There is a problem that swap pages allocated before the creation of
a hibernation image can be released and used for storing the contents
of different memory pages while the image is being saved. Since the
kernel stored in the image doesn't know of that, it causes memory
corruption to occur after resume from hibernation, especially on
systems with relatively small RAM that need to swap often.
This issue can be addressed by keeping the GFP_IOFS bits clear
in gfp_allowed_mask during the entire hibernation, including the
saving of the image, until the system is finally turned off or
the hibernation is aborted. Unfortunately, for this purpose
it's necessary to rework the way in which the hibernate and
suspend code manipulates gfp_allowed_mask.
This change is based on an earlier patch from Hugh Dickins.
Reported-by: Ondrej Zary <linux@rainbow-software.org>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6
* 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6:
sisfb: delete osdef.h
sisfb: move the CONFIG warning to sis_main.c
sisfb: replace SiS_SetMemory with memset_io
sisfb: remove InPort/OutPort wrappers
sisfb: use CONFIG_FB_SIS_301/315 instead of SIS301/315H
sisfb: delete redudant #define SIS_LINUX_KERNEL
sisfb: delete dead SIS_XORG_XF86 code
sisfb: delete fallback code for pci_map_rom()
sisfb: delete obsolete PCI ROM bug workaround
fbdev: Update documentation index file.
lxfb: Program panel v/h sync output polarity correctly
fbcmap: integer overflow bug
fbcmap: cleanup white space in fb_alloc_cmap()
MAINTAINERS: Add fbdev patchwork entry, tidy up file patterns.
fbdev: da8xx: punt duplicated FBIO_WAITFORVSYNC define
fbdev: sh_mobile_lcdcfb: fix bug in reconfig()
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: clkfwk: Build fix for non-legacy CPG changes.
sh: Use GCC __builtin_prefetch() to implement prefetch().
sh: fix vsyscall compilation due to .eh_frame issue
sh: avoid to flush all cache in sys_cacheflush
sh: clkfwk: Disable init clk op for non-legacy clocks.
sh: clkfwk: Kill off now unused algo_id in set_rate op.
sh: clkfwk: Kill off unused clk_set_rate_ex().
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
virtio: fix format of sysfs driver/vendor files
Char: virtio_console, fix memory leak
virtio: return correct capacity to users
module: Update prototype for ref_module (formerly use_module)
Fix this:
kernel BUG at mm/memcontrol.c:2155!
invalid opcode: 0000 [#1]
last sysfs file:
Pid: 18, comm: sh Not tainted 2.6.37-rc3 #3 /Bochs
EIP: 0060:[<c10731b2>] EFLAGS: 00000246 CPU: 0
EIP is at mem_cgroup_move_account+0xe2/0xf0
EAX: 00000004 EBX: c6f931d4 ECX: c681c300 EDX: c681c000
ESI: c681c300 EDI: ffffffea EBP: c681c000 ESP: c46f3e30
DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
Process sh (pid: 18, ti=c46f2000 task=c6826e60 task.ti=c46f2000)
Stack:
00000155 c681c000 0805f000 c46ee180 c46f3e5c c7058820 c1074d37 00000000
08060000 c46db9a0 c46ec080 c7058820 0805f000 08060000 c46f3e98 c1074c50
c106c75e c46f3e98 c46ec080 08060000 0805ffff c46db9a0 c46f3e98 c46e0340
Call Trace:
[<c1074d37>] ? mem_cgroup_move_charge_pte_range+0xe7/0x130
[<c1074c50>] ? mem_cgroup_move_charge_pte_range+0x0/0x130
[<c106c75e>] ? walk_page_range+0xee/0x1d0
[<c10725d6>] ? mem_cgroup_move_task+0x66/0x90
[<c1072570>] ? mem_cgroup_move_task+0x0/0x90
[<c1042616>] ? cgroup_attach_task+0x136/0x200
[<c1042878>] ? cgroup_tasks_write+0x48/0xc0
[<c1041e9e>] ? cgroup_file_write+0xde/0x220
[<c101398d>] ? do_page_fault+0x17d/0x3f0
[<c108a79d>] ? alloc_fd+0x2d/0xd0
[<c1041dc0>] ? cgroup_file_write+0x0/0x220
[<c1077ba2>] ? vfs_write+0x92/0xc0
[<c1077c81>] ? sys_write+0x41/0x70
[<c1140e3d>] ? syscall_call+0x7/0xb
Code: 03 00 74 09 8b 44 24 04 e8 1c f1 ff ff 89 73 04 8d 86 b0 00 00 00 b9 01 00 00 00 89 da 31 ff e8 65 f5 ff ff e9 4d ff ff ff 0f 0b <0f> 0b 0f 0b 0f 0b 90 8d b4 26 00 00 00 00 83 ec 10 8b 0d f4 e3
EIP: [<c10731b2>] mem_cgroup_move_account+0xe2/0xf0 SS:ESP 0068:c46f3e30
---[ end trace 7daa1582159b6532 ]---
lock_page_cgroup and unlock_page_cgroup are implemented using
bit_spinlock. bit_spinlock doesn't touch the bit if we are on non-SMP
machine, so we can't use the bit to check whether the lock was taken.
Let's introduce is_page_cgroup_locked based on bit_spin_is_locked instead
of PageCgroupLocked to fix it.
[akpm@linux-foundation.org: s/is_page_cgroup_locked/page_is_cgroup_locked/]
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujtisu.com>
dpkg uses fiemap but didn't particularly need to include stdint.h so far.
Since 367a51a33902 ("fs: Add FITRIM ioctl"), build of linux/fs.h failed in
dpkg with:
In file included from ../../src/filesdb.c:27:0:
/usr/include/linux/fs.h:37:2: error: expected specifier-qualifier-list before 'uint64_t'
Use exportable type __u64 to avoid the dependency on stdint.h.
b31d42a5af18 ("Fix compile brekage with !CONFIG_BLOCK") fixed only the
kernel build by including linux/types.h, but this also fixed "make
headers_check", so don't revert it.
Signed-off-by: Loïc Minier <loic.minier@linaro.org>
Tested-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Cc: Lukas Czerner <lczerner@redhat.com>
Cc: Dmitry Monakhov <dmonakhov@openvz.org>
Cc: Theodore Ts'o <tytso@mit.edu>
Commit 9bea7f23952d5948f8e5dfdff4de09bb9981fb5f renamed use_module to
ref_module (and changed its return value), but forgot to update this
prototype in module.h.
Signed-off-by: Anders Kaseorg <andersk@ksplice.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (41 commits)
ALSA: hda - Identify more variants for ALC269
ALSA: hda - Fix wrong ALC269 variant check
ALSA: hda - Enable jack sense for Thinkpad Edge 11
ALSA: Revert "ALSA: hda - Fix switching between dmic and mic using the same mux on IDT/STAC"
ALSA: hda - Fixed ALC887-VD initial error
ALSA: atmel - Fix the return value in error path
ALSA: hda: Use hp-laptop quirk to enable headphones automute for Asus A52J
ALSA: snd-atmel-abdac: test wrong variable
ALSA: azt3328: period bug fix (for PA), add missing ACK on stop timer
ALSA: hda: Add Samsung R720 SSID for subwoofer pin fixup
ALSA: sound/pci/asihpi/hpioctl.c: Remove unnecessary casts of pci_get_drvdata
ALSA: sound/core/pcm_lib.c: Remove unnecessary semicolons
ALSA: sound/ppc: Use printf extension %pR for struct resource
ALSA: ac97: Apply quirk for Dell Latitude D610 binding Master and Headphone controls
ASoC: uda134x - set reg_cache_default to uda134x_reg
ASoC: Add support for MAX98089 CODEC
ASoC: davinci: fixes for multi-component
ASoC: Fix register cache setup WM8994 for multi-component
ASoC: Fix dapm_seq_compare() for multi-component
ASoC: RX1950: Fix hw_params function
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
of/phylib: Use device tree properties to initialize Marvell PHYs.
phylib: Add support for Marvell 88E1149R devices.
phylib: Use common page register definition for Marvell PHYs.
qlge: Fix incorrect usage of module parameters and netdev msg level
ipv6: fix missing in6_ifa_put in addrconf
SuperH IrDA: correct Baud rate error correction
atl1c: Fix hardware type check for enabling OTP CLK
net: allow GFP_HIGHMEM in __vmalloc()
bonding: change list contact to netdev@vger.kernel.org
e1000: fix screaming IRQ
The 88E1149R is 10/100/1000 quad-gigabit Ethernet PHY. The
.config_aneg function can be shared with 88E1118, but it needs its own
.config_init.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Cc: Cyril Chemparathy <cyril@ti.com>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Cc: Wolfram Sang <w.sang@pengutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: Add EXT4_IOC_TRIM ioctl to handle batched discard
fs: Do not dispatch FITRIM through separate super_operation
ext4: ext4_fill_super shouldn't return 0 on corruption
jbd2: fix /proc/fs/jbd2/<dev> when using an external journal
ext4: missing unlock in ext4_clear_request_list()
ext4: fix setting random pages PageUptodate
There was concern that FITRIM ioctl is not common enough to be included
in core vfs ioctl, as Christoph Hellwig pointed out there's no real point
in dispatching this out to a separate vector instead of just through
->ioctl.
So this commit removes ioctl_fstrim() from vfs ioctl and trim_fs
from super_operation structure.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: fix readdir EOVERFLOW on 32-bit archs
ceph: fix frag offset for non-leftmost frags
ceph: fix dangling pointer
ceph: explicitly specify page alignment in network messages
ceph: make page alignment explicit in osd interface
ceph: fix comment, remove extraneous args
ceph: fix update of ctime from MDS
ceph: fix version check on racing inode updates
ceph: fix uid/gid on resent mds requests
ceph: fix rdcache_gen usage and invalidate
ceph: re-request max_size if cap auth changes
ceph: only let auth caps update max_size
ceph: fix open for write on clustered mds
ceph: fix bad pointer dereference in ceph_fill_trace
ceph: fix small seq message skipping
Revert "ceph: update issue_seq on cap grant"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (31 commits)
net: fix kernel-doc for sk_filter_rcu_release
be2net: Fix to avoid firmware update when interface is not open.
netfilter: fix IP_VS dependencies
net: irda: irttp: sync error paths of data- and udata-requests
ipv6: Expose reachable and retrans timer values as msecs
ipv6: Expose IFLA_PROTINFO timer values in msecs instead of jiffies
3c59x: fix build failure on !CONFIG_PCI
ipg.c: remove id [SUNDANCE, 0x1021]
net: caif: spi: fix potential NULL dereference
ath9k_htc: Avoid setting QoS control for non-QoS frames
net: zero kobject in rx_queue_release
net: Fix duplicate volatile warning.
MAINTAINERS: Add stmmac maintainer
bonding: fix a race in IGMP handling
cfg80211: fix can_beacon_sec_chan, reenable HT40
gianfar: fix signedness issue
net: bnx2x: fix error value sign
8139cp: fix checksum broken
r8169: fix checksum broken
rds: Integer overflow in RDS cmsg handling
This really isn't the right thing to do, and strictly speaking we should
have the BKL depth count in the thread info right next to the preempt
count. The two really do go together.
However, since that would involve a patch to all architectures, and the
BKL is finally going away, it's simply not worth the effort to do the
RightThing(tm). Just re-instate the <linux/sched.h> include that we
used to get accidentally from the smp_lock.h one.
This is all fallout from the same old "BKL: remove extraneous #include
<smp_lock.h>" commit.
Reported-by: Ingo Molnar <mingo@elte.hu>
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Commit 451a3c24b013 ("BKL: remove extraneous #include <smp_lock.h>")
removed the #include line that was the only thing that was surrounded by
the #ifdef/#endif.
So now that #ifdef is guarding nothing at all. Just remove it.
Reported-by: Byeong-ryeol Kim <brofkims@gmail.com>
Arnd Bergmann did an automated scripting run to find left-over instances
of <linux/smp_lock.h>, and had made it trigger it on the normal BKL use
of lock_kernel and unlock_lernel (and apparently release_kernel_lock and
reacquire_kernel_lock too, used by the scheduler).
That resulted in commit 451a3c24b013 ("BKL: remove extraneous #include
<smp_lock.h>").
However, hardirq.h was the only remaining user of the old
'kernel_locked()' interface, and Arnd's script hadn't checked for that.
So depending on your configuration and what header files had been
included, you would get errors like "implicit declaration of function
'kernel_locked'" during the build.
The right fix is not to just re-instate the smp_lock.h include - it is
to just remove 'kernel_locked()' entirely, since the only use was this
one special low-level detail. Just make hardirq.h do it directly.
In fact this simplifies and clarifies the code, because some trivial
analysis makes it clear that hardirq.h only ever used _one_ of the two
definitions of kernel_locked(), so we can remove the other one entirely.
Reported-by: Zimny Lech <napohybelskurwysynom2010@gmail.com>
Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
There is an integer overflow in fb_set_user_cmap() because cmap->len * 2
can wrap. It's basically harmless. Your terminal will be messed up
until you type reset.
This patch does three things to fix the bug.
First, it checks the return value of fb_copy_cmap() in fb_alloc_cmap().
That is enough to fix address the overflow.
Second it checks for the integer overflow in fb_set_user_cmap().
Lastly I wanted to cap "cmap->len" in fb_set_user_cmap() much lower
because it gets used to determine the size of allocation. Unfortunately
no one knows what the limit should be. Instead what this patch does
is makes the allocation happen with GFP_KERNEL instead of GFP_ATOMIC
and lets the kmalloc() decide what values of cmap->len are reasonable.
To do this, the patch introduces a function called fb_alloc_cmap_gfp()
which is like fb_alloc_cmap() except that it takes a GFP flag.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
nfs: Ignore kmemleak false positive in nfs_readdir_make_qstr
SUNRPC: Simplify rpc_alloc_iostats by removing pointless local variable
nfs: trivial: remove unused nfs_wait_event macro
NFS: readdir shouldn't read beyond the reply returned by the server
NFS: Fix a couple of regressions in readdir.
Revert "NFSv4: Fall back to ordinary lookup if nfs4_atomic_open() returns EISDIR"
Regression: fix mounting NFS when NFSv3 support is not compiled
NLM: Fix a regression in lockd
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Fix cross-sched-class wakeup preemption
sched: Fix runnable condition for stoptask
sched: Use group weight, idle cpu metrics to fix imbalances during idle
Move the mid-layer's ->queuecommand() invocation from being locked
with the host lock to being unlocked to facilitate speeding up the
critical path for drivers who don't need this lock taken anyway.
The patch below presents a simple SCSI host lock push-down as an
equivalent transformation. No locking or other behavior should change
with this patch. All existing bugs and locking orders are preserved.
Additionally, add one parameter to queuecommand,
struct Scsi_Host *
and remove one parameter from queuecommand,
void (*done)(struct scsi_cmnd *)
Scsi_Host* is a convenient pointer that most host drivers need anyway,
and 'done' is redundant to struct scsi_cmnd->scsi_done.
Minimal code disturbance was attempted with this change. Most drivers
needed only two one-line modifications for their host lock push-down.
Acked-by: James Bottomley <James.Bottomley@suse.de>
Nothing uses this macro anymore.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Nick Bowler reports:
There are no unusual messages on the client... but I just logged into
the server and I see lots of messages of the following form:
nfsd: request from insecure port (192.168.8.199:35766)!
Bisected to commit 9247685088398cf21bcb513bd2832b4cd42516c4 (SUNRPC:
Properly initialize sock_xprt.srcaddr in all cases)
Apparently, removing the 'transport->srcaddr.ss_family = family' from
xs_create_sock() triggers this due to nlmclnt_lookup_host() incorrectly
initialising the srcaddr family to AF_UNSPEC.
Reported-by: Nick Bowler <nbowler@elliptictech.com>
The addition of CONFIG_SECURITY_DMESG_RESTRICT resulted in a build
failure when CONFIG_PRINTK=n. This is because the capabilities code
which used the new option was built even though the variable in question
didn't exist.
The patch here fixes this by moving the capabilities checks out of the
LSM and into the caller. All (known) LSMs should have been calling the
capabilities hook already so it actually makes the code organization
better to eliminate the hook altogether.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: James Morris <jmorris@namei.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c: Sanity checks on adapter registration
i2c: Mark i2c_adapter.id as deprecated
i2c: Drivers shouldn't include <linux/i2c-id.h>
i2c: Delete unused adapter IDs
i2c: Remove obsolete cleanup for clientdata
It's about time to make it clear that i2c_adapter.id is deprecated.
Hopefully this will remind the last user to move over to a different
strategy.
Acked-by: Jarod Wilson <jarod@redhat.com>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
Delete unused I2C adapter IDs. Special cases are:
* I2C_HW_B_RIVA was still set in driver rivafb, however no other
driver is ever looking for this value, so we can safely remove it.
* I2C_HW_B_HDPVR is used in staging driver lirc_zilog, however no
adapter ID is ever set to this value, so the code in question never
runs. As the code additionally expects that I2C_HW_B_HDPVR may not
be defined, we can delete it now and let the lirc_zilog driver
maintainer rewrite this piece of code.
Big thanks for Hans Verkuil for doing all the hard work :)
Move the logging bits from kernel.h into printk.h so that
there is a bit more logical separation of the generic from
the printk logging specific parts.
The commit below added a new helper dev_ingress_queue to cleanly obtain the
ingress queue pointer. This necessitated including 'linux/netdevice.h':
commit 24824a09e35402b8d58dcc5be803a5ad3937bdba
Author: Eric Dumazet <eric.dumazet@gmail.com>
Date: Sat Oct 2 06:11:55 2010 +0000
net: dynamic ingress_queue allocation
However this include triggers issues for applications in userspace
which use the rtnetlink interfaces. Commonly this requires they include
'net/if.h' and 'linux/rtnetlink.h' leading to a compiler error as below:
In file included from /usr/include/linux/netdevice.h:28:0,
from /usr/include/linux/rtnetlink.h:9,
from t.c:2:
/usr/include/linux/if.h:135:8: error: redefinition of ‘struct ifmap’
/usr/include/net/if.h:112:8: note: originally defined here
/usr/include/linux/if.h:169:8: error: redefinition of ‘struct ifreq’
/usr/include/net/if.h:127:8: note: originally defined here
/usr/include/linux/if.h:218:8: error: redefinition of ‘struct ifconf’
/usr/include/net/if.h:177:8: note: originally defined here
The new helper is only defined for the kernel and protected by __KERNEL__
therefore we can simply pull the include down into the same protected
section.
Signed-off-by: Andy Whitcroft <apw@canonical.com>
fsl-diu-fb: drop dead ioctl define
MAINTAINERS: Add an fbdev git tree entry.
OMAP: DSS: Fix documentation regarding 'vram' kernel parameter
OMAP: VRAM: Fix boot-time memory allocation
OMAP: VRAM: improve VRAM error prints
sisfb: limit POST memory test according to PCI resource length
fbdev: sh_mobile_lcdc: use correct number of modes, when using the default
fbdev: sh_mobile_lcdc: use the standard CEA-861 720p timing
fbdev: sh_mobile_hdmi: properly clean up modedb on monitor unplug
Presently it's only legacy users that are using this clock op, guard it
with an ifdef to ensure that no new users start using it.
Now that clk_set_rate_ex() is gone, there is also no way to get at rate
setting algo id, which is now also completely unused. Kill it off before
new clock ops start using it.
With the refactoring of the SH7722 clock framework some time ago this
abstraction has become unecessary. Kill it off before anyone else gets
the bright idea to start using it.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh/urgent
The fsl-diu-fb driver no longer uses this define, and we have a common one
to cover this already (FBIO_WAITFORVSYNC).
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (66 commits)
can-bcm: fix minor heap overflow
gianfar: Do not call device_set_wakeup_enable() under a spinlock
ipv6: Warn users if maximum number of routes is reached.
docs: Add neigh/gc_thresh3 and route/max_size documentation.
axnet_cs: fix resume problem for some Ax88790 chip
ipv6: addrconf: don't remove address state on ifdown if the address is being kept
tcp: Don't change unlocked socket state in tcp_v4_err().
x25: Prevent crashing when parsing bad X.25 facilities
cxgb4vf: add call to Firmware to reset VF State.
cxgb4vf: Fail open if link_start() fails.
cxgb4vf: flesh out PCI Device ID Table ...
cxgb4vf: fix some errors in Gather List to skb conversion
cxgb4vf: fix bug in Generic Receive Offload
cxgb4vf: don't implement trivial (and incorrect) ndo_select_queue()
ixgbe: Look inside vlan when determining offload protocol.
bnx2x: Look inside vlan when determining checksum proto.
vlan: Add function to retrieve EtherType from vlan packets.
virtio-net: init link state correctly
ucc_geth: Fix deadlock
ucc_geth: Do not bring the whole IF down when TX failure.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (28 commits)
Revert "USB: xhci: Use GFP_ATOMIC under spin_lock"
USB: ohci-jz4740: Fix spelling in MODULE_ALIAS
UWB: Return UWB_RSV_ALLOC_NOT_FOUND rather than crashing on NULL dereference if kzalloc fails
usb: core: fix information leak to userland
usb: misc: iowarrior: fix information leak to userland
usb: misc: sisusbvga: fix information leak to userland
usb: subtle increased memory usage in u_serial
USB: option: fix when the driver is loaded incorrectly for some Huawei devices.
usb: gadget: goku_udc: add registered flag bit, fixing build
USB: ehci/mxc: compile fix
USB: Fix FSL USB driver on non Open Firmware systems
USB: the development of the usb tree is now in git
usb: musb: fail unaligned DMA transfers on v1.8 and above
USB: ftdi_sio: add device IDs for Milkymist One JTAG/serial
usb.h: fix ioctl kernel-doc info
usb: musb: gadget: kill duplicate code in musb_gadget_queue()
usb: musb: Fix handling of spurious SESSREQ
usb: musb: fix kernel oops when loading musb_hdrc module for the 2nd time
USB: musb: blackfin: push clkin value to platform resources
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
n_gsm: Fix length handling
n_gsm: Copy n2 over when configuring via ioctl interface
serial: bfin_5xx: grab port lock before making port termios changes
serial: bfin_5xx: disable CON_PRINTBUFFER for consoles
serial: bfin_5xx: remove redundant SSYNC to improve TX speed
serial: bfin_5xx: always include DMA headers
vcs: make proper usage of the poll flags
amiserial: Remove unused variable icount
8250: Fix tcsetattr to avoid ioctl(TIOCMIWAIT) hang
tty_ldisc: Fix BUG() on hangup
TTY: restore tty_ldisc_wait_idle
SERIAL: blacklist si3052 chip
drivers/serial/bfin_5xx.c: Fix line continuation defects
tty: prevent DOS in the flush_to_ldisc
8250: add support for Kouwell KW-L221N-2
nozomi: Fix warning from the previous TIOCGCOUNT changes
tty: fix warning in synclink driver
tty: Fix formatting in tty.h
tty: the development tree is now done in git
Depending on how a packet is vlan tagged (i.e. hardware accelerated or
not), the encapsulated protocol is stored in different locations. This
provides a consistent method of accessing that protocol, which is needed
by drivers, security checks, etc.
Signed-off-by: Hao Zheng <hzheng@nicira.com>
Signed-off-by: Jesse Gross <jesse@nicira.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: do not pass injected events back to the originating handler
Input: pcf8574_keypad - fix error handling in pcf8574_kp_probe
Input: acecad - fix a memory leak in usb_acecad_probe error path
Input: atkbd - add 'terminal' parameter for IBM Terminal keyboards
Input: i8042 - add Sony VAIOs to MUX blacklist
kgdboc: reset input devices (keyboards) when exiting debugger
Input: export input_reset_device() for use in KGDB
Input: adp5588-keys - unify common header defines
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (27 commits)
block: remove unused copy_io_context()
Documentation: remove anticipatory scheduler info
block: remove REQ_HARDBARRIER
ioprio: rcu_read_lock/unlock protect find_task_by_vpid call (V2)
ioprio: fix RCU locking around task dereference
block: ioctl: fix information leak to userland
block: read i_size with i_size_read()
cciss: fix proc warning on attempt to remove non-existant directory
bio: take care not overflow page count when mapping/copying user data
block: limit vec count in bio_kmalloc() and bio_alloc_map_data()
block: take care not to overflow when calculating total iov length
block: check for proper length of iov entries in blk_rq_map_user_iov()
cciss: remove controllers supported by hpsa
cciss: use usleep_range not msleep for small sleeps
cciss: limit commands allocated on reset_devices
cciss: Use kernel provided PCI state save and restore functions
cciss: fix board status waiting code
drbd: Removed checks for REQ_HARDBARRIER on incomming BIOs
drbd: REQ_HARDBARRIER -> REQ_FUA transition for meta data accesses
drbd: Removed the BIO_RW_BARRIER support form the receiver/epoch code
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf, amd: Use kmalloc_node(,__GFP_ZERO) for northbridge structure allocation
perf_events: Fix time tracking in samples
perf trace: update usage
perf trace: update Documentation with new perf trace variants
perf trace: live-mode command-line cleanup
perf trace record: handle commands correctly
perf record: make the record options available outside perf record
perf trace scripting: remove system-wide param from shell scripts
perf trace scripting: fix some small memory leaks and missing error checks
perf: Fix usages of profile_cpu in builtin-top.c to use cpu_list
perf, ui: Eliminate stack-smashing protection compiler complaint
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux:
locks: remove dead lease error-handling code
locks: fix leak on merging leases
nfsd4: fix 4.1 connection registration race
The intensity of the backlight can be varied from a range of
max_brightness to zero. Though most, if not all the pwm based backlight
devices start flickering at lower brightness value. And also for each
device there exists a brightness value below which the backlight appears
to be turned off though the value is not equal to zero.
If the range of brightness for a device is from zero to max_brightness. A
graph is plotted for brightness Vs intensity for the pwm based backlight
device has to be a linear graph.
intensity
0 max_brightness
But pratically on measuring the above we note that the intensity of
backlight goes to zero(OFF) when the value in not zero almost nearing to
zero(some x%). so the graph looks like
intensity
0 x max_brightness
In order to overcome this drawback knowing this x% i.e nothing but the low
threshold beyond which the backlight is off and will have no effect, the
brightness value is being offset by the low threshold value(retaining the
linearity of the graph). Now the graph becomes
intensity
0 max_brightness
With this for each and every digit increment in the brightness from zero
there is a change in the intensity of backlight. Devices having this
behaviour can set the low threshold brightness(lth_brightness) and pass
the same as platform data else can have it as zero.
Signed-off-by: Arun Murthy <arun.murthy@stericsson.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
LP5523 chip is nine channel led driver with programmable engines. Driver
provides support for that chip for direct access via led class or via
Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Jean Delvare <khali@linux-fr.org>
This patchset provides support for LP5521 and LP5523 LED driver chips from
National Semicondutor. Both drivers supports programmable engines and
naturally LED class features.
Documentation is provided as a part of the patchset. I created "leds"
subdirectory under Documentation. Perhaps the rest of the leds*
documentation should be moved there.
Datasheets are freely available at National Semiconductor www pages.
This patch:
LP5521 chip is three channel led driver with programmable engines. Driver
Currently, blinking LEDs can be awkward because it is not guaranteed that
all LEDs implement blinking. The trigger that wants it to blink then
needs to implement its own timer solution.
Rather than require that, add led_blink_set() API that triggers can use.
This function will attempt to use hw blinking, but if that fails
implements a timer for it. To stop blinking again, brightness_set() also
needs to be wrapped into API that will stop the software blink.
As a result of this, the timer trigger becomes a very trivial one, and
hopefully we can finally see triggers using blinking as well because it's
always easy to use.
