path: root/include/linux/v4l2-mediabus.h
2011-05-20[media] v4l: Add V4L2_MBUS_FMT_JPEG_1X8 media bus formatSylwester Nawrocki
Add V4L2_MBUS_FMT_JPEG_1X8 format and the corresponding Docbook documentation. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] media: add missing 8-bit bayer formats and Y12Michael Jones
8-bit SGBRG and SRGGB media bus formats are missing, as well as the 12-bit grey format. Add them. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Add missing 12 bits bayer media bus formatsLaurent Pinchart
Add codes and documentation for the following media bus formats: - V4L2_MBUS_FMT_SGBRG12_1X12 - V4L2_MBUS_FMT_SGRBG12_1X12 - V4L2_MBUS_FMT_SRGGB12_1X12 Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Add remaining RAW10 patterns w DPCM pixel code variantsLaurent Pinchart
This adds following formats: - V4L2_MBUS_FMT_SRGGB10_1X10 - V4L2_MBUS_FMT_SGBRG10_1X10 - V4L2_MBUS_FMT_SRGGB10_DPCM8_1X8 - V4L2_MBUS_FMT_SGBRG10_DPCM8_1X8 - V4L2_MBUS_FMT_SBGGR10_DPCM8_1X8 Signed-off-by: Sergio Aguirre <saaguirre@ti.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Add 8-bit YUYV on 16-bit bus and SGRBG10 media bus pixel codesLaurent Pinchart
Add the following media bus format code definitions: - V4L2_MBUS_FMT_SGRBG10_1X10 for 10-bit GRBG Bayer - V4L2_MBUS_FMT_SGRBG10_DPCM8_1X8 for 10-bit DPCM compressed GRBG Bayer - V4L2_MBUS_FMT_YUYV16_1X16 for 8-bit YUYV on 16-bit bus - V4L2_MBUS_FMT_UYVY16_1X16 for 8-bit UYVY on 16-bit bus - V4L2_MBUS_FMT_YVYU16_1X16 for 8-bit YVYU on 16-bit bus - V4L2_MBUS_FMT_VYUY16_1X16 for 8-bit VYUY on 16-bit bus Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Group media bus pixel codes by types and sort them alphabeticallyLaurent Pinchart
Adding new pixel codes at the end of the enumeration will soon create a mess, so group the pixel codes by type and sort them by bus_width, bits per component, samples per pixel and order of subsamples. As the codes are part of the kernel ABI their value can't change when a new code is inserted in the enumeration, so they are given an explicit numerical value. When inserting a new pixel code developers must use and update the next free value. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Rename V4L2_MBUS_FMT_GREY8_1X8 to V4L2_MBUS_FMT_Y8_1X8Laurent Pinchart
For consistency with the V4L2_MBUS_FMT_Y10_1X10 format. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Replace enums with fixed-sized fields in public structureLaurent Pinchart
The v4l2_mbus_framefmt structure will be part of the public userspace API and used (albeit indirectly) as an ioctl argument. As such, its size must be fixed across userspace ABIs. Replace the v4l2_field and v4l2_colorspace enums by __u32 fields and add padding for future enhancements. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Move the media/v4l2-mediabus.h header to include/linuxLaurent Pinchart
The header defines the v4l2_mbus_framefmt structure which will be used by the V4L2 subdevs userspace API. Change the type of the v4l2_mbus_framefmt::code field to __u32, as enum sizes can differ between different ABIs on the same architectures. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
