic ide_core ata_generic ata_piix libata thermal processor thermal_sys hwmon mptsas mptscsih mptbase scsi_transport_sas scsi_mod
Pid: 7949, comm: sh Not tainted 2.6.32.12-qiuxishi-5-default #92 Tecal RH2285
RIP: 0010:exit_creds+0x12/0x78
RSP: 0018:ffff8806044f1d78 EFLAGS: 00010202
RAX: 0000000000000000 RBX: ffff880604f22140 RCX: 0000000000019502
RDX: 0000000000000000 RSI: 0000000000000202 RDI: 0000000000000000
RBP: ffff880604f22150 R08: 0000000000000000 R09: ffffffff81a4dc10
R10: 00000000000032a0 R11: ffff880006202500 R12: 0000000000000000
R13: 0000000000c40000 R14: 0000000000008000 R15: 0000000000000001
FS: 00007fbc03d066f0(0000) GS:ffff8800282e0000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000000 CR3: 000000060f029000 CR4: 00000000000006e0
Process sh (pid: 7949, threadinfo ffff8806044f0000, task ffff880603d7c600)
Stack:
ffff880604f22140 ffffffff8103aac5 ffff880604f22140 ffffffff8104d21e
ffff880006202500 0000000000008000 0000000000c38000 ffffffff810bd5b1
0000000000000000 ffff880603d7c600 00000000ffffdd29 0000000000000003
Call Trace:
__put_task_struct+0x5d/0x97
kthread_stop+0x50/0x58
offline_pages+0x324/0x3da
memory_block_change_state+0x179/0x1db
store_mem_state+0x9e/0xbb
sysfs_write_file+0xd0/0x107
vfs_write+0xad/0x169
sys_write+0x45/0x6e
system_call_fastpath+0x16/0x1b
Code: ff 4d 00 0f 94 c0 84 c0 74 08 48 89 ef e8 1f fd ff ff 5b 5d 31 c0 41 5c c3 53 48 8b 87 20 06 00 00 48 89 fb 48 8b bf 18 06 00 00 <8b> 00 48 c7 83 18 06 00 00 00 00 00 00 f0 ff 0f 0f 94 c0 84 c0
RIP exit_creds+0x12/0x78
RSP <ffff8806044f1d78>
[akpm@linux-foundation.org: add pglist_data.kswapd locking comments]
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: David Rientjes <rientjes@google.com>
Reviewed-by: Minchan Kim <minchan@kernel.org>
To finally fix the infamous leap second issue and other race windows
caused by functions which change the offsets between the various time
bases (CLOCK_MONOTONIC, CLOCK_REALTIME and CLOCK_BOOTTIME) we need a
function which atomically gets the current monotonic time and updates
the offsets of CLOCK_REALTIME and CLOCK_BOOTTIME with minimalistic
overhead. The previous patch which provides ktime_t offsets allows us
to make this function almost as cheap as ktime_get() which is going to
be replaced in hrtimer_interrupt().
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Prarit Bhargava <prarit@redhat.com>
Cc: stable@vger.kernel.org
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Link: http://lkml.kernel.org/r/1341960205-56738-7-git-send-email-johnstul@us.ibm.com
clock_was_set() cannot be called from hard interrupt context because
it calls on_each_cpu().
For fixing the widely reported leap seconds issue it is necessary to
call it from hard interrupt context, i.e. the timer tick code, which
does the timekeeping updates.
Provide a new function which denotes it in the hrtimer cpu base
structure of the cpu on which it is called and raise the hrtimer
softirq. We then execute the clock_was_set() notificiation from
softirq context in run_hrtimer_softirq(). The hrtimer softirq is
rarely used, so polling the flag there is not a performance issue.
[ tglx: Made it depend on CONFIG_HIGH_RES_TIMERS. We really should get
rid of all this ifdeffery ASAP ]
Reported-by: Jan Engelhardt <jengelh@inai.de>
Link: http://lkml.kernel.org/r/1341960205-56738-2-git-send-email-johnstul@us.ibm.com
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg Kroah-Hartman:
"Here are a few fixes and new device ids for the 3.5-rc6 tree.
The PCI changes resolve a long-standing issue with resuming some EHCI
controllers. It has been acked by the PCI maintainer, and he asked
for it to go through my USB tree instead of his.
The xhci patches also resolve a number of reported issues.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.5-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
PCI: EHCI: fix crash during suspend on ASUS computers
USB: cdc-wdm: fix lockup on error in wdm_read
USB: metro-usb: fix tty_flip_buffer_push use
USB: option: Add MEDIATEK product ids
USB: option: add ZTE MF60
xhci: Fix hang on back-to-back Set TR Deq Ptr commands.
usb: Add support for root hub port status CAS
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
"Yes, this is a *LATE* GPIO pull request with fixes for v3.5.
Grant moved across the planet and accidentally fell off the grid, so
he asked me to take over the GPIO merges for a while 10 days ago.
Since then I went over the archives and collected this pile of fixes,
and pulled two of them from the TI maintainer Kevin Hilman. Then
waited for them to at least hit linux-next once or twice."
GPIO fixes for v3.5:
- Invalid context restore on bank 0 for OMAP driver in runtime
suspend/resume cycle
- Check for NULL platform data in sta-2x11 driver
- Constrain selection of the V1 MSM GPIO driver to applicable platforms
(Kconfig issue)
- Make sure the correct output value is set in the wm8994 driver
- Export devm_gpio_request_one() so it can be used in modules.
Apparently some in-kernel modules can be configured to use this
leading to breakage.
- Check that the GPIO is valid in the lantiq driver
- Fix the flag bits introduced for v3.5, so they don't overlap
- Fix a device tree intialization bug for imx21-compatible devices
- Carry over the OF node to the TPS65910 GPIO chip struct
* tag 'fixes-for-v3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: tps65910: initialize of_node of gpio_chip
gpio/mxc: make irqs work for fsl,imx21-gpio devices
gpio: fix bits conflict for gpio flags
mips: pci-lantiq: Fix check for valid gpio
gpio: export devm_gpio_request_one
gpiolib: wm8994: Pay attention to the value set when enabling as output
gpio/msm_v1: CONFIG_GPIO_MSM_V1 is only available on three SoCs
gpio-sta2x11: don't use pdata if null
gpio/omap: fix invalid context restore of gpio bank-0
gpio/omap: fix irq loss while in idle with debounce on
Quite a few ASUS computers experience a nasty problem, related to the
EHCI controllers, when going into system suspend. It was observed
that the problem didn't occur if the controllers were not put into the
D3 power state before starting the suspend, and commit
151b61284776be2d6f02d48c23c3625678960b97 (USB: EHCI: fix crash during
suspend on ASUS computers) was created to do this.
It turned out this approach messed up other computers that didn't have
the problem -- it prevented USB wakeup from working. Consequently
commit c2fb8a3fa25513de8fedb38509b1f15a5bbee47b (USB: add
NO_D3_DURING_SLEEP flag and revert 151b61284776be2) was merged; it
reverted the earlier commit and added a whitelist of known good board
names.
Now we know the actual cause of the problem. Thanks to AceLan Kao for
tracking it down.
According to him, an engineer at ASUS explained that some of their
BIOSes contain a bug that was added in an attempt to work around a
problem in early versions of Windows. When the computer goes into S3
suspend, the BIOS tries to verify that the EHCI controllers were first
quiesced by the OS. Nothing's wrong with this, but the BIOS does it
by checking that the PCI COMMAND registers contain 0 without checking
the controllers' power state. If the register isn't 0, the BIOS
assumes the controller needs to be quiesced and tries to do so. This
involves making various MMIO accesses to the controller, which don't
work very well if the controller is already in D3. The end result is
a system hang or memory corruption.
Since the value in the PCI COMMAND register doesn't matter once the
controller has been suspended, and since the value will be restored
anyway when the controller is resumed, we can work around the BIOS bug
simply by setting the register to 0 during system suspend. This patch
(as1590) does so and also reverts the second commit mentioned above,
which is now unnecessary.
In theory we could do this for every PCI device. However to avoid
introducing new problems, the patch restricts itself to EHCI host
controllers.
Finally the affected systems can suspend with USB wakeup working
properly.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=37632
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=42728
Based-on-patch-by: AceLan Kao <acelan.kao@canonical.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Dâniel Fraga <fragabr@gmail.com>
Tested-by: Javier Marcet <jmarcet@gmail.com>
Tested-by: Andrey Rahmatullin <wrar@wrar.name>
Tested-by: Oleksij Rempel <bug-track@fisher-privat.net>
Tested-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Cc: stable <stable@vger.kernel.org>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/rpmsg
Pull rpmsg fixes from Ohad Ben-Cohen:
"Fixing two (somewhat rare) endpoint-related race issues, both of which
were reported by Fernando Guzman Lugo."
* tag 'rpmsg-3.5-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/rpmsg:
rpmsg: make sure inflight messages don't invoke just-removed callbacks
rpmsg: avoid premature deallocation of endpoints
The documentation didn't actually mention how to enable no_new_privs.
This also adds a note about possible interactions between
no_new_privs and LSMs (i.e. why teaching systemd to set no_new_privs
is not necessarily a good idea), and it references the new docs
from include/linux/prctl.h.
Suggested-by: Rob Landley <rob@landley.net>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
Pull ocfs2 fixes from Joel Becker.
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
aio: make kiocb->private NUll in init_sync_kiocb()
ocfs2: Fix bogus error message from ocfs2_global_read_info
ocfs2: for SEEK_DATA/SEEK_HOLE, return internal error unchanged if ocfs2_get_clusters_nocache() or ocfs2_inode_lock() call failed.
ocfs2: use spinlock irqsave for downconvert lock.patch
ocfs2: Misplaced parens in unlikley
ocfs2: clear unaligned io flag when dio fails
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input layer fixes from Dmitry Torokhov:
"Two fixes for regressions in Wacom driver and fixes for drivers using
threaded IRQ framework without specifying IRQF_ONESHOT."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: request threaded-only IRQs with IRQF_ONESHOT
Input: wacom - don't retrieve touch_max when it is predefined
Input: wacom - fix retrieving touch_max bug
Input: fix input.h kernel-doc warning
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/urgent
Pull low probability CONFIG_RCU_BOOST=y deadlock fix from Paul E. McKenney.
Pull KVM fix from Marcelo Tosatti:
"Memory leak and oops on the x86 mmu code, and sanitization of the
KVM_IRQFD ioctl."
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: MMU: fix shrinking page from the empty mmu
KVM: fix fault page leak
KVM: Sanitize KVM_IRQFD flags
KVM: Add missing KVM_IRQFD API documentation
KVM: Pass kvm_irqfd to functions
Thanks to Charles Wang for spotting the defects in the current code:
- If we go idle during the sample window -- after sampling, we get a
negative bias because we can negate our own sample.
- If we wake up during the sample window we get a positive bias
because we push the sample to a known active period.
So rewrite the entire nohz load-avg muck once again, now adding
copious documentation to the code.
Reported-and-tested-by: Doug Smythies <dsmythies@telus.net>
Reported-and-tested-by: Charles Wang <muming.wq@gmail.com>
Cc: stable@kernel.org
Link: http://lkml.kernel.org/r/1340373782.18025.74.camel@twins
[ minor edits ]
The bit 2 and 3 in GPIO flag are allocated for the
flag OPEN_DRAIN/OPEN_SOURCE. These bits are reused
for the flag EXPORT/EXPORT_CHANGEABLE and so creating
conflict.
Fix this conflict by assigning bit 4 and 5 for the
flag EXPORT/EXPORT_CHANGEABLE.
Ocfs2 uses kiocb.*private as a flag of unsigned long size. In
commit a11f7e6 ocfs2: serialize unaligned aio, the unaligned
io flag is involved in it to serialize the unaligned aio. As
*private is not initialized in init_sync_kiocb() of do_sync_write(),
this unaligned io flag may be unexpectly set in an aligned dio.
And this will cause OCFS2_I(inode)->ip_unaligned_aio decreased
to -1 in ocfs2_dio_end_io(), thus the following unaligned dio
will hang forever at ocfs2_aiodio_wait() in ocfs2_file_aio_write().
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Joel Becker <jlbec@evilplan.org>
When inbound messages arrive, rpmsg core looks up their associated
endpoint (by destination address) and then invokes their callback.
We've made sure that endpoints will never be de-allocated after they
were found by rpmsg core, but we also need to protect against the
(rare) scenario where the rpmsg driver was just removed, and its
callback function isn't available anymore.
This is achieved by introducing a callback mutex, which must be taken
before the callback is invoked, and, obviously, before it is removed.
Reported-by: Fernando Guzman Lugo <fernando.lugo@ti.com>
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
When an inbound message arrives, the rpmsg core looks up its
associated endpoint and invokes the registered callback.
If a message arrives while its endpoint is being removed (because
the rpmsg driver was removed, or a recovery of a remote processor
has kicked in) we must ensure atomicity, i.e.:
- Either the ept is removed before it is found
or
- The ept is found but will not be freed until the callback returns
This is achieved by maintaining a per-ept reference count, which,
when drops to zero, will trigger deallocation of the ept.
With this in hand, it is now forbidden to directly deallocate
epts once they have been added to the endpoints idr.
Pull block bits from Jens Axboe:
"As vacation is coming up, thought I'd better get rid of my pending
changes in my for-linus branch for this iteration. It contains:
- Two patches for mtip32xx. Killing a non-compliant sysfs interface
and moving it to debugfs, where it belongs.
- A few patches from Asias. Two legit bug fixes, and one killing an
interface that is no longer in use.
- A patch from Jan, making the annoying partition ioctl warning a bit
less annoying, by restricting it to !CAP_SYS_RAWIO only.
- Three bug fixes for drbd from Lars Ellenberg.
- A fix for an old regression for umem, it hasn't really worked since
the plugging scheme was changed in 3.0.
- A few fixes from Tejun.
- A splice fix from Eric Dumazet, fixing an issue with pipe
resizing."
* 'for-linus' of git://git.kernel.dk/linux-block:
scsi: Silence unnecessary warnings about ioctl to partition
block: Drop dead function blk_abort_queue()
block: Mitigate lock unbalance caused by lock switching
block: Avoid missed wakeup in request waitqueue
umem: fix up unplugging
splice: fix racy pipe->buffers uses
drbd: fix null pointer dereference with on-congestion policy when diskless
drbd: fix list corruption by failing but already aborted reads
drbd: fix access of unallocated pages and kernel panic
xen/blkfront: Add WARN to deal with misbehaving backends.
blkcg: drop local variable @q from blkg_destroy()
mtip32xx: Create debugfs entries for troubleshooting
mtip32xx: Remove 'registers' and 'flags' from sysfs
blkcg: fix blkg_alloc() failure path
block: blkcg_policy_cfq shouldn't be used if !CONFIG_CFQ_GROUP_IOSCHED
block: fix return value on cfq_init() failure
mtip32xx: Remove version.h header file inclusion
xen/blkback: Copy id field when doing BLKIF_DISCARD.
Prune this down to just the struct kvm_irqfd so we can avoid
changing function definition for every flag or field we use.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
This reverts commit 616c310e83b872024271c915c1b9ab505b9efad9.
(Move PREEMPT_RCU preemption to switch_to() invocation).
Testing by Sasha Levin <levinsasha928@gmail.com> showed that this
can result in deadlock due to invoking the scheduler when one of
the runqueue locks is held. Because this commit was simply a
performance optimization, revert it.
Tested-by: Sasha Levin <levinsasha928@gmail.com>
Fix kernel-doc warning. This struct member was removed in commit
875682648b89 ("irq: Remove irq_chip->release()") so remove its
associated kernel-doc entry also.
Warning(include/linux/irq.h:338): Excess struct/union/enum/typedef member 'release' description in 'irq_chip'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Richard Weinberger <richard@nod.at>
Pull networking update from David Miller:
1) Pairing and deadlock fixes in bluetooth from Johan Hedberg.
2) Add device IDs for AR3011 and AR3012 bluetooth chips. From
Giancarlo Formicuccia and Marek Vasut.
3) Fix wireless regulatory deadlock, from Eliad Peller.
4) Fix full TX ring panic in bnx2x driver, from Eric Dumazet.
5) Revert the two commits that added skb_orphan_try(), it causes
erratic bonding behavior with UDP clients and the gains it used to
give are mostly no longer happening due to how BQL works. From Eric
Dumazet.
6) It took two tries, but Thomas Graf fixed a problem wherein we
registered ipv6 routing procfs files before their backend data were
initialized properly.
7) Fix max GSO size setting in be2net, from Sarveshwar Bandi.
8) PHY device id mask is wrong for KSZ9021 and KS8001 chips, fix from
Jason Wang.
9) Fix use of stale SKB data pointer after skb_linearize() call in
batman-adv, from Antonio Quartulli.
10) Fix memory leak in IXGBE due to missing __GFP_COMP, from Alexander
Duyck.
11) Fix probing of Gobi devices in qmi_wwan usbnet driver, from Bjørn
Mork.
12) Fix suspend/resume and open failure handling in usbnet from Ming
Lei.
13) Attempt to fix device r8169 hangs for certain chips, from Francois
Romieu.
14) Fix advancement of RX dirty pointer in some situations in sh_eth
driver, from Yoshihiro Shimoda.
15) Attempt to fix restart of IPV6 routing table dumps when there is an
intervening table update. From Eric Dumazet.
16) Respect security_inet_conn_request() return value in ipv6 TCP. From
Neal Cardwell.
17) Add another iPAD device ID to ipheth driver, from Davide Gerhard.
18) Fix access to freed SKB in l2tp_eth_dev_xmit(), and fix l2tp lockdep
splats, from Eric Dumazet.
19) Make sure all bridge devices, regardless of whether they were
created via netlink or ioctls, have their rtnetlink ops hooked up.
From Thomas Graf and Stephen Hemminger.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (81 commits)
9p: fix min_t() casting in p9pdu_vwritef()
can: flexcan: use be32_to_cpup to handle the value of dt entry
xen/netfront: teardown the device before unregistering it.
bridge: Assign rtnl_link_ops to bridge devices created via ioctl (v2)
vhost: use USER_DS in vhost_worker thread
ixgbe: Do not pad FCoE frames as this can cause issues with FCoE DDP
net: l2tp_eth: use LLTX to avoid LOCKDEP splats
mac802154: add missed braces
net: l2tp_eth: fix l2tp_eth_dev_xmit race
net/mlx4_en: Release QP range in free_resources
net/mlx4: Use single completion vector after NOP failure
net/mlx4_en: Set correct port parameters during device initialization
ipheth: add support for iPad
caif-hsi: Add missing return in error path
caif-hsi: Bugfix - Piggyback'ed embedded CAIF frame lost
caif: Clear shutdown mask to zero at reconnect.
tcp: heed result of security_inet_conn_request() in tcp_v6_conn_request()
ipv6: fib: fix fib dump restart
batman-adv: fix race condition in TT full-table replacement
batman-adv: only drop packets of known wifi clients
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab.
Trivial conflict due to new USB HID ID's being added next to each other
(Baanto vs Axentia).
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (44 commits)
[media] smia: Fix compile failures
[media] Fix VIDIOC_DQEVENT docbook entry
[media] s5p-fimc: Fix control creation function
[media] s5p-mfc: Fix checkpatch error in s5p_mfc_shm.h file
[media] s5p-mfc: Fix setting controls
[media] v4l/s5p-mfc: added image size align in VIDIOC_TRY_FMT
[media] v4l/s5p-mfc: corrected encoder v4l control definitions
[media] v4l: mem2mem_testdev: Fix race conditions in driver
[media] s5p-mfc: Bug fix of timestamp/timecode copy mechanism
[media] cxd2820r: Fix an incorrect modulation type bitmask
[media] em28xx: Show a warning if the board does not support remote controls
[media] em28xx: Add remote control support for Terratec's Cinergy HTC Stick HD
[media] USB: Staging: media: lirc: initialize spinlocks before usage
[media] Revert "[media] media: mx2_camera: Fix mbus format handling"
[media] bw-qcam: driver and pixfmt documentation fixes
[media] cx88: fix firmware load on big-endian systems
[media] cx18: support big-endian systems
[media] ivtv: fix support for big-endian systems
[media] tuner-core: return the frequency range of the correct tuner
[media] v4l2-dev.c: fix g_parm regression in determine_valid_ioctls()
Pull drm fixes from Dave Airlie:
"Nothing major in here, one radeon SI fix for tiling, and one uninit
var fix, two minor header file fixes."
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm: drop comment about this header being autogenerated.
drm/edid: don't return stack garbage from supports_rb
vga_switcheroo: Add include guard
drm/radeon: SI tiling fixes for display
