path: root/include/linux/usb/r8a66597.h
2011-10-13usb: gadget: r8a66597-udc: add support for SUDMACYoshihiro Shimoda
SH7757 has a USB function with internal DMA controller (SUDMAC). This patch supports the SUDMAC. The SUDMAC is incompatible with general-purpose DMAC. So, it doesn't use dmaengine. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-07-08Merge branch 'for-next' of ↵Greg Kroah-Hartman
master.kernel.org:/pub/scm/linux/kernel/git/balbi/usb into usb-next * 'for-next' of master.kernel.org:/pub/scm/linux/kernel/git/balbi/usb: usb: gadget: m66592-udc: add pullup function usb: gadget: m66592-udc: add function for external controller usb: gadget: r8a66597-udc: add pullup function usb: gadget: zero: add superspeed support usb: gadget: add SS descriptors to Ethernet gadget usb: gadget: r8a66597-udc: add support for TEST_MODE usb: gadget: m66592-udc: add support for TEST_MODE usb: gadget: r8a66597-udc: Make BUSWAIT configurable through platform data usb: gadget: r8a66597-udc: fix cannot connect after rmmod gadget driver usb: update email address in r8a66597-udc and m66592-udc usb: musb: restore INDEX register in resume path usb: gadget: fix up depencies usb: gadget: fusb300_udc: fix compile warnings usb: gadget: ci13xx_udc.c: fix compile warning usb: gadget: net2272: fix compile warnings usb: gadget: langwell_udc: fix compile warnings usb: gadget: fusb300_udc: drop dead code
2011-07-08usb: update email address in ohci-sh and r8a66597-hcdYoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-08usb: r8a66597-hcd: add function for external controllerYoshihiro Shimoda
R8A66597 has the pin of WR0 and WR1. So, if one write-pin of CPU connects to the pins, we have to change the setting of FIFOSEL register in the controller. If we don't change the setting, the controller cannot send the data of odd length. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-08usb: gadget: r8a66597-udc: Make BUSWAIT configurable through platform dataYoshihiro Shimoda
BUSWAIT is a 4-bit-wide value that controls the number of access waits from the CPU to on-chip USB module. b'0000 inserts 0 wait (2 access cycles) and b'1111 inserts 15 waits (17 access cycles, hardware initial value), respectively. BUSWAIT value depends on peripheral clock frequency supplied to on-chip of each CPU, hence should be configurable through platform data. Note that this patch assumes that b'0000 (0 wait, 2 access cycles) is rerely used and considered as invalid. If valid 'buswait' data is not provided by platform, initial b'1111 (15 waits, 17 access cycles) will be applied as a safe default. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2009-07-23usb: move r8a66597 register definesMagnus Damm
Move r8a66597 hardware register definitions from the host controller header file to the platform data header file. With this change in place we can easily share register definitions between the host controller driver and a future gadget driver. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-07-20usb: r8a66597-hcd platform data on_chip supportMagnus Damm
Convert the r8a66597-hcd driver to use the on_chip flag from platform data to enable on chip behaviour instead of relying on CONFIG_SUPERH_ON_CHIP_R8A66597 ugliness. This makes the code cleaner and also allows us to support both external and internal r8a66597 with the same kernel. It also makes the Kconfig part more future proof since we with this patch can add support for new processors with on-chip r8a66597 without modifying the Kconfig. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-15USB: r8a66597-hcd: use platform_data instead of module_paramYoshihiro Shimoda
CPU/board specific parameters (PLL clock, vif etc...) can be set by platform_data instead of module_param. v2: remove irq_sense member in platform_data because it can OR in IRQF_TRIGGER_LOW or IRQF_TRIGGER_FALLING against IORESOURCE_IRQ in the struct resource. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Reviewed-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
