Pull more networking fixes from David Miller:
1) Fix mlx4_en_netpoll implementation, it needs to schedule a NAPI
context, not synchronize it. From Chris Mason.
2) Ipv4 flow input interface should never be zero, it should be
LOOPBACK_IFINDEX instead. From Cong Wang and Julian Anastasov.
3) Properly configure MAC to PHY connection in mvneta devices, from
Thomas Petazzoni.
4) sys_recv should use SYSCALL_DEFINE. From Jan Glauber.
5) Tunnel driver ioctls do not use the correct namespace, fix from
Nicolas Dichtel.
6) Fix memory leak on seccomp filter attach, from Kees Cook.
7) Fix lockdep warning for nested vlans, from Ding Tianhong.
8) Crashes can happen in SCTP due to how the auth_enable value is
managed, fix from Vlad Yasevich.
9) Wireless fixes from John W Linville and co.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (45 commits)
net: sctp: cache auth_enable per endpoint
tg3: update rx_jumbo_pending ring param only when jumbo frames are enabled
vlan: Fix lockdep warning when vlan dev handle notification
seccomp: fix memory leak on filter attach
isdn: icn: buffer overflow in icn_command()
ip6_tunnel: use the right netns in ioctl handler
sit: use the right netns in ioctl handler
ip_tunnel: use the right netns in ioctl handler
net: use SYSCALL_DEFINEx for sys_recv
net: mdio-gpio: Add support for separate MDI and MDO gpio pins
net: mdio-gpio: Add support for active low gpio pins
net: mdio-gpio: Use devm_ functions where possible
ipv4, route: pass 0 instead of LOOPBACK_IFINDEX to fib_validate_source()
ipv4, fib: pass LOOPBACK_IFINDEX instead of 0 to flowi4_iif
mlx4_en: don't use napi_synchronize inside mlx4_en_netpoll
net: mvneta: properly configure the MAC <-> PHY connection in all situations
net: phy: add minimal support for QSGMII PHY
sfc:On MCDI timeout, issue an FLR (and mark MCDI to fail-fast)
mwifiex: fix hung task on command timeout
mwifiex: process event before command response
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Here are a few driver fixes for char/misc drivers that resolve
reported issues.
All have been in linux-next successfully for a few days"
* tag 'char-misc-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
Drivers: hv: vmbus: Negotiate version 3.0 when running on ws2012r2 hosts
Tools: hv: Handle the case when the target file exists correctly
vme_tsi148: Utilize to_pci_dev() macro
vme_tsi148: Fix PCI address mapping assumption
vme_tsi148: Fix typo in tsi148_slave_get()
w1: avoid recursive device_add
w1: fix netlink refcnt leak on error path
misc: Grammar s/addition/additional/
drivers: mcb: fix memory leak in chameleon_parse_cells() error path
mei: ignore client writing state during cb completion
mei: me: do not load the driver if the FW doesn't support MEI interface
GenWQE: Increase driver version number
GenWQE: Fix multithreading problems
GenWQE: Ensure rc is not returning an uninitialized value
GenWQE: Add wmb before DDCB is started
GenWQE: Enable access to VPD flash area
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core fixes from Greg KH:
"Here are some driver core fixes for 3.15-rc2. Also in here are some
documentation updates, as well as an API removal that had to wait for
after -rc1 due to the cleanups coming into you from multiple developer
trees (this one and the PPC tree.)
All have been in linux next successfully"
* tag 'driver-core-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
drivers/base/dd.c incorrect pr_debug() parameters
Documentation: Update stable address in Chinese and Japanese translations
topology: Fix compilation warning when not in SMP
Chinese: add translation of io_ordering.txt
stable_kernel_rules: spelling/word usage
sysfs, driver-core: remove unused {sysfs|device}_schedule_callback_owner()
kernfs: protect lazy kernfs_iattrs allocation with mutex
fs: Don't return 0 from get_anon_bdev
Merge misc fixes from Andrew Morton:
"13 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
thp: close race between split and zap huge pages
mm: fix new kernel-doc warning in filemap.c
mm: fix CONFIG_DEBUG_VM_RB description
mm: use paravirt friendly ops for NUMA hinting ptes
mips: export flush_icache_range
mm/hugetlb.c: add cond_resched_lock() in return_unused_surplus_pages()
wait: explain the shadowing and type inconsistencies
Shiraz has moved
Documentation/vm/numa_memory_policy.txt: fix wrong document in numa_memory_policy.txt
powerpc/mm: fix ".__node_distance" undefined
kernel/watchdog.c:touch_softlockup_watchdog(): use raw_cpu_write()
init/Kconfig: move the trusted keyring config option to general setup
vmscan: reclaim_clean_pages_from_list() must use mod_zone_page_state()
Stick in a comment before someone else tries to fix the sparse warning
this generates.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-o2ro6f3vkxklni0bc8f7m68s@git.kernel.org
shiraz.hashim@st.com email-id doesn't exist anymore as he has left the
company. Replace ST's id with shiraz.linux.kernel@gmail.com.
It also updates .mailmap file to fix address for 'git shortlog'.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband/rdma updates from Roland Dreier:
- mostly cxgb4 fixes unblocked by the merge of some prerequisites via
the net tree
- drop deprecated MSI-X API use.
- a couple other miscellaneous things.
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
RDMA/cxgb4: Fix over-dereference when terminating
RDMA/cxgb4: Use uninitialized_var()
RDMA/cxgb4: Add missing debug stats
RDMA/cxgb4: Initialize reserved fields in a FW work request
RDMA/cxgb4: Use pr_warn_ratelimited
RDMA/cxgb4: Max fastreg depth depends on DSGL support
RDMA/cxgb4: SQ flush fix
RDMA/cxgb4: rmb() after reading valid gen bit
RDMA/cxgb4: Endpoint timeout fixes
RDMA/cxgb4: Use the BAR2/WC path for kernel QPs and T5 devices
IB/mlx5: Add block multicast loopback support
IB/mthca: Use pci_enable_msix_exact() instead of pci_enable_msix()
IB/qib: Use pci_enable_msix_range() instead of pci_enable_msix()
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree fixes from Rob Herring:
- fix error handling in of_update_property
- fix section mismatch warnings in __reserved_mem_check_root
- add empty of_find_node_by_path for !OF builds
- add various missing binding documentation
* tag 'dt-fixes-for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of: add empty of_find_node_by_path() for !OF
of: Clean up of_update_property
DT: add vendor prefix for EBV Elektronik
of: Fix the section mismatch warnings.
of: Add vendor prefix for Digi International Inc.
DT: I2C: Add trivial bindings used by kirkwood boards
DT: Vendor: Add prefixes used by Kirkwood devices
DT: bindings: add missing Marvell Kirkwood SoC documentation
dt-bindings: add vendor-prefix for Newhaven Display
of: add vendor prefix for I2SE GmbH
of: add vendor prefix for ISEE 2007 S.L.
Add an empty version of of_find_node_by_path().
This fixes following build error for asoc tree:
sound/soc/fsl/fsl_ssi.c: In function 'fsl_ssi_probe':
sound/soc/fsl/fsl_ssi.c:1471:2: error: implicit declaration of function 'of_find_node_by_path' [-Werror=implicit-function-declaration]
sprop = of_get_property(of_find_node_by_path("/"), "compatible", NULL);
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Signed-off-by: Rob Herring <robh@kernel.org>
Merge ipmi fixes from Corey Minyard:
"Things collected since last kernel release.
Some of these are pretty important. The first three are bug fixes.
The next two are to hopefully make everyone happy about allowing
ACPI to be on all the time and not have IPMI have an effect on the
system when not in use. The last is a little cleanup"
* emailed patches from Corey Minyard <cminyard@mvista.com>:
ipmi: boolify some things
ipmi: Turn off all activity on an idle ipmi interface
ipmi: Turn off default probing of interfaces
ipmi: Reset the KCS timeout when starting error recovery
ipmi: Fix a race restarting the timer
Char: ipmi_bt_sm, fix infinite loop
Convert some ints to bools.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
The IPMI driver would wake up periodically looking for events and
watchdog pretimeouts. If there is nothing waiting for these events,
it's really kind of pointless to be checking for them. So modify the
driver so the message handler can pass down if it needs the lower layer
to be waiting for these. Modify the system interface lower layer to
turn off all timer and thread activity if the upper layer doesn't need
anything and it is not currently handling messages. And modify the
message handler to not restart the timer if its timer is not needed.
The timers and kthread will still be enabled if:
- the SI interface is handling a message.
- a user has enabled watching for events.
- the IPMI watchdog timer is in use (since it uses pretimeouts).
- the message handler is waiting on a remote response.
- a user has registered to receive commands.
This mostly affects interfaces without interrupts. Interfaces with
interrupts already don't use CPU in the system interface when the
interface is idle.
Pull x86 fixes from Ingo Molnar:
"Various fixes:
- reboot regression fix
- build message spam fix
- GPU quirk fix
- 'make kvmconfig' fix
plus the wire-up of the renameat2() system call on i386"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Remove the PCI reboot method from the default chain
x86/build: Supress "Nothing to be done for ..." messages
x86/gpu: Fix sign extension issue in Intel graphics stolen memory quirks
x86/platform: Fix "make O=dir kvmconfig"
i386: Wire up the renameat2() syscall
Only ws2012r2 hosts support the ability to reconnect to the host on VMBUS. This functionality
is needed by kexec in Linux. To use this functionality we need to negotiate version 3.0 of the
VMBUS protocol.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Cc: <stable@vger.kernel.org> [3.9+]
This is for a system with fixed assignments of input and output pins
(various variants of Kontron COMe).
Some systems using mdio-gpio may use active-low gpio pins
(eg with inverters or FETs connected to all or some of the
gpio pins).
All device_schedule_callback_owner() users are converted to use
device_remove_file_self(). Remove now unused
{sysfs|device}_schedule_callback_owner().
This commit adds the necessary definitions for the PHY layer to
recognize "qsgmii" as a valid PHY interface. A QSMII interface, as
defined at
http://en.wikipedia.org/wiki/Media_Independent_Interface#Quad_Serial_Gigabit_Media_Independent_Interface,
is "is a method of combining four SGMII lines into a 5Gbit/s
interface. QSGMII, like SGMII, uses LVDS signalling for the TX and RX
data and a single LVDS clock signal. QSGMII uses significantly fewer
signal lines than four SGMII busses."
This type of MAC <-> PHY connection might require special handling on
the MAC driver side, so it should be possible to express this type of
MAC <-> PHY connection, for example in the Device Tree.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: devicetree@vger.kernel.org
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Steve reported a reboot hang and bisected it back to this commit:
a4f1987e4c54 x86, reboot: Add EFI and CF9 reboot methods into the default list
He heroically tested all reboot methods and found the following:
reboot=t # triple fault ok
reboot=k # keyboard ctrl FAIL
reboot=b # BIOS ok
reboot=a # ACPI FAIL
reboot=e # EFI FAIL [system has no EFI]
reboot=p # PCI 0xcf9 FAIL
And I think it's pretty obvious that we should only try PCI 0xcf9 as a
last resort - if at all.
The other observation is that (on this box) we should never try
the PCI reboot method, but close with either the 'triple fault'
or the 'BIOS' (terminal!) reboot methods.
Thirdly, CF9_COND is a total misnomer - it should be something like
CF9_SAFE or CF9_CAREFUL, and 'CF9' should be 'CF9_FORCE' ...
So this patch fixes the worst problems:
- it orders the actual reboot logic to follow the reboot ordering
pattern - it was in a pretty random order before for no good
reason.
- it fixes the CF9 misnomers and uses BOOT_CF9_FORCE and
BOOT_CF9_SAFE flags to make the code more obvious.
- it tries the BIOS reboot method before the PCI reboot method.
(Since 'BIOS' is a terminal reboot method resulting in a hang
if it does not work, this is essentially equivalent to removing
the PCI reboot method from the default reboot chain.)
- just for the miraculous possibility of terminal (resulting
in hang) reboot methods of triple fault or BIOS returning
without having done their job, there's an ordering between
them as well.
Reported-and-bisected-and-tested-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Li Aubrey <aubrey.li@linux.intel.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Link: http://lkml.kernel.org/r/20140404064120.GB11877@gmail.com
Pull networking fixes from David Miller:
1) Fix BPF filter validation of netlink attribute accesses, from
Mathias Kruase.
2) Netfilter conntrack generation seqcount not initialized properly,
from Andrey Vagin.
3) Fix comparison mask computation on big-endian in nft_cmp_fast(),
from Patrick McHardy.
4) Properly limit MTU over ipv6, from Eric Dumazet.
5) Fix seccomp system call argument population on 32-bit, from Daniel
Borkmann.
6) skb_network_protocol() should not use hard-coded ETH_HLEN, instead
skb->mac_len needs to be used. From Vlad Yasevich.
7) We have several cases of using socket based communications to
implement a tunnel. For example, some tunnels are encapsulations
over UDP so we use an internal kernel UDP socket to do the
transmits.
These tunnels should behave just like other software devices and
pass the packets on down to the next layer.
Most importantly we want the top-level socket (eg TCP) that created
the traffic to be charged for the SKB memory.
However, once you get into the IP output path, we have code that
assumed that whatever was attached to skb->sk is an IP socket.
To keep the top-level socket being charged for the SKB memory,
whilst satisfying the needs of the IP output path, we now pass in an
explicit 'sk' argument.
From Eric Dumazet.
8) ping_init_sock() leaks group info, from Xiaoming Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (33 commits)
cxgb4: use the correct max size for firmware flash
qlcnic: Fix MSI-X initialization code
ip6_gre: don't allow to remove the fb_tunnel_dev
ipv4: add a sock pointer to dst->output() path.
ipv4: add a sock pointer to ip_queue_xmit()
driver/net: cosa driver uses udelay incorrectly
at86rf230: fix __at86rf230_read_subreg function
at86rf230: remove check if AVDD settled
net: cadence: Add architecture dependencies
net: Start with correct mac_len in skb_network_protocol
Revert "net: sctp: Fix a_rwnd/rwnd management to reflect real state of the receiver's buffer"
cxgb4: Save the correct mac addr for hw-loopback connections in the L2T
net: filter: seccomp: fix wrong decoding of BPF_S_ANC_SECCOMP_LD_W
seccomp: fix populating a0-a5 syscall args in 32-bit x86 BPF
qlcnic: Do not disable SR-IOV when VFs are assigned to VMs
qlcnic: Fix QLogic application/driver interface for virtual NIC configuration
qlcnic: Fix PVID configuration on eSwitch port.
qlcnic: Fix max ring count calculation
qlcnic: Fix to send INIT_NIC_FUNC as first mailbox.
qlcnic: Fix panic due to uninitialzed delayed_work struct in use.
Pablo Neira Ayuso says:
Netfilter fixes for net
The following patchset contains three Netfilter fixes for your net tree,
they are:
* Fix missing generation sequence initialization which results in a splat
if lockdep is enabled, it was introduced in the recent works to improve
nf_conntrack scalability, from Andrey Vagin.
* Don't flush the GRE keymap list in nf_conntrack when the pptp helper is
disabled otherwise this crashes due to a double release, from Andrey
Vagin.
* Fix nf_tables cmp fast in big endian, from Patrick McHardy.
While reviewing seccomp code, we found that BPF_S_ANC_SECCOMP_LD_W has
been wrongly decoded by commit a8fc927780 ("sk-filter: Add ability to
get socket filter program (v2)") into the opcode BPF_LD|BPF_B|BPF_ABS
although it should have been decoded as BPF_LD|BPF_W|BPF_ABS.
In practice, this should not have much side-effect though, as such
conversion is/was being done through prctl(2) PR_SET_SECCOMP. Reverse
operation PR_GET_SECCOMP will only return the current seccomp mode, but
not the filter itself. Since the transition to the new BPF infrastructure,
it's also not used anymore, so we can simply remove this as it's
unreachable.
Fixes: a8fc927780 ("sk-filter: Add ability to get socket filter program (v2)")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
Pull slab changes from Pekka Enberg:
"The biggest change is byte-sized freelist indices which reduces slab
freelist memory usage:
https://lkml.org/lkml/2013/12/2/64"
* 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux:
mm: slab/slub: use page->list consistently instead of page->lru
mm/slab.c: cleanup outdated comments and unify variables naming
slab: fix wrongly used macro
slub: fix high order page allocation problem with __GFP_NOFAIL
slab: Make allocations with GFP_ZERO slightly more efficient
slab: make more slab management structure off the slab
slab: introduce byte sized index for the freelist of a slab
slab: restrict the number of objects in a slab
slab: introduce helper functions to get/set free object
slab: factor out calculate nr objects in cache_estimate
Pull yet more networking updates from David Miller:
1) Various fixes to the new Redpine Signals wireless driver, from
Fariya Fatima.
2) L2TP PPP connect code takes PMTU from the wrong socket, fix from
Dmitry Petukhov.
3) UFO and TSO packets differ in whether they include the protocol
header in gso_size, account for that in skb_gso_transport_seglen().
From Florian Westphal.
4) If VLAN untagging fails, we double free the SKB in the bridging
output path. From Toshiaki Makita.
5) Several call sites of sk->sk_data_ready() were referencing an SKB
just added to the socket receive queue in order to calculate the
second argument via skb->len. This is dangerous because the moment
the skb is added to the receive queue it can be consumed in another
context and freed up.
It turns out also that none of the sk->sk_data_ready()
implementations even care about this second argument.
So just kill it off and thus fix all these use-after-free bugs as a
side effect.
6) Fix inverted test in tcp_v6_send_response(), from Lorenzo Colitti.
7) pktgen needs to do locking properly for LLTX devices, from Daniel
Borkmann.
8) xen-netfront driver initializes TX array entries in RX loop :-) From
Vincenzo Maffione.
9) After refactoring, some tunnel drivers allow a tunnel to be
configured on top itself. Fix from Nicolas Dichtel.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (46 commits)
vti: don't allow to add the same tunnel twice
gre: don't allow to add the same tunnel twice
drivers: net: xen-netfront: fix array initialization bug
pktgen: be friendly to LLTX devices
r8152: check RTL8152_UNPLUG
net: sun4i-emac: add promiscuous support
net/apne: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
net: ipv6: Fix oif in TCP SYN+ACK route lookup.
drivers: net: cpsw: enable interrupts after napi enable and clearing previous interrupts
drivers: net: cpsw: discard all packets received when interface is down
net: Fix use after free by removing length arg from sk_data_ready callbacks.
Drivers: net: hyperv: Address UDP checksum issues
Drivers: net: hyperv: Negotiate suitable ndis version for offload support
Drivers: net: hyperv: Allocate memory for all possible per-pecket information
bridge: Fix double free and memory leak around br_allowed_ingress
bonding: Remove debug_fs files when module init fails
i40evf: program RSS LUT correctly
i40evf: remove open-coded skb_cow_head
ixgb: remove open-coded skb_cow_head
igbvf: remove open-coded skb_cow_head
git://git.linuxfoundation.org/llvmlinux/kernel
Pull llvm patches from Behan Webster:
"These are some initial updates to support compiling the kernel with
clang.
These patches have been through the proper reviews to the best of my
ability, and have been soaking in linux-next for a few weeks. These
patches by themselves still do not completely allow clang to be used
with the kernel code, but lay the foundation for other patches which
are still under review.
Several other of the LLVMLinux patches have been already added via
maintainer trees"
* tag 'llvmlinux-for-v3.15' of git://git.linuxfoundation.org/llvmlinux/kernel:
x86: LLVMLinux: Fix "incomplete type const struct x86cpu_device_id"
x86 kbuild: LLVMLinux: More cc-options added for clang
x86, acpi: LLVMLinux: Remove nested functions from Thinkpad ACPI
LLVMLinux: Add support for clang to compiler.h and new compiler-clang.h
LLVMLinux: Remove warning about returning an uninitialized variable
kbuild: LLVMLinux: Fix LINUX_COMPILER definition script for compilation with clang
Documentation: LLVMLinux: Update Documentation/dontdiff
kbuild: LLVMLinux: Adapt warnings for compilation with clang
kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang
Pull PCIe non-transparent bridge fixes and features from Jon Mason:
"NTB driver bug fixes to address issues in list traversal, skb leak in
ntb_netdev, a typo, and a leak of msix entries in the error path.
Clean ups of the event handling logic, as well as a overall style
cleanup. Finally, the driver was converted to use the new
pci_enable_msix_range logic (and the refactoring to go along with it)"
* tag 'ntb-3.15' of git://github.com/jonmason/ntb:
ntb: Use pci_enable_msix_range() instead of pci_enable_msix()
ntb: Split ntb_setup_msix() into separate BWD/SNB routines
ntb: Use pci_msix_vec_count() to obtain number of MSI-Xs
NTB: Code Style Clean-up
NTB: client event cleanup
ntb: Fix leakage of ntb_device::msix_entries[] array
NTB: Fix typo in setting one translation register
ntb_netdev: Fix skb free issue in open
ntb_netdev: Fix list_for_each_entry exit issue
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull more tracing updates from Steven Rostedt:
"This includes the final patch to clean up and fix the issue with the
design of tracepoints and how a user could register a tracepoint and
have that tracepoint not be activated but no error was shown.
The design was for an out of tree module but broke in tree users. The
clean up was to remove the saving of the hash table of tracepoint
names such that they can be enabled before they exist (enabling a
module tracepoint before that module is loaded). This added more
complexity than needed. The clean up was to remove that code and just
enable tracepoints that exist or fail if they do not.
This removed a lot of code as well as the complexity that it brought.
As a side effect, instead of registering a tracepoint by its name, the
tracepoint needs to be registered with the tracepoint descriptor.
This removes having to duplicate the tracepoint names that are
enabled.
The second patch was added that simplified the way modules were
searched for.
This cleanup required changes that were in the 3.15 queue as well as
some changes that were added late in the 3.14-rc cycle. This final
change waited till the two were merged in upstream and then the change
was added and full tests were run. Unfortunately, the test found some
errors, but after it was already submitted to the for-next branch and
not to be rebased. Sparse errors were detected by Fengguang Wu's bot
tests, and my internal tests discovered that the anonymous union
initialization triggered a bug in older gcc compilers. Luckily, there
was a bugzilla for the gcc bug which gave a work around to the
problem. The third and fourth patch handled the sparse error and the
gcc bug respectively.
A final patch was tagged along to fix a missing documentation for the
README file"
* tag 'trace-3.15-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Add missing function triggers dump and cpudump to README
tracing: Fix anonymous unions in struct ftrace_event_call
tracepoint: Fix sparse warnings in tracepoint.c
tracepoint: Simplify tracepoint module search
tracepoint: Use struct pointer instead of name hash for reg/unreg tracepoints
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
Pull NVMe driver updates from Matthew Wilcox:
"Various updates to the NVMe driver. The most user-visible change is
that drive hotplugging now works and CPU hotplug while an NVMe drive
is installed should also work better"
* git://git.infradead.org/users/willy/linux-nvme:
NVMe: Retry failed commands with non-fatal errors
NVMe: Add getgeo to block ops
NVMe: Start-stop nvme_thread during device add-remove.
NVMe: Make I/O timeout a module parameter
NVMe: CPU hot plug notification
NVMe: per-cpu io queues
NVMe: Replace DEFINE_PCI_DEVICE_TABLE
NVMe: Fix divide-by-zero in nvme_trans_io_get_num_cmds
NVMe: IOCTL path RCU protect queue access
NVMe: RCU protected access to io queues
NVMe: Initialize device reference count earlier
NVMe: Add CONFIG_PM_SLEEP to suspend/resume functions
Pull more ACPI and power management fixes and updates from Rafael Wysocki:
"This is PM and ACPI material that has emerged over the last two weeks
and one fix for a CPU hotplug regression introduced by the recent CPU
hotplug notifiers registration series.
Included are intel_idle and turbostat updates from Len Brown (these
have been in linux-next for quite some time), a new cpufreq driver for
powernv (that might spend some more time in linux-next, but BenH was
asking me so nicely to push it for 3.15 that I couldn't resist), some
cpufreq fixes and cleanups (including fixes for some silly breakage in
a couple of cpufreq drivers introduced during the 3.14 cycle),
assorted ACPI cleanups, wakeup framework documentation fixes, a new
sysfs attribute for cpuidle and a new command line argument for power
domains diagnostics.
Specifics:
- Fix for a recently introduced CPU hotplug regression in ARM KVM
from Ming Lei.
- Fixes for breakage in the at32ap, loongson2_cpufreq, and unicore32
cpufreq drivers introduced during the 3.14 cycle (-stable material)
from Chen Gang and Viresh Kumar.
- New powernv cpufreq driver from Vaidyanathan Srinivasan, with bits
from Gautham R Shenoy and Srivatsa S Bhat.
- Exynos cpufreq driver fix preventing it from being included into
multiplatform builds that aren't supported by it from Sachin Kamat.
- cpufreq cleanups related to the usage of the driver_data field in
struct cpufreq_frequency_table from Viresh Kumar.
- cpufreq ppc driver cleanup from Sachin Kamat.
- Intel BayTrail support for intel_idle and ACPI idle from Len Brown.
- Intel CPU model 54 (Atom N2000 series) support for intel_idle from
Jan Kiszka.
- intel_idle fix for Intel Ivy Town residency targets from Len Brown.
- turbostat updates (Intel Broadwell support and output cleanups)
from Len Brown.
- New cpuidle sysfs attribute for exporting C-states' target
residency information to user space from Daniel Lezcano.
- New kernel command line argument to prevent power domains enabled
by the bootloader from being turned off even if they are not in use
(for diagnostics purposes) from Tushar Behera.
- Fixes for wakeup sysfs attributes documentation from Geert
Uytterhoeven.
- New ACPI video blacklist entry for ThinkPad Helix from Stephen
Chandler Paul.
- Assorted ACPI cleanups and a Kconfig help update from Jonghwan
Choi, Zhihui Zhang, Hanjun Guo"
* tag 'pm+acpi-3.15-rc1-3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits)
ACPI: Update the ACPI spec information in Kconfig
arm, kvm: fix double lock on cpu_add_remove_lock
cpuidle: sysfs: Export target residency information
cpufreq: ppc: Remove duplicate inclusion of fsl_soc.h
cpufreq: create another field .flags in cpufreq_frequency_table
cpufreq: use kzalloc() to allocate memory for cpufreq_frequency_table
cpufreq: don't print value of .driver_data from core
cpufreq: ia64: don't set .driver_data to index
cpufreq: powernv: Select CPUFreq related Kconfig options for powernv
cpufreq: powernv: Use cpufreq_frequency_table.driver_data to store pstate ids
cpufreq: powernv: cpufreq driver for powernv platform
cpufreq: at32ap: don't declare local variable as static
cpufreq: loongson2_cpufreq: don't declare local variable as static
cpufreq: unicore32: fix typo issue for 'clk'
cpufreq: exynos: Disable on multiplatform build
PM / wakeup: Correct presence vs. emptiness of wakeup_* attributes
PM / domains: Add pd_ignore_unused to keep power domains enabled
ACPI / dock: Drop dock_device_ids[] table
ACPI / video: Favor native backlight interface for ThinkPad Helix
ACPI / thermal: Fix wrong variable usage in debug statement
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
'struct page' has two list_head fields: 'lru' and 'list'. Conveniently,
they are unioned together. This means that code can use them
interchangably, which gets horribly confusing like with this nugget from
slab.c:
> list_del(&page->lru);
> if (page->active == cachep->num)
> list_add(&page->list, &n->slabs_full);
This patch makes the slab and slub code use page->lru universally instead
of mixing ->list and ->lru.
So, the new rule is: page->lru is what the you use if you want to keep
your page on a list. Don't like the fact that it's not called ->list?
Too bad.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: Christoph Lameter <cl@linux.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Pekka Enberg <penberg@kernel.org>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Add support for the block multicast loopback QP creation flag along
the proper firmware API for that.
Signed-off-by: Eli Cohen <eli@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
On systems with CONFIG_COMPAT we introduced the new requirement that
audit_classify_compat_syscall() exists. This wasn't true for everything
(apparently not for "tilegx", which I know less that nothing about.)
Instead of wrapping the preprocessor optomization with CONFIG_COMPAT we
should have used the new CONFIG_AUDIT_COMPAT_GENERIC. This patch uses
that config option to make sure only arches which intend to implement
this have the requirement.
This works fine for tilegx according to Chris Metcalf
Signed-off-by: Eric Paris <eparis@redhat.com>
For commands returned with failed status, queue these for resubmission
and continue retrying them until success or for a limited amount of
time. The final timeout was arbitrarily chosen so requests can't be
retried indefinitely.
Since these are requeued on the nvmeq that submitted the command, the
callbacks have to take an nvmeq instead of an nvme_dev as a parameter
so that we can use the locked queue to append the iod to retry later.
The nvme_iod conviently can be used to track how long we've been trying
to successfully complete an iod request. The nvme_iod also provides the
nvme prp dma mappings, so I had to move a few things around so we can
keep those mappings.
Signed-off-by: Keith Busch <keith.busch@intel.com>
[fixed checkpatch issue with long line]
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Increase the default timeout to 30 seconds to match SCSI.
[use byte instead of ushort]
Registers with hot cpu notification to rebalance, and potentially allocate
additional, io queues.
The device's IO queues are associated with CPUs, so we can use a per-cpu
variable to map the a qid to a cpu. This provides a convienient way
to optimally assign queues to multiple cpus when the device supports
fewer queues than the host has cpus. The previous implementation may
have assigned these poorly in these situations. This patch addresses
this by sharing queues among cpus that are "close" together and should
have a lower lock contention penalty.
Pull block layer fixes from Jens Axboe:
"A small collection of fixes that should go in before -rc1. The pull
request contains:
- A two patch fix for a regression with block enabled tagging caused
by a commit in the initial pull request. One patch is from Martin
and ensures that SCSI doesn't truncate 64-bit block flags, the
other one is from me and prevents us from double using struct
request queuelist for both completion and busy tags. This caused
anything from a boot crash for some, to crashes under load.
- A blk-mq fix for a potential soft stall when hot unplugging CPUs
with busy IO.
- percpu_counter fix is listed in here, that caused a suspend issue
with virtio-blk due to percpu counters having an inconsistent state
during CPU removal. Andrew sent this in separately a few days ago,
but it's here. JFYI.
- A few fixes for block integrity from Martin.
- A ratelimit fix for loop from Mike Galbraith, to avoid spewing too
much in error cases"
* 'for-linus' of git://git.kernel.dk/linux-block:
block: fix regression with block enabled tagging
scsi: Make sure cmd_flags are 64-bit
block: Ensure we only enable integrity metadata for reads and writes
block: Fix integrity verification
block: Fix for_each_bvec()
drivers/block/loop.c: ratelimit error messages
blk-mq: fix potential stall during CPU unplug with IO pending
percpu_counter: fix bad counter state during suspend
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds
Pull LED updates from Bryan Wu:
"This cycle we got:
- new driver for leds-mc13783
- bug fixes
- code cleanup"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds:
leds: make sure we unregister a trigger only once
leds: leds-pwm: properly clean up after probe failure
leds: clevo-mail: Make probe function __init
leds-ot200: Fix dependencies
leds-gpio: of: introduce MODULE_DEVICE_TABLE for module autoloading
leds: clevo-mail: remove __initdata marker
leds: leds-ss4200: remove __initdata marker
leds: blinkm: remove unnecessary spaces
leds: lp5562: remove unnecessary parentheses
leds: leds-ss4200: remove DEFINE_PCI_DEVICE_TABLE macro
leds: leds-s3c24xx: Trivial cleanup in header file
drivers/leds: delete non-required instances of include <linux/init.h>
leds: leds-gpio: add retain-state-suspended property
leds: leds-mc13783: Add devicetree support
leds: leds-mc13783: Remove unnecessary cleaning of registers on exit
leds: leds-mc13783: Use proper "max_brightness" value fo LEDs
leds: leds-mc13783: Use LED core PM functions
leds: leds-mc13783: Add MC34708 LED support
leds: Turn off led if blinking is disabled
ledtrig-cpu: Handle CPU hot(un)plugging
Pull slave-dmaengine updates from Vinod Koul:
- New driver for Qcom bam dma
- New driver for RCAR peri-peri
- New driver for FSL eDMA
- Various odd fixes and updates thru the subsystem
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (29 commits)
dmaengine: add Qualcomm BAM dma driver
shdma: add R-Car Audio DMAC peri peri driver
dmaengine: sirf: enable generic dt binding for dma channels
dma: omap-dma: Implement device_slave_caps callback
dmaengine: qcom_bam_dma: Add device tree binding
dma: dw: Add suspend and resume handling for PCI mode DW_DMAC.
dma: dw: allocate memory in two stages in probe
Add new line to test result strings produced in verbose mode
dmaengine: pch_dma: use tasklet_kill in teardown
dmaengine: at_hdmac: use tasklet_kill in teardown
dma: cppi41: start tear down only if channel is busy
usb: musb: musb_cppi41: Dont reprogram DMA if tear down is initiated
dmaengine: s3c24xx-dma: make phy->irq signed for error handling
dma: imx-dma: Add missing module owner field
dma: imx-dma: Replace printk with dev_*
dma: fsl-edma: fix static checker warning of NULL dereference
dma: Remove comment about embedding dma_slave_config into custom structs
dma: mmp_tdma: move to generic device tree binding
dma: mmp_pdma: add IRQF_SHARED when request irq
dma: edma: Fix memory leak in edma_prep_dma_cyclic()
Martin reported that his test system would not boot with
current git, it oopsed with this:
BUG: unable to handle kernel paging request at ffff88046c6c9e80
IP: [<ffffffff812971e0>] blk_queue_start_tag+0x90/0x150
PGD 1ddf067 PUD 1de2067 PMD 47fc7d067 PTE 800000046c6c9060
Oops: 0002 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: sd_mod lpfc(+) scsi_transport_fc scsi_tgt oracleasm
rpcsec_gss_krb5 ipv6 igb dca i2c_algo_bit i2c_core hwmon
CPU: 3 PID: 87 Comm: kworker/u17:1 Not tainted 3.14.0+ #246
Hardware name: Supermicro X9DRX+-F/X9DRX+-F, BIOS 3.00 07/09/2013
Workqueue: events_unbound async_run_entry_fn
task: ffff8802743c2150 ti: ffff880273d02000 task.ti: ffff880273d02000
RIP: 0010:[<ffffffff812971e0>] [<ffffffff812971e0>]
RSP: 0018:ffff880273d03a58 EFLAGS: 00010092
RAX: ffff88046c6c9e78 RBX: ffff880077208e78 RCX: 00000000fffc8da6
RDX: 00000000fffc186d RSI: 0000000000000009 RDI: 00000000fffc8d9d
RBP: ffff880273d03a88 R08: 0000000000000001 R09: ffff8800021c2410
R10: 0000000000000005 R11: 0000000000015b30 R12: ffff88046c5bb8a0
R13: ffff88046c5c0890 R14: 000000000000001e R15: 000000000000001e
FS: 0000000000000000(0000) GS:ffff880277b00000(0000)
knlGS:0000000000000000
CR2: ffff88046c6c9e80 CR3: 00000000018f6000 CR4: 00000000000407e0
Stack:
ffff880273d03a98 ffff880474b18800 0000000000000000 ffff880474157000
ffff88046c5c0890 ffff880077208e78 ffff880273d03ae8 ffffffff813b9e62
ffff880200000010 ffff880474b18968 ffff880474b18848 ffff88046c5c0cd8
Call Trace:
[<ffffffff813b9e62>] scsi_request_fn+0xf2/0x510
[<ffffffff81293167>] __blk_run_queue+0x37/0x50
[<ffffffff8129ac43>] blk_execute_rq_nowait+0xb3/0x130
[<ffffffff8129ad24>] blk_execute_rq+0x64/0xf0
[<ffffffff8108d2b0>] ? bit_waitqueue+0xd0/0xd0
[<ffffffff813bba35>] scsi_execute+0xe5/0x180
[<ffffffff813bbe4a>] scsi_execute_req_flags+0x9a/0x110
[<ffffffffa01b1304>] sd_spinup_disk+0x94/0x460 [sd_mod]
[<ffffffff81160000>] ? __unmap_hugepage_range+0x200/0x2f0
[<ffffffffa01b2b9a>] sd_revalidate_disk+0xaa/0x3f0 [sd_mod]
[<ffffffffa01b2fb8>] sd_probe_async+0xd8/0x200 [sd_mod]
[<ffffffff8107703f>] async_run_entry_fn+0x3f/0x140
[<ffffffff8106a1c5>] process_one_work+0x175/0x410
[<ffffffff8106b373>] worker_thread+0x123/0x400
[<ffffffff8106b250>] ? manage_workers+0x160/0x160
[<ffffffff8107104e>] kthread+0xce/0xf0
[<ffffffff81070f80>] ? kthread_freezable_should_stop+0x70/0x70
[<ffffffff815f0bac>] ret_from_fork+0x7c/0xb0
Code: 48 0f ab 11 72 db 48 81 4b 40 00 00 10 00 89 83 08 01 00 00 48 89
df 49 8b 04 24 48 89 1c d0 e8 f7 a8 ff ff 49 8b 85 28 05 00 00 <48> 89
58 08 48 89 03 49 8d 85 28 05 00 00 48 89 43 08 49 89 9d
RIP [<ffffffff812971e0>] blk_queue_start_tag+0x90/0x150
RSP <ffff880273d03a58>
Martin bisected and found this to be the problem patch;
commit 6d113398dcf4dfcd9787a4ead738b186f7b7ff0f
Author: Jan Kara <jack@suse.cz>
Date: Mon Feb 24 16:39:54 2014 +0100
block: Stop abusing rq->csd.list in blk-softirq
and the problem was immediately apparent. The patch states that
it is safe to reuse queuelist at completion time, since it is
no longer used. However, that is not true if a device is using
block enabled tagging. If that is the case, then the queuelist
is reused to keep track of busy tags. If a device also ended
up using softirq completions, we'd reuse ->queuelist for the
IPI handling while block tagging was still using it. Boom.
Fix this by adding a new ipi_list list head, and share the
memory used with the request hash table. The hash table is
never used after the request is moved to the dispatch list,
which happens long before any potential completion of the
request. Add a new request bit for this, so we don't have
cases that check rq->hash while it could potentially have
been reused for the IPI completion.
Reported-by: Martin K. Petersen <martin.petersen@oracle.com>
Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
gcc <= 4.5.x has significant limitations with respect to initialization
of anonymous unions within structures. They need to be surrounded by
brackets, _and_ they need to be initialized in the same order in which
they appear in the structure declaration.
Link: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=10676
Link: http://lkml.kernel.org/r/1397077568-3156-1-git-send-email-mathieu.desnoyers@efficios.com
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Similar to the fix in 40413dcb7b273bda681dca38e6ff0bbb3728ef11
MODULE_DEVICE_TABLE(x86cpu, ...) expects the struct to be called struct
x86cpu_device_id, and not struct x86_cpu_id which is what is used in the rest
of the kernel code. Although gcc seems to ignore this error, clang fails
without this define to fix the name.
Code from drivers/thermal/x86_pkg_temp_thermal.c
static const struct x86_cpu_id __initconst pkg_temp_thermal_ids[] = { ... };
MODULE_DEVICE_TABLE(x86cpu, pkg_temp_thermal_ids);
Error from clang:
drivers/thermal/x86_pkg_temp_thermal.c:577:1: error: variable has
incomplete type 'const struct x86cpu_device_id'
include/linux/module.h:145:3: note: expanded from macro
'MODULE_DEVICE_TABLE'
MODULE_GENERIC_TABLE(type##_device, name)
include/linux/module.h:87:32: note: expanded from macro
'MODULE_GENERIC_TABLE'
extern const struct gtype##_id __mod_##gtype##_table \
<scratch space>:143:1: note: expanded from here
__mod_x86cpu_device_table
drivers/thermal/x86_pkg_temp_thermal.c:577:1: note: forward declaration of
'struct x86cpu_device_id'
include/linux/module.h:87:21: note: expanded from macro
<scratch space>:141:1: note: expanded from here
x86cpu_device_id
1 error generated.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Add a compiler-clang.h file to add specific macros needed for compiling the
kernel with clang.
Initially the only override required is the macro for silencing the
compiler for a purposefully uninintialized variable.
Author: Mark Charlebois <charlebm@gmail.com>
Signed-off-by: Mark Charlebois <charlebm@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Here is the pull request from the i2c subsystem. It got a little
delayed because I needed to wait for a dependency to be included
(commit b424080a9e08: "reset: Add optional resets and stubs"). Plus,
I had some email problems. All done now, the highlights are:
- drivers can now deprecate their use of i2c classes. That shouldn't
be used on embedded platforms anyhow and was often blindly
copy&pasted. This mechanism gives users time to switch away and
ultimately boot faster once the use of classes for those drivers is
gone for good.
- new drivers for QUP, Cadence, efm32
- tracepoint support for I2C and SMBus
- bigger cleanups for the mv64xxx, nomadik, and designware drivers
And the usual bugfixes, cleanups, feature additions. Most stuff has
been in linux-next for a while. Just some hot fixes and new drivers
were added a bit more recently."
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (63 commits)
i2c: cadence: fix Kconfig dependency
i2c: Add driver for Cadence I2C controller
i2c: cadence: Document device tree bindings
Documentation: i2c: improve section about flags mangling the protocol
i2c: qup: use proper type fro clk_freq
i2c: qup: off by ones in qup_i2c_probe()
i2c: efm32: fix binding doc
MAINTAINERS: update I2C web resources
i2c: qup: New bus driver for the Qualcomm QUP I2C controller
i2c: qup: Add device tree bindings information
i2c: i2c-xiic: deprecate class based instantiation
i2c: i2c-sirf: deprecate class based instantiation
i2c: i2c-mv64xxx: deprecate class based instantiation
i2c: i2c-designware-platdrv: deprecate class based instantiation
i2c: i2c-davinci: deprecate class based instantiation
i2c: i2c-bcm2835: deprecate class based instantiation
i2c: mv64xxx: Fix reset controller handling
i2c: omap: fix usage of IS_ERR_VALUE with pm_runtime_get_sync
i2c: efm32: new bus driver
i2c: exynos5: remove unnecessary cast of void pointer
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
"MMC highlights for 3.15:
Core:
- CONFIG_MMC_UNSAFE_RESUME=y is now default behavior
- DT bindings for SDHCI UHS, eMMC HS200, high-speed DDR, at 1.8/1.2V
- Add GPIO descriptor based slot-gpio card detect API
Drivers:
- dw_mmc: Refactor SOCFPGA support as a variant inside dw_mmc-pltfm.c
- mmci: Support HW busy detection on ux500
- omap: Support MMC_ERASE
- omap_hsmmc: Support MMC_PM_KEEP_POWER, MMC_PM_WAKE_SDIO_IRQ, (a)cmd23
- rtsx: Support pre-req/post-req async
- sdhci: Add support for Realtek RTS5250 controllers
- sdhci-acpi: Add support for 80860F16, fix 80860F14/SDIO card detect
- sdhci-msm: Add new driver for Qualcomm SDHCI chipset support
- sdhci-pxav3: Add support for Marvell Armada 380 and 385 SoCs"
* tag 'mmc-updates-for-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (102 commits)
mmc: sdhci-acpi: Intel SDIO has broken card detect
mmc: sdhci-pxav3: add support for the Armada 38x SDHCI controller
mmc: sdhci-msm: Add platform_execute_tuning implementation
mmc: sdhci-msm: Initial support for Qualcomm chipsets
mmc: sdhci-msm: Qualcomm SDHCI binding documentation
sdhci: only reprogram retuning timer when flag is set
mmc: rename ARCH_BCM to ARCH_BCM_MOBILE
mmc: sdhci: Allow for irq being shared
mmc: sdhci-acpi: Add device id 80860F16
mmc: sdhci-acpi: Fix broken card detect for ACPI HID 80860F14
mmc: slot-gpio: Add GPIO descriptor based CD GPIO API
mmc: slot-gpio: Split out CD IRQ request into a separate function
mmc: slot-gpio: Record GPIO descriptors instead of GPIO numbers
Revert "dts: socfpga: Add support for SD/MMC on the SOCFPGA platform"
mmc: sdhci-spear: use generic card detection gpio support
mmc: sdhci-spear: remove support for power gpio
mmc: sdhci-spear: simplify resource handling
mmc: sdhci-spear: fix platform_data usage
mmc: sdhci-spear: fix error handling paths for DT
mmc: sdhci-bcm-kona: fix build errors when built-in
Fix the following sparse warnings:
CHECK kernel/tracepoint.c
kernel/tracepoint.c:184:18: warning: incorrect type in assignment (different address spaces)
kernel/tracepoint.c:184:18: expected struct tracepoint_func *tp_funcs
kernel/tracepoint.c:184:18: got struct tracepoint_func [noderef] <asn:4>*funcs
kernel/tracepoint.c:216:18: warning: incorrect type in assignment (different address spaces)
kernel/tracepoint.c:216:18: expected struct tracepoint_func *tp_funcs
kernel/tracepoint.c:216:18: got struct tracepoint_func [noderef] <asn:4>*funcs
kernel/tracepoint.c:392:24: error: return expression in void function
CC kernel/tracepoint.o
kernel/tracepoint.c: In function tracepoint_module_going:
kernel/tracepoint.c:491:6: warning: symbol 'syscall_regfunc' was not declared. Should it be static?
kernel/tracepoint.c:508:6: warning: symbol 'syscall_unregfunc' was not declared. Should it be static?
Link: http://lkml.kernel.org/r/1397049883-28692-1-git-send-email-mathieu.desnoyers@efficios.com
Commit 4550dd6c6b062 introduced for_each_bvec() which iterates over each
bvec attached to a bio or bip. However, the macro fails to check bi_size
before dereferencing which can lead to crashes while counting/mapping
integrity scatterlist segments.
Cc: Kent Overstreet <kmo@daterainc.com>
Cc: Nicholas Bellinger <nab@linux-iscsi.org>
Cc: <stable@vger.kernel.org> # v3.14+
