commit 1c8924eb106c1ac755d5d35ce9b3ff42e89e2511 upstream.
ext4 needs to convert allocated (metadata) blocks back into blocks
reserved for delayed allocation. Add functions into quota code for
supporting such operation.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: Josh Hunt <johunt@akamai.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 6ada1fc0e1c4775de0e043e1bd3ae9d065491aa5 upstream.
An unvalidated user input is multiplied by a constant, which can result in
an undefined behaviour for large values. While this is validated later,
we should avoid triggering undefined behaviour.
[jstultz: include trivial milisecond->microsecond correction noticed
by Andy]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream.
Jay Foad reports that the address sanitizer test (asan) sometimes gets
confused by a stack pointer that ends up being outside the stack vma
that is reported by /proc/maps.
This happens due to an interaction between RLIMIT_STACK and the guard
page: when we do the guard page check, we ignore the potential error
from the stack expansion, which effectively results in a missing guard
page, since the expected stack expansion won't have been done.
And since /proc/maps explicitly ignores the guard page (commit
d7824370e263: "mm: fix up some user-visible effects of the stack guard
page"), the stack pointer ends up being outside the reported stack area.
This is the minimal patch: it just propagates the error. It also
effectively makes the guard page part of the stack limit, which in turn
measn that the actual real stack is one page less than the stack limit.
Let's see if anybody notices. We could teach acct_stack_growth() to
allow an extra page for a grow-up/grow-down stack in the rlimit test,
but I don't want to add more complexity if it isn't needed.
Reported-and-tested-by: Jay Foad <jay.foad@gmail.com>
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream.
On some ARMs the memory can be mapped pgprot_noncached() and still
be working for atomic operations. As pointed out by Colin Cross
<ccross@android.com>, in some cases you do want to use
pgprot_noncached() if the SoC supports it to see a debug printk
just before a write hanging the system.
On ARMs, the atomic operations on strongly ordered memory are
implementation defined. So let's provide an optional kernel parameter
for configuring pgprot_noncached(), and use pgprot_writecombine() by
default.
Cc: Rob Herring <robherring2@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Colin Cross <ccross@android.com>
Cc: Olof Johansson <olof@lixom.net>
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream.
- Expose the knob to user space through a proc file /proc/<pid>/setgroups
A value of "deny" means the setgroups system call is disabled in the
current processes user namespace and can not be enabled in the
future in this user namespace.
A value of "allow" means the segtoups system call is enabled.
- Descendant user namespaces inherit the value of setgroups from
their parents.
- A proc file is used (instead of a sysctl) as sysctls currently do
not allow checking the permissions at open time.
- Writing to the proc file is restricted to before the gid_map
for the user namespace is set.
This ensures that disabling setgroups at a user namespace
level will never remove the ability to call setgroups
from a process that already has that ability.
A process may opt in to the setgroups disable for itself by
creating, entering and configuring a user namespace or by calling
setns on an existing user namespace with setgroups disabled.
Processes without privileges already can not call setgroups so this
is a noop. Prodcess with privilege become processes without
privilege when entering a user namespace and as with any other path
to dropping privilege they would not have the ability to call
setgroups. So this remains within the bounds of what is possible
without a knob to disable setgroups permanently in a user namespace.
commit 273d2c67c3e179adb1e74f403d1e9a06e3f841b5 upstream.
setgroups is unique in not needing a valid mapping before it can be called,
in the case of setgroups(0, NULL) which drops all supplemental groups.
The design of the user namespace assumes that CAP_SETGID can not actually
be used until a gid mapping is established. Therefore add a helper function
to see if the user namespace gid mapping has been established and call
that function in the setgroups permission check.
This is part of the fix for CVE-2014-8989, being able to drop groups
without privilege using user namespaces.
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
commit 7ff4d90b4c24a03666f296c3d4878cd39001e81e upstream.
Today there are 3 instances of setgroups and due to an oversight their
permission checking has diverged. Add a common function so that
they may all share the same permission checking code.
This corrects the current oversight in the current permission checks
and adds a helper to avoid this in the future.
A user namespace security fix will update this new helper, shortly.
commit ccf54555da9a5e91e454b909ca6a5303c7d6b910 upstream.
The direction field is set on 7 bits, thus we need to AND it with 0111 111 mask
in order to retrieve it, that is 0x7F, not 0xCF as it is now.
Fixes: ade7ef7ba (staging:iio: Differential channel handling)
Signed-off-by: Cristina Ciocan <cristina.ciocan@intel.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit f144d1496b47e7450f41b767d0d91c724c2198bc upstream.
This can be set by quirks/drivers to be used by the architecture code
that assigns the MSI addresses.
We additionally add verification in the core MSI code that the values
assigned by the architecture do satisfy the limitation in order to fail
gracefully if they don't (ie. the arch hasn't been updated to deal with
that quirk yet).
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
[ Upstream commit 84bc88688e3f6ef843aa8803dbcd90168bb89faf ]
There could be a signed overflow in the following code.
The expression, (32-logmask) is comprised between 0 and 31 included.
It may be equal to 31.
In such a case the left shift will produce a signed integer overflow.
According to the C99 Standard, this is an undefined behavior.
A simple fix is to replace the signed int 1 with the unsigned int 1U.
Signed-off-by: Vincent BENAYOUN <vincent.benayoun@trust-in-soft.com>
commit 4942642080ea82d99ab5b653abb9a12b7ba31f4a upstream.
Commit 3812c8c8f395 ("mm: memcg: do not trap chargers with full
callstack on OOM") assumed that only a few places that can trigger a
memcg OOM situation do not return VM_FAULT_OOM, like optional page cache
readahead. But there are many more and it's impractical to annotate
them all.
First of all, we don't want to invoke the OOM killer when the failed
allocation is gracefully handled, so defer the actual kill to the end of
the fault handling as well. This simplifies the code quite a bit for
added bonus.
Second, since a failed allocation might not be the abrupt end of the
fault, the memcg OOM handler needs to be re-entrant until the fault
finishes for subsequent allocation attempts. If an allocation is
attempted after the task already OOMed, allow it to bypass the limit so
that it can quickly finish the fault and invoke the OOM killer.
Reported-by: azurIt <azurit@pobox.sk>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
commit 3812c8c8f3953921ef18544110dafc3505c1ac62 upstream.
The memcg OOM handling is incredibly fragile and can deadlock. When a
task fails to charge memory, it invokes the OOM killer and loops right
there in the charge code until it succeeds. Comparably, any other task
that enters the charge path at this point will go to a waitqueue right
then and there and sleep until the OOM situation is resolved. The problem
is that these tasks may hold filesystem locks and the mmap_sem; locks that
the selected OOM victim may need to exit.
For example, in one reported case, the task invoking the OOM killer was
about to charge a page cache page during a write(), which holds the
i_mutex. The OOM killer selected a task that was just entering truncate()
and trying to acquire the i_mutex:
OOM invoking task:
mem_cgroup_handle_oom+0x241/0x3b0
mem_cgroup_cache_charge+0xbe/0xe0
add_to_page_cache_locked+0x4c/0x140
add_to_page_cache_lru+0x22/0x50
grab_cache_page_write_begin+0x8b/0xe0
ext3_write_begin+0x88/0x270
generic_file_buffered_write+0x116/0x290
__generic_file_aio_write+0x27c/0x480
generic_file_aio_write+0x76/0xf0 # takes ->i_mutex
do_sync_write+0xea/0x130
vfs_write+0xf3/0x1f0
sys_write+0x51/0x90
system_call_fastpath+0x18/0x1d
OOM kill victim:
do_truncate+0x58/0xa0 # takes i_mutex
do_last+0x250/0xa30
path_openat+0xd7/0x440
do_filp_open+0x49/0xa0
do_sys_open+0x106/0x240
sys_open+0x20/0x30
The OOM handling task will retry the charge indefinitely while the OOM
killed task is not releasing any resources.
A similar scenario can happen when the kernel OOM killer for a memcg is
disabled and a userspace task is in charge of resolving OOM situations.
In this case, ALL tasks that enter the OOM path will be made to sleep on
the OOM waitqueue and wait for userspace to free resources or increase
the group's limit. But a userspace OOM handler is prone to deadlock
itself on the locks held by the waiting tasks. For example one of the
sleeping tasks may be stuck in a brk() call with the mmap_sem held for
writing but the userspace handler, in order to pick an optimal victim,
may need to read files from /proc/<pid>, which tries to acquire the same
mmap_sem for reading and deadlocks.
This patch changes the way tasks behave after detecting a memcg OOM and
makes sure nobody loops or sleeps with locks held:
1. When OOMing in a user fault, invoke the OOM killer and restart the
fault instead of looping on the charge attempt. This way, the OOM
victim can not get stuck on locks the looping task may hold.
2. When OOMing in a user fault but somebody else is handling it
(either the kernel OOM killer or a userspace handler), don't go to
sleep in the charge context. Instead, remember the OOMing memcg in
the task struct and then fully unwind the page fault stack with
-ENOMEM. pagefault_out_of_memory() will then call back into the
memcg code to check if the -ENOMEM came from the memcg, and then
either put the task to sleep on the memcg's OOM waitqueue or just
restart the fault. The OOM victim can no longer get stuck on any
lock a sleeping task may hold.
Debugged by Michal Hocko.
Acked-by: Michal Hocko <mhocko@suse.cz>
commit 519e52473ebe9db5cdef44670d5a97f1fd53d721 upstream.
System calls and kernel faults (uaccess, gup) can handle an out of memory
situation gracefully and just return -ENOMEM.
Enable the memcg OOM killer only for user faults, where it's really the
only option available.
Cc: azurIt <azurit@pobox.sk>
commit 759496ba6407c6994d6a5ce3a5e74937d7816208 upstream.
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
user-triggered faults.
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 96a2adbc6f501996418da9f7afe39bf0e4d006a9 upstream.
kernel/time/jiffies.c provides a default clocksource_default_clock()
definition explicitly marked "weak". arch/s390 provides its own definition
intended to override the default, but the "weak" attribute on the
declaration applied to the s390 definition as well, so the linker chose one
based on link order (see 10629d711ed7 ("PCI: Remove __weak annotation from
pcibios_get_phb_of_node decl")).
Remove the "weak" attribute from the clocksource_default_clock()
declaration so we always prefer a non-weak definition over the weak one,
independent of link order.
Fixes: f1b82746c1e9 ("clocksource: Cleanup clocksource selection")
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: John Stultz <john.stultz@linaro.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
CC: Daniel Lezcano <daniel.lezcano@linaro.org>
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 107bcc6d566cb40184068d888637f9aefe6252dd upstream.
kernel/debug/debug_core.c provides a default kgdb_arch_pc() definition
explicitly marked "weak". Several architectures provide their own
definitions intended to override the default, but the "weak" attribute on
the declaration applied to the arch definitions as well, so the linker
chose one based on link order (see 10629d711ed7 ("PCI: Remove __weak
annotation from pcibios_get_phb_of_node decl")).
Remove the "weak" attribute from the declaration so we always prefer a
non-weak definition over the weak one, independent of link order.
Fixes: 688b744d8bc8 ("kgdb: fix signedness mixmatches, add statics, add declaration to header")
Tested-by: Vineet Gupta <vgupta@synopsys.com> # for ARC build
Reviewed-by: Harvey Harrison <harvey.harrison@gmail.com>
commit 8c393f9a721c30a030049a680e1bf896669bb279 upstream.
For pNFS direct writes, layout driver may dynamically allocate ds_cinfo.buckets.
So we need to take care to free them when freeing dreq.
Ideally this needs to be done inside layout driver where ds_cinfo.buckets
are allocated. But buckets are attached to dreq and reused across LD IO iterations.
So I feel it's OK to free them in the generic layer.
Signed-off-by: Peng Tao <tao.peng@primarydata.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit a87fa1d81a9fb5e9adca9820e16008c40ad09f33 upstream.
The string property read helpers will run off the end of the buffer if
it is handed a malformed string property. Rework the parsers to make
sure that doesn't happen. At the same time add new test cases to make
sure the functions behave themselves.
The original implementations of of_property_read_string_index() and
of_property_count_strings() both open-coded the same block of parsing
code, each with it's own subtly different bugs. The fix here merges
functions into a single helper and makes the original functions static
inline wrappers around the helper.
One non-bugfix aspect of this patch is the addition of a new wrapper,
of_property_read_string_array(). The new wrapper is needed by the
device_properties feature that Rafael is working on and planning to
merge for v3.19. The implementation is identical both with and without
the new static inline wrapper, so it just got left in to reduce the
churn on the header file.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Darren Hart <darren.hart@intel.com>
commit 5695be142e203167e3cb515ef86a88424f3524eb upstream.
PM freezer relies on having all tasks frozen by the time devices are
getting frozen so that no task will touch them while they are getting
frozen. But OOM killer is allowed to kill an already frozen task in
order to handle OOM situtation. In order to protect from late wake ups
OOM killer is disabled after all tasks are frozen. This, however, still
keeps a window open when a killed task didn't manage to die by the time
freeze_processes finishes.
Reduce the race window by checking all tasks after OOM killer has been
disabled. This is still not race free completely unfortunately because
oom_killer_disable cannot stop an already ongoing OOM killer so a task
might still wake up from the fridge and get killed without
freeze_processes noticing. Full synchronization of OOM and freezer is,
however, too heavy weight for this highly unlikely case.
Introduce and check oom_kills counter which gets incremented early when
the allocator enters __alloc_pages_may_oom path and only check all the
tasks if the counter changes during the freezing attempt. The counter
is updated so early to reduce the race window since allocator checked
oom_killer_disabled which is set by PM-freezing code. A false positive
will push the PM-freezer into a slow path but that is not a big deal.
Changes since v1
- push the re-check loop out of freeze_processes into
check_frozen_processes and invert the condition to make the code more
readable as per Rafael
Fixes: f660daac474c6f (oom: thaw threads if oom killed thread is frozen before deferring)
commit b8839b8c55f3fdd60dc36abcda7e0266aff7985c upstream.
The math in both blk_stack_limits() and queue_limit_alignment_offset()
assume that a block device's io_min (aka minimum_io_size) is always a
power-of-2. Fix the math such that it works for non-power-of-2 io_min.
This issue (of alignment_offset != 0) became apparent when testing
dm-thinp with a thinp blocksize that matches a RAID6 stripesize of
1280K. Commit fdfb4c8c1 ("dm thin: set minimum_io_size to pool's data
block size") unlocked the potential for alignment_offset != 0 due to
the dm-thin-pool's io_min possibly being a non-power-of-2.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit d4c5efdb97773f59a2b711754ca0953f24516739 upstream.
zatimend has reported that in his environment (3.16/gcc4.8.3/corei7)
memset() calls which clear out sensitive data in extract_{buf,entropy,
entropy_user}() in random driver are being optimized away by gcc.
Add a helper memzero_explicit() (similarly as explicit_bzero() variants)
that can be used in such cases where a variable with sensitive data is
being cleared out in the end. Other use cases might also be in crypto
code. [ I have put this into lib/string.c though, as it's always built-in
and doesn't need any dependencies then. ]
Fixes kernel bugzilla: 82041
Reported-by: zatimend@hotmail.co.uk
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit fe8c8a126806fea4465c43d62a1f9d273a572bf5 upstream.
[Only use the compiler.h portion of this patch, to get the
OPTIMIZER_HIDE_VAR() macro, which we need for other -stable patches
- gregkh]
Disabling compiler optimizations can be fragile, since a new
optimization could be added to -O0 or -Os that breaks the assumptions
the code is making.
Instead of disabling compiler optimizations, use a dummy inline assembly
(based on RELOC_HIDE) to block the problematic kinds of optimization,
while still allowing other optimizations to be applied to the code.
The dummy inline assembly is added after every OR, and has the
accumulator variable as its input and output. The compiler is forced to
assume that the dummy inline assembly could both depend on the
accumulator variable and change the accumulator variable, so it is
forced to compute the value correctly before the inline assembly, and
cannot assume anything about its value after the inline assembly.
This change should be enough to make crypto_memneq work correctly (with
data-independent timing) even if it is inlined at its call sites. That
can be done later in a followup patch.
Compile-tested on x86_64.
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.eti.br>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
commit 90a8020278c1598fafd071736a0846b38510309c upstream.
->page_mkwrite() is used by filesystems to allocate blocks under a page
which is becoming writeably mmapped in some process' address space. This
allows a filesystem to return a page fault if there is not enough space
available, user exceeds quota or similar problem happens, rather than
silently discarding data later when writepage is called.
However VFS fails to call ->page_mkwrite() in all the cases where
filesystems need it when blocksize < pagesize. For example when
blocksize = 1024, pagesize = 4096 the following is problematic:
ftruncate(fd, 0);
pwrite(fd, buf, 1024, 0);
map = mmap(NULL, 1024, PROT_WRITE, MAP_SHARED, fd, 0);
map[0] = 'a'; ----> page_mkwrite() for index 0 is called
ftruncate(fd, 10000); /* or even pwrite(fd, buf, 1, 10000) */
mremap(map, 1024, 10000, 0);
map[4095] = 'a'; ----> no page_mkwrite() called
At the moment ->page_mkwrite() is called, filesystem can allocate only
one block for the page because i_size == 1024. Otherwise it would create
blocks beyond i_size which is generally undesirable. But later at
->writepage() time, we also need to store data at offset 4095 but we
don't have block allocated for it.
This patch introduces a helper function filesystems can use to have
->page_mkwrite() called at all the necessary moments.
commit 71458cfc782eafe4b27656e078d379a34e472adf upstream.
We're missing include/linux/compiler-gcc5.h which is required now
because gcc branched off to v5 in trunk.
Just copy the relevant bits out of include/linux/compiler-gcc4.h,
no new code is added as of now.
This fixes a build error when using gcc 5.
commit 934f3072c17cc8886f4c043b47eeeb1b12f8de33 upstream.
commit 21caf2fc1931 ("mm: teach mm by current context info to not do I/O
during memory allocation") introduces PF_MEMALLOC_NOIO flag to avoid doing
I/O inside memory allocation, __GFP_IO is cleared when this flag is set,
but __GFP_FS implies __GFP_IO, it should also be cleared. Or it may still
run into I/O, like in superblock shrinker. And this will make the kernel
run into the deadlock case described in that commit.
See Dave Chinner's comment about io in superblock shrinker:
Filesystem shrinkers do indeed perform IO from the superblock shrinker and
have for years. Even clean inodes can require IO before they can be freed
- e.g. on an orphan list, need truncation of post-eof blocks, need to
wait for ordered operations to complete before it can be freed, etc.
IOWs, Ext4, btrfs and XFS all can issue and/or block on arbitrary amounts
of IO in the superblock shrinker context. XFS, in particular, has been
doing transactions and IO from the VFS inode cache shrinker since it was
first introduced....
Fix this by clearing __GFP_FS in memalloc_noio_flags(), this function has
masked all the gfp_mask that will be passed into fs for the processes
setting PF_MEMALLOC_NOIO in the direct reclaim path.
v1 thread at: https://lkml.org/lkml/2014/9/3/32
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Cc: joyce.xue <xuejiufei@huawei.com>
Cc: Ming Lei <ming.lei@canonical.com>
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
commit ddbe1fca0bcb87ca8c199ea873a456ca8a948567 upstream.
This full-speed USB device generates spurious remote wakeup event
as soon as USB_DEVICE_REMOTE_WAKEUP feature is set. As the result,
Linux can't enter system suspend and S0ix power saving modes once
this keyboard is used.
This patch tries to introduce USB_QUIRK_IGNORE_REMOTE_WAKEUP quirk.
With this quirk set, wakeup capability will be ignored during
device configure.
This patch could be back-ported to kernels as old as 2.6.39.
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit d78c9300c51d6ceed9f6d078d4e9366f259de28c upstream.
timeval_to_jiffies tried to round a timeval up to an integral number
of jiffies, but the logic for doing so was incorrect: intervals
corresponding to exactly N jiffies would become N+1. This manifested
itself particularly repeatedly stopping/starting an itimer:
setitimer(ITIMER_PROF, &val, NULL);
setitimer(ITIMER_PROF, NULL, &val);
would add a full tick to val, _even if it was exactly representable in
terms of jiffies_ (say, the result of a previous rounding.) Doing
this repeatedly would cause unbounded growth in val. So fix the math.
Here's what was wrong with the conversion: we essentially computed
(eliding seconds)
jiffies = usec * (NSEC_PER_USEC/TICK_NSEC)
by using scaling arithmetic, which took the best approximation of
NSEC_PER_USEC/TICK_NSEC with denominator of 2^USEC_JIFFIE_SC =
x/(2^USEC_JIFFIE_SC), and computed:
jiffies = (usec * x) >> USEC_JIFFIE_SC
and rounded this calculation up in the intermediate form (since we
can't necessarily exactly represent TICK_NSEC in usec.) But the
scaling arithmetic is a (very slight) *over*approximation of the true
value; that is, instead of dividing by (1 usec/ 1 jiffie), we
effectively divided by (1 usec/1 jiffie)-epsilon (rounding
down). This would normally be fine, but we want to round timeouts up,
and we did so by adding 2^USEC_JIFFIE_SC - 1 before the shift; this
would be fine if our division was exact, but dividing this by the
slightly smaller factor was equivalent to adding just _over_ 1 to the
final result (instead of just _under_ 1, as desired.)
In particular, with HZ=1000, we consistently computed that 10000 usec
was 11 jiffies; the same was true for any exact multiple of
TICK_NSEC.
We could possibly still round in the intermediate form, adding
something less than 2^USEC_JIFFIE_SC - 1, but easier still is to
convert usec->nsec, round in nanoseconds, and then convert using
time*spec*_to_jiffies. This adds one constant multiplication, and is
not observably slower in microbenchmarks on recent x86 hardware.
Tested: the following program:
int main() {
struct itimerval zero = {{0, 0}, {0, 0}};
/* Initially set to 10 ms. */
struct itimerval initial = zero;
initial.it_interval.tv_usec = 10000;
setitimer(ITIMER_PROF, &initial, NULL);
/* Save and restore several times. */
for (size_t i = 0; i < 10; ++i) {
struct itimerval prev;
setitimer(ITIMER_PROF, &zero, &prev);
/* on old kernels, this goes up by TICK_USEC every iteration */
printf("previous value: %ld %ld %ld %ld\n",
prev.it_interval.tv_sec, prev.it_interval.tv_usec,
prev.it_value.tv_sec, prev.it_value.tv_usec);
setitimer(ITIMER_PROF, &prev, NULL);
return 0;
Cc: Paul Turner <pjt@google.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Reviewed-by: Paul Turner <pjt@google.com>
Reported-by: Aaron Jacobs <jacobsa@google.com>
Signed-off-by: Andrew Hunter <ahh@google.com>
[jstultz: Tweaked to apply to 3.17-rc]
[bwh: Backported to 3.16: adjust filename]
commit 0c740d0afc3bff0a097ad03a1c8df92757516f5c upstream.
while_each_thread() and next_thread() should die, almost every lockless
usage is wrong.
1. Unless g == current, the lockless while_each_thread() is not safe.
while_each_thread(g, t) can loop forever if g exits, next_thread()
can't reach the unhashed thread in this case. Note that this can
happen even if g is the group leader, it can exec.
2. Even if while_each_thread() itself was correct, people often use
it wrongly.
It was never safe to just take rcu_read_lock() and loop unless
you verify that pid_alive(g) == T, even the first next_thread()
can point to the already freed/reused memory.
This patch adds signal_struct->thread_head and task->thread_node to
create the normal rcu-safe list with the stable head. The new
for_each_thread(g, t) helper is always safe under rcu_read_lock() as
long as this task_struct can't go away.
Note: of course it is ugly to have both task_struct->thread_node and the
old task_struct->thread_group, we will kill it later, after we change
the users of while_each_thread() to use for_each_thread().
Perhaps we can kill it even before we convert all users, we can
reimplement next_thread(t) using the new thread_head/thread_node. But
we can't do this right now because this will lead to subtle behavioural
changes. For example, do/while_each_thread() always sees at least one
task, while for_each_thread() can do nothing if the whole thread group
has died. Or thread_group_empty(), currently its semantics is not clear
unless thread_group_leader(p) and we need to audit the callers before we
can change it.
So this patch adds the new interface which has to coexist with the old
one for some time, hopefully the next changes will be more or less
straightforward and the old one will go away soon.
Reviewed-by: Sergey Dyasly <dserrg@gmail.com>
Tested-by: Sergey Dyasly <dserrg@gmail.com>
Reviewed-by: Sameer Nanda <snanda@chromium.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Mandeep Singh Baines <msb@chromium.org>
Cc: "Ma, Xindong" <xindong.ma@intel.com>
Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com>
Cc: Li Zefan <lizefan@huawei.com>
commit e09c2c295468476a239d13324ce9042ec4de05eb upstream.
create_singlethread_workqueue() is a compat interface for single
threaded workqueue which maps to ordered workqueue w/ rescuer in the
current implementation. create_singlethread_workqueue() currently
implemented by invoking alloc_workqueue() w/ appropriate parameters.
8719dceae2f9 ("workqueue: reject adjusting max_active or applying
attrs to ordered workqueues") introduced __WQ_ORDERED to protect
ordered workqueues against dynamic attribute changes which can break
ordering guarantees but forgot to apply it to
create_singlethread_workqueue(). This in itself is okay as nobody
currently uses dynamic attribute change on workqueues created with
However, 4c16bd327c ("workqueue: implement NUMA affinity for unbound
workqueues") broke singlethreaded guarantee for ordered workqueues
through allocating a separate pool_workqueue on each NUMA node by
default. A later change 8a2b75384444 ("workqueue: fix ordered
workqueues in NUMA setups") fixed it by allocating only one global
pool_workqueue if __WQ_ORDERED is set.
Combined, the __WQ_ORDERED omission in create_singlethread_workqueue()
became critical breaking its single threadedness and ordering
guarantee.
Let's make create_singlethread_workqueue() wrap
alloc_ordered_workqueue() instead so that it inherits __WQ_ORDERED and
can implicitly track future ordered_workqueue changes.
v2: I missed that __WQ_ORDERED now protects against pwq splitting
across NUMA nodes and incorrectly described the patch as a
nice-to-have fix to protect against future dynamic attribute
usages. Oleg pointed out that this is actually a critical
breakage due to 8a2b75384444 ("workqueue: fix ordered workqueues
in NUMA setups").
Reported-by: Mike Anderson <mike.anderson@us.ibm.com>
Cc: Oleg Nesterov <onestero@redhat.com>
Cc: Gustavo Luiz Duarte <gduarte@redhat.com>
Cc: Tomas Henzl <thenzl@redhat.com>
Fixes: 4c16bd327c ("workqueue: implement NUMA affinity for unbound workqueues")
commit f153566570fb9e32c2f59182883f4f66048788fb upstream.
Instead of a void function, return the trigger pointer.
Whilst not in of itself a fix, this makes the following set of
7 fixes cleaner than they would otherwise be.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
commit 3cea4c3071d4e55e9d7356efe9d0ebf92f0c2204 upstream.
Rename front_max field of struct ceph_msg to front_alloc_len to make
its purpose more clear.
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
commit 9566d6742852c527bf5af38af5cbb878dad75705 upstream.
While invesgiating the issue where in "mount --bind -oremount,ro ..."
would result in later "mount --bind -oremount,rw" succeeding even if
the mount started off locked I realized that there are several
additional mount flags that should be locked and are not.
In particular MNT_NOSUID, MNT_NODEV, MNT_NOEXEC, and the atime
flags in addition to MNT_READONLY should all be locked. These
flags are all per superblock, can all be changed with MS_BIND,
and should not be changable if set by a more privileged user.
The following additions to the current logic are added in this patch.
- nosuid may not be clearable by a less privileged user.
- nodev may not be clearable by a less privielged user.
- noexec may not be clearable by a less privileged user.
- atime flags may not be changeable by a less privileged user.
The logic with atime is that always setting atime on access is a
global policy and backup software and auditing software could break if
atime bits are not updated (when they are configured to be updated),
and serious performance degradation could result (DOS attack) if atime
updates happen when they have been explicitly disabled. Therefore an
unprivileged user should not be able to mess with the atime bits set
The additional restrictions are implemented with the addition of
MNT_LOCK_NOSUID, MNT_LOCK_NODEV, MNT_LOCK_NOEXEC, and MNT_LOCK_ATIME
mnt flags.
Taken together these changes and the fixes for MNT_LOCK_READONLY
should make it safe for an unprivileged user to create a user
namespace and to call "mount --bind -o remount,... ..." without
the danger of mount flags being changed maliciously.
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
commit a6138db815df5ee542d848318e5dae681590fccd upstream.
Kenton Varda <kenton@sandstorm.io> discovered that by remounting a
read-only bind mount read-only in a user namespace the
MNT_LOCK_READONLY bit would be cleared, allowing an unprivileged user
to the remount a read-only mount read-write.
Correct this by replacing the mask of mount flags to preserve
with a mask of mount flags that may be changed, and preserve
all others. This ensures that any future bugs with this mask and
remount will fail in an easy to detect way where new mount flags
simply won't change.
commit 7d8b6c63751cfbbe5eef81a48c22978b3407a3ad upstream.
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 3c45ddf823d679a820adddd53b52c6699c9a05ac upstream.
The current code always selects XPRT_TRANSPORT_BC_TCP for the back
channel, even when the forward channel was not TCP (eg, RDMA). When
a 4.1 mount is attempted with RDMA, the server panics in the TCP BC
code when trying to send CB_NULL.
Instead, construct the transport protocol number from the forward
channel transport or'd with XPRT_TRANSPORT_BC. Transports that do
not support bi-directional RPC will not have registered a "BC"
transport, causing create_backchannel_client() to fail immediately.
Fixes: https://bugzilla.linux-nfs.org/show_bug.cgi?id=265
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit aac74dc495456412c4130a1167ce4beb6c1f0b38 upstream.
After learning we'll need some sort of deferred printk functionality in
the timekeeping core, Peter suggested we rename the printk_sched function
so it can be reused by needed subsystems.
This only changes the function name. No logic changes.
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jan Kara <jack@suse.cz>
Cc: Jiri Bohac <jbohac@suse.cz>
commit 1a112d10f03e83fb3a2fdc4c9165865dec8a3ca6 upstream.
1871ee134b73 ("libata: support the ata host which implements a queue
depth less than 32") directly used ata_port->scsi_host->can_queue from
ata_qc_new() to determine the number of tags supported by the host;
unfortunately, SAS controllers doing SATA don't initialize ->scsi_host
leading to the following oops.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000058
IP: [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0
PGD 0
Oops: 0002 [#1] SMP
Modules linked in: isci libsas scsi_transport_sas mgag200 drm_kms_helper ttm
CPU: 1 PID: 518 Comm: udevd Not tainted 3.16.0-rc6+ #62
Hardware name: Intel Corporation S2600CO/S2600CO, BIOS SE5C600.86B.02.02.0002.122320131210 12/23/2013
task: ffff880c1a00b280 ti: ffff88061a000000 task.ti: ffff88061a000000
RIP: 0010:[<ffffffff814e0618>] [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0
RSP: 0018:ffff88061a003ae8 EFLAGS: 00010012
RAX: 0000000000000001 RBX: ffff88000241ca80 RCX: 00000000000000fa
RDX: 0000000000000020 RSI: 0000000000000020 RDI: ffff8806194aa298
RBP: ffff88061a003ae8 R08: ffff8806194a8000 R09: 0000000000000000
R10: 0000000000000000 R11: ffff88000241ca80 R12: ffff88061ad58200
R13: ffff8806194aa298 R14: ffffffff814e67a0 R15: ffff8806194a8000
FS: 00007f3ad7fe3840(0000) GS:ffff880627620000(0000) knlGS:0000000000000000
CR2: 0000000000000058 CR3: 000000061a118000 CR4: 00000000001407e0
Stack:
ffff88061a003b20 ffffffff814e96e1 ffff88000241ca80 ffff88061ad58200
ffff8800b6bf6000 ffff880c1c988000 ffff880619903850 ffff88061a003b68
ffffffffa0056ce1 ffff88061a003b48 0000000013d6e6f8 ffff88000241ca80
Call Trace:
[<ffffffff814e96e1>] ata_sas_queuecmd+0xa1/0x430
[<ffffffffa0056ce1>] sas_queuecommand+0x191/0x220 [libsas]
[<ffffffff8149afee>] scsi_dispatch_cmd+0x10e/0x300 [<ffffffff814a3bc5>] scsi_request_fn+0x2f5/0x550
[<ffffffff81317613>] __blk_run_queue+0x33/0x40
[<ffffffff8131781a>] queue_unplugged+0x2a/0x90
[<ffffffff8131ceb4>] blk_flush_plug_list+0x1b4/0x210
[<ffffffff8131d274>] blk_finish_plug+0x14/0x50
[<ffffffff8117eaa8>] __do_page_cache_readahead+0x198/0x1f0
[<ffffffff8117ee21>] force_page_cache_readahead+0x31/0x50
[<ffffffff8117ee7e>] page_cache_sync_readahead+0x3e/0x50
[<ffffffff81172ac6>] generic_file_read_iter+0x496/0x5a0
[<ffffffff81219897>] blkdev_read_iter+0x37/0x40
[<ffffffff811e307e>] new_sync_read+0x7e/0xb0
[<ffffffff811e3734>] vfs_read+0x94/0x170
[<ffffffff811e43c6>] SyS_read+0x46/0xb0
[<ffffffff811e33d1>] ? SyS_lseek+0x91/0xb0
[<ffffffff8171ee29>] system_call_fastpath+0x16/0x1b
Code: 00 00 00 88 50 29 83 7f 08 01 19 d2 83 e2 f0 83 ea 50 88 50 34 c6 81 1d 02 00 00 40 c6 81 17 02 00 00 00 5d c3 66 0f 1f 44 00 00 <89> 14 25 58 00 00 00
Fix it by introducing ata_host->n_tags which is initialized to
ATA_MAX_QUEUE - 1 in ata_host_init() for SAS controllers and set to
scsi_host_template->can_queue in ata_host_register() for !SAS ones.
As SAS hosts are never registered, this will give them the same
ATA_MAX_QUEUE - 1 as before. Note that we can't use
scsi_host->can_queue directly for SAS hosts anyway as they can go
higher than the libata maximum.
Reported-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Reported-by: Jesse Brandeburg <jesse.brandeburg@gmail.com>
Reported-by: Peter Hurley <peter@hurleysoftware.com>
Reported-by: Peter Zijlstra <peterz@infradead.org>
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Fixes: 1871ee134b73 ("libata: support the ata host which implements a queue depth less than 32")
Cc: Kevin Hao <haokexin@gmail.com>
Cc: Dan Williams <dan.j.williams@intel.com>
commit 8b8b36834d0fff67fc8668093f4312dd04dcf21d upstream.
The per_cpu buffers are created one per possible CPU. But these do
not mean that those CPUs are online, nor do they even exist.
With the addition of the ring buffer polling, it assumes that the
caller polls on an existing buffer. But this is not the case if
the user reads trace_pipe from a CPU that does not exist, and this
causes the kernel to crash.
Simple fix is to check the cpu against buffer bitmask against to see
if the buffer was allocated or not and return -ENODEV if it is
not.
More updates were done to pass the -ENODEV back up to userspace.
Link: http://lkml.kernel.org/r/5393DB61.6060707@oracle.com
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit b9cd18de4db3c9ffa7e17b0dc0ca99ed5aa4d43a upstream.
The 'sysret' fastpath does not correctly restore even all regular
registers, much less any segment registers or reflags values. That is
very much part of why it's faster than 'iret'.
Normally that isn't a problem, because the normal ptrace() interface
catches the process using the signal handler infrastructure, which
always returns with an iret.
However, some paths can get caught using ptrace_event() instead of the
signal path, and for those we need to make sure that we aren't going to
return to user space using 'sysret'. Otherwise the modifications that
may have been done to the register set by the tracer wouldn't
necessarily take effect.
Fix it by forcing IRET path by setting TIF_NOTIFY_RESUME from
arch_ptrace_stop_needed() which is invoked from ptrace_stop().
Reported-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 1e77d0a1ed7417d2a5a52a7b8d32aea1833faa6c upstream.
Till reported that the spurious interrupt detection of threaded
interrupts is broken in two ways:
- note_interrupt() is called for each action thread of a shared
interrupt line. That's wrong as we are only interested whether none
of the device drivers felt responsible for the interrupt, but by
calling multiple times for a single interrupt line we account
IRQ_NONE even if one of the drivers felt responsible.
- note_interrupt() when called from the thread handler is not
serialized. That leaves the members of irq_desc which are used for
the spurious detection unprotected.
To solve this we need to defer the spurious detection of a threaded
interrupt to the next hardware interrupt context where we have
implicit serialization.
If note_interrupt is called with action_ret == IRQ_WAKE_THREAD, we
check whether the previous interrupt requested a deferred check. If
not, we request a deferred check for the next hardware interrupt and
return.
If set, we check whether one of the interrupt threads signaled
success. Depending on this information we feed the result into the
spurious detector.
If one primary handler of a shared interrupt returns IRQ_HANDLED we
disable the deferred check of irq threads on the same line, as we have
found at least one device driver who cared.
Reported-by: Till Straumann <strauman@slac.stanford.edu>
Tested-by: Austin Schuh <austin@peloton-tech.com>
Cc: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: linux-can@vger.kernel.org
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1303071450130.22263@ionos
commit 4e52365f279564cef0ddd41db5237f0471381093 upstream.
When tracing a process in another pid namespace, it's important for fork
event messages to contain the child's pid as seen from the tracer's pid
namespace, not the parent's. Otherwise, the tracer won't be able to
correlate the fork event with later SIGTRAP signals it receives from the
child.
We still risk a race condition if a ptracer from a different pid
namespace attaches after we compute the pid_t value. However, sending a
bogus fork event message in this unlikely scenario is still a vast
improvement over the status quo where we always send bogus fork event
messages to debuggers in a different pid namespace than the forking
process.
Signed-off-by: Matthew Dempsky <mdempsky@chromium.org>
Cc: Julien Tinnes <jln@chromium.org>
Cc: Roland McGrath <mcgrathr@chromium.org>
Cc: Jan Kratochvil <jan.kratochvil@redhat.com>
[ Upstream commit 9d0d68faea6962d62dd501cd6e71ce5cc8ed262b ]
Now it is not possible to set mtu to team device which has a port
enslaved to it. The reason is that when team_change_mtu() calls
dev_set_mtu() for port device, notificator for NETDEV_PRECHANGEMTU
event is called and team_device_event() returns NOTIFY_BAD forbidding
the change. So fix this by returning NOTIFY_DONE here in case team is
changing mtu in team_change_mtu().
Introduced-by: 3d249d4c "net: introduce ethernet teaming device"
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Flavio Leitner <fbl@redhat.com>
[ Upstream commit 2d7a85f4b06e9c27ff629f07a524c48074f07f81 ]
It was possible to get a setuid root or setcap executable to write to
it's stdout or stderr (which has been set made a netlink socket) and
inadvertently reconfigure the networking stack.
To prevent this we check that both the creator of the socket and
the currentl applications has permission to reconfigure the network
stack.
Unfortunately this breaks Zebra which always uses sendto/sendmsg
and creates it's socket without any privileges.
To keep Zebra working don't bother checking if the creator of the
socket has privilege when a destination address is specified. Instead
rely exclusively on the privileges of the sender of the socket.
Note from Andy: This is exactly Eric's code except for some comment
clarifications and formatting fixes. Neither I nor, I think, anyone
else is thrilled with this approach, but I'm hesitant to wait on a
better fix since 3.15 is almost here.
Note to stable maintainers: This is a mess. An earlier series of
patches in 3.15 fix a rather serious security issue (CVE-2014-0181),
but they did so in a way that breaks Zebra. The offending series
includes:
commit aa4cf9452f469f16cea8c96283b641b4576d4a7b
Author: Eric W. Biederman <ebiederm@xmission.com>
Date: Wed Apr 23 14:28:03 2014 -0700
net: Add variants of capable for use on netlink messages
If a given kernel version is missing that series of fixes, it's
probably worth backporting it and this patch. if that series is
present, then this fix is critical if you care about Zebra.
Cc: stable@vger.kernel.org
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit aa4cf9452f469f16cea8c96283b641b4576d4a7b ]
netlink_net_capable - The common case use, for operations that are safe on a network namespace
netlink_capable - For operations that are only known to be safe for the global root
netlink_ns_capable - The general case of capable used to handle special cases
__netlink_ns_capable - Same as netlink_ns_capable except taking a netlink_skb_parms instead of
the skbuff of a netlink message.
[ Upstream commit a53b72c83a4216f2eb883ed45a0cbce014b8e62d ]
The permission check in sock_diag_put_filterinfo is wrong, and it is so removed
from it's sources it is not clear why it is wrong. Move the computation
into packet_diag_dump and pass a bool of the result into sock_diag_filterinfo.
This does not yet correct the capability check but instead simply moves it to make
it clear what is going on.
commit 23adbe12ef7d3d4195e80800ab36b37bee28cd03 upstream.
The kernel has no concept of capabilities with respect to inodes; inodes
exist independently of namespaces. For example, inode_capable(inode,
CAP_LINUX_IMMUTABLE) would be nonsense.
This patch changes inode_capable to check for uid and gid mappings and
renames it to capable_wrt_inode_uidgid, which should make it more
obvious what it does.
Fixes CVE-2014-4014.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
commit 14c63f17b1fde5a575a28e96547a22b451c71fb5 upstream.
This patch keeps track of how long perf's NMI handler is taking,
and also calculates how many samples perf can take a second. If
the sample length times the expected max number of samples
exceeds a configurable threshold, it drops the sample rate.
This way, we don't have a runaway sampling process eating up the
CPU.
This patch can tend to drop the sample rate down to level where
perf doesn't work very well. *BUT* the alternative is that my
system hangs because it spends all of its time handling NMIs.
I'll take a busted performance tool over an entire system that's
busted and undebuggable any day.
BTW, my suspicion is that there's still an underlying bug here.
Using the HPET instead of the TSC is definitely a contributing
factor, but I suspect there are some other things going on.
But, I can't go dig down on a bug like that with my machine
hanging all the time.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: paulus@samba.org
Cc: acme@ghostprotocols.net
Cc: Dave Hansen <dave@sr71.net>
[ Prettified it a bit. ]
Cc: Weng Meiling <wengmeiling.weng@huawei.com>
commit 4c88d7f9b0d5fb0588c3386be62115cc2eaa8f9f upstream.
Patch 01f8fa4f01d "genirq: Allow forcing cpu affinity of interrupts" added
an irq_force_affinity() function, and 30ccf03b4a6 "clocksource: Exynos_mct:
Use irq_force_affinity() in cpu bringup" subsequently uses it. However, the
driver can be used with CONFIG_SMP disabled, but the function declaration
is only available for CONFIG_SMP, leading to this build error:
drivers/clocksource/exynos_mct.c:431:3: error: implicit declaration of function 'irq_force_affinity' [-Werror=implicit-function-declaration]
irq_force_affinity(mct_irqs[MCT_L0_IRQ + cpu], cpumask_of(cpu));
This patch introduces a dummy helper function for the non-SMP case
that always returns success, to get rid of the build error.
Since the patches causing the problem are marked for stable backports,
this one should be as well.
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Link: http://lkml.kernel.org/r/5619084.0zmrrIUZLV@wuerfel
commit 03367ef5ea811475187a0732aada068919e14d61 upstream.
Only ws2012r2 hosts support the ability to reconnect to the host on VMBUS. This functionality
is needed by kexec in Linux. To use this functionality we need to negotiate version 3.0 of the
VMBUS protocol.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
