path: root/include/linux/wireless.h
2008-06-16wext: Emit event stream entries correctly when compat.David S. Miller
Three major portions to this change: 1) Add IW_EV_COMPAT_LCP_LEN, IW_EV_COMPAT_POINT_OFF, and IW_EV_COMPAT_POINT_LEN helper defines. 2) Delete iw_stream_check_add_*(), they are unused. 3) Add iw_request_info argument to iwe_stream_add_*(), and use it to size the event and pointer lengths correctly depending upon whether IW_REQUEST_FLAG_COMPAT is set or not. 4) The mechanical transformations to the drivers and wireless stack bits to get the iw_request_info passed down into the routines modified in #3. Also, explicit references to IW_EV_LCP_LEN are replaced with iwe_stream_lcp_len(info). With a lot of help and bug fixes from Masakazu Mokuno. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16wext: Dispatch and handle compat ioctls entirely in net/wireless/wext.cDavid S. Miller
Next we can kill the hacks in fs/compat_ioctl.c and also dispatch compat ioctls down into the driver and 80211 protocol helper layers in order to handle iw_point objects embedded in stream replies which need to be translated. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03WEXT: Add support for passing PMK and capability flags to WEXTMasakazu Mokuno
This defines the flags for setting the PMK to the driver and the capability flag for this so that the user space program can figure out whether the target driver wants to do 4-way hand shake by itself and pass the PMK which is needed before 4-way handshake to the driver. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-01Make linux/wireless.h be able to compileKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06WEXT: add mesh interface typeJohannes Berg
This introduces a new WEXT type IW_MODE_MESH for mesh networks, used for scan results. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-28introduce WEXT scan capabilitiesDan Williams
Introduce scan capabilities to WEXT so that userspace can do intelligent things with scan behavior such as handling hidden SSIDs more gracefully. If the driver reports a specific scan capability, the driver must respect the options specified in the iw_scan_req structure when handling the SIOCSIWSCAN call, unless it's mode or state does not allow it to do so, in which case it must return an error. This version switches to Dave Kilroy's suggestion of claiming unused padding space for the scan_capa field. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-28[PATCH] Update my email address from jkmaline@cc.hut.fi to j@w1.fiJouni Malinen
After 13 years of use, it looks like my email address is finally going to disappear. While this is likely to drop the amount of incoming spam greatly ;-), it may also affect more appropriate messages, so let's update my email address in various places. In addition, Host AP mailing list is subscribers-only and linux-wireless can also be used for discussing issues related to this driver which is now shown in MAINTAINERS. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-03-27[PATCH] WE-22 : prevent information leak on 64 bitJean Tourrilhes
Johannes Berg discovered that kernel space was leaking to userspace on 64 bit platform. He made a first patch to fix that. This is an improved version of his patch. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-14[PATCH] wireless: fix IW_IS_{GET,SET} comment in wireless.hIngo van Lil
I just noticed the comments about even/odd ioctl command numbers in Linux's wireless.h file are mixed up. Signed-off-by: Ingo van Lil <inguin@gmx.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] wext: extend MLME supportChristian Lamparter
This patch adds two new defines for the SIOCSIWMLME to cover all kinds MLMEs (well, except REASSOC) through a ioctl. Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-25[PATCH] WE-21 support (core API)John W. Linville
This is version 21 of the Wireless Extensions. Changelog : o finishes migrating the ESSID API (remove the +1) o netdev->get_wireless_stats is no more o long/short retry This is a redacted version of a patch originally submitted by Jean Tourrilhes. I removed most of the additions, in order to minimize future support requirements for nl80211 (or other WE successor). CC: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-23[PATCH] WE-20 for kernel 2.6.16Jean Tourrilhes
This is version 20 of the Wireless Extensions. This is the completion of the RtNetlink work I started early 2004, it enables the full Wireless Extension API over RtNetlink. Few comments on the patch : o totally driver transparent, no change in drivers needed. o iwevent were already RtNetlink based since they were created (around 2.5.7). This adds all the regular SET and GET requests over RtNetlink, using the exact same mechanism and data format as iwevents. o This is a Kconfig option, as currently most people have no need for it. Surprisingly, patch is actually small and well encapsulated. o Tested on SMP, attention as been paid to make it 64 bits clean. o Code do probably too many checks and could be further optimised, but better safe than sorry. o RtNetlink based version of the Wireless Tools available on my web page for people inclined to try out this stuff. I would also like to thank Alexey Kuznetsov for his helpful suggestions to make this patch better. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-09-07[wireless] build fixes after merging WE-19Jeff Garzik
2005-09-06[PATCH] WE-19 for kernel 2.6.13Jean Tourrilhes
Hi Jeff, This is version 19 of the Wireless Extensions. It was supposed to be the fallback of the WPA API changes, but people seem quite happy about it (especially Jouni), so the patch is rather small. The patch has been fully tested with 2.6.13 and various wireless drivers, and is in its final version. Would you mind pushing that into Linus's kernel so that the driver and the apps can take advantage ot it ? It includes : o iwstat improvement (explicit dBm). This is the result of long discussions with Dan Williams, the authors of NetworkManager. Thanks to him for all the fruitful feedback. o remove pointer from event stream. I was not totally sure if this pointer was 32-64 bits clean, so I'd rather remove it and be at peace with it. o remove linux header from wireless.h. This has long been requested by people writting user space apps, now it's done, and it was not even painful. o final deprecation of spy_offset. You did not like it, it's now gone for good. o Start deprecating dev->get_wireless_stats -> debloat netdev o Add "check" version of event macros for ieee802.11 stack. Jiri Benc doesn't like the current macros, we aim to please ;-) All those changes, except the last one, have been bit-roting on my web pages for a while... Patches for most kernel drivers will follow. Patches for the Orinoco and the HostAP drivers have been sent to their respective maintainers. Have fun... Jean Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12 [PATCH] Wireless Extensions 18 (aka WPA)
This is version 18 of the Wireless Extensions. The main change is that it adds all the necessary APIs for WPA and WPA2 support. This work was entirely done by Jouni Malinen, so let's thank him for both his hard work and deep expertise on the subject ;-) This APIs obviously doesn't do much by itself and works in concert with driver support (Jouni already sent you the HostAP changes) and userspace (Jouni is updating wpa_supplicant). This is also orthogonal with the ongoing work on in-kernel IEEE support (but potentially useful). The patch is attached, tested with 2.6.11. Normally, I would ask you to push that directly in the kernel (99% of the patch has been on my web page for ages and it does not affect non-WPA stuff), but Jouni convinced me that it should bake a few weeks in wireless-2.6 first, so that other driver maintainers can get up to speed with it. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
