[ Upstream commit 119a784c81270eb88e573174ed2209225d646656 ]
Sometimes we want to know an accurate number of samples even if it's
lost. Currenlty PERF_RECORD_LOST is generated for a ring-buffer which
might be shared with other events. So it's hard to know per-event
lost count.
Add event->lost_samples field and PERF_FORMAT_LOST to retrieve it from
userspace.
Original-patch-by: Jiri Olsa <jolsa@redhat.com>
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Link: https://lkml.kernel.org/r/20220616180623.1358843-1-namhyung@kernel.org
Stable-dep-of: 382c27f4ed28 ("perf: Fix perf_event_validate_size()")
[ Upstream commit d721def7392a7348ffb9f3583b264239cbd3702c ]
Making kallsyms_on_each_symbol generally available, so it can be
used outside CONFIG_LIVEPATCH option in following changes.
Rather than adding another ifdef option let's make the function
generally available (when CONFIG_KALLSYMS option is defined).
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Link: https://lore.kernel.org/r/20220510122616.2652285-2-jolsa@kernel.org
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
commit d839a656d0f3caca9f96e9bf912fd394ac6a11bc upstream.
It seems that the pointer-to-kretprobe "rp" within the kretprobe_holder is
RCU-managed, based on the (non-rethook) implementation of get_kretprobe().
The thought behind this patch is to make use of the RCU API where possible
when accessing this pointer so that the needed barriers are always in place
and to self-document the code.
The __rcu annotation to "rp" allows for sparse RCU checking. Plain writes
done to the "rp" pointer are changed to make use of the RCU macro for
assignment. For the single read, the implementation of get_kretprobe()
is simplified by making use of an RCU macro which accomplishes the same,
but note that the log warning text will be more generic.
I did find that there is a difference in assembly generated between the
usage of the RCU macros vs without. For example, on arm64, when using
rcu_assign_pointer(), the corresponding store instruction is a
store-release (STLR) which has an implicit barrier. When normal assignment
is done, a regular store (STR) is found. In the macro case, this seems to
be a result of rcu_assign_pointer() using smp_store_release() when the
value to write is not NULL.
Link: https://lore.kernel.org/all/20231122132058.3359-1-inwardvessel@gmail.com/
Fixes: d741bf41d7c7 ("kprobes: Remove kretprobe hash")
Cc: stable@vger.kernel.org
Signed-off-by: JP Kobryn <inwardvessel@gmail.com>
Acked-by: Masami Hiramatsu (Google) <mhiramat@kernel.org>
Signed-off-by: Masami Hiramatsu (Google) <mhiramat@kernel.org>
[ Upstream commit 37e4b8df27bc68340f3fc80dbb27e3549c7f881c ]
The status bits of register MAC_FPE_CTRL_STS are clear on read. Using
32-bit read for MAC_FPE_CTRL_STS in dwmac5_fpe_configure() and
dwmac5_fpe_send_mpacket() clear the status bits. Then the stmmac interrupt
handler missing FPE event status and leads to FPE handshaking failure and
retries.
To avoid clear status bits of MAC_FPE_CTRL_STS in dwmac5_fpe_configure()
and dwmac5_fpe_send_mpacket(), add fpe_csr to stmmac_fpe_cfg structure to
cache the control bits of MAC_FPE_CTRL_STS and to avoid reading
MAC_FPE_CTRL_STS in those methods.
Fixes: 5a5586112b92 ("net: stmmac: support FPE link partner hand-shaking procedure")
Reviewed-by: Serge Semin <fancer.lancer@gmail.com>
Signed-off-by: Jianheng Zhang <Jianheng.Zhang@synopsys.com>
Link: https://lore.kernel.org/r/CY5PR12MB637225A7CF529D5BE0FBE59CBF81A@CY5PR12MB6372.namprd12.prod.outlook.com
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit e397c3c460bf3849384f2f55516d1887617cfca9 ]
Add quirk for ASUS ROG X13 Flow 2-in-1 to enable tablet mode with
lid flip (all screen rotations).
Signed-off-by: Luke D. Jones <luke@ljones.dev>
Link: https://lore.kernel.org/r/20220813092753.6635-2-luke@ljones.dev
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Stable-dep-of: b52cbca22cbf ("platform/x86: asus-wmi: Move i8042 filter install to shared asus-wmi code")
[ Upstream commit 5c0930ccaad5a74d74e8b18b648c5eb21ed2fe94 ]
2b8272ff4a70 ("cpu/hotplug: Prevent self deadlock on CPU hot-unplug")
solved the straight forward CPU hotplug deadlock vs. the scheduler
bandwidth timer. Yu discovered a more involved variant where a task which
has a bandwidth timer started on the outgoing CPU holds a lock and then
gets throttled. If the lock required by one of the CPU hotplug callbacks
the hotplug operation deadlocks because the unthrottling timer event is not
handled on the dying CPU and can only be recovered once the control CPU
reaches the hotplug state which pulls the pending hrtimers from the dead
CPU.
Solve this by pushing the hrtimers away from the dying CPU in the dying
callbacks. Nothing can queue a hrtimer on the dying CPU at that point because
all other CPUs spin in stop_machine() with interrupts disabled and once the
operation is finished the CPU is marked offline.
Reported-by: Yu Liao <liaoyu15@huawei.com>
Tested-by: Liu Tie <liutie4@huawei.com>
Link: https://lore.kernel.org/r/87a5rphara.ffs@tglx
[ Upstream commit 8d91f3f8ae57e6292142ca89f322e90fa0d6ac02 ]
There's a number of drivers (e.g. dw_mmc, meson-gx, mmci, sunxi) using
the same mechanism and a private flag vqmmc_enabled to deal with
enabling/disabling the vqmmc regulator.
Move this to the core and create new helpers mmc_regulator_enable_vqmmc
and mmc_regulator_disable_vqmmc.
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Acked-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Link: https://lore.kernel.org/r/71586432-360f-9b92-17f6-b05a8a971bc2@gmail.com
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Stable-dep-of: 477865af60b2 ("mmc: sdhci-sprd: Fix vqmmc not shutting down after the card was pulled")
[ Upstream commit 9b6304c1d53745c300b86f202d0dcff395e2d2db ]
struct timespec64 has unused bits in the tv_nsec field that can be used
for other purposes. In future patches, we're going to change how the
inode->i_ctime is accessed in certain inodes in order to make use of
them. In order to do that safely though, we'll need to eradicate raw
accesses of the inode->i_ctime field from the kernel.
Add new accessor functions for the ctime that we use to replace them.
Reviewed-by: Luis Chamberlain <mcgrof@kernel.org>
Signed-off-by: Jeff Layton <jlayton@kernel.org>
Reviewed-by: Damien Le Moal <dlemoal@kernel.org>
Message-Id: <20230705185812.579118-2-jlayton@kernel.org>
Signed-off-by: Christian Brauner <brauner@kernel.org>
Stable-dep-of: 5923d6686a10 ("smb3: fix caching of ctime on setxattr")
[ Upstream commit cd45c9bf8b43cd387e167cf166ae5c517f56d658 ]
The soc_intel_is_foo() helpers from
sound/soc/intel/common/soc-intel-quirks.h are useful outside of the
sound subsystem too.
Move these to include/linux/platform_data/x86/soc.h, so that
other code can use them too.
Suggested-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Acked-by: Mark Brown <broonie@kernel.org>
Link: https://lore.kernel.org/r/20211018143324.296961-2-hdegoede@redhat.com
Stable-dep-of: 7dd692217b86 ("ASoC: SOF: sof-pci-dev: Fix community key quirk detection")
[ Upstream commit 73b4b53276a1d6290cd4f47dbbc885b6e6e59ac6 ]
This reverts commit 6417250d3f894e66a68ba1cd93676143f2376a6f.
amdpgu need this function in order to prematurly stop pending
reset works when another reset work already in progress.
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Andrey Grodzovsky <andrey.grodzovsky@amd.com>
Reviewed-by: Lai Jiangshan<jiangshanlai@gmail.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Stable-dep-of: 91d3d149978b ("r8169: prevent potential deadlock in rtl8169_close")
commit 8001f49394e353f035306a45bcf504f06fca6355 upstream.
The code that checks for unknown boot options is unaware of the sysctl
alias facility, which maps bootparams to sysctl values. If a user sets
an old value that has a valid alias, a message about an invalid
parameter will be printed during boot, and the parameter will get passed
to init. Fix by checking for the existence of aliased parameters in the
unknown boot parameter code. If an alias exists, don't return an error
or pass the value to init.
Signed-off-by: Krister Johansen <kjlx@templeofstupid.com>
Fixes: 0a477e1ae21b ("kernel/sysctl: support handling command line aliases")
Signed-off-by: Luis Chamberlain <mcgrof@kernel.org>
[ Upstream commit fc43e9c857b7aa55efba9398419b14d9e35dcc7d ]
hid_debug_events_release releases resources bound to the HID device instance.
hid_device_release releases the underlying HID device instance potentially
before hid_debug_events_release has completed releasing debug resources bound
to the same HID device instance.
Reference count to prevent the HID device instance from being torn down
preemptively when HID debugging support is used. When count reaches zero,
release core resources of HID device instance using hiddev_free.
The crash:
[ 120.728477][ T4396] kernel BUG at lib/list_debug.c:53!
[ 120.728505][ T4396] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 120.739806][ T4396] Modules linked in: bcmdhd dhd_static_buf 8822cu pcie_mhi r8168
[ 120.747386][ T4396] CPU: 1 PID: 4396 Comm: hidt_bridge Not tainted 5.10.110 #257
[ 120.754771][ T4396] Hardware name: Rockchip RK3588 EVB4 LP4 V10 Board (DT)
[ 120.761643][ T4396] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[ 120.768338][ T4396] pc : __list_del_entry_valid+0x98/0xac
[ 120.773730][ T4396] lr : __list_del_entry_valid+0x98/0xac
[ 120.779120][ T4396] sp : ffffffc01e62bb60
[ 120.783126][ T4396] x29: ffffffc01e62bb60 x28: ffffff818ce3a200
[ 120.789126][ T4396] x27: 0000000000000009 x26: 0000000000980000
[ 120.795126][ T4396] x25: ffffffc012431000 x24: ffffff802c6d4e00
[ 120.801125][ T4396] x23: ffffff8005c66f00 x22: ffffffc01183b5b8
[ 120.807125][ T4396] x21: ffffff819df2f100 x20: 0000000000000000
[ 120.813124][ T4396] x19: ffffff802c3f0700 x18: ffffffc01d2cd058
[ 120.819124][ T4396] x17: 0000000000000000 x16: 0000000000000000
[ 120.825124][ T4396] x15: 0000000000000004 x14: 0000000000003fff
[ 120.831123][ T4396] x13: ffffffc012085588 x12: 0000000000000003
[ 120.837123][ T4396] x11: 00000000ffffbfff x10: 0000000000000003
[ 120.843123][ T4396] x9 : 455103d46b329300 x8 : 455103d46b329300
[ 120.849124][ T4396] x7 : 74707572726f6320 x6 : ffffffc0124b8cb5
[ 120.855124][ T4396] x5 : ffffffffffffffff x4 : 0000000000000000
[ 120.861123][ T4396] x3 : ffffffc011cf4f90 x2 : ffffff81fee7b948
[ 120.867122][ T4396] x1 : ffffffc011cf4f90 x0 : 0000000000000054
[ 120.873122][ T4396] Call trace:
[ 120.876259][ T4396] __list_del_entry_valid+0x98/0xac
[ 120.881304][ T4396] hid_debug_events_release+0x48/0x12c
[ 120.886617][ T4396] full_proxy_release+0x50/0xbc
[ 120.891323][ T4396] __fput+0xdc/0x238
[ 120.895075][ T4396] ____fput+0x14/0x24
[ 120.898911][ T4396] task_work_run+0x90/0x148
[ 120.903268][ T4396] do_exit+0x1bc/0x8a4
[ 120.907193][ T4396] do_group_exit+0x8c/0xa4
[ 120.911458][ T4396] get_signal+0x468/0x744
[ 120.915643][ T4396] do_signal+0x84/0x280
[ 120.919650][ T4396] do_notify_resume+0xd0/0x218
[ 120.924262][ T4396] work_pending+0xc/0x3f0
[ Rahul Rameshbabu <sergeantsagara@protonmail.com>: rework changelog ]
Fixes: cd667ce24796 ("HID: use debugfs for events/reports dumping")
Signed-off-by: Charles Yi <be286@163.com>
[ Upstream commit 1e839143d674603b0bbbc4c513bca35404967dbc ]
This unique identifier is currently used only for ensuring uniqueness in
sysfs. However, this could be handful for userspace to refer to a specific
hid_device by this id.
2 use cases are in my mind: LEDs (and their naming convention), and
HID-BPF.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Link: https://lore.kernel.org/r/20220902132938.2409206-9-benjamin.tissoires@redhat.com
Stable-dep-of: fc43e9c857b7 ("HID: fix HID device resource race between HID core and debugging support")
commit bb32500fb9b78215e4ef6ee8b4345c5f5d7eafb4 upstream.
The following can crash the kernel:
# cd /sys/kernel/tracing
# echo 'p:sched schedule' > kprobe_events
# exec 5>>events/kprobes/sched/enable
# > kprobe_events
# exec 5>&-
The above commands:
1. Change directory to the tracefs directory
2. Create a kprobe event (doesn't matter what one)
3. Open bash file descriptor 5 on the enable file of the kprobe event
4. Delete the kprobe event (removes the files too)
5. Close the bash file descriptor 5
The above causes a crash!
BUG: kernel NULL pointer dereference, address: 0000000000000028
#PF: supervisor read access in kernel mode
#PF: error_code(0x0000) - not-present page
PGD 0 P4D 0
Oops: 0000 [#1] PREEMPT SMP PTI
CPU: 6 PID: 877 Comm: bash Not tainted 6.5.0-rc4-test-00008-g2c6b6b1029d4-dirty #186
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS 1.16.2-debian-1.16.2-1 04/01/2014
RIP: 0010:tracing_release_file_tr+0xc/0x50
What happens here is that the kprobe event creates a trace_event_file
"file" descriptor that represents the file in tracefs to the event. It
maintains state of the event (is it enabled for the given instance?).
Opening the "enable" file gets a reference to the event "file" descriptor
via the open file descriptor. When the kprobe event is deleted, the file is
also deleted from the tracefs system which also frees the event "file"
descriptor.
But as the tracefs file is still opened by user space, it will not be
totally removed until the final dput() is called on it. But this is not
true with the event "file" descriptor that is already freed. If the user
does a write to or simply closes the file descriptor it will reference the
event "file" descriptor that was just freed, causing a use-after-free bug.
To solve this, add a ref count to the event "file" descriptor as well as a
new flag called "FREED". The "file" will not be freed until the last
reference is released. But the FREE flag will be set when the event is
removed to prevent any more modifications to that event from happening,
even if there's still a reference to the event "file" descriptor.
Link: https://lore.kernel.org/linux-trace-kernel/20231031000031.1e705592@gandalf.local.home/
Link: https://lore.kernel.org/linux-trace-kernel/20231031122453.7a48b923@gandalf.local.home
Cc: Mark Rutland <mark.rutland@arm.com>
Fixes: f5ca233e2e66d ("tracing: Increase trace array ref count on enable and filter files")
Reported-by: Beau Belgrave <beaub@linux.microsoft.com>
Tested-by: Beau Belgrave <beaub@linux.microsoft.com>
Reviewed-by: Masami Hiramatsu (Google) <mhiramat@kernel.org>
Signed-off-by: Steven Rostedt (Google) <rostedt@goodmis.org>
commit f55d8e60f10909dbc5524e261041e1d28d7d20d8 upstream.
This function takes a pointer to a pointer, unlike sprintf() which is
passed a plain pointer. Fix up the documentation to make this clear.
Fixes: 7888fe53b706 ("ethtool: Add common function for filling out strings")
Cc: Alexander Duyck <alexanderduyck@fb.com>
Cc: Justin Stitt <justinstitt@google.com>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Justin Stitt <justinstitt@google.com>
Link: https://lore.kernel.org/r/20231028192511.100001-1-andrew@lunn.ch
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
commit b36995b8609a5a8fe5cf259a1ee768fcaed919f8 upstream.
-EOPNOTSUPP is the return value that implements a "no-op" hook, not 0.
Without this fix having only the BPF LSM enabled (with no programs
attached) can cause uninitialized variable reads in
nfsd4_encode_fattr(), because the BPF hook returns 0 without touching
the 'ctxlen' variable and the corresponding 'contextlen' variable in
nfsd4_encode_fattr() remains uninitialized, yet being treated as valid
based on the 0 return value.
Fixes: 98e828a0650f ("security: Refactor declaration of LSM hooks")
Reported-by: Benjamin Coddington <bcodding@redhat.com>
Signed-off-by: Ondrej Mosnacek <omosnace@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
commit 866d648059d5faf53f1cd960b43fe8365ad93ea7 upstream.
1 is the return value that implements a "no-op" hook, not 0.
[ Upstream commit bfca5fb4e97c46503ddfc582335917b0cc228264 ]
RPC client pipefs dentries cleanup is in separated rpc_remove_pipedir()
workqueue,which takes care about pipefs superblock locking.
In some special scenarios, when kernel frees the pipefs sb of the
current client and immediately alloctes a new pipefs sb,
rpc_remove_pipedir function would misjudge the existence of pipefs
sb which is not the one it used to hold. As a result,
the rpc_remove_pipedir would clean the released freed pipefs dentries.
To fix this issue, rpc_remove_pipedir should check whether the
current pipefs sb is consistent with the original pipefs sb.
This error can be catched by KASAN:
[ 250.497700] BUG: KASAN: slab-use-after-free in dget_parent+0x195/0x200
[ 250.498315] Read of size 4 at addr ffff88800a2ab804 by task kworker/0:18/106503
[ 250.500549] Workqueue: events rpc_free_client_work
[ 250.501001] Call Trace:
[ 250.502880] kasan_report+0xb6/0xf0
[ 250.503209] ? dget_parent+0x195/0x200
[ 250.503561] dget_parent+0x195/0x200
[ 250.503897] ? __pfx_rpc_clntdir_depopulate+0x10/0x10
[ 250.504384] rpc_rmdir_depopulate+0x1b/0x90
[ 250.504781] rpc_remove_client_dir+0xf5/0x150
[ 250.505195] rpc_free_client_work+0xe4/0x230
[ 250.505598] process_one_work+0x8ee/0x13b0
[ 22.039056] Allocated by task 244:
[ 22.039390] kasan_save_stack+0x22/0x50
[ 22.039758] kasan_set_track+0x25/0x30
[ 22.040109] __kasan_slab_alloc+0x59/0x70
[ 22.040487] kmem_cache_alloc_lru+0xf0/0x240
[ 22.040889] __d_alloc+0x31/0x8e0
[ 22.041207] d_alloc+0x44/0x1f0
[ 22.041514] __rpc_lookup_create_exclusive+0x11c/0x140
[ 22.041987] rpc_mkdir_populate.constprop.0+0x5f/0x110
[ 22.042459] rpc_create_client_dir+0x34/0x150
[ 22.042874] rpc_setup_pipedir_sb+0x102/0x1c0
[ 22.043284] rpc_client_register+0x136/0x4e0
[ 22.043689] rpc_new_client+0x911/0x1020
[ 22.044057] rpc_create_xprt+0xcb/0x370
[ 22.044417] rpc_create+0x36b/0x6c0
[ 22.049524] Freed by task 0:
[ 22.049803] kasan_save_stack+0x22/0x50
[ 22.050165] kasan_set_track+0x25/0x30
[ 22.050520] kasan_save_free_info+0x2b/0x50
[ 22.050921] __kasan_slab_free+0x10e/0x1a0
[ 22.051306] kmem_cache_free+0xa5/0x390
[ 22.051667] rcu_core+0x62c/0x1930
[ 22.051995] __do_softirq+0x165/0x52a
[ 22.052347]
[ 22.052503] Last potentially related work creation:
[ 22.052952] kasan_save_stack+0x22/0x50
[ 22.053313] __kasan_record_aux_stack+0x8e/0xa0
[ 22.053739] __call_rcu_common.constprop.0+0x6b/0x8b0
[ 22.054209] dentry_free+0xb2/0x140
[ 22.054540] __dentry_kill+0x3be/0x540
[ 22.054900] shrink_dentry_list+0x199/0x510
[ 22.055293] shrink_dcache_parent+0x190/0x240
[ 22.055703] do_one_tree+0x11/0x40
[ 22.056028] shrink_dcache_for_umount+0x61/0x140
[ 22.056461] generic_shutdown_super+0x70/0x590
[ 22.056879] kill_anon_super+0x3a/0x60
[ 22.057234] rpc_kill_sb+0x121/0x200
Fixes: 0157d021d23a ("SUNRPC: handle RPC client pipefs dentries by network namespace aware routines")
Signed-off-by: felix <fuzhen5@huawei.com>
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
[ Upstream commit 87c3a5893e865739ce78aa7192d36011022e0af7 ]
Except on x86, preempt_count is always accessed with READ_ONCE().
Repeated invocations in macros like irq_count() produce repeated loads.
These redundant instructions appear in various fast paths. In the one
shown below, for example, irq_count() is evaluated during kernel entry
if !tick_nohz_full_cpu(smp_processor_id()).
0001ed0a <irq_enter_rcu>:
1ed0a: 4e56 0000 linkw %fp,#0
1ed0e: 200f movel %sp,%d0
1ed10: 0280 ffff e000 andil #-8192,%d0
1ed16: 2040 moveal %d0,%a0
1ed18: 2028 0008 movel %a0@(8),%d0
1ed1c: 0680 0001 0000 addil #65536,%d0
1ed22: 2140 0008 movel %d0,%a0@(8)
1ed26: 082a 0001 000f btst #1,%a2@(15)
1ed2c: 670c beqs 1ed3a <irq_enter_rcu+0x30>
1ed2e: 2028 0008 movel %a0@(8),%d0
1ed32: 2028 0008 movel %a0@(8),%d0
1ed36: 2028 0008 movel %a0@(8),%d0
1ed3a: 4e5e unlk %fp
1ed3c: 4e75 rts
This patch doesn't prevent the pointless btst and beqs instructions
above, but it does eliminate 2 of the 3 pointless move instructions
here and elsewhere.
On x86, preempt_count is per-cpu data and the problem does not arise
presumably because the compiler is free to optimize more effectively.
This patch was tested on m68k and x86. I was expecting no changes
to object code for x86 and mostly that's what I saw. However, there
were a few places where code generation was perturbed for some reason.
The performance issue addressed here is minor on uniprocessor m68k. I
got a 0.01% improvement from this patch for a simple "find /sys -false"
benchmark. For architectures and workloads susceptible to cache line bounce
the improvement is expected to be larger. The only SMP architecture I have
is x86, and as x86 unaffected I have not done any further measurements.
Fixes: 15115830c887 ("preempt: Cleanup the macro maze a bit")
Signed-off-by: Finn Thain <fthain@linux-m68k.org>
Link: https://lore.kernel.org/r/0a403120a682a525e6db2d81d1a3ffcc137c3742.1694756831.git.fthain@linux-m68k.org
[ Upstream commit 91ebe8bcbff9d2ff21303e73bf7434f39a98b255 ]
Now that there are three different instances of doing the addition trick
to the preempt_count() and NMI_MASK, HARDIRQ_MASK and SOFTIRQ_OFFSET
macros, it deserves a helper function defined in the preempt.h header.
Add the interrupt_context_level() helper and replace the three instances
that do that logic with it.
Link: https://lore.kernel.org/all/20211015142541.4badd8a9@gandalf.local.home/
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Stable-dep-of: 87c3a5893e86 ("sched/core: Optimize in_task() and in_interrupt() a bit")
[ Upstream commit 9b84fadc444de5456ab5f5487e2108311c724c3f ]
Instead of having branches that adds noise to the branch prediction, use
the addition logic to set the bit for the level of interrupt context that
the state is currently in. This copies the logic from perf's
get_recursion_context() function.
Link: https://lore.kernel.org/all/20211015161702.GF174703@worktop.programming.kicks-ass.net/
Suggested-by: Peter Zijlstra <peterz@infradead.org>
[ Upstream commit d27abbfd4888d79dd24baf50e774631046ac4732 ]
These enums are passed to set/test_bit(). The set/test_bit() functions
take a bit number instead of a shifted value. Passing a shifted value
is a double shift bug like doing BIT(BIT(1)). The double shift bug
doesn't cause a problem here because we are only checking 0 and 1 but
if the value was 5 or above then it can lead to a buffer overflow.
Signed-off-by: Dan Carpenter <dan.carpenter@linaro.org>
Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
[ Upstream commit 313ebe47d75558511aa1237b6e35c663b5c0ec6f ]
Currently, user array duplications are sometimes done without an
overflow check. Sometimes the checks are done manually; sometimes the
array size is calculated with array_size() and sometimes by calculating
n * size directly in code.
Introduce wrappers for arrays for memdup_user() and vmemdup_user() to
provide a standardized and safe way for duplicating user arrays.
This is both for new code as well as replacing usage of (v)memdup_user()
in existing code that uses, e.g., n * size to calculate array sizes.
Suggested-by: David Airlie <airlied@redhat.com>
Signed-off-by: Philipp Stanner <pstanner@redhat.com>
Reviewed-by: Zack Rusin <zackr@vmware.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20230920123612.16914-3-pstanner@redhat.com
[ Upstream commit 265f3ed077036f053981f5eea0b5b43e7c5b39ff ]
All callers of work_on_cpu() share the same lock class key for all the
functions queued. As a result the workqueue related locking scenario for
a function A may be spuriously accounted as an inversion against the
locking scenario of function B such as in the following model:
long A(void *arg)
mutex_lock(&mutex);
mutex_unlock(&mutex);
long B(void *arg)
void launchA(void)
work_on_cpu(0, A, NULL);
void launchB(void)
mutex_lock(&mutex);
work_on_cpu(1, B, NULL);
launchA and launchB running concurrently have no chance to deadlock.
However the above can be reported by lockdep as a possible locking
inversion because the works containing A() and B() are treated as
belonging to the same locking class.
The following shows an existing example of such a spurious lockdep splat:
WARNING: possible circular locking dependency detected
6.6.0-rc1-00065-g934ebd6e5359 #35409 Not tainted
kworker/0:1/9 is trying to acquire lock:
ffffffff9bc72f30 (cpu_hotplug_lock){++++}-{0:0}, at: _cpu_down+0x57/0x2b0
but task is already holding lock:
ffff9e3bc0057e60 ((work_completion)(&wfc.work)){+.+.}-{0:0}, at: process_scheduled_works+0x216/0x500
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 ((work_completion)(&wfc.work)){+.+.}-{0:0}:
__flush_work+0x83/0x4e0
work_on_cpu+0x97/0xc0
rcu_nocb_cpu_offload+0x62/0xb0
rcu_nocb_toggle+0xd0/0x1d0
kthread+0xe6/0x120
ret_from_fork+0x2f/0x40
ret_from_fork_asm+0x1b/0x30
-> #1 (rcu_state.barrier_mutex){+.+.}-{3:3}:
__mutex_lock+0x81/0xc80
rcu_nocb_cpu_deoffload+0x38/0xb0
rcu_nocb_toggle+0x144/0x1d0
kthread+0xe6/0x120
-> #0 (cpu_hotplug_lock){++++}-{0:0}:
__lock_acquire+0x1538/0x2500
lock_acquire+0xbf/0x2a0
percpu_down_write+0x31/0x200
__cpu_down_maps_locked+0x10/0x20
work_for_cpu_fn+0x15/0x20
process_scheduled_works+0x2a7/0x500
worker_thread+0x173/0x330
kthread+0xe6/0x120
Chain exists of:
cpu_hotplug_lock --> rcu_state.barrier_mutex --> (work_completion)(&wfc.work)
Possible unsafe locking scenario:
CPU0 CPU1
lock((work_completion)(&wfc.work));
lock(rcu_state.barrier_mutex);
lock(cpu_hotplug_lock);
*** DEADLOCK ***
2 locks held by kworker/0:1/9:
#0: ffff900481068b38 ((wq_completion)events){+.+.}-{0:0}, at: process_scheduled_works+0x212/0x500
#1: ffff9e3bc0057e60 ((work_completion)(&wfc.work)){+.+.}-{0:0}, at: process_scheduled_works+0x216/0x500
stack backtrace:
CPU: 0 PID: 9 Comm: kworker/0:1 Not tainted 6.6.0-rc1-00065-g934ebd6e5359 #35409
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.12.0-59-gc9ba5276e321-prebuilt.qemu.org 04/01/2014
Workqueue: events work_for_cpu_fn
Call Trace:
rcu-torture: rcu_torture_read_exit: Start of episode
<TASK>
dump_stack_lvl+0x4a/0x80
check_noncircular+0x132/0x150
? _cpu_down+0x57/0x2b0
? __pfx_worker_thread+0x10/0x10
kthread+0xe6/0x120
? __pfx_kthread+0x10/0x10
</TASK
Fix this with providing one lock class key per work_on_cpu() caller.
Reported-and-tested-by: Paul E. McKenney <paulmck@kernel.org>
Signed-off-by: Frederic Weisbecker <frederic@kernel.org>
[ Upstream commit e8ae8ad479e2d037daa33756e5e72850a7bd37a9 ]
The comment for idr_for_each_entry_ul() states
after normal termination @entry is left with the value NULL
This is not correct in the case where UINT_MAX has an entry in the idr.
In that case @entry will be non-NULL after termination.
No current code depends on the documentation being correct, but to
save future code we should fix it.
Also fix idr_for_each_entry_continue_ul(). While this is not documented
as leaving @entry as NULL, the mellanox driver appears to depend on
it doing so. So make that explicit in the documentation as well as in
the code.
Fixes: e33d2b74d805 ("idr: fix overflow case for idr_for_each_entry_ul()")
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Chris Mi <chrism@mellanox.com>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Signed-off-by: NeilBrown <neilb@suse.de>
[ Upstream commit 3c70342f1f0045dc827bb2f02d814ce31e0e0d05 ]
Enable dynamically filling in the whole mfd_cell structure. All other
fields already allow that.
Fixes: 466a62d7642f ("mfd: core: Make a best effort attempt to match devices with the correct of_nodes")
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Link: https://lore.kernel.org/r/b73fe4bc4bd6ba1af90940a640ed65fe254c0408.1693253717.git.mirq-linux@rere.qmqm.pl
Signed-off-by: Lee Jones <lee@kernel.org>
[ Upstream commit 20f3b8eafe0ba5d3c69d5011a9b07739e9645132 ]
When KPTI is in use, we cannot register a runstate region as XEN
requires that this is always a valid VA, which we cannot guarantee. Due
to this, xen_starting_cpu() must avoid registering each CPU's runstate
region, and xen_guest_init() must avoid setting up features that depend
upon it.
We tried to ensure that in commit:
f88af7229f6f22ce (" xen/arm: do not setup the runstate info page if kpti is enabled")
... where we added checks for xen_kernel_unmapped_at_usr(), which wraps
arm64_kernel_unmapped_at_el0() on arm64 and is always false on 32-bit
arm.
Unfortunately, as xen_guest_init() is an early_initcall, this happens
before secondary CPUs are booted and arm64 has finalized the
ARM64_UNMAP_KERNEL_AT_EL0 cpucap which backs
arm64_kernel_unmapped_at_el0(), and so this can subsequently be set as
secondary CPUs are onlined. On a big.LITTLE system where the boot CPU
does not require KPTI but some secondary CPUs do, this will result in
xen_guest_init() intializing features that depend on the runstate
region, and xen_starting_cpu() registering the runstate region on some
CPUs before KPTI is subsequent enabled, resulting the the problems the
aforementioned commit tried to avoid.
Handle this more robsutly by deferring the initialization of the
runstate region until secondary CPUs have been initialized and the
ARM64_UNMAP_KERNEL_AT_EL0 cpucap has been finalized. The per-cpu work is
moved into a new hotplug starting function which is registered later
when we're certain that KPTI will not be used.
Fixes: f88af7229f6f ("xen/arm: do not setup the runstate info page if kpti is enabled")
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Bertrand Marquis <bertrand.marquis@arm.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Stefano Stabellini <sstabellini@kernel.org>
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
Cc: Will Deacon <will@kernel.org>
[ Upstream commit 0b068c714ca9479d2783cc333fff5bc2d4a6d45c ]
Companion of DEV_STATS_INC() & DEV_STATS_ADD().
This is going to be used in the series.
Use it in macsec_get_stats64().
Stable-dep-of: ff672b9ffeb3 ("ipvlan: properly track tx_errors")
Micron MTFC4GACAJCN eMMC supports cache but requires that flush cache
operation be allowed only after a write has occurred. Otherwise, the
cache flush command or subsequent commands will time out.
Upstream-Status: Backport [ed9009ad300c0f15a3ecfe9613547b1962bde02c]
Signed-off-by: Bean Huo <beanhuo@micron.com>
Signed-off-by: Rafael Beims <rafael.beims@toradex.com>
Link: https://lore.kernel.org/r/20231030224809.59245-1-beanhuo@iokpp.de
commit 7e6f3b6d2c352b5fde37ce3fed83bdf6172eebd4 upstream.
The AMD VanGogh SoC contains a DesignWare USB3 Dual-Role Device that can be
operated as either a USB Host or a USB Device, similar to on the AMD Nolan
platform.
be6646bfbaec ("PCI: Prevent xHCI driver from claiming AMD Nolan USB3 DRD
device") added a quirk to let the dwc3 driver claim the Nolan device since
it provides more specific support.
Extend that quirk to include the VanGogh SoC USB3 device.
Link: https://lore.kernel.org/r/20230927202212.2388216-1-vi@endrift.com
Signed-off-by: Vicki Pfau <vi@endrift.com>
[bhelgaas: include be6646bfbaec reference, add stable tag]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: stable@vger.kernel.org # v3.19+
commit bb17d110cbf270d5247a6e261c5ad50e362d1675 upstream.
driver_set_override() helper uses device_lock() so it should not be
called before rpmsg_register_device() (which calls device_register()).
Effect can be seen with CONFIG_DEBUG_MUTEXES:
DEBUG_LOCKS_WARN_ON(lock->magic != lock)
WARNING: CPU: 3 PID: 57 at kernel/locking/mutex.c:582 __mutex_lock+0x1ec/0x430
Call trace:
mutex_lock_nested+0x44/0x50
driver_set_override+0x124/0x150
qcom_glink_native_probe+0x30c/0x3b0
glink_rpm_probe+0x274/0x350
platform_probe+0x6c/0xe0
really_probe+0x17c/0x3d0
__driver_probe_device+0x114/0x190
driver_probe_device+0x3c/0xf0
Refactor the rpmsg_register_device() function to use two-step device
registering (initialization + add) and call driver_set_override() in
proper moment.
This moves the code around, so while at it also NULL-ify the
rpdev->driver_override in error path to be sure it won't be kfree()
second time.
Fixes: 42cd402b8fd4 ("rpmsg: Fix kfree() of static memory on setting driver_override")
Reported-by: Marek Szyprowski <m.szyprowski@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzysztof.kozlowski@linaro.org>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Link: https://lore.kernel.org/r/20220429195946.1061725-2-krzysztof.kozlowski@linaro.org
commit 42cd402b8fd4672b692400fe5f9eecd55d2794ac upstream.
The driver_override field from platform driver should not be initialized
from static memory (string literal) because the core later kfree() it,
for example when driver_override is set via sysfs.
Use dedicated helper to set driver_override properly.
Fixes: 950a7388f02b ("rpmsg: Turn name service into a stand alone driver")
Fixes: c0cdc19f84a4 ("rpmsg: Driver for user space endpoint interface")
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Link: https://lore.kernel.org/r/20220419113435.246203-13-krzysztof.kozlowski@linaro.org
commit 6c2f421174273de8f83cde4286d1c076d43a2d35 upstream.
Several core drivers and buses expect that driver_override is a
dynamically allocated memory thus later they can kfree() it.
However such assumption is not documented, there were in the past and
there are already users setting it to a string literal. This leads to
kfree() of static memory during device release (e.g. in error paths or
during unbind):
kernel BUG at ../mm/slub.c:3960!
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
(kfree) from [<c058da50>] (platform_device_release+0x88/0xb4)
(platform_device_release) from [<c0585be0>] (device_release+0x2c/0x90)
(device_release) from [<c0a69050>] (kobject_put+0xec/0x20c)
(kobject_put) from [<c0f2f120>] (exynos5_clk_probe+0x154/0x18c)
(exynos5_clk_probe) from [<c058de70>] (platform_drv_probe+0x6c/0xa4)
(platform_drv_probe) from [<c058b7ac>] (really_probe+0x280/0x414)
(really_probe) from [<c058baf4>] (driver_probe_device+0x78/0x1c4)
(driver_probe_device) from [<c0589854>] (bus_for_each_drv+0x74/0xb8)
(bus_for_each_drv) from [<c058b48c>] (__device_attach+0xd4/0x16c)
(__device_attach) from [<c058a638>] (bus_probe_device+0x88/0x90)
(bus_probe_device) from [<c05871fc>] (device_add+0x3dc/0x62c)
(device_add) from [<c075ff10>] (of_platform_device_create_pdata+0x94/0xbc)
(of_platform_device_create_pdata) from [<c07600ec>] (of_platform_bus_create+0x1a8/0x4fc)
(of_platform_bus_create) from [<c0760150>] (of_platform_bus_create+0x20c/0x4fc)
(of_platform_bus_create) from [<c07605f0>] (of_platform_populate+0x84/0x118)
(of_platform_populate) from [<c0f3c964>] (of_platform_default_populate_init+0xa0/0xb8)
(of_platform_default_populate_init) from [<c01031f8>] (do_one_initcall+0x8c/0x404)
Provide a helper which clearly documents the usage of driver_override.
This will allow later to reuse the helper and reduce the amount of
duplicated code.
Convert the platform driver to use a new helper and make the
driver_override field const char (it is not modified by the core).
Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Link: https://lore.kernel.org/r/20220419113435.246203-2-krzysztof.kozlowski@linaro.org
[ Upstream commit a29c3283653b80b916c5ca5292c5d36415e38e92 ]
This is a preparatory change required for the addition of temperature
sensing front ends.
Signed-off-by: Liam Beguin <liambeguin@gmail.com>
Reviewed-by: Peter Rosin <peda@axentia.se>
Link: https://lore.kernel.org/r/20220213025739.2561834-4-liambeguin@gmail.com
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
Stable-dep-of: bee448390e51 ("iio: afe: rescale: Accept only offset channels")
[ Upstream commit bc437f7515f5e14aec9f2801412d9ea48116a97d ]
In preparation for the addition of kunit tests, expose the logic
responsible for combining channel scales.
Link: https://lore.kernel.org/r/20220213025739.2561834-2-liambeguin@gmail.com
commit babddbfb7d7d70ae7f10fedd75a45d8ad75fdddf upstream.
when the checked address is illegal,the corresponding shadow address from
kasan_mem_to_shadow may have no mapping in mmu table. Access such shadow
address causes kernel oops. Here is a sample about oops on arm64(VA
39bit) with KASAN_SW_TAGS and KASAN_OUTLINE on:
[ffffffb80aaaaaaa] pgd=000000005d3ce003, p4d=000000005d3ce003,
pud=000000005d3ce003, pmd=0000000000000000
Internal error: Oops: 0000000096000006 [#1] PREEMPT SMP
Modules linked in:
CPU: 3 PID: 100 Comm: sh Not tainted 6.6.0-rc1-dirty #43
Hardware name: linux,dummy-virt (DT)
pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
pc : __hwasan_load8_noabort+0x5c/0x90
lr : do_ib_ob+0xf4/0x110
ffffffb80aaaaaaa is the shadow address for efffff80aaaaaaaa.
The problem is reading invalid shadow in kasan_check_range.
The generic kasan also has similar oops.
It only reports the shadow address which causes oops but not
the original address.
Commit 2f004eea0fc8("x86/kasan: Print original address on #GP")
introduce to kasan_non_canonical_hook but limit it to KASAN_INLINE.
This patch extends it to KASAN_OUTLINE mode.
Link: https://lkml.kernel.org/r/20231009073748.159228-1-haibo.li@mediatek.com
Fixes: 2f004eea0fc8("x86/kasan: Print original address on #GP")
Signed-off-by: Haibo Li <haibo.li@mediatek.com>
Reviewed-by: Andrey Konovalov <andreyknvl@gmail.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: AngeloGioacchino Del Regno <angelogioacchino.delregno@collabora.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Haibo Li <haibo.li@mediatek.com>
Cc: Matthias Brugger <matthias.bgg@gmail.com>
Cc: Vincenzo Frascino <vincenzo.frascino@arm.com>
commit 32671e3799ca2e4590773fd0e63aaa4229e50c06 upstream.
Because group consistency is non-atomic between parent (filedesc) and children
(inherited) events, it is possible for PERF_FORMAT_GROUP read() to try and sum
non-matching counter groups -- with non-sensical results.
Add group_generation to distinguish the case where a parent group removes and
adds an event and thus has the same number, but a different configuration of
events as inherited groups.
This became a problem when commit fa8c269353d5 ("perf/core: Invert
perf_read_group() loops") flipped the order of child_list and sibling_list.
Previously it would iterate the group (sibling_list) first, and for each
sibling traverse the child_list. In this order, only the group composition of
the parent is relevant. By flipping the order the group composition of the
child (inherited) events becomes an issue and the mis-match in group
composition becomes evident.
That said; even prior to this commit, while reading of a group that is not
equally inherited was not broken, it still made no sense.
(Ab)use ECHILD as error return to indicate issues with child process group
composition.
Fixes: fa8c269353d5 ("perf/core: Invert perf_read_group() loops")
Reported-by: Budimir Markovic <markovicbudimir@gmail.com>
Link: https://lkml.kernel.org/r/20231018115654.GK33217@noisy.programming.kicks-ass.net
[ Upstream commit 75ea27d0d62281c31ee259c872dfdeb072cf5e39 ]
__dev_get_by_name is currently used to either retrieve a net device
reference using its name or to check if a name is already used by a
registered net device (per ns). In the later case there is no need to
return a reference to a net device.
Introduce a new helper, netdev_name_in_use, to check if a name is
currently used by a registered net device without leaking a reference
the corresponding net device. This helper uses netdev_name_node_lookup
instead of __dev_get_by_name as we don't need the extra logic retrieving
a reference to the corresponding net device.
Signed-off-by: Antoine Tenart <atenart@kernel.org>
Stable-dep-of: 311cca40661f ("net: fix ifname in netlink ntf during netns move")
[ Upstream commit 0a8565425afd8ba0e1a0ea73e21da119ee6dacea ]
These APIs are analogous to iio_device_claim_direct_mode() and
iio_device_release_direct_mode() but, as the name suggests, with the
logic flipped. While this looks odd enough, it will have at least two
users (in following changes) and it will be important to move the IIO
mlock to the private struct.
Signed-off-by: Nuno Sá <nuno.sa@analog.com>
Link: https://lore.kernel.org/r/20221012151620.1725215-2-nuno.sa@analog.com
Stable-dep-of: 7771c8c80d62 ("iio: cros_ec: fix an use-after-free in cros_ec_sensors_push_data()")
[ Upstream commit 8c576f87ad7eb639b8bd4472a9bb830e0696dda5 ]
In order to later move this variable within the opaque structure, let's
create a helper for accessing it in read-only mode. This helper will be
exposed to device drivers and kept accessible for the few that could need
it. The write access to this variable however should be fully reserved to
the core so in a second step we will hide this variable into the opaque
structure.
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Alexandre Belloni <alexandre.belloni@bootlin.com>
Cc: Ludovic Desroches <ludovic.desroches@microchip.com>
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Link: https://lore.kernel.org/r/20220207143840.707510-11-miquel.raynal@bootlin.com
[ Upstream commit 2f53b4adfede66f1bc1c8bb7efd7ced2bad1191a ]
As we are going to hide the currentmode inside the opaque structure,
this helper would soon need to call a non-inline function which would
simply drop the benefit of having the helper defined inline in a header.
One alternative is to move this helper in the core as there is no more
interest in defining it inline in a header. We will pay the minor cost
either way.
Let's do like the iio_device_id() helper which also refers to the opaque
structure and gets defined in the core.
Suggested-by: Jonathan Cameron <jic23@kernel.org>
Link: https://lore.kernel.org/r/20220207143840.707510-10-miquel.raynal@bootlin.com
commit 0f28ada1fbf0054557cddcdb93ad17f767105208 upstream.
When calling mcb_bus_add_devices(), both mcb devices and the mcb
bus will attempt to attach a device to a driver because they share
the same bus_type. This causes an issue when trying to cast the
container of the device to mcb_device struct using to_mcb_device(),
leading to a wrong cast when the mcb_bus is added. A crash occurs
when freing the ida resources as the bus numbering of mcb_bus gets
confused with the is_added flag on the mcb_device struct.
The only reason for this cast was to keep an is_added flag on the
mcb_device struct that does not seem necessary. The function
device_attach() handles already bound devices and the mcb subsystem
does nothing special with this is_added flag so remove it completely.
Fixes: 18d288198099 ("mcb: Correctly initialize the bus's device")
Cc: stable <stable@kernel.org>
Signed-off-by: Jorge Sanjuan Garcia <jorge.sanjuangarcia@duagon.com>
Co-developed-by: Jose Javier Rodriguez Barbarin <JoseJavier.Rodriguez@duagon.com>
Signed-off-by: Jose Javier Rodriguez Barbarin <JoseJavier.Rodriguez@duagon.com>
Link: https://lore.kernel.org/r/20230906114901.63174-2-JoseJavier.Rodriguez@duagon.com
commit 5027d54a9c30bc7ec808360378e2b4753f053f25 upstream.
accept_ra_min_rtr_lft only considered the lifetime of the default route
and discarded entire RAs accordingly.
This change renames accept_ra_min_rtr_lft to accept_ra_min_lft, and
applies the value to individual RA sections; in particular, router
lifetime, PIO preferred lifetime, and RIO lifetime. If any of those
lifetimes are lower than the configured value, the specific RA section
is ignored.
In order for the sysctl to be useful to Android, it should really apply
to all lifetimes in the RA, since that is what determines the minimum
frequency at which RAs must be processed by the kernel. Android uses
hardware offloads to drop RAs for a fraction of the minimum of all
lifetimes present in the RA (some networks have very frequent RAs (5s)
with high lifetimes (2h)). Despite this, we have encountered networks
that set the router lifetime to 30s which results in very frequent CPU
wakeups. Instead of disabling IPv6 (and dropping IPv6 ethertype in the
WiFi firmware) entirely on such networks, it seems better to ignore the
misconfigured routers while still processing RAs from other IPv6 routers
on the same network (i.e. to support IoT applications).
The previous implementation dropped the entire RA based on router
lifetime. This turned out to be hard to expand to the other lifetimes
present in the RA in a consistent manner; dropping the entire RA based
on RIO/PIO lifetimes would essentially require parsing the whole thing
twice.
Fixes: 1671bcfd76fd ("net: add sysctl accept_ra_min_rtr_lft")
Cc: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Patrick Rohr <prohr@google.com>
Reviewed-by: Maciej Żenczykowski <maze@google.com>
Reviewed-by: David Ahern <dsahern@kernel.org>
Link: https://lore.kernel.org/r/20230726230701.919212-1-prohr@google.com
commit 1671bcfd76fdc0b9e65153cf759153083755fe4c upstream.
This change adds a new sysctl accept_ra_min_rtr_lft to specify the
minimum acceptable router lifetime in an RA. If the received RA router
lifetime is less than the configured value (and not 0), the RA is
ignored.
This is useful for mobile devices, whose battery life can be impacted
by networks that configure RAs with a short lifetime. On such networks,
the device should never gain IPv6 provisioning and should attempt to
drop RAs via hardware offload, if available.
Cc: Maciej Żenczykowski <maze@google.com>
commit 869b6ea1609f655a43251bf41757aa44e5350a8f upstream.
Eric has reported that commit dabc8b207566 ("quota: fix dqput() to
follow the guarantees dquot_srcu should provide") heavily increases
runtime of generic/270 xfstest for ext4 in nojournal mode. The reason
for this is that ext4 in nojournal mode leaves dquots dirty until the last
dqput() and thus the cleanup done in quota_release_workfn() has to write
them all. Due to the way quota_release_workfn() is written this results
in synchronize_srcu() call for each dirty dquot which makes the dquot
cleanup when turning quotas off extremely slow.
To be able to avoid synchronize_srcu() for each dirty dquot we need to
rework how we track dquots to be cleaned up. Instead of keeping the last
dquot reference while it is on releasing_dquots list, we drop it right
away and mark the dquot with new DQ_RELEASING_B bit instead. This way we
can we can remove dquot from releasing_dquots list when new reference to
it is acquired and thus there's no need to call synchronize_srcu() each
time we drop dq_list_lock.
References: https://lore.kernel.org/all/ZRytn6CxFK2oECUt@debian-BULLSEYE-live-builder-AMD64
Reported-by: Eric Whitney <enwlinux@gmail.com>
Fixes: dabc8b207566 ("quota: fix dqput() to follow the guarantees dquot_srcu should provide")
CC: stable@vger.kernel.org
[ Upstream commit 59df44bfb0ca4c3ee1f1c3c5d0ee8e314844799e ]
The iommu_suspend() syscore suspend callback is invoked with IRQ disabled.
Allocating memory with the GFP_KERNEL flag may re-enable IRQs during
the suspend callback, which can cause intermittent suspend/hibernation
problems with the following kernel traces:
Calling iommu_suspend+0x0/0x1d0
WARNING: CPU: 0 PID: 15 at kernel/time/timekeeping.c:868 ktime_get+0x9b/0xb0
CPU: 0 PID: 15 Comm: rcu_preempt Tainted: G U E 6.3-intel #r1
RIP: 0010:ktime_get+0x9b/0xb0
Call Trace:
<IRQ>
tick_sched_timer+0x22/0x90
? __pfx_tick_sched_timer+0x10/0x10
__hrtimer_run_queues+0x111/0x2b0
hrtimer_interrupt+0xfa/0x230
__sysvec_apic_timer_interrupt+0x63/0x140
sysvec_apic_timer_interrupt+0x7b/0xa0
</IRQ>
<TASK>
asm_sysvec_apic_timer_interrupt+0x1f/0x30
Interrupts enabled after iommu_suspend+0x0/0x1d0
WARNING: CPU: 0 PID: 27420 at drivers/base/syscore.c:68 syscore_suspend+0x147/0x270
CPU: 0 PID: 27420 Comm: rtcwake Tainted: G U W E 6.3-intel #r1
RIP: 0010:syscore_suspend+0x147/0x270
Call Trace:
<TASK>
hibernation_snapshot+0x25b/0x670
hibernate+0xcd/0x390
state_store+0xcf/0xe0
kobj_attr_store+0x13/0x30
sysfs_kf_write+0x3f/0x50
kernfs_fop_write_iter+0x128/0x200
vfs_write+0x1fd/0x3c0
ksys_write+0x6f/0xf0
__x64_sys_write+0x1d/0x30
do_syscall_64+0x3b/0x90
entry_SYSCALL_64_after_hwframe+0x72/0xdc
Given that only 4 words memory is needed, avoid the memory allocation in
iommu_suspend().
CC: stable@kernel.org
Fixes: 33e07157105e ("iommu/vt-d: Avoid GFP_ATOMIC where it is not needed")
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Tested-by: Ooi, Chin Hao <chin.hao.ooi@intel.com>
Link: https://lore.kernel.org/r/20230921093956.234692-1-rui.zhang@intel.com
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Link: https://lore.kernel.org/r/20230925120417.55977-2-baolu.lu@linux.intel.com
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Add platform-level registration helpers that will ease transition of the
arch/platform power-off callbacks to the new sys-off based API, allowing
us to remove the global pm_power_off variable in the future.
Upstream-Status: Backport [fb61375ecfba49e153af561402f49f6fe3bebd39]
Signed-off-by: Dmitry Osipenko <dmitry.osipenko@collabora.com>
Add kernel_can_power_off() helper that replaces open-coded checks of
the global pm_power_off variable. This is a necessary step towards
supporting chained power-off handlers.
Upstream-Status: Backport [0e2110d2e910e44cc7cf23fce14613e232602602]
Add do_kernel_power_off() helper that will remove open-coded pm_power_off
invocations from the architecture code. This is the first step on the way
to remove the global pm_power_off variable, which will allow us to
implement consistent power-off chaining support.
Upstream-Status: Backport [2b6aa7332f8020dfdaffe340ff038aac4df35238]
Add atomic_notifier_call_chain_is_empty() that returns true if given
atomic call chain is empty.
The first user of this new notifier API function will be the kernel
power-off core code that will support power-off call chains. The core
code will need to check whether there is a power-off handler registered
at all in order to decide whether to halt machine or power it off.
Upstream-Status: Backport [13dfd97a341a5cf9d15f415dd469f45e971ef12a]
Reviewed-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
