commit 01f8fa4f01d8362358eb90e412bd7ae18a3ec1ad upstream.
The current implementation of irq_set_affinity() refuses rightfully to
route an interrupt to an offline cpu.
But there is a special case, where this is actually desired. Some of
the ARM SoCs have per cpu timers which require setting the affinity
during cpu startup where the cpu is not yet in the online mask.
If we can't do that, then the local timer interrupt for the about to
become online cpu is routed to some random online cpu.
The developers of the affected machines tried to work around that
issue, but that results in a massive mess in that timer code.
We have a yet unused argument in the set_affinity callbacks of the irq
chips, which I added back then for a similar reason. It was never
required so it got not used. But I'm happy that I never removed it.
That allows us to implement a sane handling of the above scenario. So
the affected SoC drivers can add the required force handling to their
interrupt chip, switch the timer code to irq_force_affinity() and
things just work.
This does not affect any existing user of irq_set_affinity().
Tagged for stable to allow a simple fix of the affected SoC clock
event drivers.
Reported-and-tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Tomasz Figa <t.figa@samsung.com>,
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>,
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: linux-arm-kernel@lists.infradead.org,
Link: http://lkml.kernel.org/r/20140416143315.717251504@linutronix.de
commit a949ae560a511fe4e3adf48fa44fefded93e5c2b upstream.
A race exists between module loading and enabling of function tracer.
CPU 1 CPU 2
load_module()
module->state = MODULE_STATE_COMING
register_ftrace_function()
mutex_lock(&ftrace_lock);
ftrace_startup()
update_ftrace_function();
ftrace_arch_code_modify_prepare()
set_all_module_text_rw();
<enables-ftrace>
ftrace_arch_code_modify_post_process()
set_all_module_text_ro();
[ here all module text is set to RO,
including the module that is
loading!! ]
blocking_notifier_call_chain(MODULE_STATE_COMING);
ftrace_init_module()
[ tries to modify code, but it's RO, and fails!
ftrace_bug() is called]
When this race happens, ftrace_bug() will produces a nasty warning and
all of the function tracing features will be disabled until reboot.
The simple solution is to treate module load the same way the core
kernel is treated at boot. To hardcode the ftrace function modification
of converting calls to mcount into nops. This is done in init/main.c
there's no reason it could not be done in load_module(). This gives
a better control of the changes and doesn't tie the state of the
module to its notifiers as much. Ftrace is special, it needs to be
treated as such.
The reason this would work, is that the ftrace_module_init() would be
called while the module is in MODULE_STATE_UNFORMED, which is ignored
by the set_all_module_text_ro() call.
Link: http://lkml.kernel.org/r/1395637826-3312-1-git-send-email-indou.takao@jp.fujitsu.com
Reported-by: Takao Indoh <indou.takao@jp.fujitsu.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
[ Upstream commit 78541c1dc60b65ecfce5a6a096fc260219d6784e ]
The caller needs capabilities on the namespace being queried, not on
their own namespace. This is a security bug, although it likely has
only a minor impact.
Cc: stable@vger.kernel.org
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit 008208c6b26f21c2648c250a09c55e737c02c5f8 ]
Add two trivial helpers list_next_entry() and list_prev_entry(), they
can have a lot of users including list.h itself. In fact the 1st one is
already defined in events/core.c and bnx2x_sp.c, so the patch simply
moves the definition to list.h.
Cc: Eilon Greenstein <eilong@broadcom.com>
commit 8a4aeec8d2d6a3edeffbdfae451cdf05cbf0fefd upstream.
The AHCI spec allows implementations to issue commands in tag order
rather than FIFO order:
5.3.2.12 P:SelectCmd
HBA sets pSlotLoc = (pSlotLoc + 1) mod (CAP.NCS + 1)
or HBA selects the command to issue that has had the
PxCI bit set to '1' longer than any other command
pending to be issued.
The result is that commands posted sequentially (time-wise) may play out
of sequence when issued by hardware.
This behavior has likely been hidden by drives that arrange for commands
to complete in issue order. However, it appears recent drives (two from
different vendors that we have found so far) inflict out-of-order
completions as a matter of course. So, we need to take care to maintain
ordered submission, otherwise we risk triggering a drive to fall out of
sequential-io automation and back to random-io processing, which incurs
large latency and degrades throughput.
This issue was found in simple benchmarks where QD=2 seq-write
performance was 30-50% *greater* than QD=32 seq-write performance.
Tagging for -stable and making the change globally since it has a low
risk-to-reward ratio. Also, word is that recent versions of an unnamed
OS also does it this way now. So, drives in the field are already
experienced with this tag ordering scheme.
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Ed Ciechanowski <ed.ciechanowski@intel.com>
Reviewed-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
commit 3064639423c48d6e0eb9ecc27c512a58e38c6c57 upstream.
There could be a case, when NFSd file system is mounted in network, different
to socket's one, like below:
"ip netns exec" creates new network and mount namespace, which duplicates NFSd
mount point, created in init_net context. And thus NFS server stop in nested
network context leads to RPCBIND client destruction in init_net.
Then, on NFSd start in nested network context, rpc.nfsd process creates socket
in nested net and passes it into "write_ports", which leads to RPCBIND sockets
creation in init_net context because of the same reason (NFSd monut point was
created in init_net context). An attempt to register passed socket in nested
net leads to panic, because no RPCBIND client present in nexted network
namespace.
This patch add check that passed socket's net matches NFSd superblock's one.
And returns -EINVAL error to user psace otherwise.
v2: Put socket on exit.
Reported-by: Weng Meiling <wengmeiling.weng@huawei.com>
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 5acda9d12dcf1ad0d9a5a2a7c646de3472fa7555 upstream.
After commit 839a8e8660b6 ("writeback: replace custom worker pool
implementation with unbound workqueue") when device is removed while we
are writing to it we crash in bdi_writeback_workfn() ->
set_worker_desc() because bdi->dev is NULL.
This can happen because even though bdi_unregister() cancels all pending
flushing work, nothing really prevents new ones from being queued from
balance_dirty_pages() or other places.
Fix the problem by clearing BDI_registered bit in bdi_unregister() and
checking it before scheduling of any flushing work.
Fixes: 839a8e8660b6777e7fe4e80af1a048aebe2b5977
Reviewed-by: Tejun Heo <tj@kernel.org>
Cc: Derek Basehore <dbasehore@chromium.org>
commit 95731ebb114c5f0c028459388560fc2a72fe5049 upstream.
Cpufreq governors' stop and start operations should be carried out
in sequence. Otherwise, there will be unexpected behavior, like in
the example below.
Suppose there are 4 CPUs and policy->cpu=CPU0, CPU1/2/3 are linked
to CPU0. The normal sequence is:
1) Current governor is userspace. An application tries to set the
governor to ondemand. It will call __cpufreq_set_policy() in
which it will stop the userspace governor and then start the
ondemand governor.
2) Current governor is userspace. The online of CPU3 runs on CPU0.
It will call cpufreq_add_policy_cpu() in which it will first
stop the userspace governor, and then start it again.
If the sequence of the above two cases interleaves, it becomes:
1) Application stops userspace governor
2) Hotplug stops userspace governor
which is a problem, because the governor shouldn't be stopped twice
in a row. What happens next is:
3) Application starts ondemand governor
4) Hotplug starts a governor
In step 4, the hotplug is supposed to start the userspace governor,
but now the governor has been changed by the application to ondemand,
so the ondemand governor is started once again, which is incorrect.
The solution is to prevent policy governors from being stopped
multiple times in a row. A governor should only be stopped once for
one policy. After it has been stopped, no more governor stop
operations should be executed.
Also add a mutex to serialize governor operations.
[rjw: Changelog. And you owe me a beverage of my choice.]
Signed-off-by: Xiaoguang Chen <chenxg@marvell.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
commit 03b8c7b623c80af264c4c8d6111e5c6289933666 upstream.
If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there
is no runtime check necessary, allow to skip the test within futex_init().
This allows to get rid of some code which would always give the same result,
and also allows the compiler to optimize a couple of if statements away.
Cc: Finn Thain <fthain@telegraphics.com.au>
Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris
[geert: Backported to v3.10..v3.13]
[ Upstream commit 14a0d635d18d0fb552dcc979d6d25106e6541f2e ]
This fixes a race which happens by freeing an object on the stack.
Quoting Julius:
> The issue is
> that it calls usbnet_terminate_urbs() before that, which temporarily
> installs a waitqueue in dev->wait in order to be able to wait on the
> tasklet to run and finish up some queues. The waiting itself looks
> okay, but the access to 'dev->wait' is totally unprotected and can
> race arbitrarily. I think in this case usbnet_bh() managed to succeed
> it's dev->wait check just before usbnet_terminate_urbs() sets it back
> to NULL. The latter then finishes and the waitqueue_t structure on its
> stack gets overwritten by other functions halfway through the
> wake_up() call in usbnet_bh().
The fix is to just not allocate the data structure on the stack.
As dev->wait is abused as a flag it also takes a runtime PM change
to fix this bug.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Reported-by: Grant Grundler <grundler@google.com>
Tested-by: Grant Grundler <grundler@google.com>
commit 668f9abbd4334e6c29fa8acd71635c4f9101caa7 upstream.
Commit bf6bddf1924e ("mm: introduce compaction and migration for
ballooned pages") introduces page_count(page) into memory compaction
which dereferences page->first_page if PageTail(page).
This results in a very rare NULL pointer dereference on the
aforementioned page_count(page). Indeed, anything that does
compound_head(), including page_count() is susceptible to racing with
prep_compound_page() and seeing a NULL or dangling page->first_page
pointer.
This patch uses Andrea's implementation of compound_trans_head() that
deals with such a race and makes it the default compound_head()
implementation. This includes a read memory barrier that ensures that
if PageTail(head) is true that we return a head page that is neither
NULL nor dangling. The patch then adds a store memory barrier to
prep_compound_page() to ensure page->first_page is set.
This is the safest way to ensure we see the head page that we are
expecting, PageTail(page) is already in the unlikely() path and the
memory barriers are unfortunately required.
Hugetlbfs is the exception, we don't enforce a store memory barrier
during init since no race is possible.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Holger Kiehl <Holger.Kiehl@dwd.de>
Cc: Christoph Lameter <cl@linux.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
commit 00a1a053ebe5febcfc2ec498bd894f035ad2aa06 upstream.
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit d29adb34a94715174c88ca93e8aba955850c9bde upstream.
The PAUSEWR and PAUSERD flags are meant to stop the cluster from
processing writes and reads, respectively. The FULL flag is set when
the cluster determines that it is out of space, and will no longer
process writes. PAUSEWR and PAUSERD are purely client-side settings
already implemented in userspace clients. The osd does nothing special
with these flags.
When the FULL flag is set, however, the osd responds to all writes
with -ENOSPC. For cephfs, this makes sense, but for rbd the block
layer translates this into EIO. If a cluster goes from full to
non-full quickly, a filesystem on top of rbd will not behave well,
since some writes succeed while others get EIO.
Fix this by blocking any writes when the FULL flag is set in the osd
client. This is the same strategy used by userspace, so apply it by
default. A follow-on patch makes this configurable.
__map_request() is called to re-target osd requests in case the
available osds changed. Add a paused field to a ceph_osd_request, and
set it whenever an appropriate osd map flag is set. Avoid queueing
paused requests in __map_request(), but force them to be resent if
they become unpaused.
Also subscribe to the next osd map from the monitor if any of these
flags are set, so paused requests can be unblocked as soon as
possible.
Fixes: http://tracker.ceph.com/issues/6079
Reviewed-by: Sage Weil <sage@inktank.com>
Signed-off-by: Josh Durgin <josh.durgin@inktank.com>
commit 87291347c49dc40aa339f587b209618201c2e527 upstream.
In event format strings, the array size is reported in two locations.
One in array subscript and then via the "size:" attribute. The values
reported there have a mismatch.
For e.g., in sched:sched_switch the prev_comm and next_comm character
arrays have subscript values as [32] where as the actual field size is
16.
format:
field:unsigned short common_type; offset:0; size:2; signed:0;
field:unsigned char common_flags; offset:2; size:1; signed:0;
field:unsigned char common_preempt_count; offset:3; size:1;signed:0;
field:int common_pid; offset:4; size:4; signed:1;
field:char prev_comm[32]; offset:8; size:16; signed:1;
field:pid_t prev_pid; offset:24; size:4; signed:1;
field:int prev_prio; offset:28; size:4; signed:1;
field:long prev_state; offset:32; size:8; signed:1;
field:char next_comm[32]; offset:40; size:16; signed:1;
field:pid_t next_pid; offset:56; size:4; signed:1;
field:int next_prio; offset:60; size:4; signed:1;
After bisection, the following commit was blamed:
92edca0 tracing: Use direct field, type and system names
This commit removes the duplication of strings for field->name and
field->type assuming that all the strings passed in
__trace_define_field() are immutable. This is not true for arrays, where
the type string is created in event_storage variable and field->type for
all array fields points to event_storage.
Use __stringify() to create a string constant for the type string.
Also, get rid of event_storage and event_storage_mutex that are not
needed anymore.
also, an added benefit is that this reduces the overhead of events a bit more:
8424787 2036472 1302528 11763787 b3804b vmlinux
8420814 2036408 1302528 11759750 b37086 vmlinux.patched
Link: http://lkml.kernel.org/r/1392349908-29685-1-git-send-email-vnagarnaik@google.com
Cc: Laurent Chavey <chavey@google.com>
Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com>
commit 5a581b367b5df0531265311fc681c2abd377e5e6 upstream.
According to the C standard 3.4.3p3, overflow of a signed integer results
in undefined behavior. This commit therefore changes the definitions
of time_after(), time_after_eq(), time_after64(), and time_after_eq64()
to avoid this undefined behavior. The trick is that the subtraction
is done using unsigned arithmetic, which according to 6.2.5p9 cannot
overflow because it is defined as modulo arithmetic. This has the added
(though admittedly quite small) benefit of shortening four lines of code
by four characters each.
Note that the C standard considers the cast from unsigned to
signed to be implementation-defined, see 6.3.1.3p3. However, on a
two's-complement system, an implementation that defines anything other
than a reinterpretation of the bits is free to come to me, and I will be
happy to act as a witness for its being committed to an insane asylum.
(Although I have nothing against saturating arithmetic or signals in some
cases, these things really should not be the default when compiling an
operating-system kernel.)
Cc: John Stultz <john.stultz@linaro.org>
Cc: Kevin Easton <kevin@guarana.org>
[ paulmck: Included time_after64() and time_after_eq64(), as suggested
by Eric Dumazet, also fixed commit message.]
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Ruchi Kandoi <kandoiruchi@google.com>
commit 70044d71d31d6973665ced5be04ef39ac1c09a48 upstream.
PREPARE_[DELAYED_]WORK() are being phased out. They have few users
and a nasty surprise in terms of reentrancy guarantee as workqueue
considers work items to be different if they don't have the same work
function.
firewire core-device and sbp2 have been been multiplexing work items
with multiple work functions. Introduce fw_device_workfn() and
sbp2_lu_workfn() which invoke fw_device->workfn and
sbp2_logical_unit->workfn respectively and always use the two
functions as the work functions and update the users to set the
->workfn fields instead of overriding work functions using
PREPARE_DELAYED_WORK().
This fixes a variety of possible regressions since a2c1c57be8d9
"workqueue: consider work function when searching for busy work items"
due to which fw_workqueue lost its required non-reentrancy property.
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: linux1394-devel@lists.sourceforge.net
commit 45ab2813d40d88fc575e753c38478de242d03f88 upstream.
If a module fails to add its tracepoints due to module tainting, do not
create the module event infrastructure in the debugfs directory. As the events
will not work and worse yet, they will silently fail, making the user wonder
why the events they enable do not display anything.
Having a warning on module load and the events not visible to the users
will make the cause of the problem much clearer.
Link: http://lkml.kernel.org/r/20140227154923.265882695@goodmis.org
Fixes: 6d723736e472 "tracing/events: add support for modules to TRACE_EVENT"
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
commit f3713fd9cff733d9df83116422d8e4af6e86b2bb upstream.
Commit 93e6f119c0ce ("ipc/mqueue: cleanup definition names and
locations") added global hardcoded limits to the amount of message
queues that can be created. While these limits are per-namespace,
reality is that it ends up breaking userspace applications.
Historically users have, at least in theory, been able to create up to
INT_MAX queues, and limiting it to just 1024 is way too low and dramatic
for some workloads and use cases. For instance, Madars reports:
"This update imposes bad limits on our multi-process application. As
our app uses approaches that each process opens its own set of queues
(usually something about 3-5 queues per process). In some scenarios
we might run up to 3000 processes or more (which of-course for linux
is not a problem). Thus we might need up to 9000 queues or more. All
processes run under one user."
Other affected users can be found in launchpad bug #1155695:
https://bugs.launchpad.net/ubuntu/+source/manpages/+bug/1155695
Instead of increasing this limit, revert it entirely and fallback to the
original way of dealing queue limits -- where once a user's resource
limit is reached, and all memory is used, new queues cannot be created.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Reported-by: Madars Vitolins <m@silodev.com>
Acked-by: Doug Ledford <dledford@redhat.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
commit fe6cc55f3a9a053482a76f5a6b2257cee51b4663 upstream.
Marcelo Ricardo Leitner reported problems when the forwarding link path
has a lower mtu than the incoming one if the inbound interface supports GRO.
Given:
Host <mtu1500> R1 <mtu1200> R2
Host sends tcp stream which is routed via R1 and R2. R1 performs GRO.
In this case, the kernel will fail to send ICMP fragmentation needed
messages (or pkt too big for ipv6), as GSO packets currently bypass dstmtu
checks in forward path. Instead, Linux tries to send out packets exceeding
the mtu.
When locking route MTU on Host (i.e., no ipv4 DF bit set), R1 does
not fragment the packets when forwarding, and again tries to send out
packets exceeding R1-R2 link mtu.
This alters the forwarding dstmtu checks to take the individual gso
segment lengths into account.
For ipv6, we send out pkt too big error for gso if the individual
segments are too big.
For ipv4, we either send icmp fragmentation needed, or, if the DF bit
is not set, perform software segmentation and let the output path
create fragments when the packet is leaving the machine.
It is not 100% correct as the error message will contain the headers of
the GRO skb instead of the original/segmented one, but it seems to
work fine in my (limited) tests.
Eric Dumazet suggested to simply shrink mss via ->gso_size to avoid
sofware segmentation.
However it turns out that skb_segment() assumes skb nr_frags is related
to mss size so we would BUG there. I don't want to mess with it considering
Herbert and Eric disagree on what the correct behavior should be.
Hannes Frederic Sowa notes that when we would shrink gso_size
skb_segment would then also need to deal with the case where
SKB_MAX_FRAGS would be exceeded.
This uses sofware segmentation in the forward path when we hit ipv4
non-DF packets and the outgoing link mtu is too small. Its not perfect,
but given the lack of bug reports wrt. GRO fwd being broken this is a
rare case anyway. Also its not like this could not be improved later
once the dust settles.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Reported-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
commit d206940319c41df4299db75ed56142177bb2e5f6 upstream.
Will be used by upcoming ipv4 forward path change that needs to
determine feature mask using skb->dst->dev instead of skb->dev.
commit de960aa9ab4decc3304959f69533eef64d05d8e8 upstream.
[ no skb_gso_seglen helper in 3.10, leave tbf alone ]
This moves part of Eric Dumazets skb_gso_seglen helper from tbf sched to
skbuff core so it may be reused by upcoming ip forwarding path patch.
[ Upstream commit 0ae89beb283a0db5980d1d4781c7d7be2f2810d6 ]
Self generated skbuffs in net/can/bcm.c are setting a skb->sk reference but
no explicit destructor which is enforced since Linux 3.11 with commit
376c7311bdb6 (net: add a temporary sanity check in skb_orphan()).
This patch adds some helper functions to make sure that a destructor is
properly defined when a sock reference is assigned to a CAN related skb.
To create an unshared skb owned by the original sock a common helper function
has been introduced to replace open coded functions to create CAN echo skbs.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Tested-by: Andre Naujoks <nautsch2@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
commit a9f180345f5378ac87d80ed0bea55ba421d83859 upstream.
I started noticing problems with KVM guest destruction on Linux
3.12+, where guest memory wasn't being cleaned up. I bisected it
down to the commit introducing the new 'asm goto'-based atomics,
and found this quirk was later applied to those.
Unfortunately, even with GCC 4.8.2 (which ostensibly fixed the
known 'asm goto' bug) I am still getting some kind of
miscompilation. If I enable the asm_volatile_goto quirk for my
compiler, KVM guests are destroyed correctly and the memory is
cleaned up.
So make the quirk unconditional for now, until bug is found
and fixed.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Steven Noonan <steven@uplinklabs.net>
Cc: Jakub Jelinek <jakub@redhat.com>
Cc: Richard Henderson <rth@twiddle.net>
Link: http://lkml.kernel.org/r/1392274867-15236-1-git-send-email-steven@uplinklabs.net
Link: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670
commit d8d14bd09cddbaf0168d61af638455a26bd027ff upstream.
Commit d5dc77bfeeab ("consolidate compat lookup_dcookie()") coverted all
architectures to the new compat_sys_lookup_dcookie() syscall.
The "len" paramater of the new compat syscall must have the type
compat_size_t in order to enforce zero extension for architectures where
the ABI requires that the caller of a function performed zero and/or
sign extension to 64 bit of all parameters.
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
commit dfd948e32af2e7b28bcd7a490c0a30d4b8df2a36 upstream.
We got a report that the pwritev syscall does not work correctly in
compat mode on s390.
It turned out that with commit 72ec35163f9f ("switch compat readv/writev
variants to COMPAT_SYSCALL_DEFINE") we lost the zero extension of a
couple of syscall parameters because the some parameter types haven't
been converted from unsigned long to compat_ulong_t.
This is needed for architectures where the ABI requires that the caller
of a function performed zero and/or sign extension to 64 bit of all
parameters.
commit a1c3bfb2f67ef766de03f1f56bdfff9c8595ab14 upstream.
The VM is currently heavily tuned to avoid swapping. Whether that is
good or bad is a separate discussion, but as long as the VM won't swap
to make room for dirty cache, we can not consider anonymous pages when
calculating the amount of dirtyable memory, the baseline to which
dirty_background_ratio and dirty_ratio are applied.
A simple workload that occupies a significant size (40+%, depending on
memory layout, storage speeds etc.) of memory with anon/tmpfs pages and
uses the remainder for a streaming writer demonstrates this problem. In
that case, the actual cache pages are a small fraction of what is
considered dirtyable overall, which results in an relatively large
portion of the cache pages to be dirtied. As kswapd starts rotating
these, random tasks enter direct reclaim and stall on IO.
Only consider free pages and file pages dirtyable.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: Tejun Heo <tj@kernel.org>
Tested-by: Tejun Heo <tj@kernel.org>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 06bdadd7634551cfe8ce071fe44d0311b3033d9e upstream.
audit_syscall_exit() saves a result of regs_return_value() in intermediate
"int" variable and passes it to __audit_syscall_exit(), which expects its
second argument as a "long" value. This will result in truncating the
value returned by a system call and making a wrong audit record.
I don't know why gcc compiler doesn't complain about this, but anyway it
causes a problem at runtime on arm64 (and probably most 64-bit archs).
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Cc: Eric Paris <eparis@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 28a625cbc2a14f17b83e47ef907b2658576a32aa upstream.
Having this struct in module memory could Oops when if the module is
unloaded while the buffer still persists in a pipe.
Since sock_pipe_buf_ops is essentially the same as fuse_dev_pipe_buf_steal
merge them into nosteal_pipe_buf_ops (this is the same as
default_pipe_buf_ops except stealing the page from the buffer is not
allowed).
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit ecd75ad514d73efc1bbcc5f10a13566c3ace5f53 upstream.
For some reason, some early WD drives spin up and down drives
erratically when the link is put into slumber mode which can reduce
the life expectancy of the device significantly. Unfortunately, we
don't have full list of devices and given the nature of the issue it'd
be better to err on the side of false positives than the other way
around. Let's disable LPM on all WD devices which match one of the
known problematic model prefixes and are SATA-I.
As horkage list doesn't support matching SATA capabilities, this is
implemented as two horkages - WD_BROKEN_LPM and NOLPM. The former is
set for the known prefixes and sets the latter if the matched device
is SATA-I.
Note that this isn't optimal as this disables all LPM operations and
partial link power state reportedly works fine on these; however, the
way LPM is implemented in libata makes it difficult to precisely map
libata LPM setting to specific link power state. Well, these devices
are already fairly outdated. Let's just disable whole LPM for now.
Reported-and-tested-by: Nikos Barkas <levelwol@gmail.com>
Reported-and-tested-by: Ioannis Barkas <risc4all@yahoo.com>
References: https://bugzilla.kernel.org/show_bug.cgi?id=57211
commit 27c73ae759774e63313c1fbfeb17ba076cea64c5 upstream.
Commit 7cb2ef56e6a8 ("mm: fix aio performance regression for database
caused by THP") can cause dereference of a dangling pointer if
split_huge_page runs during PageHuge() if there are updates to the
tail_page->private field.
Also it is repeating compound_head twice for hugetlbfs and it is running
compound_head+compound_trans_head for THP when a single one is needed in
both cases.
The new code within the PageSlab() check doesn't need to verify that the
THP page size is never bigger than the smallest hugetlbfs page size, to
avoid memory corruption.
A longstanding theoretical race condition was found while fixing the
above (see the change right after the skip_unlock label, that is
relevant for the compound_lock path too).
By re-establishing the _mapcount tail refcounting for all compound
pages, this also fixes the below problem:
echo 0 >/sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages
BUG: Bad page state in process bash pfn:59a01
page:ffffea000139b038 count:0 mapcount:10 mapping: (null) index:0x0
page flags: 0x1c00000000008000(tail)
Modules linked in:
CPU: 6 PID: 2018 Comm: bash Not tainted 3.12.0+ #25
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x55/0x76
bad_page+0xd5/0x130
free_pages_prepare+0x213/0x280
__free_pages+0x36/0x80
update_and_free_page+0xc1/0xd0
free_pool_huge_page+0xc2/0xe0
set_max_huge_pages.part.58+0x14c/0x220
nr_hugepages_store_common.isra.60+0xd0/0xf0
nr_hugepages_store+0x13/0x20
kobj_attr_store+0xf/0x20
sysfs_write_file+0x189/0x1e0
vfs_write+0xc5/0x1f0
SyS_write+0x55/0xb0
system_call_fastpath+0x16/0x1b
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Pravin Shelar <pshelar@nicira.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Guillaume Morin <guillaume@morinfr.org>
commit f92f455f67fef27929e6043499414605b0c94872 upstream.
{,set}page_address() are macros if WANT_PAGE_VIRTUAL. If
!WANT_PAGE_VIRTUAL, they're plain C functions.
If someone calls them with a void *, this pointer is auto-converted to
struct page * if !WANT_PAGE_VIRTUAL, but causes a build failure on
architectures using WANT_PAGE_VIRTUAL (arc, m68k and sparc64):
drivers/md/bcache/bset.c: In function `__btree_sort':
drivers/md/bcache/bset.c:1190: warning: dereferencing `void *' pointer
drivers/md/bcache/bset.c:1190: error: request for member `virtual' in something not a structure or union
Convert them to static inline functions to fix this. There are already
plenty of users of struct page members inside <linux/mm.h>, so there's
no reason to keep them as macros.
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: David Rientjes <rientjes@google.com>
[ Upstream commit 2205369a314e12fcec4781cc73ac9c08fc2b47de ]
When the vlan code detects that the real device can do TX VLAN offloads
in hardware, it tries to arrange for the real device's header_ops to
be invoked directly.
But it does so illegally, by simply hooking the real device's
header_ops up to the VLAN device.
This doesn't work because we will end up invoking a set of header_ops
routines which expect a device type which matches the real device, but
will see a VLAN device instead.
Fix this by providing a pass-thru set of header_ops which will arrange
to pass the proper real device instead.
To facilitate this add a dev_rebuild_header(). There are
implementations which provide a ->cache and ->create but not a
->rebuild (f.e. PLIP). So we need a helper function just like
dev_hard_header() to avoid crashes.
Use this helper in the one existing place where the
header_ops->rebuild was being invoked, the neighbour code.
With lots of help from Florian Westphal.
[ Upstream commit 12663bfc97c8b3fdb292428105dd92d563164050 ]
unix_dgram_recvmsg() will hold the readlock of the socket until recv
is complete.
In the same time, we may try to setsockopt(SO_PEEK_OFF) which will hang until
unix_dgram_recvmsg() will complete (which can take a while) without allowing
us to break out of it, triggering a hung task spew.
Instead, allow set_peek_off to fail, this way userspace will not hang.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
commit dd935f44a40f8fb02aff2cc0df2269c92422df1c upstream.
Without a way to flush the osd client's notify workqueue, a watch
event that is unregistered could continue receiving callbacks
indefinitely.
Unregistering the event simply means no new notifies are added to the
queue, but there may still be events in the queue that will call the
watch callback for the event. If the queue is flushed after the event
is unregistered, the caller can be sure no more watch callbacks will
occur for the canceled watch.
Reviewed-by: Alex Elder <elder@linaro.org>
commit eb845ff13a44477f8a411baedbf11d678b9daf0a upstream.
handle_reply() calls complete_request() only if the first OSD reply
has ONDISK flag.
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
table updates
commit af2c1401e6f9177483be4fad876d0073669df9df upstream.
According to documentation on barriers, stores issued before a LOCK can
complete after the lock implying that it's possible tlb_flush_pending
can be visible after a page table update. As per revised documentation,
this patch adds a smp_mb__before_spinlock to guarantee the correct
ordering.
commit 20841405940e7be0617612d521e206e4b6b325db upstream.
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Alex Thorlton <athorlton@sgi.com>
commit e0acd0a68ec7dbf6b7a81a87a867ebd7ac9b76c4 upstream.
This is only theoretical, but after try_to_wake_up(p) was changed
to check p->state under p->pi_lock the code like
__set_current_state(TASK_INTERRUPTIBLE);
schedule();
can miss a signal. This is the special case of wait-for-condition,
it relies on try_to_wake_up/schedule interaction and thus it does
not need mb() between __set_current_state() and if(signal_pending).
However, this __set_current_state() can move into the critical
section protected by rq->lock, now that try_to_wake_up() takes
another lock we need to ensure that it can't be reordered with
"if (signal_pending(current))" check inside that section.
The patch is actually one-liner, it simply adds smp_wmb() before
spin_lock_irq(rq->lock). This is what try_to_wake_up() already
does by the same reason.
We turn this wmb() into the new helper, smp_mb__before_spinlock(),
for better documentation and to allow the architectures to change
the default implementation.
While at it, kill smp_mb__after_lock(), it has no callers.
Perhaps we can also add smp_mb__before/after_spinunlock() for
prepare_to_wait().
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit 966fbe193f47c68e70a80ec9991098e88e7959cb upstream.
Some device require DMADIR to be enabled, but are not detected as such
by atapi_id_dmadir. One such example is "Asus Serillel 2"
SATA-host-to-PATA-device bridge: the bridge itself requires DMADIR,
even if the bridged device does not.
As atapi_dmadir module parameter can cause problems with some devices
(as per Tejun Heo's memory), enabling it globally may not be possible
depending on the hardware.
This patch adds atapi_dmadir in the form of a "force" horkage value,
allowing global, per-bus and per-device control.
Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com>
commit f60900f2609e893c7f8d0bccc7ada4947dac4cd5 upstream.
Commit 2171364d1a92 ("powerpc: Add HWCAP2 aux entry") introduced a new
AT_ auxv entry type AT_HWCAP2 but failed to update AT_VECTOR_SIZE_BASE
accordingly.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Fixes: 2171364d1a92 (powerpc: Add HWCAP2 aux entry)
Acked-by: Michael Neuling <michael@neuling.org>
Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
commit 503cf95c061a0551eb684da364509297efbe55d9 upstream.
When compiling with icc, <linux/compiler-gcc.h> ends up included
because the icc environment defines __GNUC__. Thus, we neither need
nor want to have this macro defined in both compiler-gcc.h and
compiler-intel.h, and the fact that they are inconsistent just makes
the compiler spew warnings.
Reported-by: Sunil K. Pandey <sunil.k.pandey@intel.com>
Cc: Kevin B. Smith <kevin.b.smith@intel.com>
Link: http://lkml.kernel.org/n/tip-0mbwou1zt7pafij09b897lg3@git.kernel.org
commit 4fc9bbf98fd66f879e628d8537ba7c240be2b58e upstream.
Add a flag to tell the PCI subsystem that kernel is shutting down in
preparation to kexec a kernel. Add code in PCI subsystem to use this flag
to clear Bus Master bit on PCI devices only in case of kexec reboot.
This fixes a power-off problem on Acer Aspire V5-573G and likely other
machines and avoids any other issues caused by clearing Bus Master bit on
PCI devices in normal shutdown path. The problem was introduced by
b566a22c2332 ("PCI: disable Bus Master on PCI device shutdown").
This patch is based on discussion at
http://marc.info/?l=linux-pci&m=138425645204355&w=2
Link: https://bugzilla.kernel.org/show_bug.cgi?id=63861
Reported-by: Chang Liu <cl91tp@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Konstantin Khlebnikov <koct9i@gmail.com>
commit 674470d97958a0ec72f72caf7f6451da40159cc7 upstream.
In struct gen_pool_chunk, end_addr means the end address of memory chunk
(inclusive), but in the implementation it is treated as address + size of
memory chunk (exclusive), so it points to the address plus one instead of
correct ending address.
The ending address of memory chunk plus one will cause overflow on the
memory chunk including the last address of memory map, e.g. when starting
address is 0xFFF00000 and size is 0x100000 on 32bit machine, ending
address will be 0x100000000.
Use correct ending address like starting address + size - 1.
[akpm@linux-foundation.org: add comment to struct gen_pool_chunk:end_addr]
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
commit 72403b4a0fbdf433c1fe0127e49864658f6f6468 upstream.
Commit 0255d4918480 ("mm: Account for a THP NUMA hinting update as one
PTE update") was added to account for the number of PTE updates when
marking pages prot_numa. task_numa_work was using the old return value
to track how much address space had been updated. Altering the return
value causes the scanner to do more work than it is configured or
documented to in a single unit of work.
This patch reverts that commit and accounts for the number of THP
updates separately in vmstat. It is up to the administrator to
interpret the pair of values correctly. This is a straight-forward
operation and likely to only be of interest when actively debugging NUMA
balancing problems.
The impact of this patch is that the NUMA PTE scanner will scan slower
when THP is enabled and workloads may converge slower as a result. On
the flip size system CPU usage should be lower than recent tests
reported. This is an illustrative example of a short single JVM specjbb
test
specjbb
3.12.0 3.12.0
vanilla acctupdates
TPut 1 26143.00 ( 0.00%) 25747.00 ( -1.51%)
TPut 7 185257.00 ( 0.00%) 183202.00 ( -1.11%)
TPut 13 329760.00 ( 0.00%) 346577.00 ( 5.10%)
TPut 19 442502.00 ( 0.00%) 460146.00 ( 3.99%)
TPut 25 540634.00 ( 0.00%) 549053.00 ( 1.56%)
TPut 31 512098.00 ( 0.00%) 519611.00 ( 1.47%)
TPut 37 461276.00 ( 0.00%) 474973.00 ( 2.97%)
TPut 43 403089.00 ( 0.00%) 414172.00 ( 2.75%)
3.12.0 3.12.0
vanillaacctupdates
User 5169.64 5184.14
System 100.45 80.02
Elapsed 252.75 251.85
Performance is similar but note the reduction in system CPU time. While
this showed a performance gain, it will not be universal but at least
it'll be behaving as documented. The vmstats are obviously different but
here is an obvious interpretation of them from mmtests.
3.12.0 3.12.0
vanillaacctupdates
NUMA page range updates 1408326 11043064
NUMA huge PMD updates 0 21040
NUMA PTE updates 1408326 291624
"NUMA page range updates" == nr_pte_updates and is the value returned to
the NUMA pte scanner. NUMA huge PMD updates were the number of THP
updates which in combination can be used to calculate how many ptes were
updated from userspace.
Reported-by: Alex Thorlton <athorlton@sgi.com>
Cc: <stable@vger.kernel.org>
commit ccf33d6880f39a35158fff66db13000ae4943fac upstream.
We want to be able to remove clockevent modules as well. Add a
refcount so we don't remove a module with an active clock event
device.
Cc: Magnus Damm <magnus.damm@gmail.com>
Link: http://lkml.kernel.org/r/20130425143436.307435149@linutronix.de
Cc: Kim Phillips <kim.phillips@linaro.org>
commit 7172a286ced0c1f4f239a0fa09db54ed37d3ead2 upstream.
7+ years and still a single user. Kill it.
Link: http://lkml.kernel.org/r/20130425143436.098520211@linutronix.de
[ Upstream commit 6aafeef03b9d9ecf255f3a80ed85ee070260e1ae ]
Pushing original fragments through causes several problems. For example
for matching, frags may not be matched correctly. Take following
example:
<example>
On HOSTA do:
ip6tables -I INPUT -p icmpv6 -j DROP
ip6tables -I INPUT -p icmpv6 -m icmp6 --icmpv6-type 128 -j ACCEPT
and on HOSTB you do:
ping6 HOSTA -s2000 (MTU is 1500)
Incoming echo requests will be filtered out on HOSTA. This issue does
not occur with smaller packets than MTU (where fragmentation does not happen)
</example>
As was discussed previously, the only correct solution seems to be to use
reassembled skb instead of separete frags. Doing this has positive side
effects in reducing sk_buff by one pointer (nfct_reasm) and also the reams
dances in ipvs and conntrack can be removed.
Future plan is to remove net/ipv6/netfilter/nf_conntrack_reasm.c
entirely and use code in net/ipv6/reassembly.c instead.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
[ Upstream commit 51c37a70aaa3f95773af560e6db3073520513912 ]
For properly initialising the Tausworthe generator [1], we have
a strict seeding requirement, that is, s1 > 1, s2 > 7, s3 > 15.
Commit 697f8d0348 ("random32: seeding improvement") introduced
a __seed() function that imposes boundary checks proposed by the
errata paper [2] to properly ensure above conditions.
However, we're off by one, as the function is implemented as:
"return (x < m) ? x + m : x;", and called with __seed(X, 1),
__seed(X, 7), __seed(X, 15). Thus, an unwanted seed of 1, 7, 15
would be possible, whereas the lower boundary should actually
be of at least 2, 8, 16, just as GSL does. Fix this, as otherwise
an initialization with an unwanted seed could have the effect
that Tausworthe's PRNG properties cannot not be ensured.
Note that this PRNG is *not* used for cryptography in the kernel.
[1] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme.ps
[2] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme2.ps
Joint work with Hannes Frederic Sowa.
Fixes: 697f8d0348a6 ("random32: seeding improvement")
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
