path: root/include/linux/udp.h
2014-09-01udp: Add support for doing checksum unnecessary conversionTom Herbert
Add support for doing CHECKSUM_UNNECESSARY to CHECKSUM_COMPLETE conversion in UDP tunneling path. In the normal UDP path, we call skb_checksum_try_convert after locating the UDP socket. The check is that checksum conversion is enabled for the socket (new flag in UDP socket) and that checksum field is non-zero. In the UDP GRO path, we call skb_gro_checksum_try_convert after checksum is validated and checksum field is non-zero. Since this is already in GRO we assume that checksum conversion is always wanted. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-23net: Make enabling of zero UDP6 csums more restrictiveTom Herbert
RFC 6935 permits zero checksums to be used in IPv6 however this is recommended only for certain tunnel protocols, it does not make checksums completely optional like they are in IPv4. This patch restricts the use of IPv6 zero checksums that was previously intoduced. no_check6_tx and no_check6_rx have been added to control the use of checksums in UDP6 RX and TX path. The normal sk_no_check_{rx,tx} settings are not used (this avoids ambiguity when dealing with a dual stack socket). A helper function has been added (udp_set_no_check6) which can be called by tunnel impelmentations to all zero checksums (send on the socket, and accept them as valid). Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20udp: add encap_destroy callbackTom Parkin
Users of udp encapsulation currently have an encap_rcv callback which they can use to hook into the udp receive path. In situations where a encapsulation user allocates resources associated with a udp encap socket, it may be convenient to be able to also hook the proto .destroy operation. For example, if an encap user holds a reference to the udp socket, the destroy hook might be used to relinquish this reference. This patch adds a socket destroy hook into udp, which is set and enabled in the same way as the existing encap_rcv hook. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-09net: Add support for hardware-offloaded encapsulationJoseph Gasparakis
This patch adds support in the kernel for offloading in the NIC Tx and Rx checksumming for encapsulated packets (such as VXLAN and IP GRE). For Tx encapsulation offload, the driver will need to set the right bits in netdev->hw_enc_features. The protocol driver will have to set the skb->encapsulation bit and populate the inner headers, so the NIC driver will use those inner headers to calculate the csum in hardware. For Rx encapsulation offload, the driver will need to set again the skb->encapsulation flag and the skb->ip_csum to CHECKSUM_UNNECESSARY. In that case the protocol driver should push the decapsulated packet up to the stack, again with CHECKSUM_UNNECESSARY. In ether case, the protocol driver should set the skb->encapsulation flag back to zero. Finally the protocol driver should have NETIF_F_RXCSUM flag set in its features. Signed-off-by: Joseph Gasparakis <joseph.gasparakis@intel.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2009-11-10udp: bind() optimisationEric Dumazet
UDP bind() can be O(N^2) in some pathological cases. Thanks to secondary hash tables, we can make it O(N) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-08udp: secondary hash on (local port, local address)Eric Dumazet
Extends udp_table to contain a secondary hash table. socket anchor for this second hash is free, because UDP doesnt use skc_bind_node : We define an union to hold both skc_bind_node & a new hlist_nulls_node udp_portaddr_node udp_lib_get_port() inserts sockets into second hash chain (additional cost of one atomic op) udp_lib_unhash() deletes socket from second hash chain (additional cost of one atomic op) Note : No spinlock lockdep annotation is needed, because lock for the secondary hash chain is always get after lock for primary hash chain. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-08udp: split sk_hash into two u16 hashesEric Dumazet
Union sk_hash with two u16 hashes for udp (no extra memory taken) One 16 bits hash on (local port) value (the previous udp 'hash') One 16 bits hash on (local address, local port) values, initialized but not yet used. This second hash is using jenkin hash for better distribution. Because the 'port' is xored later, a partial hash is performed on local address + net_hash_mix(net) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07udp: dynamically size hash tables at boot timeEric Dumazet
UDP_HTABLE_SIZE was initialy defined to 128, which is a bit small for several setups. 4000 active UDP sockets -> 32 sockets per chain in average. An incoming frame has to lookup all sockets to find best match, so long chains hurt latency. Instead of a fixed size hash table that cant be perfect for every needs, let UDP stack choose its table size at boot time like tcp/ip route, using alloc_large_system_hash() helper Add an optional boot parameter, uhash_entries=x so that an admin can force a size between 256 and 65536 if needed, like thash_entries and rhash_entries. dmesg logs two new lines : [ 0.647039] UDP hash table entries: 512 (order: 0, 4096 bytes) [ 0.647099] UDP Lite hash table entries: 512 (order: 0, 4096 bytes) Maximal size on 64bit arches would be 65536 slots, ie 1 MBytes for non debugging spinlocks. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16netns: introduce the net_hash_mix "salt" for hashesPavel Emelyanov
There are many possible ways to add this "salt", thus I made this patch to be the last in the series to change it if required. Currently I propose to use the struct net pointer itself as this salt, but since this pointer is most often cache-line aligned, shift this right to eliminate the bits, that are most often zeroed. After this, simply add this mix to prepared hashfn-s. For CONFIG_NET_NS=n case this salt is 0 and no changes in hashfn appear. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16udp: add struct net argument to udp_hashfnPavel Emelyanov
Every caller already has this one. The new argument is currently unused, but this will be fixed shortly. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16udp: introduce a udp_hashfn functionPavel Emelyanov
Currently the chain to store a UDP socket is calculated with simple (x & (UDP_HTABLE_SIZE - 1)). But taking net into account would make this calculation a bit more complex, so moving it into a function would help. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[NET]: include/linux/udp.h - remove duplicate includeJoe Perches
Remove duplicate #include <linux/types.h> Combine #ifdef __KERNEL__ blocks Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[UDP]: Revert udplite and code split.David S. Miller
This reverts commit db1ed684f6c430c4cdad67d058688b8a1b5e607c ("[IPV6] UDP: Rename IPv6 UDP files."), commit 8be8af8fa4405652e6c0797db5465a4be8afb998 ("[IPV4] UDP: Move IPv4-specific bits to other file.") and commit e898d4db2749c6052072e9bc4448e396cbdeb06a ("[UDP]: Allow users to configure UDP-Lite."). First, udplite is of such small cost, and it is a core protocol just like TCP and normal UDP are. We spent enormous amounts of effort to make udplite share as much code with core UDP as possible. All of that work is less valuable if we're just going to slap a config option on udplite support. It is also causing build failures, as reported on linux-next, showing that the changeset was not tested very well. In fact, this is the second build failure resulting from the udplite change. Finally, the config options provided was a bool, instead of a modular option. Meaning the udplite code does not even get build tested by allmodconfig builds, and furthermore the user is not presented with a reasonable modular build option which is particularly needed by distribution vendors. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[UDP]: Allow users to configure UDP-Lite.YOSHIFUJI Hideaki
Let's give users an option for disabling UDP-Lite (~4K). old: | text data bss dec hex filename | 286498 12432 6072 305002 4a76a net/ipv4/built-in.o | 193830 8192 3204 205226 321aa net/ipv6/ipv6.o new (without UDP-Lite): | text data bss dec hex filename | 284086 12136 5432 301654 49a56 net/ipv4/built-in.o | 191835 7832 3076 202743 317f7 net/ipv6/ipv6.o Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-07-10[UDP]: Introduce UDP encapsulation type for L2TPJames Chapman
This patch adds a new UDP_ENCAP_L2TPINUDP encapsulation type for UDP sockets. When a UDP socket's encap_type is UDP_ENCAP_L2TPINUDP, the skb is delivered to a function pointed to by the udp_sock's encap_rcv funcptr. If the skb isn't wanted by L2TP, it returns >0, which causes it to be passed through to UDP. Include padding to put the new encap_rcv field on a 4-byte boundary. Previously, the only user of UDP encap sockets was ESP, so when CONFIG_XFRM was not defined, some of the encap code was compiled out. This patch changes that. As a result, udp_encap_rcv() will now do a little more work when CONFIG_XFRM is not defined. Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce udp_hdr(), remove skb->h.uhArnaldo Carvalho de Melo
2006-12-02[NET]: Annotate checksums in on-the-wire packets.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: UDP header annotationsAl Viro
2006-06-30typo fixes: infomation -> informationAdrian Bunk
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
