With the new system call defines we get this on uml:
arch/um/sys-i386/built-in.o: In function `sys_call_table':
(.rodata+0x308): undefined reference to `sys_sigprocmask'
Reason for this is that uml passes the preprocessor option
-Dsigprocmask=kernel_sigprocmask to gcc when compiling the kernel.
This causes SYSCALL_DEFINE3(sigprocmask, ...) to be expanded to
SYSCALL_DEFINEx(3, kernel_sigprocmask, ...) and finally to a system
call named sys_kernel_sigprocmask. However sys_sigprocmask is missing
because of this.
To avoid macro expansion for the system call name just concatenate the
name at first define instead of carrying it through severel levels.
This was pointed out by Al Viro.
Reviewed-by: WANG Cong <wangcong@zeuux.org>
I enabled all cgroup subsystems when compiling kernel, and then:
# mount -t cgroup -o net_cls xxx /mnt
# mkdir /mnt/0
This showed up immediately:
BUG: MAX_LOCKDEP_SUBCLASSES too low!
turning off the locking correctness validator.
It's caused by the cgroup hierarchy lock:
for (i = 0; i < CGROUP_SUBSYS_COUNT; i++) {
struct cgroup_subsys *ss = subsys[i];
if (ss->root == root)
mutex_lock_nested(&ss->hierarchy_mutex, i);
Now we have 9 cgroup subsystems, and the above 'i' for net_cls is 8, but
MAX_LOCKDEP_SUBCLASSES is 8.
This patch uses different lockdep keys for different subsystems.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Paul Menage <menage@google.com>
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
timers: fix TIMER_ABSTIME for process wide cpu timers
timers: split process wide cpu clocks/timers, fix
x86: clean up hpet timer reinit
timers: split process wide cpu clocks/timers, remove spurious warning
signal: re-add dead task accumulation stats.
x86: fix hpet timer reinit for x86_64
sched: fix nohz load balancer on cpu offline
The POSIX timer interface allows for absolute time expiry values through the
TIMER_ABSTIME flag, therefore we have to synchronize the timer to the clock
every time we start it.
To decrease the chance of a missed enable, always enable the timer when we
sample it, we'll always disable it when we find that there are no active timers
in the jiffy tick.
This fixes a flood of warnings reported by Mike Galbraith.
Reported-by: Mike Galbraith <efault@gmx.de>
Fix regression due to 5a6fe125950676015f5108fb71b2a67441755003,
"Do not account for the address space used by hugetlbfs using VM_ACCOUNT"
which added an argument to the function hugetlb_file_setup() but not to
the macro hugetlb_file_setup().
Reported-by: Chris Clayton <chris2553@googlemail.com>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Acked-by: Mel Gorman <mel@csn.ul.ie>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (23 commits)
bridge: Fix LRO crash with tun
IPv6: fix to set device name when new IPv6 over IPv6 tunnel device is created.
gianfar: Fix boot hangs while bringing up gianfar ethernet
netfilter: xt_sctp: sctp chunk mapping doesn't work
netfilter: ctnetlink: fix echo if not subscribed to any multicast group
netfilter: ctnetlink: allow changing NAT sequence adjustment in creation
netfilter: nf_conntrack_ipv6: don't track ICMPv6 negotiation message
netfilter: fix tuple inversion for Node information request
netxen: fix msi-x interrupt handling
de2104x: force correct order when writing to rx ring
tun: Fix unicast filter overflow
drivers/isdn: introduce missing kfree
drivers/atm: introduce missing kfree
sunhme: Don't match PCI devices in SBUS probe.
9p: fix endian issues [attempt 3]
net_dma: call dmaengine_get only if NET_DMA enabled
3c509: Fix resume from hibernation for PnP mode.
sungem: Soft lockup in sungem on Netra AC200 when switching interface up
RxRPC: Fix a potential NULL dereference
r8169: Don't update statistics counters when interface is down
When overcommit is disabled, the core VM accounts for pages used by anonymous
shared, private mappings and special mappings. It keeps track of VMAs that
should be accounted for with VM_ACCOUNT and VMAs that never had a reserve
with VM_NORESERVE.
Overcommit for hugetlbfs is much riskier than overcommit for base pages
due to contiguity requirements. It avoids overcommiting on both shared and
private mappings using reservation counters that are checked and updated
during mmap(). This ensures (within limits) that hugepages exist in the
future when faults occurs or it is too easy to applications to be SIGKILLed.
As hugetlbfs makes its own reservations of a different unit to the base page
size, VM_ACCOUNT should never be set. Even if the units were correct, we would
double account for the usage in the core VM and hugetlbfs. VM_NORESERVE may
be set because an application can request no reserves be made for hugetlbfs
at the risk of getting killed later.
With commit fc8744adc870a8d4366908221508bb113d8b72ee, VM_NORESERVE and
VM_ACCOUNT are getting unconditionally set for hugetlbfs-backed mappings. This
breaks the accounting for both the core VM and hugetlbfs, can trigger an
OOM storm when hugepage pools are too small lockups and corrupted counters
otherwise are used. This patch brings hugetlbfs more in line with how the
core VM treats VM_NORESERVE but prevents VM_ACCOUNT being set.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: scatterwalk - Avoid flush_dcache_page on slab pages
crypto: shash - Fix tfm destruction
crypto: api - Fix zeroing on free
crypto: shash - Fix module refcount
crypto: api - Fix algorithm test race that broke aead initialisation
Architectures other than mips and x86 are not using ticket spinlocks.
Therefore, the contention on the lock is meaningless, since there is
nobody known to be waiting on it (arguably /fairly/ unfair locks).
Dummy it out to return 0 on other architectures.
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Impact: saves sizeof(long) bytes per task_struct
By guaranteeing that sysctl_hung_task_timeout_secs have elapsed between
tasklist scans we can avoid using timestamps.
Signed-off-by: Mandeep Singh Baines <msb@google.com>
Rename the async_*_special() functions to async_*_domain(), which
describes the purpose of these functions much better.
[Broke up long lines to silence checkpatch]
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI PM: make the PM core more careful with drivers using the new PM framework
PCI PM: Read power state from device after trying to change it on resume
PCI PM: Do not disable and enable bridges during suspend-resume
PCI: PCIe portdrv: Simplify suspend and resume
PCI PM: Fix saving of device state in pci_legacy_suspend
PCI PM: Check if the state has been saved before trying to restore it
PCI PM: Fix handling of devices without drivers
PCI: return error on failure to read PCI ROMs
PCI: properly clean up ASPM link state on device remove
Impact: fix spurious BUG_ON() triggered under load
module_refcount() isn't reliable outside stop_machine(), as demonstrated
by Karsten Keil <kkeil@suse.de>, networking can trigger it under load
(an inc on one cpu and dec on another while module_refcount() is tallying
can give false results, for example).
Almost noone should be using __module_get, but that's another issue.
Cc: Karsten Keil <kkeil@suse.de>
Based upon a patch from Atsushi Nemoto <anemo@mba.ocn.ne.jp>
The commit 649274d993212e7c23c0cb734572c2311c200872 ("net_dma:
acquire/release dma channels on ifup/ifdown") added unconditional call
of dmaengine_get() to net_dma. The API should be called only if
NET_DMA was enabled.
Acked-by: Dan Williams <dan.j.williams@intel.com>
Mike Galbraith reported that the new warning in thread_group_cputimer()
triggers en masse with Amarok running.
Oleg Nesterov observed:
Can't fastpath_timer_check()->thread_group_cputimer() have the
false warning too? Suppose we had the timer, then posix_cpu_timer_del()
removes this timer, but task_cputime_zero(&sig->cputime_expires) still
not true.
Remove the spurious debug warning.
Explained-by: Oleg Nesterov <oleg@redhat.com>
With exclusive waiters, every process woken up through the wait queue must
ensure that the next waiter down the line is woken when it has finished.
Interruptible waiters don't do that when aborting due to a signal. And if
an aborting waiter is concurrently woken up through the waitqueue, noone
will ever wake up the next waiter.
This has been observed with __wait_on_bit_lock() used by
lock_page_killable(): the first contender on the queue was aborting when
the actual lock holder woke it up concurrently. The aborted contender
didn't acquire the lock and therefor never did an unlock followed by
waking up the next waiter.
Add abort_exclusive_wait() which removes the process' wait descriptor from
the waitqueue, iff still queued, or wakes up the next waiter otherwise.
It does so under the waitqueue lock. Racing with a wake up means the
aborting process is either already woken (removed from the queue) and will
wake up the next waiter, or it will remove itself from the queue and the
concurrent wake up will apply to the next waiter after it.
Use abort_exclusive_wait() in __wait_event_interruptible_exclusive() and
__wait_on_bit_lock() when they were interrupted by other means than a wake
up through the queue.
Reported-by: Chris Mason <chris.mason@oracle.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Mentored-by: Oleg Nesterov <oleg@redhat.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Chuck Lever <cel@citi.umich.edu>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: <stable@kernel.org> ["after some testing"]
Avoid calling copy_from/to_user() with fb_info->lock mutex held in fbmem
ioctl().
fb_mmap() is called under mm->mmap_sem (A) held, that also acquires
fb_info->lock (B); fb_ioctl() takes fb_info->lock (B) and does
copy_from/to_user() that might acquire mm->mmap_sem (A), causing a
deadlock.
NOTE: it doesn't push down the fb_info->lock in each own driver's
fb_ioctl(), so there are still potential deadlocks elsewhere.
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
Cc: Dave Jones <davej@redhat.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Johannes Weiner <hannes@saeurebad.de>
Cc: Krzysztof Helt <krzysztof.h1@wp.pl>
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
The swap() macro is accidentally retuning the value of its first argument.
Change it into a doesn't-return-anything macro before someone goes and
relies upon this behaviour.
Cc: Wu Fengguang <wfg@linux.intel.com>
Change the process wide cpu timers/clocks so that we:
1) don't mess up the kernel with too many threads,
2) don't have a per-cpu allocation for each process,
3) have no impact when not used.
In order to accomplish this we're going to split it into two parts:
- clocks; which can take all the time they want since they run
from user context -- ie. sys_clock_gettime(CLOCK_PROCESS_CPUTIME_ID)
- timers; which need constant time sampling but since they're
explicity used, the user can pay the overhead.
The clock readout will go back to a full sum of the thread group, while the
timers will run of a global 'clock' that only runs when needed, so only
programs that make use of the facility pay the price.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
We're going to split the process wide cpu accounting into two parts:
from user context.
- timers; which need constant time tracing but can affort the overhead
because they're default off -- and rare.
The clock readout will go back to a full sum of the thread group, for this
we need to re-add the exit stats that were removed in the initial itimer
rework (f06febc9: timers: fix itimer/many thread hang).
Furthermore, since that full sum can be rather slow for large thread groups
and we have the complete dead task stats, revert the do_notify_parent time
computation.
Geert Uytterhoeven pointed out that we're not zeroing all the
memory when freeing a transform. This patch fixes it by calling
ksize to ensure that we zero everything in sight.
Reported-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
This patch makes the ROM reading code return an error to user space if
the size of the ROM read is equal to 0.
The patch also emits a warnings if the contents of the ROM are invalid,
and documents the effects of the "enable" file on ROM reading.
Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au>
Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: add missing kernel-doc in sched.h
sunrpc: fix rdma dependencies
e1000: Fix PCI enable to honor the need_ioport flag
sgi-xp: link XPNET's net_device_ops to its net_device structure
pcnet_cs: Fix misuse of the equality operator.
hso: add new device id's
dca: redesign locks to fix deadlocks
cassini/sungem: limit reaches -1, but 0 tested
net: variables reach -1, but 0 tested
qlge: bugfix: Add missing netif_napi_del call.
qlge: bugfix: Add flash offset for second port.
qlge: bugfix: Fix endian issue when reading flash.
udp: increments sk_drops in __udp_queue_rcv_skb()
net: Fix userland breakage wrt. linux/if_tunnel.h
net: packet socket packet_lookup_frame fix
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: implement HORKAGE_1_5_GBPS and apply it to WD My Book
libata: add no penalty retry request for EH device handling routines
libata: improve probe failure handling
libata: add @spd_limit to sata_down_spd_limit()
libata: clear dev->ering in smarter way
libata: check onlineness before using SPD in sata_down_spd_limit()
libata: move ata_dev_disable() to libata-eh.c
libata: fix EH device failure handling
sata_nv: ck804 has borked hardreset too
ide/libata: fix ata_id_is_cfa() (take 4)
libata: fix kernel-doc warnings
ahci: add a module parameter to ignore the SSS flags for async scanning
sata_mv: Fix chip type for Hightpoint RocketRaid 1740/1742
[libata] sata_sil: Fix compilation error with libata debugging enabled
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Add kernel-doc notation for @lock:
include/linux/sched.h:457: No description found for parameter 'lock'
3Gbps is often much more prone to transmission failures. It's usually
okay to let EH handle speed down after transmission failures but some
WD My Book drives completely shutdown after certain transmission
failures and after it only power cycling can revive them. Combined
with the fact that external drives often end up with cable assembly
which is longer than usual and more likely to have intervening gender,
this makes these drives very likely to shutdown under certain
configurations virtually rendering them unusable.
This patch implements HOARKGE_1_5_GBPS and applies it to WD My Book
such that 1.5Gbps is forced once the device is identified.
Please take a look at the following bz for related reports.
http://bugzilla.kernel.org/show_bug.cgi?id=9913
dev->ering used to be cleared together with the rest of ata_device in
ata_dev_init() which is called whenever a probing event occurs.
dev->ering is about to be used to track probing failures so it needs
to remain persistent over multiple porbing events. This patch
achieves this by doing the following.
* Instead of CLEAR_OFFSET, define CLEAR_BEGIN and CLEAR_END and only
clear between BEGIN and END. ering is moved after END. The split
of persistent area is to allow hotter items remain at the head.
* ering is explicitly cleared on ata_dev_disable() and when device
attach succeeds. So, ering is persistent throug a device's life
time (unless explicitly cleared of course) and also through periods
inbetween disablement of an attached device and successful detection
of the next one.
When checking for the CFA feature set support, ata_id_is_cfa() tests bit 2 in
word 82 of the identify data instead the word 83; it also checks the ATA/PI
version support in the word 80 (which the CompactFlash specifications have as
reserved), this having no slightest chance to work on the modern CF cards that
don't have 0x848A in the word 0...
PCI hotplug: Change link order of pciehp & acpiphp
PCI hotplug: fakephp: Allocate PCI resources before adding the device
PCI MSI: Fix undefined shift by 32
PCI PM: Do not wait for buses in B2 or B3 during resume
PCI PM: Power up devices before restoring their state
PCI PM: Fix hibernation breakage on EeePC 701
PCI: irq and pci_ids patch for Intel Tigerpoint DeviceIDs
PCI PM: Fix suspend error paths and testing facility breakage
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
slub: fix per cpu kmem_cache_cpu array memory leak
kmalloc: return NULL instead of link failure
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: add text file detailing queue/ sysfs files
bio.h: If they MUST be inlined, then use __always_inline
Fix misleading comment in bio.h
block: fix inconsistent parenthesisation of QUEUE_FLAG_DEFAULT
block: fix oops in blk_queue_io_stat()
Current refcounting for modules (done if CONFIG_MODULE_UNLOAD=y) is
using a lot of memory.
Each 'struct module' contains an [NR_CPUS] array of full cache lines.
This patch uses existing infrastructure (percpu_modalloc() &
percpu_modfree()) to allocate percpu space for the refcount storage.
Instead of wasting NR_CPUS*128 bytes (on i386), we now use
nr_cpu_ids*sizeof(local_t) bytes.
On a typical distro, where NR_CPUS=8, shiping 2000 modules, we reduce
size of module files by about 2 Mbytes. (1Kb per module)
Instead of having all refcounters in the same memory node - with TLB misses
because of vmalloc() - this new implementation permits to have better
NUMA properties, since each CPU will use storage on its preferred node,
thanks to percpu storage.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Reported by Andrew Walrond <andrew@walrond.org>
Changeset c19e654ddbe3831252f61e76a74d661e1a755530
("gre: Add netlink interface") added an include
of linux/ip.h to linux/if_tunnel.h
We can't really let that get exposed to userspace
because this conflicts with types defined in netinet/ip.h
which userland is almost certainly going to have included
either explicitly or implicitly.
So guard this include with a __KERNEL__ ifdef.
bvec_kmap_irq() and bvec_kunmap_irq() comments say they MUST be inlined,
so mark them as __always_inline.
Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar>
The comment says "remember to add offset!", but the function already adds
it.
* 'header-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (90 commits)
headers_check fix: x86, swab.h
headers_check fix: x86, sigcontext32.h
headers_check fix: x86, sigcontext.h
headers_check fix: x86, ptrace-abi.h
headers_check fix: x86, mtrr.h
headers_check fix: x86, mce.h
headers_check fix: x86, kvm.h
headers_check fix: x86, e820.h
headers_check fix: linux/rtnetlink.h
headers_check fix: linux/nubus.h
headers_check fix: video/uvesafb.h
headers_check fix: video/sisfb.h
headers_check fix: sound/hdsp.h
headers_check fix: mtd/inftl-user.h
headers_check fix: linux/virtio_net.h
headers_check fix: linux/virtio_console.h
headers_check fix: linux/virtio_blk.h
headers_check fix: linux/videodev.h
headers_check fix: linux/video_encoder.h
headers_check fix: linux/video_decoder.h
hrtimer: prevent negative expiry value after clock_was_set()
hrtimers: allow the hot-unplugging of all cpus
hrtimers: increase clock min delta threshold while interrupt hanging
The definition of spawn_softlockup_task in sched.h became
unnecessary once it was converted to the early_initcall()
interface.
Impact: fix CPU hotplug hang on Power6 testbox
On architectures that support offlining all cpus (at least powerpc/pseries),
hot-unpluging the tick_do_timer_cpu can result in a system hang.
This comes from the fact that if the cpu going down happens to be the
cpu doing the tick, then as the tick_do_timer_cpu handover happens after the
cpu is dead (via the CPU_DEAD notification), we're left without ticks,
jiffies are frozen and any task relying on timers (msleep, ...) is stuck.
That's particularly the case for the cpu looping in __cpu_die() waiting
for the dying cpu to be dead.
This patch addresses this by having the tick_do_timer_cpu handover happen
earlier during the CPU_DYING notification. For this, a new clockevent
notification type is introduced (CLOCK_EVT_NOTIFY_CPU_DYING) which is triggered
in hrtimer_cpu_notify().
Signed-off-by: Sebastien Dugue <sebastien.dugue@bull.net>
fix the following 'make headers_check' warning:
usr/include/linux/rtnetlink.h:328: found __[us]{8,16,32,64} type without #include <linux/types.h>
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
usr/include/linux/nubus.h:232: found __[us]{8,16,32,64} type without #include <linux/types.h>
usr/include/linux/virtio_net.h:28: found __[us]{8,16,32,64} type without #include <linux/types.h>
usr/include/linux/virtio_console.h:15: found __[us]{8,16,32,64} type without #include <linux/types.h>
usr/include/linux/virtio_blk.h:21: found __[us]{8,16,32,64} type without #include <linux/types.h>
usr/include/linux/videodev.h:53: found __[us]{8,16,32,64} type without #include <linux/types.h>
