The bcdDevice field is defined as
|Device release number in binary-coded decimal
in the USB 2.0 specification. We use this field to distinguish the UDCs
from each other. In theory this could be used on the host side to apply
certain quirks if the "special" UDC in combination with this gadget is
used. This hasn't been done as far as I am aware. In practice it would
be better to fix the UDC driver before shipping since a later release
might not need this quirk anymore.
There are some driver in tree (on the host side) which use the bcdDevice
field to figure out special workarounds for a given firmware revision.
This seems to make sense. Therefore this patch converts all gadgets
(except a few) to use the kernel version instead a random 2 or 3 plus
the UDC number. The few that don't report kernel's version are:
- webcam
This one reports always a version 0x10 so allow it to do so in future.
- nokia
This one reports always 0x211. The comment says that this gadget works
only if the UDC supports altsettings so I added a check for this.
- serial
This one reports 0x2400 + UDC number. Since the gadget version is 2.4
this could make sense. Therefore bcdDevice is 0x2400 here.
I also remove various gadget_is_<name> macros which are unused. The
remaining few macros should be moved to feature / bug bitfield.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Some gadgets provide custom entry here. Some may override it with an
etntry that is also created by composite if there was no value sumbitted
at all.
This patch removes all "custom manufacturer" strings which are the same
as these which are created by composite. Then it moves the creation of
the default manufacturer string to usb_composite_overwrite_options() in
case no command line argument has been used and the entry is still an
empty string.
By doing this we get rid of the global variable "composite_manufacturer"
in composite.
The struct usb_composite_driver members iProduct, iSerial and
iManufacturer can be entered directly via the string array. There is no
need for them to appear here.
This patch pushes the iProduct module argument from composite
into each gadget.
This patch pushes the iManufacturer module argument from composite into
each gadget. Once the user uses the module paramter, the string is
overwritten with the final value.
This patch pushes the iSerialNumber module argument from composite into
The index in usb_string array is defined by the gadget. The gadget can
choose which index entry it assigns for the serial number and which the
product name. The gadget has just to ensure that the descriptor contains
the proper string id which is assigned by composite.
If the composite layer knows the index of the "default" information
which will be overwritten by module parameters, it can be used later to
overwrite it.
This patch moves the module options idVendor, idProduct and bcdDevice
from composite.c into each gadgets. This ensures compatibility with
current gadgets and removes the global variable which brings me step
closer towards composite.c in libcomposite
there is no read user of bufsiz, its content is available via
USB_COMP_EP0_BUFSIZ. Remove it.
This patch moves USB_BUFSIZ into global header file as
USB_COMP_EP0_BUFSIZ. There is currently only one user (f_sourcesink)
besides composite which need it. Ideally f_sourcesink would have its
own ep0 buffer. Lets keep it that way it was for now.
This patch removes the global variable composite in composite.c.
The private data which was saved there is now passed via an additional
argument to the bind() function in struct usb_gadget_driver.
Only the "old-style" UDC drivers have to be touched here, new style are
doing it right because this change is made in udc-core.
This partly reverts 07a18bd7 ("usb gadget: don't save bind callback in
struct usb_composite_driver") and fixes new drivers. The section missmatch
problems was solved by whitelisting structs in question via __ref.
Cc: devel@driverdev.osuosl.org
It was moved to be an argument in 07a18bd716ed5 ("usb gadget: don't
save bind callback in struct usb_composite_driver"). The reason was to
avoid the section missmatch. The warning was shown because ->bind is
marked as __init becuase it is a one time init. The warning can be also
suppresed by whitelisting the variable i.e. rename it to lets say _probe.
Add iSerialNumber to usb_composite_driver to allow setting a default value.
This is useful when the module is compiled-in. Then the composite_bind
is executed at kernel boot and string id for iSerialNumber can be overridden
even if there is no iSerialNumber kernel commandline parameter.
If the string id is not overridden, then get_string will never attempt to
look for the alternative string contents using cdev->serial_override.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Add usb_remove_config to unbind a configuration and remove it from
the configs list. This allows implementing composite gadget drivers that
can disconnect themself from the bus and that will later be re-enumerated
with a different configuration.
Gadget drivers must call usb_gadget_disconnect before calling this
function to disable the pullup, disconnect the device from the host,
and prevent the host from enumerating the device while we are changing
the gadget configuration.
Signed-off-by: Benoit Goby <benoit@android.com>
[change return type of [usb_]remove_config]
SuperSpeed USB has defined a new descriptor, called
the Binary Device Object Store (BOS) Descriptor. It
has also changed a bit the definition of SET_FEATURE
and GET_STATUS requests to add USB3-specific details.
This patch implements both changes to the Composite
Gadget Framework.
[ balbi@ti.com : slight changes to commit log
fixed a compile error on ARM ]
Signed-off-by: Tatyana Brokhman <tlinder@codeaurora.org>
This field is used by the Gadget drivers to specify
the maximum speed they support, meaning: the maximum
speed they can provide descriptors for.
The driver speed will be set in consideration of this
value.
[ balbi@ti.com : dropped the ifdeffery ]
Remove obsolete functions:
1. ep_choose()
2. usb_find_endpoint()
Add config_ep_by_speed() to configure the endpoint
according to the gadget speed.
Using this function will spare the FDs from handling
the endpoint chosen descriptor.
Some USB function drivers (e.g. f_mass_storage.c) need to delay or defer the
data/status stages of standard control requests like SET_CONFIGURATION or
SET_INTERFACE till they are done with their bookkeeping and are actually ready
for accepting new commands to their interface.
They can now achieve this functionality by returning USB_GADGET_DELAYED_STATUS
in their setup handlers (e.g. set_alt()). The composite framework will then
defer completion of the control transfer by not completing the data/status stages.
This ensures that the host does not send new packets to the interface till the
function driver is ready to take them.
When the function driver that requested for USB_GADGET_DELAYED_STATUS is done
with its bookkeeping, it should signal the composite framework to continue with
the data/status stages of the control transfer. It can do so by invoking
the new API usb_composite_setup_continue(). This is where the control transfer's
data/status stages are completed and host can initiate new transfers.
The DELAYED_STATUS mechanism is currently only supported if the expected data phase
is 0 bytes (i.e. w_length == 0). Since SET_CONFIGURATION and SET_INTERFACE are the
only cases that will use this mechanism, this is not a limitation.
Signed-off-by: Roger Quadros <roger.quadros@nokia.com>
The bind function is most of the time only called at init time so there
is no need to save a pointer to it in the configuration structure.
This fixes many section mismatches reported by modpost.
[m.nazarewicz@samsung.com: updated for -next]
Signed-off-by: Michał Nazarewicz <m.nazarewicz@samsung.com>
is no need to save a pointer to it in the composite driver structure.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
The iManufatcurer, iProduct and iSerialNumber composite module
parameters were only used when the gadget driver registers
strings for manufacturer, product and serial number. If the
gadget never bothered to set corresponding fields in USB device
descriptors those module parameters are ignored.
This commit makes the parameters work even if the strings ID
have not been assigned. It also changes the way IDs are
overridden -- what IDs are overridden is now saved in
usb_composite_dev structure -- which makes it unnecessary to
modify the string tables the way previous code did.
The commit also adds a iProduct and iManufatcurer fields to the
usb_composite_device structure. If they are set, appropriate
strings are reserved and added to device descriptor. This makes
it unnecessary for gadget drivers to maintain code for setting
those. If iProduct is not set it defaults to
usb_composite_device::name; if iManufatcurer is not set
a default "<system> <release> with <gadget-name>" is used.
The last thing is that if needs_serial field of
usb_composite_device is set and user failed to provided
iSerialNumber parameter a warning is issued.
Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com>
Warning(include/linux/usb/composite.h:284): No description found for parameter 'disconnect'
Warning(drivers/usb/gadget/composite.c:744): No description found for parameter 'c'
Warning(drivers/usb/gadget/composite.c:744): Excess function parameter 'cdev' description in 'usb_string_ids_n'
Cc: David Brownell <dbrownell@users.sourceforge.net>
Added a disconnect() callback to composite devices which
is called by composite glue when its disconnect callback
is called by gadget.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
usb_string_ids_tab() and usb_string_ids_n() functions added to
the composite framework. The first accepts an array of
usb_string object and for each registeres a string id and the
second registeres a given number of ids and returns the first.
This may simplify string ids registration since gadgets and
composite functions won't have to call usb_string_id() several
times and each time check for errer status -- all this will be
done with a single call.
This patch adds a sysfs entry (/sys/devices/platform/_UDC_/gadget/suspended) to
show the suspend state of an USB composite gadget.
Signed-off-by: Fabien Chouteau <fabien.chouteau@barco.com>
Control requests targeted at an endpoint (that is sent to EP0 but
specifying the target endpoint address in wIndex) are dispatched to the
current configuration's setup callback, requiring all gadget drivers to
dispatch the requests to the correct function driver.
To avoid this, record which endpoints are used by each function in the
composite driver SET CONFIGURATION handler and dispatch requests
targeted at endpoints to the correct function.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Mark internal struct members as /* private: */ so that kernel-doc
won't produce warnings about missing descriptions for them.
Address one open question in the composite gadget framework:
Yes, we should have device-level suspend/resume callbacks
in addition to the function-level ones. We have at least one
scenario (with gadget zero in OTG test mode) that's awkward
to handle without it.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Felipe Balbi <felipe.balbi@nokia.com>
Add a new mechanism to the composite gadget framework, letting
functions deactivate (and reactivate) themselves. Think of it
as a refcounted wrapper for the software pullup control.
A key example of why to use this mechanism involves functions that
require a userspace daemon. Those functions shuld use this new
mechanism to prevent the gadget from enumerating until those daemons
are activated. Without this mechanism, hosts would see devices that
malfunction until the relevant daemons start.
We want to use WARN() as a variant of WARN_ON(), however a few drivers are
using WARN() internally. This patch renames these to WARNING() to avoid the
namespace clash. A few cases were defining but not using the thing, for those
cases I just deleted the definition.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Greg KH <greg@kroah.com>
Cc: Karsten Keil <kkeil@suse.de>
Add <linux/usb/composite.h> interfaces for composite gadget drivers, and
basic implementation support behind it:
- struct usb_function ... groups one or more interfaces into a function
managed as one unit within a configuration, to which it's added by
usb_add_function().
- struct usb_configuration ... groups one or more such functions into
a configuration managed as one unit by a driver, to which it's added
by usb_add_config(). These operate at either high or full/low speeds
and at a given bMaxPower.
- struct usb_composite_driver ... groups one or more such configurations
into a gadget driver, which may be registered or unregistered.
- struct usb_composite_dev ... a usb_composite_driver manages this; it
wraps the usb_gadget exposed by the controller driver.
This also includes some basic kerneldoc.
How to use it (the short version): provide a usb_composite_driver with a
bind() that calls usb_add_config() for each of the needed configurations.
The configurations in turn have bind() calls, which will usb_add_function()
for each function required. Each function's bind() allocates resources
needed to perform its tasks, like endpoints; sometimes configurations will
allocate resources too.
Separate patches will convert most gadget drivers to this infrastructure.
