"struct dirent" is a kernel type here, but is a **different type** in
userspace! This means both the structure and the IOCTL number is wrong!
So, this adds new "struct __fat_dirent" to generate correct IOCTL number.
And kernel stuff moves to under __KERNEL__.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
j_commit_lock is a semaphore but uses it as if it were a mutex. This patch
converts it to a mutex.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Edward Shishkin <edward.shishkin@gmail.com>
j_flush_sem is a semaphore but uses it as if it were a mutex. This patch
[akpm@linux-foundation.org: fix mutex_trylock retval treatment]
j_lock is a semaphore but uses it as if it were a mutex. This patch converts
it to a mutex.
While fixing CONFIG_ leakages to the userspace kernel headers I ran into
CODA_FS_OLD_API.
After five years, are there still people using the old API left?
Especially considering that you have to choose at compile time which API
to support in the kernel (and distributions tend to offer the new API for
some time).
Jan: "The old API can definitely go. Around the time the new
interface went in there were some non-Coda userspace file system
implementations that took a while longer to convert to the new API,
but by now they all switched to the new interface or in some cases
to a FUSE-based solution."
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Jan Harkes <jaharkes@cs.cmu.edu>
If the orphan node list includes valid, untruncatable nodes with nlink > 0
the ext3_orphan_cleanup loop which attempts to delete them will not do so,
causing it to loop forever. Fix by checking for such nodes in the
ext3_orphan_get function.
This patch fixes the second case (image hdb.20000009.softlockup.gz)
reported in http://bugzilla.kernel.org/show_bug.cgi?id=10882.
[akpm@linux-foundation.org: printk warning fix]
Signed-off-by: Duane Griffin <duaneg@dghda.com>
Cc: <linux-ext4@vger.kernel.org>
Fix typo in Hurd part of include/linux/ext2_fs.h
The ';' here is redundant or can even pose problem. This is actually not
used by the Linux kernel, but it is exposed in GNU/Hurd.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
This adds a driver supporting a family of I2C port expanders from Maxim,
which includes the MAX7319 and MAX7320-7327 chips.
[dbrownell@users.sourceforge.net: minor fixes]
Signed-off-by: Jack Ren <jack.ren@marvell.com>
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Teach the mcp23s08 driver about a curious feature of these chips: up to
four of them can share the same chipselect, with the SPI signals wired in
parallel, by matching two bits in the first protocol byte against two
address lines on the chip.
This is handled by three software changes:
* Platform data now holds an array of per-chip structs, not
just one chip's address and pullup configuration.
* Probe() and remove() now use another level of structure,
wrapping an instance of the original structure for each
mcp23s08 chip sharing that chipselect.
* The HAEN bit is set, so that the hardware address bits can no
longer be ignored (boot firmware may not have enabled them).
The "one struct per chip" preserves the guts of the current code,
but platform_data will need minor changes.
OLD:
/* incorrect "slave" ID may not have mattered */
.slave = 3,
.pullups = BIT(3) | BIT(1) | BIT(0),
NEW:
/* slave address _must_ match chip's wiring */
.chip[3] = {
.is_present = true,
There's no change in how things _behave_ for spi_device nodes with a
single mcp23s08 chip. New multi-chip configurations assign GPIOs in
sequence, without holes. The spi_device just resembles a bigger
controller, but internally it has multiple gpio_chip instances.
This adds a simple sysfs interface for GPIOs.
/sys/class/gpio
/export ... asks the kernel to export a GPIO to userspace
/unexport ... to return a GPIO to the kernel
/gpioN ... for each exported GPIO #N
/value ... always readable, writes fail for input GPIOs
/direction ... r/w as: in, out (default low); write high, low
/gpiochipN ... for each gpiochip; #N is its first GPIO
/base ... (r/o) same as N
/label ... (r/o) descriptive, not necessarily unique
/ngpio ... (r/o) number of GPIOs; numbered N .. N+(ngpio - 1)
GPIOs claimed by kernel code may be exported by its owner using a new
gpio_export() call, which should be most useful for driver debugging.
Such exports may optionally be done without a "direction" attribute.
Userspace may ask to take over a GPIO by writing to a sysfs control file,
helping to cope with incomplete board support or other "one-off"
requirements that don't merit full kernel support:
echo 23 > /sys/class/gpio/export
... will gpio_request(23, "sysfs") and gpio_export(23);
use /sys/class/gpio/gpio-23/direction to (re)configure it,
when that GPIO can be used as both input and output.
echo 23 > /sys/class/gpio/unexport
... will gpio_free(23), when it was exported as above
The extra D-space footprint is a few hundred bytes, except for the sysfs
resources associated with each exported GPIO. The additional I-space
footprint is about two thirds of the current size of gpiolib (!). Since
no /dev node creation is involved, no "udev" support is needed.
Related changes:
* This adds a device pointer to "struct gpio_chip". When GPIO
providers initialize that, sysfs gpio class devices become children of
that device instead of being "virtual" devices.
* The (few) gpio_chip providers which have such a device node have
been updated.
* Some gpio_chip drivers also needed to update their module "owner"
field ... for which missing kerneldoc was added.
* Some gpio_chips don't support input GPIOs. Those GPIOs are now
flagged appropriately when the chip is registered.
Based on previous patches, and discussion both on and off LKML.
A Documentation/ABI/testing/sysfs-gpio update is ready to submit once this
merges to mainline.
[akpm@linux-foundation.org: a few maintenance build fixes]
Cc: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de>
Cc: Greg KH <greg@kroah.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Currently list of kretprobe instances are stored in kretprobe object (as
used_instances,free_instances) and in kretprobe hash table. We have one
global kretprobe lock to serialise the access to these lists. This causes
only one kretprobe handler to execute at a time. Hence affects system
performance, particularly on SMP systems and when return probe is set on
lot of functions (like on all systemcalls).
Solution proposed here gives fine-grain locks that performs better on SMP
system compared to present kretprobe implementation.
Solution:
1) Instead of having one global lock to protect kretprobe instances
present in kretprobe object and kretprobe hash table. We will have
two locks, one lock for protecting kretprobe hash table and another
lock for kretporbe object.
2) We hold lock present in kretprobe object while we modify kretprobe
instance in kretprobe object and we hold per-hash-list lock while
modifying kretprobe instances present in that hash list. To prevent
deadlock, we never grab a per-hash-list lock while holding a kretprobe
lock.
3) We can remove used_instances from struct kretprobe, as we can
track used instances of kretprobe instances using kretprobe hash
table.
Time duration for kernel compilation ("make -j 8") on a 8-way ppc64 system
with return probes set on all systemcalls looks like this.
cacheline non-cacheline Un-patched kernel
aligned patch aligned patch
real 9m46.784s 9m54.412s 10m2.450s
user 40m5.715s 40m7.142s 40m4.273s
sys 2m57.754s 2m58.583s 3m17.430s
Time duration for kernel compilation ("make -j 8) on the same system, when
kernel is not probed.
real 9m26.389s
user 40m8.775s
sys 2m7.283s
Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com>
Signed-off-by: Jim Keniston <jkenisto@us.ibm.com>
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: Masami Hiramatsu <mhiramat@redhat.com>
Add support for adding the GPIO based I2C resources.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Cc: Arnaud Patard <apatard@mandriva.com>
Cc: David Brownell <david-b@pacbell.net>
The SM501 PCI card requires a dyanmic gpio allocation as the number of
cards is not known at compile time. Fixup the platform data and
registration to deal with this.
Acked-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
Add support for exporting the GPIOs on the SM501 via gpiolib.
Add callback to get or set the power control if the device has the sleep
connected to some form of GPIO.
All ratelimit user use same jiffies and burst params, so some messages
(callbacks) will be lost.
For example:
a call printk_ratelimit(5 * HZ, 1)
b call printk_ratelimit(5 * HZ, 1) before the 5*HZ timeout of a, then b will
will be supressed.
- rewrite __ratelimit, and use a ratelimit_state as parameter. Thanks for
hints from andrew.
- Add WARN_ON_RATELIMIT, update rcupreempt.h
- remove __printk_ratelimit
- use __ratelimit in net_ratelimit
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Cc: Dave Young <hidave.darkstar@gmail.com>
Use the %p format string which already accounts for the padding you need
with a pointer type on a particular architecture.
Also replace the macro with a static inline function to match the rest of
the file.
Cc: Arjan van de Ven <arjan@infradead.org>
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
We want to use WARN() as a variant of WARN_ON(), however a few drivers are
using WARN() internally. This patch renames these to WARNING() to avoid the
namespace clash. A few cases were defining but not using the thing, for those
cases I just deleted the definition.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Greg KH <greg@kroah.com>
Cc: Karsten Keil <kkeil@suse.de>
Remove apparently obsolete content from init.h referring to gcc 2.9x
and to "no_module_init".
Presently call_usermodehelper_setup() uses GFP_ATOMIC. but it can return
NULL _very_ easily.
GFP_ATOMIC is needed only when we can't sleep. and, GFP_KERNEL is robust
and better.
thus, I add gfp_mask argument to call_usermodehelper_setup().
So, its callers pass the gfp_t as below:
call_usermodehelper() and call_usermodehelper_keys():
depend on 'wait' argument.
call_usermodehelper_pipe():
always GFP_KERNEL because always run under process context.
orderly_poweroff():
pass to GFP_ATOMIC because may run under interrupt context.
Cc: "Paul Menage" <menage@google.com>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: Adrian Bunk <bunk@kernel.org>
Build kernel/profile.o only if CONFIG_PROFILING is enabled.
This makes CONFIG_PROFILING=n kernels smaller.
As a bonus, some profile_tick() calls and one branch from schedule() are
now eliminated with CONFIG_PROFILING=n (but I doubt these are
measurable effects).
This patch changes the effects of CONFIG_PROFILING=n, but I don't think
having more than two choices would be the better choice.
This patch also adds the name of the first parameter to the prototypes
of profile_{hits,tick}() since I anyway had to add them for the dummy
functions.
Remove the conditional surrounding the definition of list_add() from list.h
since, if you define CONFIG_DEBUG_LIST, the definition you will subsequently
pick up from lib/list_debug.c will be absolutely identical, at which point you
can remove that redundant definition from list_debug.c as well.
Cc: Dave Jones <davej@codemonkey.org.uk>
This header file has been unused for quite some time, and the
corresponding source files appear to have been removed back in commit
99eb8a550dbccc0e1f6c7e866fe421810e0585f6 ("Remove the arm26 port")
Cc: Adrian Bunk <bunk@stusta.de>
Cc: Ian Molton <spyro@f2s.com>
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
There haave been several areas in the kernel where an int has been used for
flags in local_irq_save() and friends instead of a long. This can cause some
hard to debug problems on some architectures.
This patch adds a typecheck inside the irqsave and restore functions to flag
these cases.
[akpm@linux-foundation.org: build fix]
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Needed to fix up a recursive include snafu in
locking-add-typecheck-on-irqsave-and-friends-for-correct-flags.patch
Changeset 7fa897b91a3ea0f16c2873b869d7a0eef05acff4 ("ide: trivial sparse
annotations") created an IDE bootup regression on big-endian systems.
In drivers/ide/ide-iops.c, function ide_fixstring() we now have the
loop:
for (p = end ; p != s;)
be16_to_cpus((u16 *)(p -= 2));
which will never terminate on big-endian because in such
a configuration be16_to_cpus() evaluates to "do { } while (0)"
Therefore, always evaluate the arguments to nop endian transformation
operations.
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
virtio: Add transport feature handling stub for virtio_ring.
virtio: Rename set_features to finalize_features
virtio: Formally reserve bits 28-31 to be 'transport' features.
s390: use virtio_console for KVM on s390
virtio: console as a config option
virtio_console: use virtqueue notification for hvc_console
hvc_console: rework setup to replace irq functions with callbacks
virtio_blk: check for hardsector size from host
virtio: Use bus_type probe and remove methods
virtio: don't always force a notification when ring is full
virtio: clarify that ABI is usable by any implementations
virtio: Recycle unused recv buffer pages for large skbs in net driver
virtio net: Allow receiving SG packets
virtio net: Add ethtool ops for SG/GSO
virtio: fix virtio_net xmit of freed skb bug
Obvious misc patch been in my queue (& linux-next) for over a cycle.
To prepare for virtio_ring transport feature bits, hook in a call in
all the users to manipulate them. This currently just clears all the
bits, since it doesn't understand any features.
Rather than explicitly handing the features to the lower-level, we just
hand the virtio_device and have it set the features. This make it clear
that it has the chance to manipulate the features of the device at this
point (and that all feature negotiation is already done).
We assign feature bits as required, but it makes sense to reserve some
for the particular transport, rather than the particular device.
Currently virtio_blk assumes a 512 byte hard sector size. This can cause
trouble / performance issues if the backing has a different block size
(like a file on an ext3 file system formatted with 4k block size or a dasd).
Lets add a feature flag that tells the guest to use a different hard sector
size than 512 byte.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
We want others to implement and use virtio, so it makes sense to BSD
license the non-__KERNEL__ parts of the headers to make this crystal
clear.
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Mark McLoughlin <markmc@redhat.com>
Acked-by: Ryan Harper <ryanh@us.ibm.com>
Acked-by: Eric Van Hensbergen <ericvh@gmail.com>
Acked-by: Anthony Liguori <aliguori@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (76 commits)
ide: use proper printk() KERN_* levels in ide-probe.c
ide: fix for EATA SCSI HBA in ATA emulating mode
ide: remove stale comments from drivers/ide/Makefile
ide: enable local IRQs in all handlers for TASKFILE_NO_DATA data phase
ide-scsi: remove kmalloced struct request
ht6560b: remove old history
ht6560b: update email address
ide-cd: fix oops when using growisofs
gayle: release resources on ide_host_add() failure
palm_bk3710: add UltraDMA/100 support
ide: trivial sparse annotations
ide: ide-tape.c sparse annotations and unaligned access removal
ide: drop 'name' parameter from ->init_chipset method
ide: prefix messages from IDE PCI host drivers by driver name
it821x: remove DECLARE_ITE_DEV() macro
it8213: remove DECLARE_ITE_DEV() macro
ide: include PCI device name in messages from IDE PCI host drivers
ide: remove <asm/ide.h> for some archs
ide-generic: remove ide_default_{io_base,irq}() inlines (take 3)
ide-generic: is no longer needed on ppc32
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: fixup sparse endianness warnings in proc.c
PCI PM: make more PCI PM core functionality available to drivers
PCI/DMAR: don't assume presence of RMRRs
PCI hotplug: fix error path in pci_slot's register_slot
There should be no functional changes caused by this patch.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
* Remove <linux/irq.h> include from <asm-ia64.h> (<linux/ide.h> includes
<linux/interrupt.h> which is enough).
* Remove <asm/ide.h> for alpha/blackfin/h8300/ia64/m32r/sh/x86/xtensa
(this leaves us with arm/frv/m68k/mips/mn10300/parisc/powerpc/sparc[64]).
* Now that ide_hwif_t instances are allocated dynamically
the difference between MAX_HWIFS == 2 and MAX_HWIFS == 10
is ~100 bytes (x86-32) so use MAX_HWIFS == 10 on all archs
except these ones that use MAX_HWIFS == 1.
* Define MAX_HWIFS in <linux/ide.h> instead of <asm/ide.h>.
[ Please note that avr32/cris/v850 have no <asm/ide.h>
and alpha/ia64/sh always define CONFIG_IDE_MAX_HWIFS. ]
* Add 'unsigned long host_flags' field to struct ide_host.
* Set ->host_flags in ide_host_alloc_all().
* Always set PCI dev's ->driver_data in ide_pci_init_{one,two}().
* Add ide_pci_remove() helper (the default implementation for
struct pci_driver's ->remove method).
* Add 'struct ide_host *host' field to ide_hwif_t and set it
* Add ide_device_{get,put}() helpers loosely based on SCSI's
scsi_device_{get,put}() ones.
* Convert IDE device drivers to use ide_device_{get,put}().
* Add 'struct device *dev[2]' and 'void *host_priv' fields
to struct ide_host.
* Set ->dev[] in ide_host_alloc_all()/ide_setup_pci_device[s]().
* Pass 'void *priv' argument to ide_setup_pci_device[s]()
and use it to set ->host_priv.
* Set PCI dev's ->driver_data to point to the struct ide_host
instance if PCI host driver wants to use ->host_priv.
* Rename ide_setup_pci_device[s]() to ide_pci_init_{one,two}().
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
MAINTAINERS: Remove Glenn Streiff from NetEffect entry
mlx4_core: Improve error message when not enough UAR pages are available
IB/mlx4: Add support for memory management extensions and local DMA L_Key
IB/mthca: Keep free count for MTT buddy allocator
mlx4_core: Keep free count for MTT buddy allocator
mlx4_code: Add missing FW status return code
IB/mlx4: Rename struct mlx4_lso_seg to mlx4_wqe_lso_seg
mlx4_core: Add module parameter to enable QoS support
RDMA/iwcm: Remove IB_ACCESS_LOCAL_WRITE from remote QP attributes
IPoIB: Include err code in trace message for ib_sa_path_rec_get() failures
IB/sa_query: Check if sm_ah is NULL in ib_sa_remove_one()
IB/ehca: Release mutex in error path of alloc_small_queue_page()
IB/ehca: Use default value for Local CA ACK Delay if FW returns 0
IB/ehca: Filter PATH_MIG events if QP was never armed
IB/iser: Add support for RDMA_CM_EVENT_ADDR_CHANGE event
RDMA/cma: Add RDMA_CM_EVENT_TIMEWAIT_EXIT event
RDMA/cma: Add RDMA_CM_EVENT_ADDR_CHANGE event
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
nohz: adjust tick_nohz_stop_sched_tick() call of s390 as well
nohz: prevent tick stop outside of the idle loop
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc
* 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc:
Remove __DECLARE_SEMAPHORE_GENERIC
Remove asm/semaphore.h
Remove use of asm/semaphore.h
Add missing semaphore.h includes
Remove mention of semaphores from kernel-locking
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds:
leds: Ensure led->trigger is set earlier
leds: Add support for Philips PCA955x I2C LED drivers
leds: Fix sparse warnings in leds-h1940 driver
leds: mark led_classdev.default_trigger as const
leds: fix unsigned value overflow in atmel pwm driver
leds: Add pca9532 platform data for Thecus N2100
leds: Add pca9532 led driver
This patch adds a "const" to the parser token table. I've done an
allmodconfig build to see if this produces any warnings/failures and the
patch includes a fix for the only warning that was produced.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Alexander Viro <aviro@redhat.com>
Acked-by: Evgeniy Dushistov <dushistov@mail.ru>
Currently, linux/major.h defines a GRAPHDEV_MAJOR (29) that nobody uses,
and linux/fb.h defines the real FB_MAJOR (also 29), that only fbmem.c
needs. Drop GRAPHDEV_MAJOR from major.h, move FB_MAJOR definition from
fb.h to major.h, and fix fbmem.c to use major.h's definition.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
This patch adds a platform driver using the ATMEL PWM driver to control a
backlight which requires a PWM signal and optional GPIO signal for discrete
on/off signal. It has been tested on Favr-32 board from EarthLCD.
The driver is configurable by supplying a struct with the platform data. See
the include/linux/atmel-pwm-bl.h for details.
The board code for Favr-32 will be submitted to the AVR32 kernel list.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
