Based on 1 normalized pattern(s):
this file is licensed under gplv2
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 22 file(s).
Reviewed-by: Armijn Hemel <armijn@tjaldur.nl>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190531190115.129548190@linutronix.de
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
Let attribute group vectors be declared "const". We'd
like to let most attribute metadata live in read-only
sections... this is a start.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
It's big, but there doesn't seem to be a way to split it up smaller...
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Every current transport class calls transport_container_release but
ignores the return value. This is catastrophic if it returns an error
because the containers are part of a global list and the next action of
almost every transport class is to free the memory used by the
container.
Fix this by making transport_container_release a void, but making it BUG
if attribute_container_release returns an error ... this catches the
root cause of a system panic much earlier. If we don't do this, we get
an eventual BUG when the attribute container list notices the corruption
caused by the freed memory it's still referencing.
Also made attribute_container_release __must_check as a reminder.
Cc: Greg KH <greg@kroah.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
I recently tried to construct a totally generic transport class and
found there were certain features missing from the current abstract
transport class. Most notable is that you have to hang the data on the
class_device but most of the API is framed in terms of the generic
device, not the class_device.
These changes are two fold
- Provide the class_device to all of the setup and configure APIs
- Provide and extra API to take the device and the attribute class and
return the corresponding class_device
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
infrastructure for it.
Let it rip!
