path: root/include/linux/syscalls.h
2006-10-11[PATCH] epoll_pwait()Davide Libenzi
Implement the epoll_pwait system call, that extend the event wait mechanism with the same logic ppoll and pselect do. The definition of epoll_pwait is: int epoll_pwait(int epfd, struct epoll_event *events, int maxevents, int timeout, const sigset_t *sigmask, size_t sigsetsize); The difference between the vanilla epoll_wait and epoll_pwait is that the latter allows the caller to specify a signal mask to be set while waiting for events. Hence epoll_pwait will wait until either one monitored event, or an unmasked signal happen. If sigmask is NULL, the epoll_pwait system call will act exactly like epoll_wait. For the POSIX definition of pselect, information is available here: http://www.opengroup.org/onlinepubs/009695399/functions/select.html Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Andi Kleen <ak@muc.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] __user annotations: futexAl Viro
2006-10-02[PATCH] rename the provided execve functions to kernel_execveArnd Bergmann
Some architectures provide an execve function that does not set errno, but instead returns the result code directly. Rename these to kernel_execve to get the right semantics there. Moreover, there is no reasone for any of these architectures to still provide __KERNEL_SYSCALLS__ or _syscallN macros, so remove these right away. [akpm@osdl.org: build fix] [bunk@stusta.de: build fix] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] sys_getcpu() prototype annotatedAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] x86: Add portable getcpu callAndi Kleen
For NUMA optimization and some other algorithms it is useful to have a fast to get the current CPU and node numbers in user space. x86-64 added a fast way to do this in a vsyscall. This adds a generic syscall for other architectures to make it a generic portable facility. I expect some of them will also implement it as a faster vsyscall. The cache is an optimization for the x86-64 vsyscall optimization. Since what the syscall returns is an approximation anyways and user space often wants very fast results it can be cached for some time. The norma methods to get this information in user space are relatively slow The vsyscall is in a better position to manage the cache because it has direct access to a fast time stamp (jiffies). For the generic syscall optimization it doesn't help much, but enforce a valid argument to keep programs portable I only added an i386 syscall entry for now. Other architectures can follow as needed. AK: Also added some cleanups from Andrew Morton Signed-off-by: Andi Kleen <ak@suse.de>
2006-06-27[PATCH] pi-futex: futex code cleanupsIngo Molnar
We are pleased to announce "lightweight userspace priority inheritance" (PI) support for futexes. The following patchset and glibc patch implements it, ontop of the robust-futexes patchset which is included in 2.6.16-mm1. We are calling it lightweight for 3 reasons: - in the user-space fastpath a PI-enabled futex involves no kernel work (or any other PI complexity) at all. No registration, no extra kernel calls - just pure fast atomic ops in userspace. - in the slowpath (in the lock-contention case), the system call and scheduling pattern is in fact better than that of normal futexes, due to the 'integrated' nature of FUTEX_LOCK_PI. [more about that further down] - the in-kernel PI implementation is streamlined around the mutex abstraction, with strict rules that keep the implementation relatively simple: only a single owner may own a lock (i.e. no read-write lock support), only the owner may unlock a lock, no recursive locking, etc. Priority Inheritance - why, oh why??? ------------------------------------- Many of you heard the horror stories about the evil PI code circling Linux for years, which makes no real sense at all and is only used by buggy applications and which has horrible overhead. Some of you have dreaded this very moment, when someone actually submits working PI code ;-) So why would we like to see PI support for futexes? We'd like to see it done purely for technological reasons. We dont think it's a buggy concept, we think it's useful functionality to offer to applications, which functionality cannot be achieved in other ways. We also think it's the right thing to do, and we think we've got the right arguments and the right numbers to prove that. We also believe that we can address all the counter-arguments as well. For these reasons (and the reasons outlined below) we are submitting this patch-set for upstream kernel inclusion. What are the benefits of PI? The short reply: ---------------- User-space PI helps achieving/improving determinism for user-space applications. In the best-case, it can help achieve determinism and well-bound latencies. Even in the worst-case, PI will improve the statistical distribution of locking related application delays. The longer reply: ----------------- Firstly, sharing locks between multiple tasks is a common programming technique that often cannot be replaced with lockless algorithms. As we can see it in the kernel [which is a quite complex program in itself], lockless structures are rather the exception than the norm - the current ratio of lockless vs. locky code for shared data structures is somewhere between 1:10 and 1:100. Lockless is hard, and the complexity of lockless algorithms often endangers to ability to do robust reviews of said code. I.e. critical RT apps often choose lock structures to protect critical data structures, instead of lockless algorithms. Furthermore, there are cases (like shared hardware, or other resource limits) where lockless access is mathematically impossible. Media players (such as Jack) are an example of reasonable application design with multiple tasks (with multiple priority levels) sharing short-held locks: for example, a highprio audio playback thread is combined with medium-prio construct-audio-data threads and low-prio display-colory-stuff threads. Add video and decoding to the mix and we've got even more priority levels. So once we accept that synchronization objects (locks) are an unavoidable fact of life, and once we accept that multi-task userspace apps have a very fair expectation of being able to use locks, we've got to think about how to offer the option of a deterministic locking implementation to user-space. Most of the technical counter-arguments against doing priority inheritance only apply to kernel-space locks. But user-space locks are different, there we cannot disable interrupts or make the task non-preemptible in a critical section, so the 'use spinlocks' argument does not apply (user-space spinlocks have the same priority inversion problems as other user-space locking constructs). Fact is, pretty much the only technique that currently enables good determinism for userspace locks (such as futex-based pthread mutexes) is priority inheritance: Currently (without PI), if a high-prio and a low-prio task shares a lock [this is a quite common scenario for most non-trivial RT applications], even if all critical sections are coded carefully to be deterministic (i.e. all critical sections are short in duration and only execute a limited number of instructions), the kernel cannot guarantee any deterministic execution of the high-prio task: any medium-priority task could preempt the low-prio task while it holds the shared lock and executes the critical section, and could delay it indefinitely. Implementation: --------------- As mentioned before, the userspace fastpath of PI-enabled pthread mutexes involves no kernel work at all - they behave quite similarly to normal futex-based locks: a 0 value means unlocked, and a value==TID means locked. (This is the same method as used by list-based robust futexes.) Userspace uses atomic ops to lock/unlock these mutexes without entering the kernel. To handle the slowpath, we have added two new futex ops: FUTEX_LOCK_PI FUTEX_UNLOCK_PI If the lock-acquire fastpath fails, [i.e. an atomic transition from 0 to TID fails], then FUTEX_LOCK_PI is called. The kernel does all the remaining work: if there is no futex-queue attached to the futex address yet then the code looks up the task that owns the futex [it has put its own TID into the futex value], and attaches a 'PI state' structure to the futex-queue. The pi_state includes an rt-mutex, which is a PI-aware, kernel-based synchronization object. The 'other' task is made the owner of the rt-mutex, and the FUTEX_WAITERS bit is atomically set in the futex value. Then this task tries to lock the rt-mutex, on which it blocks. Once it returns, it has the mutex acquired, and it sets the futex value to its own TID and returns. Userspace has no other work to perform - it now owns the lock, and futex value contains FUTEX_WAITERS|TID. If the unlock side fastpath succeeds, [i.e. userspace manages to do a TID -> 0 atomic transition of the futex value], then no kernel work is triggered. If the unlock fastpath fails (because the FUTEX_WAITERS bit is set), then FUTEX_UNLOCK_PI is called, and the kernel unlocks the futex on the behalf of userspace - and it also unlocks the attached pi_state->rt_mutex and thus wakes up any potential waiters. Note that under this approach, contrary to other PI-futex approaches, there is no prior 'registration' of a PI-futex. [which is not quite possible anyway, due to existing ABI properties of pthread mutexes.] Also, under this scheme, 'robustness' and 'PI' are two orthogonal properties of futexes, and all four combinations are possible: futex, robust-futex, PI-futex, robust+PI-futex. glibc support: -------------- Ulrich Drepper and Jakub Jelinek have written glibc support for PI-futexes (and robust futexes), enabling robust and PI (PTHREAD_PRIO_INHERIT) POSIX mutexes. (PTHREAD_PRIO_PROTECT support will be added later on too, no additional kernel changes are needed for that). [NOTE: The glibc patch is obviously inofficial and unsupported without matching upstream kernel functionality.] the patch-queue and the glibc patch can also be downloaded from: http://redhat.com/~mingo/PI-futex-patches/ Many thanks go to the people who helped us create this kernel feature: Steven Rostedt, Esben Nielsen, Benedikt Spranger, Daniel Walker, John Cooper, Arjan van de Ven, Oleg Nesterov and others. Credits for related prior projects goes to Dirk Grambow, Inaky Perez-Gonzalez, Bill Huey and many others. Clean up the futex code, before adding more features to it: - use u32 as the futex field type - that's the ABI - use __user and pointers to u32 instead of unsigned long - code style / comment style cleanups - rename hash-bucket name from 'bh' to 'hb'. I checked the pre and post futex.o object files to make sure this patch has no code effects. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] move_pages: fix 32 -> 64 bit compat functionChristoph Lameter
The definition of the third parameter is a pointer to an array of virtual addresses which give us some trouble. The existing code calculated the wrong address in the array since I used void to avoid having to specify a type. I now use the correct type "compat_uptr_t __user *" in the definition of the function in kernel/compat.c. However, I used __u32 in syscalls.h. Would have to include compat.h there in order to provide the same definition which would generate an ugly include situation. On both ia64 and x86_64 compat_uptr_t is u32. So this works although parameter declarations differ. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] sys_move_pages: 32bit support (i386, x86_64)Christoph Lameter
sys_move_pages() support for 32bit (i386 plus x86_64 compat layer) Add support for move_pages() on i386 and also add the compat functions necessary to run 32 bit binaries on x86_64. Add compat_sys_move_pages to the x86_64 32bit binary layer. Note that it is not up to date so I added the missing pieces. Not sure if this is done the right way. [akpm@osdl.org: compile fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] page migration: sys_move_pages(): support moving of individual pagesChristoph Lameter
move_pages() is used to move individual pages of a process. The function can be used to determine the location of pages and to move them onto the desired node. move_pages() returns status information for each page. long move_pages(pid, number_of_pages_to_move, addresses_of_pages[], nodes[] or NULL, status[], flags); The addresses of pages is an array of void * pointing to the pages to be moved. The nodes array contains the node numbers that the pages should be moved to. If a NULL is passed instead of an array then no pages are moved but the status array is updated. The status request may be used to determine the page state before issuing another move_pages() to move pages. The status array will contain the state of all individual page migration attempts when the function terminates. The status array is only valid if move_pages() completed successfullly. Possible page states in status[]: 0..MAX_NUMNODES The page is now on the indicated node. -ENOENT Page is not present -EACCES Page is mapped by multiple processes and can only be moved if MPOL_MF_MOVE_ALL is specified. -EPERM The page has been mlocked by a process/driver and cannot be moved. -EBUSY Page is busy and cannot be moved. Try again later. -EFAULT Invalid address (no VMA or zero page). -ENOMEM Unable to allocate memory on target node. -EIO Unable to write back page. The page must be written back in order to move it since the page is dirty and the filesystem does not provide a migration function that would allow the moving of dirty pages. -EINVAL A dirty page cannot be moved. The filesystem does not provide a migration function and has no ability to write back pages. The flags parameter indicates what types of pages to move: MPOL_MF_MOVE Move pages that are only mapped by the process. MPOL_MF_MOVE_ALL Also move pages that are mapped by multiple processes. Requires sufficient capabilities. Possible return codes from move_pages() -ENOENT No pages found that would require moving. All pages are either already on the target node, not present, had an invalid address or could not be moved because they were mapped by multiple processes. -EINVAL Flags other than MPOL_MF_MOVE(_ALL) specified or an attempt to migrate pages in a kernel thread. -EPERM MPOL_MF_MOVE_ALL specified without sufficient priviledges. or an attempt to move a process belonging to another user. -EACCES One of the target nodes is not allowed by the current cpuset. -ENODEV One of the target nodes is not online. -ESRCH Process does not exist. -E2BIG Too many pages to move. -ENOMEM Not enough memory to allocate control array. -EFAULT Parameters could not be accessed. A test program for move_pages() may be found with the patches on ftp.kernel.org:/pub/linux/kernel/people/christoph/pmig/patches-2.6.17-rc4-mm3 From: Christoph Lameter <clameter@sgi.com> Detailed results for sys_move_pages() Pass a pointer to an integer to get_new_page() that may be used to indicate where the completion status of a migration operation should be placed. This allows sys_move_pags() to report back exactly what happened to each page. Wish there would be a better way to do this. Looks a bit hacky. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Jes Sorensen <jes@trained-monkey.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andi Kleen <ak@muc.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-24Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: include/asm-powerpc/unistd.h include/asm-sparc/unistd.h include/asm-sparc64/unistd.h Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-23[PATCH] powerpc: wire up sys_[gs]et_robust_listDavid Woodhouse
Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6David Woodhouse
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-26[PATCH] Add support for the sys_vmsplice syscallJens Axboe
sys_splice() moves data to/from pipes with a file input/output. sys_vmsplice() moves data to a pipe, with the input being a user address range instead. This uses an approach suggested by Linus, where we can hold partial ranges inside the pages[] map. Hopefully this will be useful for network receive support as well. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-11[PATCH] splice: add support for sys_tee()Jens Axboe
Basically an in-kernel implementation of tee, which uses splice and the pipe buffers as an intelligent way to pass data around by reference. Where the user space tee consumes the input and produces a stdout and file output, this syscall merely duplicates the data inside a pipe to another pipe. No data is copied, the output just grabs a reference to the input pipe data. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-11Merge branch 'splice' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'splice' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] vfs: add splice_write and splice_read to documentation [PATCH] Remove sys_ prefix of new syscalls from __NR_sys_* [PATCH] splice: warning fix [PATCH] another round of fs/pipe.c cleanups [PATCH] splice: comment styles [PATCH] splice: add Ingo as addition copyright holder [PATCH] splice: unlikely() optimizations [PATCH] splice: speedups and optimizations [PATCH] pipe.c/fifo.c code cleanups [PATCH] get rid of the PIPE_*() macros [PATCH] splice: speedup __generic_file_splice_read [PATCH] splice: add direct fd <-> fd splicing support [PATCH] splice: add optional input and output offsets [PATCH] introduce a "kernel-internal pipe object" abstraction [PATCH] splice: be smarter about calling do_page_cache_readahead() [PATCH] splice: optimize the splice buffer mapping [PATCH] splice: cleanup __generic_file_splice_read() [PATCH] splice: only call wake_up_interruptible() when we really have to [PATCH] splice: potential !page dereference [PATCH] splice: mark the io page as accessed
2006-04-11[PATCH] sync_file_range(): use unsigned for flagsAndrew Morton
Ulrich suggested that the `flags' arg to sync_file_range() become unsigned. Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-10[PATCH] splice: add optional input and output offsetsIngo Molnar
add optional input and output offsets to sys_splice(), for seekable file descriptors: asmlinkage long sys_splice(int fd_in, loff_t __user *off_in, int fd_out, loff_t __user *off_out, size_t len, unsigned int flags); semantics are straightforward: f_pos will be updated with the offset provided by user-space, before the splice transfer is about to begin. Providing a NULL offset pointer means the existing f_pos will be used (and updated in situ). Providing an offset for a pipe results in -ESPIPE. Providing an invalid offset pointer results in -EFAULT. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-31[PATCH] sys_sync_file_range()Andrew Morton
Remove the recently-added LINUX_FADV_ASYNC_WRITE and LINUX_FADV_WRITE_WAIT fadvise() additions, do it in a new sys_sync_file_range() syscall instead. Reasons: - It's more flexible. Things which would require two or three syscalls with fadvise() can be done in a single syscall. - Using fadvise() in this manner is something not covered by POSIX. The patch wires up the syscall for x86. The sycall is implemented in the new fs/sync.c. The intention is that we can move sys_fsync(), sys_fdatasync() and perhaps sys_sync() into there later. Documentation for the syscall is in fs/sync.c. A test app (sync_file_range.c) is in http://www.zip.com.au/~akpm/linux/patches/stuff/ext3-tools.tar.gz. The available-to-GPL-modules do_sync_file_range() is for knfsd: "A COMMIT can say NFS_DATA_SYNC or NFS_FILE_SYNC. I can skip the ->fsync call for NFS_DATA_SYNC which is hopefully the more common." Note: the `async' writeout mode SYNC_FILE_RANGE_WRITE will turn synchronous if the queue is congested. This is trivial to fix: add a new flag bit, set wbc->nonblocking. But I'm not sure that we want to expose implementation details down to that level. Note: it's notable that we can sync an fd which wasn't opened for writing. Same with fsync() and fdatasync()). Note: the code takes some care to handle attempts to sync file contents outside the 16TB offset on 32-bit machines. It makes such attempts appear to succeed, for best 32-bit/64-bit compatibility. Perhaps it should make such requests fail... Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PATCH] Introduce sys_splice() system callJens Axboe
This adds support for the sys_splice system call. Using a pipe as a transport, it can connect to files or sockets (latter as output only). From the splice.c comments: "splice": joining two ropes together by interweaving their strands. This is the "extended pipe" functionality, where a pipe is used as an arbitrary in-memory buffer. Think of a pipe as a small kernel buffer that you can use to transfer data from one end to the other. The traditional unix read/write is extended with a "splice()" operation that transfers data buffers to or from a pipe buffer. Named by Larry McVoy, original implementation from Linus, extended by Jens to support splicing to files and fixing the initial implementation bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] add sys_unshare to syscalls.hArnd Bergmann
All architecture independent system calls should be declared in syscalls.h, add the one that is missing. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] flags parameter for linkatUlrich Drepper
I'm currently at the POSIX meeting and one thing covered was the incompatibility of Linux's link() with the POSIX definition. The name. Linux does not follow symlinks, POSIX requires it does. Even if somebody thinks this is a good default behavior we cannot change this because it would break the ABI. But the fact remains that some application might want this behavior. We have one chance to help implementing this without breaking the behavior. For this we could use the new linkat interface which would need a new flags parameter. If the new parameter is AT_SYMLINK_FOLLOW the new behavior could be invoked. I do not want to introduce such a patch now. But we could add the parameter now, just don't use it. The patch below would do this. Can we get this late patch applied before the release more or less fixes the syscall API? Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] fstatat64 supportUlrich Drepper
The *at patches introduced fstatat and, due to inusfficient research, I used the newfstat functions generally as the guideline. The result is that on 32-bit platforms we don't have all the information needed to implement fstatat64. This patch modifies the code to pass up 64-bit information if __ARCH_WANT_STAT64 is defined. I renamed the syscall entry point to make this clear. Other archs will continue to use the existing code. On x86-64 the compat code is implemented using a new sys32_ function. this is what is done for the other stat syscalls as well. This patch might break some other archs (those which define __ARCH_WANT_STAT64 and which already wired up the syscall). Yet others might need changes to accomodate the compatibility mode. I really don't want to do that work because all this stat handling is a mess (more so in glibc, but the kernel is also affected). It should be done by the arch maintainers. I'll provide some stand-alone test shortly. Those who are eager could compile glibc and run 'make check' (no installation needed). The patch below has been tested on x86 and x86-64. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] compat: fix compat_sys_openat and friendsStephen Rothwell
Most of the 64 bit architectures will zero extend the first argument to compat_sys_{openat,newfstatat,futimesat} which will fail if the 32 bit syscall was passed AT_FDCWD (which is a small negative number). Declare the first argument to be an unsigned int which will force the correct sign extension when the internal functions are called in each case. Also, do some small white space cleanups in fs/compat.c. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] prototypes for *at functions & typo fixUlrich Drepper
Here's the follow-up patch which introduces the prototypes for the new syscalls. There was also a typo in one of the new symbols. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] add missing syscall declarationsArnd Bergmann
All standard system calls should be declared in include/linux/syscalls.h. Add some of the new additions that were previously missed. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
2006-01-08[PATCH] Swap Migration V5: sys_migrate_pages interfaceChristoph Lameter
sys_migrate_pages implementation using swap based page migration This is the original API proposed by Ray Bryant in his posts during the first half of 2005 on linux-mm@kvack.org and linux-kernel@vger.kernel.org. The intent of sys_migrate is to migrate memory of a process. A process may have migrated to another node. Memory was allocated optimally for the prior context. sys_migrate_pages allows to shift the memory to the new node. sys_migrate_pages is also useful if the processes available memory nodes have changed through cpuset operations to manually move the processes memory. Paul Jackson is working on an automated mechanism that will allow an automatic migration if the cpuset of a process is changed. However, a user may decide to manually control the migration. This implementation is put into the policy layer since it uses concepts and functions that are also needed for mbind and friends. The patch also provides a do_migrate_pages function that may be useful for cpusets to automatically move memory. sys_migrate_pages does not modify policies in contrast to Ray's implementation. The current code here is based on the swap based page migration capability and thus is not able to preserve the physical layout relative to it containing nodeset (which may be a cpuset). When direct page migration becomes available then the implementation needs to be changed to do a isomorphic move of pages between different nodesets. The current implementation simply evicts all pages in source nodeset that are not in the target nodeset. Patch supports ia64, i386 and x86_64. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] spufs: The SPU file system, baseArnd Bergmann
This is the current version of the spu file system, used for driving SPEs on the Cell Broadband Engine. This release is almost identical to the version for the 2.6.14 kernel posted earlier, which is available as part of the Cell BE Linux distribution from http://www.bsc.es/projects/deepcomputing/linuxoncell/. The first patch provides all the interfaces for running spu application, but does not have any support for debugging SPU tasks or for scheduling. Both these functionalities are added in the subsequent patches. See Documentation/filesystems/spufs.txt on how to use spufs. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-30[PATCH] unify sys_ptrace prototypeChristoph Hellwig
Make sure we always return, as all syscalls should. Also move the common prototype to <linux/syscalls.h> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] Adds sys_set_mempolicy() in include/linux/syscalls.hEric Dumazet
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] move ioprio syscalls into syscalls.hAnton Blanchard
- Make ioprio syscalls return long, like set/getpriority syscalls. - Move function prototypes into syscalls.h so we can pick them up in the 32/64bit compat code. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec code cleanupManeesh Soni
o Following patch provides purely cosmetic changes and corrects CodingStyle guide lines related certain issues like below in kexec related files o braces for one line "if" statements, "for" loops, o more than 80 column wide lines, o No space after "while", "for" and "switch" key words o Changes: o take-2: Removed the extra tab before "case" key words. o take-3: Put operator at the end of line and space before "*/" Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: add kexec syscallsEric W. Biederman
This patch introduces the architecture independent implementation the sys_kexec_load, the compat_sys_kexec_load system calls. Kexec on panic support has been integrated into the core patch and is relatively clean. In addition the hopefully architecture independent option crashkernel=size@location has been docuemented. It's purpose is to reserve space for the panic kernel to live, and where no DMA transfer will ever be setup to access. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] consolidate sys_shmatStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
