git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
dmaengine: provide dummy functions for DMA_ENGINE=n
mv_xor: fix race in tasklet function
This lets drivers, optionally using the dmaengine, build with DMA_ENGINE
unselected.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits)
ipv4: dont create routes on down devices
epic100: hamachi: yellowfin: Fix skb allocation size
sundance: Fix oopses with corrupted skb_shared_info
Revert "ipv4: Allow configuring subnets as local addresses"
USB: mcs7830: return negative if auto negotiate fails
irda: prevent integer underflow in IRLMP_ENUMDEVICES
tcp: fix listening_get_next()
atl1c: Do not use legacy PCI power management
mac80211: fix mesh forwarding
MAINTAINERS: email address change
net: Fix range checks in tcf_valid_offset().
net_sched: sch_sfq: fix allot handling
hostap: remove netif_stop_queue from init
mac80211/rt2x00: add ieee80211_tx_status_ni()
typhoon: memory corruption in typhoon_get_drvinfo()
net: Add USB PID for new MOSCHIP USB ethernet controller MCS7832 variant
net_sched: always clone skbs
ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed.
netlink: fix gcc -Wconversion compilation warning
asix: add USB ID for Logitec LAN-GTJ U2A
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: print out alloc information with KERN_DEBUG instead of KERN_INFO
kthread_work: make lockdep happy
The taskstats structure is internally aligned on 8 byte boundaries but the
layout of the aggregrate reply, with two NLA headers and the pid (each 4
bytes), actually force the entire structure to be unaligned. This causes
the kernel to issue unaligned access warnings on some architectures like
ia64. Unfortunately, some software out there doesn't properly unroll the
NLA packet and assumes that the start of the taskstats structure will
always be 20 bytes from the start of the netlink payload. Aligning the
start of the taskstats structure breaks this software, which we don't
want. So, for now the alignment only happens on architectures that
require it and those users will have to update to fixed versions of those
packages. Space is reserved in the packet only when needed. This ifdef
should be removed in several years e.g. 2012 once we can be confident
that fixed versions are installed on most systems. We add the padding
before the aggregate since the aggregate is already a defined type.
Commit 85893120 ("delayacct: align to 8 byte boundary on 64-bit systems")
previously addressed the alignment issues by padding out the pid field.
This was supposed to be a compatible change but the circumstances
described above mean that it wasn't. This patch backs out that change,
since it was a hack, and introduces a new NULL attribute type to provide
the padding. Padding the response with 4 bytes avoids allocating an
aligned taskstats structure and copying it back. Since the structure
weighs in at 328 bytes, it's too big to do it on the stack.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Reported-by: Brian Rogers <brian@xyzw.org>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Guillaume Chazarain <guichaz@gmail.com>
Cc: Balbir Singh <balbir@in.ibm.com>
The current packed struct implementation of unaligned access adds the
packed attribute only to the field within the unaligned struct rather than
to the struct as a whole. This is not sufficient to enforce proper
behaviour on architectures with a default struct alignment of more than
one byte.
For example, the current implementation of __get_unaligned_cpu16 when
compiled for arm with gcc -O1 -mstructure-size-boundary=32 assumes the
struct is on a 4 byte boundary so performs the load of the 16bit packed
field as if it were on a 4 byte boundary:
__get_unaligned_cpu16:
ldrh r0, [r0, #0]
bx lr
Moving the packed attribute to the struct rather than the field causes the
proper unaligned access code to be generated:
ldrb r3, [r0, #0] @ zero_extendqisi2
ldrb r0, [r0, #1] @ zero_extendqisi2
orr r0, r3, r0, asl #8
bx lr
Signed-off-by: Will Newton <will.newton@gmail.com>
spinlock in kthread_worker and wait_queue_head in kthread_work both
should be lockdep sensible, so change the interface to make it
suiltable for CONFIG_LOCKDEP.
tj: comment update
Reported-by: Nicolas <nicolas.mailhot@laposte.net>
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Tested-by: Andy Walls <awalls@md.metrocast.net>
Cc: Tejun Heo <tj@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: handle partial result from get_user_pages
ceph: mark user pages dirty on direct-io reads
ceph: fix null pointer dereference in ceph_init_dentry for nfs reexport
ceph: fix direct-io on non-page-aligned buffers
ceph: fix msgr_init error path
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
cciss: fix cciss_revalidate panic
block: max hardware sectors limit wrapper
block: Deprecate QUEUE_FLAG_CLUSTER and use queue_limits instead
blk-throttle: Correct the placement of smp_rmb()
blk-throttle: Trim/adjust slice_end once a bio has been dispatched
block: check for proper length of iov entries earlier in blk_rq_map_user_iov()
drbd: fix for spin_lock_irqsave in endio callback
drbd: don't recvmsg with zero length
The cnt32_to_63 algorithm relies on proper counter data evaluation
ordering to work properly. This was missing from the provided
documentation.
Let's augment the documentation with the missing usage constraint and
fix the only instance that got it wrong.
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86-32: Make sure we can map all of lowmem if we need to
x86, vt-d: Handle previous faults after enabling fault handling
x86: Enable the intr-remap fault handling after local APIC setup
x86, vt-d: Fix the vt-d fault handling irq migration in the x2apic mode
x86, vt-d: Quirk for masking vtd spec errors to platform error handling logic
x86, xsave: Use alloc_bootmem_align() instead of alloc_bootmem()
bootmem: Add alloc_bootmem_align()
x86, gcc-4.6: Use gcc -m options when building vdso
x86: HPET: Chose a paranoid safe value for the ETIME check
x86: io_apic: Avoid unused variable warning when CONFIG_GENERIC_PENDING_IRQ=n
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf: Fix off by one in perf_swevent_init()
perf: Fix duplicate events with multiple-pmu vs software events
ftrace: Have recordmcount honor endianness in fn_ELF_R_INFO
scripts/tags.sh: Add magic for trace-events
tracing: Fix panic when lseek() called on "trace" opened for writing
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Fix the irqtime code for 32bit
sched: Fix the irqtime code to deal with u64 wraps
nohz: Fix get_next_timer_interrupt() vs cpu hotplug
Sched: fix skip_clock_update optimization
sched: Cure more NO_HZ load average woes
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
x86: avoid high BIOS area when allocating address space
x86: avoid E820 regions when allocating address space
x86: avoid low BIOS area when allocating address space
resources: add arch hook for preventing allocation in reserved areas
Revert "resources: support allocating space within a region from the top down"
Revert "PCI: allocate bus resources from the top down"
Revert "x86/PCI: allocate space from the end of a region, not the beginning"
Revert "x86: allocate space within a region top-down"
Revert "PCI: fix pci_bus_alloc_resource() hang, prefer positive decode"
PCI: Update MCP55 quirk to not affect non HyperTransport variants
$ cat << EOF | gcc -Wconversion -xc -S -o/dev/null -
unsigned f(void) {return NLMSG_HDRLEN;}
EOF
<stdin>: In function 'f':
<stdin>:3:26: warning: negative integer implicitly converted to unsigned type
Signed-off-by: Dmitry V. Levin <ldv@altlinux.org>
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
This adds arch_remove_reservations(), which an arch can implement if it
needs to protect part of the address space from allocation.
Sometimes that can be done by just putting a region in the resource tree,
but there are cases where that doesn't work well. For example, x86 BIOS
E820 reservations are not related to devices, so they may overlap part of,
all of, or more than a device resource, so they may not end up at the
correct spot in the resource tree.
Acked-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This reverts commit e7f8567db9a7f6b3151b0b275e245c1cef0d9c70.
For read operation, we have to set the argument _write_ of get_user_pages
to 1 since we will write data to pages. Also, we need to SetPageDirty before
releasing these pages.
Signed-off-by: Henry C Chang <henry_c_chang@tcloudcomputing.com>
Signed-off-by: Sage Weil <sage@newdream.net>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM / Runtime: Fix pm_runtime_suspended()
PM / Hibernate: Restore old swap signature to avoid user space breakage
PM / Hibernate: Fix PM_POST_* notification with user-space suspend
Implement blk_limits_max_hw_sectors() and make
blk_queue_max_hw_sectors() a wrapper around it.
DM needs this to avoid setting queue_limits' max_hw_sectors and
max_sectors directly. dm_set_device_limits() now leverages
blk_limits_max_hw_sectors() logic to establish the appropriate
max_hw_sectors minimum (PAGE_SIZE). Fixes issue where DM was
incorrectly setting max_sectors rather than max_hw_sectors (which
caused dm_merge_bvec()'s max_hw_sectors check to be ineffective).
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: stable@kernel.org
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
When stacking devices, a request_queue is not always available. This
forced us to have a no_cluster flag in the queue_limits that could be
used as a carrier until the request_queue had been set up for a
metadevice.
There were several problems with that approach. First of all it was up
to the stacking device to remember to set queue flag after stacking had
completed. Also, the queue flag and the queue limits had to be kept in
sync at all times. We got that wrong, which could lead to us issuing
commands that went beyond the max scatterlist limit set by the driver.
The proper fix is to avoid having two flags for tracking the same thing.
We deprecate QUEUE_FLAG_CLUSTER and use the queue limit directly in the
block layer merging functions. The queue_limit 'no_cluster' is turned
into 'cluster' to avoid double negatives and to ease stacking.
Clustering defaults to being enabled as before. The queue flag logic is
removed from the stacking function, and explicitly setting the cluster
flag is no longer necessary in DM and MD.
Reported-by: Ed Lin <ed.lin@promise.com>
Acked-by: Mike Snitzer <snitzer@redhat.com>
* 'for-linus' of git://git.infradead.org/users/eparis/notify:
fanotify: fill in the metadata_len field on struct fanotify_event_metadata
fanotify: split version into version and metadata_len
fanotify: Dont try to open a file descriptor for the overflow event
fanotify: Introduce FAN_NOFD
fanotify: do not leak user reference on allocation failure
inotify: stop kernel memory leak on file creation failure
fanotify: on group destroy allow all waiters to bypass permission check
fanotify: Dont allow a mask of 0 if setting or removing a mark
fanotify: correct broken ref counting in case adding a mark failed
fanotify: if set by user unset FMODE_NONOTIFY before fsnotify_perm() is called
fanotify: remove packed from access response message
fanotify: deny permissions when no event was sent
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (28 commits)
MIPS: Add a CONFIG_FORCE_MAX_ZONEORDER Kconfig option.
MIPS: LD/SD o32 macro GAS fix update
MIPS: Alchemy: fix build with SERIAL_8250=n
MIPS: Rename mips_dma_cache_sync back to dma_cache_sync
MIPS: MT: Fix typo in comment.
SSB: Fix nvram_get on BCM47xx platform
MIPS: BCM47xx: Swap serial console if ttyS1 was specified.
MIPS: BCM47xx: Use sscanf for parsing mac address
MIPS: BCM47xx: Fill values for b43 into SSB sprom
MIPS: BCM47xx: Do not read config from CFE
MIPS: FDT size is a be32
MIPS: Fix CP0 COUNTER clockevent race
MIPS: Fix regression on BCM4710 processor detection
MIPS: JZ4740: Fix pcm device name
MIPS: Separate two consecutive loads in memset.S
MIPS: Send proper signal and siginfo on FP emulator faults.
MIPS: AR7: Fix loops per jiffies on TNETD7200 devices
MIPS: AR7: Fix double ar7_gpio_init declaration
MIPS: Rework GENERIC_HARDIRQS Kconfig.
MIPS: Alchemy: Add return value check for strict_strtoul()
The nvram_get function was never in the mainline kernel, it only existed in
an external OpenWrt patch. Use nvram_getenv function, which is in mainline
and use an include instead of an extra function declaration. et0macaddr
contains the mac address in text from like 00:11:22:33:44:55. We have to
parse it before adding it into macaddr.
nvram_parse_macaddr will be merged into asm/mach-bcm47xx/nvram.h through
the MIPS git tree and will be available soon. It will not build now without
nvram_parse_macaddr, but it hasn't before either.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
To: linux-mips@linux-mips.org
Cc: mb@bu3sch.de
Cc: netdev@vger.kernel.org
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Acked-by: Michael Buesch <mb@bu3sch.de>
Patchwork: https://patchwork.linux-mips.org/patch/1849/
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: define separate EVIOCGKEYCODE_V2/EVIOCSKEYCODE_V2
Input: wacom - add another Bamboo Pen ID (0xd4)
There are some situations (e.g. in __pm_generic_call()), where
pm_runtime_suspended() is used to decide whether or not to execute
a device's (system) ->suspend() callback. The callback is not
executed if pm_runtime_suspended() returns true, but it does so
for devices that don't even support runtime PM, because the
power.disable_depth device field is ignored by it. This leads to
problems (i.e. devices are not suspened when they should), so rework
pm_runtime_suspended() so that it returns false if the device's
power.disable_depth field is different from zero.
To implement per event type optional headers we are interested in
knowing how long the metadata structure is. This patch slits the __u32
version field into a __u8 version and a __u16 metadata_len field (with
__u8 left over). This should allow for backwards compat ABI.
Signed-off-by: Alexey Zaytsev <alexey.zaytsev@gmail.com>
[rewrote descrtion and changed object sizes and ordering - eparis]
Signed-off-by: Eric Paris <eparis@redhat.com>
The desire to keep old names for the EVIOCGKEYCODE/EVIOCSKEYCODE while
extending them to support large scancodes was a mistake. While we tried
to keep ABI intact (and we succeeded in doing that, programs compiled
on older kernels will work on newer ones) there is still a problem with
recompiling existing software with newer kernel headers.
New kernel headers will supply updated ioctl numbers and kernel will
expect that userspace will use struct input_keymap_entry to set and
retrieve keymap data. But since the names of ioctls are still the same
userspace will happily compile even if not adjusted to make use of the
new structure and will start miraculously fail in the field.
To avoid this issue let's revert EVIOCGKEYCODE/EVIOCSKEYCODE definitions
and add EVIOCGKEYCODE_V2/EVIOCSKEYCODE_V2 so that userspace can explicitly
select the style of ioctls it wants to employ.
Reviewed-by: Henrik Rydberg <rydberg@euromail.se>
Acked-by: Jarod Wilson <jarod@redhat.com>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (75 commits)
pppoe.c: Fix kernel panic caused by __pppoe_xmit
WAN: Fix a TX IRQ causing BUG() in PC300 and PCI200SYN drivers.
bnx2x: Advance a version number to 1.60.01-0
bnx2x: Fixed a compilation warning
bnx2x: LSO code was broken on BE platforms
qlge: Fix deadlock when cancelling worker.
net: fix skb_defer_rx_timestamp()
cxgb4vf: Ingress Queue Entry Size needs to be 64 bytes
phy: add the IC+ IP1001 driver
atm: correct sysfs 'device' link creation and parent relationships
MAINTAINERS: remove me from tulip
SCTP: Fix SCTP_SET_PEER_PRIMARY_ADDR to accpet v4mapped address
enic: Bug Fix: Pass napi reference to the isr that services receive queue
ipv6: fix nl group when advertising a new link
connector: add module alias
net: Document the kernel_recvmsg() function
r8169: Fix runtime power management
hso: IP checksuming doesn't work on GE0301 option cards
xfrm: Fix xfrm_state_migrate leak
net: Convert netpoll blocking api in bonding driver to be a counter
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI / PM: Do not save/restore NVS on Sony Vaio VGN-NW130D
ACPI/HEST: adjust section selection
ACPI: eliminate unused variable warning for !ACPI_SLEEP
ACPI/PNP: avoid section mismatch warning
ACPI thermal: remove two unused functions
ACPI: fix a section mismatch
ACPI, APEI, use raw spinlock in ERST
ACPI: video: fix build for CONFIG_ACPI=n
ACPI: video: fix build for VIDEO_OUTPUT_CONTROL=n
ACPI: fix allowing to add/remove multiple _OSI strings
acpi: fix _OSI string setup regression
ACPI: EC: Add another dmi match entry for MSI hardware
ACPI battery: update status upon sysfs query
ACPI ac: update AC status upon sysfs query
ACPI / PM: Do not refcount power resources that can't be turned on
ACPI / PM: Check device state before refcounting power resources
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: HDA: Quirk for Dell Vostro 320 to make microphone work
ALSA: hda - Reset sample sizes and max bitrates when reading ELD
ALSA: hda - Always allow basic audio irrespective of ELD info
ALSA: hda - Do not wrongly restrict min_channels based on ELD
ASoC: Correct WM8962 interrupt mask register read
ASoC: WM8580: Debug BCLK and sample size
ASoC: Fix resource leak if soc_register_ac97_dai_link failed
ASoC: Hold client_mutex while calling snd_soc_instantiate_cards()
ASoC: Fix swap of left and right channels for WM8993/4 speaker boost gain
ASoC: Fix off by one error in WM8994 EQ register bank size
ALSA: hda: Use position_fix=1 for Acer Aspire 5538 to enable capture on internal mic
ALSA: hda - Enable jack sense for Thinkpad Edge 13
ALSA: hda - Fix ThinkPad T410[s] docking station line-out
ALSA: hda: Use model=lg quirk for LG P1 Express to enable playback and capture
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
NFS: Fix panic after nfs_umount()
nfs: remove extraneous and problematic calls to nfs_clear_request
nfs: kernel should return EPROTONOSUPPORT when not support NFSv4
NFS: Fix fcntl F_GETLK not reporting some conflicts
nfs: Discard ACL cache on mode update
NFS: Readdir cleanups
NFS: nfs_readdir_search_for_cookie() don't mark as eof if cookie not found
NFS: Fix a memory leak in nfs_readdir
Call the filesystem back whenever a page is removed from the page cache
NFS: Ensure we use the correct cookie in nfs_readdir_xdr_filler
Add an alloc_bootmem_align() interface to allocate bootmem with
specified alignment. This is necessary to be able to allocate the
xsave area in a subsequent patch.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <20101116212441.977574826@sbsiddha-MOBL3.sc.intel.com>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Cc: <stable@kernel.org>
'misc-2.6.37' and 'osi-regression' into release
drivers/built-in.o: In function `acpi_video_bus_put_devices':
video.c:(.text+0x79663): undefined reference to
`video_output_unregister'
drivers/built-in.o: In function `acpi_video_bus_add':
video.c:(.text+0x7b0b3): undefined reference to `video_output_register'
Signed-off-by: Len Brown <len.brown@intel.com>
commit b0ed7a91(ACPICA/ACPI: Add new host interfaces for _OSI suppor)
introduced a regression that _OSI string setup fails.
There are 2 paths to setup _OSI string.
DMI:
acpi_dmi_osi_linux -> set_osi_linux -> acpi_osi_setup -> copy _OSI
string to osi_setup_string
Boot command line:
acpi_osi_setup -> copy _OSI string to osi_setup_string
Later, acpi_osi_setup_late will be called to handle osi_setup_string.
If _OSI string is "Linux" or "!Linux", then the call path is,
acpi_osi_setup_late -> acpi_cmdline_osi_linux -> set_osi_linux ->
This actually never installs _OSI string(acpi_install_interface not
called), but just copy the _OSI string to osi_setup_string.
This patch fixes the regression.
Reported-and-tested-by: Lukas Hejtmanek <xhejtman@ics.muni.cz>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
The ATM subsystem was incorrectly creating the 'device' link for ATM
nodes in sysfs. This led to incorrect device/parent relationships
exposed by sysfs and udev. Instead of rolling the 'device' link by hand
in the generic ATM code, pass each ATM driver's bus device down to the
sysfs code and let sysfs do this stuff correctly.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Rather than printing the message to the log, use a mib counter to keep
track of the count of occurences of time wait bucket overflow. Reduces
spam in logs.
Signed-off-by: Tom Herbert <therbert@google.com>
There's a long-running regression that proved difficult to fix and
which is hitting certain people and is rather annoying in its effects.
Damien reported that after 74f5187ac8 (sched: Cure load average vs
NO_HZ woes) his load average is unnaturally high, he also noted that
even with that patch reverted the load avgerage numbers are not
correct.
The problem is that the previous patch only solved half the NO_HZ
problem, it addressed the part of going into NO_HZ mode, not of
comming out of NO_HZ mode. This patch implements that missing half.
When comming out of NO_HZ mode there are two important things to take
care of:
- Folding the pending idle delta into the global active count.
- Correctly aging the averages for the idle-duration.
So with this patch the NO_HZ interaction should be complete and
behaviour between CONFIG_NO_HZ=[yn] should be equivalent.
Furthermore, this patch slightly changes the load average computation
by adding a rounding term to the fixed point multiplication.
Reported-by: Damien Wyart <damien.wyart@free.fr>
Reported-by: Tim McGrath <tmhikaru@gmail.com>
Tested-by: Damien Wyart <damien.wyart@free.fr>
Tested-by: Orion Poplawski <orion@cora.nwra.com>
Tested-by: Kyle McMartin <kyle@mcmartin.ca>
Cc: Chase Douglas <chase.douglas@canonical.com>
LKML-Reference: <1291129145.32004.874.camel@laptop>
Because the multi-pmu bits can share contexts between struct pmu
instances we could get duplicate events by iterating the pmu list.
LKML-Reference: <new-submission>
Input: wacom - add new Bamboo PT (0xdb)
Input: add input driver for polled GPIO buttons
Input: turbografx - fix reference counting
Input: synaptics - fix handling of 2-button ClickPads
Input: wacom - add IDs for two new Bamboo PTs
Input: document struct input_absinfo
Input: add keycodes for touchpad on/off keys
Input: usbtouchscreen - add support for LG Flatron T1710B
When a nfs_page is freed, nfs_free_request is called which also calls
nfs_clear_request to clean out the lock and open contexts and free the
pagecache page.
However, a couple of places in the nfs code call nfs_clear_request
themselves. What happens here if the refcount on the request is still high?
We'll be releasing contexts and freeing pointers while the request is
possibly still in use.
Remove those bare calls to nfs_clear_context. That should only be done when
the request is being freed.
Note that when doing this, we need to watch out for tests of req->wb_page.
Previously, nfs_set_page_tag_locked() and nfs_clear_page_tag_locked()
would check the value of req->wb_page to figure out if the page is mapped
into the nfsi->nfs_page_tree. We now indicate the page is mapped using
the new bit PG_MAPPED in req->wb_flags .
Reported-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
FAN_NOFD is used in fanotify events that do not provide an open file
descriptor (like the overflow_event).
Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
When fanotify_release() is called, there may still be processes waiting for
access permission. Currently only processes for which an event has already been
queued into the groups access list will be woken up. Processes for which no
event has been queued will continue to sleep and thus cause a deadlock when
fsnotify_put_group() is called.
Furthermore there is a race allowing further processes to be waiting on the
access wait queue after wake_up (if they arrive before clear_marks_by_group()
is called).
This patch corrects this by setting a flag to inform processes that the group
is about to be destroyed and thus not to wait for access permission.
[additional changelog from eparis]
Lets think about the 4 relevant code paths from the PoV of the
'operator' 'listener' 'responder' and 'closer'. Where operator is the
process doing an action (like open/read) which could require permission.
Listener is the task (or in this case thread) slated with reading from
the fanotify file descriptor. The 'responder' is the thread responsible
for responding to access requests. 'Closer' is the thread attempting to
close the fanotify file descriptor.
The 'operator' is going to end up in:
fanotify_handle_event()
get_response_from_access()
(THIS BLOCKS WAITING ON USERSPACE)
The 'listener' interesting code path
fanotify_read()
copy_event_to_user()
prepare_for_access_response()
(THIS CREATES AN fanotify_response_event)
The 'responder' code path:
fanotify_write()
process_access_response()
(REMOVE A fanotify_response_event, SET RESPONSE, WAKE UP 'operator')
The 'closer':
fanotify_release()
(SUPPOSED TO CLEAN UP THE REST OF THIS MESS)
What we have today is that in the closer we remove all of the
fanotify_response_events and set a bit so no more response events are
ever created in prepare_for_access_response().
The bug is that we never wake all of the operators up and tell them to
move along. You fix that in fanotify_get_response_from_access(). You
also fix other operators which haven't gotten there yet. So I agree
that's a good fix.
[/additional changelog from eparis]
[remove additional changes to minimize patch size]
[move initialization so it was inside CONFIG_FANOTIFY_PERMISSION]
Unsetting FMODE_NONOTIFY in fsnotify_open() is too late, since fsnotify_perm()
is called before. If FMODE_NONOTIFY is set fsnotify_perm() will skip permission
checks, so a user can still disable permission checks by setting this flag
in an open() call.
This patch corrects this by unsetting the flag before fsnotify_perm is called.
Since fanotify has decided to be careful about alignment and packing
rather than rely on __attribute__((packed)) for multiarch support.
Since this attribute isn't doing anything on fanotify_response we just
drop it. This does not break API/ABI.
Suggested-by: Tvrtko Ursulin <tvrtko.ursulin@sophos.com>
The existing gpio-keys driver can be usable only for GPIO lines with
interrupt support. Several devices have buttons connected to a GPIO
line which is not capable to generate interrupts. This patch adds a
new input driver using the generic GPIO layer and the input-polldev
to support such buttons.
[Ben Gardiner <bengardiner@nanometrics.ca: fold code to use more
of the original gpio_keys infrastructure; cleanups and other
improvements.]
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
PM / Hibernate: Fix memory corruption related to swap
PM / Hibernate: Use async I/O when reading compressed hibernation image
There is a problem that swap pages allocated before the creation of
a hibernation image can be released and used for storing the contents
of different memory pages while the image is being saved. Since the
kernel stored in the image doesn't know of that, it causes memory
corruption to occur after resume from hibernation, especially on
systems with relatively small RAM that need to swap often.
This issue can be addressed by keeping the GFP_IOFS bits clear
in gfp_allowed_mask during the entire hibernation, including the
saving of the image, until the system is finally turned off or
the hibernation is aborted. Unfortunately, for this purpose
it's necessary to rework the way in which the hibernate and
suspend code manipulates gfp_allowed_mask.
This change is based on an earlier patch from Hugh Dickins.
Reported-by: Ondrej Zary <linux@rainbow-software.org>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Uk Kim <w0806.kim@samsung.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
