path: root/include/linux/tracepoint.h
2009-06-15debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem.GeunSik Lim
Many developers use "/debug/" or "/debugfs/" or "/sys/kernel/debug/" directory name to mount debugfs filesystem for ftrace according to ./Documentation/tracers/ftrace.txt file. And, three directory names(ex:/debug/, /debugfs/, /sys/kernel/debug/) is existed in kernel source like ftrace, DRM, Wireless, Documentation, Network[sky2]files to mount debugfs filesystem. debugfs means debug filesystem for debugging easy to use by greg kroah hartman. "/sys/kernel/debug/" name is suitable as directory name of debugfs filesystem. - debugfs related reference: http://lwn.net/Articles/334546/ Fix inconsistency of directory name to mount debugfs filesystem. * From Steven Rostedt - find_debugfs() and tracing_files() in this patch. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Acked-by : Inaky Perez-Gonzalez <inaky@linux.intel.com> Reviewed-by : Steven Rostedt <rostedt@goodmis.org> Reviewed-by : James Smart <james.smart@emulex.com> CC: Jiri Kosina <trivial@kernel.org> CC: David Airlie <airlied@linux.ie> CC: Peter Osterlund <petero2@telia.com> CC: Ananth N Mavinakayanahalli <ananth@in.ibm.com> CC: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> CC: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-24tracing: remove deprecated TRACE_FORMATSteven Rostedt
The TRACE_FORMAT macro has been deprecated by the TRACE_EVENT macro. There are no more users. All new users must use the TRACE_EVENT macro. [ Impact: remove old functionality ] Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14tracing: consolidate trace and trace_event headersSteven Rostedt
Impact: clean up Neil Horman (et. al.) criticized the way the trace events were broken up into two files. The reason for that was that ftrace needed to separate out the declarations from where the #include <linux/tracepoint.h> was used. It then dawned on me that the tracepoint.h header only needs to define the TRACE_EVENT macro if it is not already defined. The solution is simply to test if TRACE_EVENT is defined, and if it is not then the linux/tracepoint.h header can define it. This change consolidates all the <traces>.h and <traces>_event_types.h into the <traces>.h file. Reported-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Theodore Tso <tytso@mit.edu> Reported-by: Jiaying Zhang <jiayingz@google.com> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Jason Baron <jbaron@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-03-10tracing: remove funky whitespace in the trace codeSteven Rostedt
Impact: clean up There existed a lot of <space><tab>'s in the tracing code. This patch removes them. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-10tracing: document TRACE_EVENT macro in tracepoint.hSteven Rostedt
Impact: clean up / comments Kosaki Motohiro asked about an explanation to the TRACE_EVENT macro. Ingo Molnar replied with a nice description. This patch takes the description that Ingo wrote (with some slight modifications) and adds it to the tracepoint.h file. Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-10tracing: flip the TP_printk and TP_fast_assign in the TRACE_EVENT macroSteven Rostedt
Impact: clean up In trying to stay consistant with the C style format in the TRACE_EVENT macro, it makes more sense to do the printk after the assigning of the variables. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-10tracing: remove obsolete TRACE_EVENT_FORMAT macroSteven Rostedt
Impact: clean up The TRACE_EVENT_FORMAT macro is no longer used by trace points and only the DECLARE_TRACE, TRACE_FORMAT or TRACE_EVENT macros should be used by them. Although the TRACE_EVENT_FORMAT macro is still used by the internal tracing utility, it should not be used in core kernel code. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-10tracing: new format for specialized trace pointsSteven Rostedt
Impact: clean up and enhancement The TRACE_EVENT_FORMAT macro looks quite ugly and is limited in its ability to save data as well as to print the record out. Working with Ingo Molnar, we came up with a new format that is much more pleasing to the eye of C developers. This new macro is more C style than the old macro, and is more obvious to what it does. Here's the example. The only updated macro in this patch is the sched_switch trace point. The old method looked like this: TRACE_EVENT_FORMAT(sched_switch, TP_PROTO(struct rq *rq, struct task_struct *prev, struct task_struct *next), TP_ARGS(rq, prev, next), TP_FMT("task %s:%d ==> %s:%d", prev->comm, prev->pid, next->comm, next->pid), TRACE_STRUCT( TRACE_FIELD(pid_t, prev_pid, prev->pid) TRACE_FIELD(int, prev_prio, prev->prio) TRACE_FIELD_SPECIAL(char next_comm[TASK_COMM_LEN], next_comm, TP_CMD(memcpy(TRACE_ENTRY->next_comm, next->comm, TASK_COMM_LEN))) TRACE_FIELD(pid_t, next_pid, next->pid) TRACE_FIELD(int, next_prio, next->prio) ), TP_RAW_FMT("prev %d:%d ==> next %s:%d:%d") ); The above method is hard to read and requires two format fields. The new method: /* * Tracepoint for task switches, performed by the scheduler: * * (NOTE: the 'rq' argument is not used by generic trace events, * but used by the latency tracer plugin. ) */ TRACE_EVENT(sched_switch, TP_PROTO(struct rq *rq, struct task_struct *prev, struct task_struct *next), TP_ARGS(rq, prev, next), TP_STRUCT__entry( __array( char, prev_comm, TASK_COMM_LEN ) __field( pid_t, prev_pid ) __field( int, prev_prio ) __array( char, next_comm, TASK_COMM_LEN ) __field( pid_t, next_pid ) __field( int, next_prio ) ), TP_printk("task %s:%d [%d] ==> %s:%d [%d]", __entry->prev_comm, __entry->prev_pid, __entry->prev_prio, __entry->next_comm, __entry->next_pid, __entry->next_prio), TP_fast_assign( memcpy(__entry->next_comm, next->comm, TASK_COMM_LEN); __entry->prev_pid = prev->pid; __entry->prev_prio = prev->prio; memcpy(__entry->prev_comm, prev->comm, TASK_COMM_LEN); __entry->next_pid = next->pid; __entry->next_prio = next->prio; ) ); This macro is called TRACE_EVENT, it is broken up into 5 parts: TP_PROTO: the proto type of the trace point TP_ARGS: the arguments of the trace point TP_STRUCT_entry: the structure layout of the entry in the ring buffer TP_printk: the printk format TP_fast_assign: the method used to write the entry into the ring buffer The structure is the definition of how the event will be saved in the ring buffer. The printk is used by the internal tracing in case of an oops, and the kernel needs to print out the format of the record to the console. This the TP_printk gives a means to show the records in a human readable format. It is also used to print out the data from the trace file. The TP_fast_assign is executed directly. It is basically like a C function, where the __entry is the handle to the record. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-10tracing: replace TP<var> with TP_<var>Steven Rostedt
Impact: clean up The macros TPPROTO, TPARGS, TPFMT, TPRAWFMT, and TPCMD all look a bit ugly. This patch adds an underscore to their names. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-28tracing: create the C style tracing for the sched subsystemSteven Rostedt
This patch utilizes the TRACE_EVENT_FORMAT macro to enable the C style faster tracing for the sched subsystem trace points. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-25tracing: wrap arguments with PARAMSSteven Rostedt
Peter Zijlstra warned that TPPROTO and TPARGS might become something other than a simple copy of itself. To prevent this from having side effects in the TRACE_FORMAT macro in tracepoint.h, we add a PARAMS() macro to be defined as just a wrapper. Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-25tracing: rename DEFINE_TRACE_FMT to just TRACE_FORMATSteven Rostedt
There's been a bit confusion to whether DEFINE/DECLARE_TRACE_FMT should be a DEFINE or a DECLARE. Ingo Molnar suggested simply calling it TRACE_FORMAT. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-24tracing: add DEFINE_TRACE_FMT to tracepoint.hSteven Rostedt
This patch creates a DEFINE_TRACE_FMT to map to DECLARE_TRACE. This allows for the developers to place format strings and args in with their tracepoint declaration. A tracer may now override the DEFINE_TRACE_FMT macro and use it to record a default format. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2008-11-16tracepoints: add DECLARE_TRACE() and DEFINE_TRACE()Mathieu Desnoyers
Impact: API *CHANGE*. Must update all tracepoint users. Add DEFINE_TRACE() to tracepoints to let them declare the tracepoint structure in a single spot for all the kernel. It helps reducing memory consumption, especially when declaring a lot of tracepoints, e.g. for kmalloc tracing. *API CHANGE WARNING*: now, DECLARE_TRACE() must be used in headers for tracepoint declarations rather than DEFINE_TRACE(). This is the sane way to do it. The name previously used was misleading. Updates scheduler instrumentation to follow this API change. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-16tracepoints: do not put arguments in nameMathieu Desnoyers
Impact: cleanup That's overkill, takes space. We have a global tracepoint registery in header files anyway. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-16tracepoints: use unregister return valueMathieu Desnoyers
Impact: bugfix. Unregistering a tracepoint can fail. Return the error value. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-16tracepoints: use rcu_*_sched_notraceMathieu Desnoyers
Make sure tracepoints can be called within ftrace callbacks. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-03tracepoint: introduce *_noupdate APIs.Lai Jiangshan
Impact: add new tracepoint APIs to allow the batched registration of probes new APIs separate tracepoint_probe_register(), tracepoint_probe_unregister() into 2 steps. The first step of them is just update tracepoint_entry, not connect or disconnect. this patch introduces tracepoint_probe_update_all() for update all. these APIs are very useful for registering lots of probes but just updating once. Another very important thing is that *_noupdate APIs do not require module_mutex. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14tracepoints: synchronize unregister static inlineMathieu Desnoyers
Turn tracepoint synchronize unregister into a static inline. There is no reason to keep it as a macro over a static inline. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14tracepoints: tracepoint_synchronize_unregister()Mathieu Desnoyers
Create tracepoint_synchronize_unregister() which must be called before the end of exit() to make sure every probe callers have exited the non preemptible section and thus are not executing the probe code anymore. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14tracing: Kernel TracepointsMathieu Desnoyers
Implementation of kernel tracepoints. Inspired from the Linux Kernel Markers. Allows complete typing verification by declaring both tracing statement inline functions and probe registration/unregistration static inline functions within the same macro "DEFINE_TRACE". No format string is required. See the tracepoint Documentation and Samples patches for usage examples. Taken from the documentation patch : "A tracepoint placed in code provides a hook to call a function (probe) that you can provide at runtime. A tracepoint can be "on" (a probe is connected to it) or "off" (no probe is attached). When a tracepoint is "off" it has no effect, except for adding a tiny time penalty (checking a condition for a branch) and space penalty (adding a few bytes for the function call at the end of the instrumented function and adds a data structure in a separate section). When a tracepoint is "on", the function you provide is called each time the tracepoint is executed, in the execution context of the caller. When the function provided ends its execution, it returns to the caller (continuing from the tracepoint site). You can put tracepoints at important locations in the code. They are lightweight hooks that can pass an arbitrary number of parameters, which prototypes are described in a tracepoint declaration placed in a header file." Addition and removal of tracepoints is synchronized by RCU using the scheduler (and preempt_disable) as guarantees to find a quiescent state (this is really RCU "classic"). The update side uses rcu_barrier_sched() with call_rcu_sched() and the read/execute side uses "preempt_disable()/preempt_enable()". We make sure the previous array containing probes, which has been scheduled for deletion by the rcu callback, is indeed freed before we proceed to the next update. It therefore limits the rate of modification of a single tracepoint to one update per RCU period. The objective here is to permit fast batch add/removal of probes on _different_ tracepoints. Changelog : - Use #name ":" #proto as string to identify the tracepoint in the tracepoint table. This will make sure not type mismatch happens due to connexion of a probe with the wrong type to a tracepoint declared with the same name in a different header. - Add tracepoint_entry_free_old. - Change __TO_TRACE to get rid of the 'i' iterator. Masami Hiramatsu <mhiramat@redhat.com> : Tested on x86-64. Performance impact of a tracepoint : same as markers, except that it adds about 70 bytes of instructions in an unlikely branch of each instrumented function (the for loop, the stack setup and the function call). It currently adds a memory read, a test and a conditional branch at the instrumentation site (in the hot path). Immediate values will eventually change this into a load immediate, test and branch, which removes the memory read which will make the i-cache impact smaller (changing the memory read for a load immediate removes 3-4 bytes per site on x86_32 (depending on mov prefixes), or 7-8 bytes on x86_64, it also saves the d-cache hit). About the performance impact of tracepoints (which is comparable to markers), even without immediate values optimizations, tests done by Hideo Aoki on ia64 show no regression. His test case was using hackbench on a kernel where scheduler instrumentation (about 5 events in code scheduler code) was added. Quoting Hideo Aoki about Markers : I evaluated overhead of kernel marker using linux-2.6-sched-fixes git tree, which includes several markers for LTTng, using an ia64 server. While the immediate trace mark feature isn't implemented on ia64, there is no major performance regression. So, I think that we don't have any issues to propose merging marker point patches into Linus's tree from the viewpoint of performance impact. I prepared two kernels to evaluate. The first one was compiled without CONFIG_MARKERS. The second one was enabled CONFIG_MARKERS. I downloaded the original hackbench from the following URL: http://devresources.linux-foundation.org/craiger/hackbench/src/hackbench.c I ran hackbench 5 times in each condition and calculated the average and difference between the kernels. The parameter of hackbench: every 50 from 50 to 800 The number of CPUs of the server: 2, 4, and 8 Below is the results. As you can see, major performance regression wasn't found in any case. Even if number of processes increases, differences between marker-enabled kernel and marker- disabled kernel doesn't increase. Moreover, if number of CPUs increases, the differences doesn't increase either. Curiously, marker-enabled kernel is better than marker-disabled kernel in more than half cases, although I guess it comes from the difference of memory access pattern. * 2 CPUs Number of | without | with | diff | diff | processes | Marker [Sec] | Marker [Sec] | [Sec] | [%] | -------------------------------------------------------------- 50 | 4.811 | 4.872 | +0.061 | +1.27 | 100 | 9.854 | 10.309 | +0.454 | +4.61 | 150 | 15.602 | 15.040 | -0.562 | -3.6 | 200 | 20.489 | 20.380 | -0.109 | -0.53 | 250 | 25.798 | 25.652 | -0.146 | -0.56 | 300 | 31.260 | 30.797 | -0.463 | -1.48 | 350 | 36.121 | 35.770 | -0.351 | -0.97 | 400 | 42.288 | 42.102 | -0.186 | -0.44 | 450 | 47.778 | 47.253 | -0.526 | -1.1 | 500 | 51.953 | 52.278 | +0.325 | +0.63 | 550 | 58.401 | 57.700 | -0.701 | -1.2 | 600 | 63.334 | 63.222 | -0.112 | -0.18 | 650 | 68.816 | 68.511 | -0.306 | -0.44 | 700 | 74.667 | 74.088 | -0.579 | -0.78 | 750 | 78.612 | 79.582 | +0.970 | +1.23 | 800 | 85.431 | 85.263 | -0.168 | -0.2 | -------------------------------------------------------------- * 4 CPUs Number of | without | with | diff | diff | processes | Marker [Sec] | Marker [Sec] | [Sec] | [%] | -------------------------------------------------------------- 50 | 2.586 | 2.584 | -0.003 | -0.1 | 100 | 5.254 | 5.283 | +0.030 | +0.56 | 150 | 8.012 | 8.074 | +0.061 | +0.76 | 200 | 11.172 | 11.000 | -0.172 | -1.54 | 250 | 13.917 | 14.036 | +0.119 | +0.86 | 300 | 16.905 | 16.543 | -0.362 | -2.14 | 350 | 19.901 | 20.036 | +0.135 | +0.68 | 400 | 22.908 | 23.094 | +0.186 | +0.81 | 450 | 26.273 | 26.101 | -0.172 | -0.66 | 500 | 29.554 | 29.092 | -0.461 | -1.56 | 550 | 32.377 | 32.274 | -0.103 | -0.32 | 600 | 35.855 | 35.322 | -0.533 | -1.49 | 650 | 39.192 | 38.388 | -0.804 | -2.05 | 700 | 41.744 | 41.719 | -0.025 | -0.06 | 750 | 45.016 | 44.496 | -0.520 | -1.16 | 800 | 48.212 | 47.603 | -0.609 | -1.26 | -------------------------------------------------------------- * 8 CPUs Number of | without | with | diff | diff | processes | Marker [Sec] | Marker [Sec] | [Sec] | [%] | -------------------------------------------------------------- 50 | 2.094 | 2.072 | -0.022 | -1.07 | 100 | 4.162 | 4.273 | +0.111 | +2.66 | 150 | 6.485 | 6.540 | +0.055 | +0.84 | 200 | 8.556 | 8.478 | -0.078 | -0.91 | 250 | 10.458 | 10.258 | -0.200 | -1.91 | 300 | 12.425 | 12.750 | +0.325 | +2.62 | 350 | 14.807 | 14.839 | +0.032 | +0.22 | 400 | 16.801 | 16.959 | +0.158 | +0.94 | 450 | 19.478 | 19.009 | -0.470 | -2.41 | 500 | 21.296 | 21.504 | +0.208 | +0.98 | 550 | 23.842 | 23.979 | +0.137 | +0.57 | 600 | 26.309 | 26.111 | -0.198 | -0.75 | 650 | 28.705 | 28.446 | -0.259 | -0.9 | 700 | 31.233 | 31.394 | +0.161 | +0.52 | 750 | 34.064 | 33.720 | -0.344 | -1.01 | 800 | 36.320 | 36.114 | -0.206 | -0.57 | -------------------------------------------------------------- Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: 'Peter Zijlstra' <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
