__ARCH_WANT_SYS_RT_SIGACTION,
__ARCH_WANT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore
CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} -
can be assumed always set.
conditional on OLD_SIGACTION/COMPAT_OLD_SIGACTION
conditional on OLD_SIGSUSPEND/OLD_SIGSUSPEND3, depending on which
variety of that fossil is needed.
Switch from __ARCH_WANT_SYS_RT_SIGACTION to opposite
(!CONFIG_ODD_RT_SIGACTION); the only two architectures that
need it are alpha and sparc. The reason for use of CONFIG_...
instead of __ARCH_... is that it's needed only kernel-side
and doing it that way avoids a mess with include order on many
architectures.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull signal handling cleanups from Al Viro:
"sigaltstack infrastructure + conversion for x86, alpha and um,
COMPAT_SYSCALL_DEFINE infrastructure.
Note that there are several conflicts between "unify
SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline;
resolution is trivial - just remove definitions of SS_ONSTACK and
SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and
include/uapi/linux/signal.h contains the unified variant."
Fixed up conflicts as per Al.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
alpha: switch to generic sigaltstack
new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those
generic compat_sys_sigaltstack()
introduce generic sys_sigaltstack(), switch x86 and um to it
new helper: compat_user_stack_pointer()
new helper: restore_altstack()
unify SS_ONSTACK/SS_DISABLE definitions
new helper: current_user_stack_pointer()
missing user_stack_pointer() instances
Bury the conditionals from kernel_thread/kernel_execve series
COMPAT_SYSCALL_DEFINE: infrastructure
Conditional on CONFIG_GENERIC_SIGALTSTACK; architectures that do not
select it are completely unaffected
All architectures have
CONFIG_GENERIC_KERNEL_THREAD
CONFIG_GENERIC_KERNEL_EXECVE
__ARCH_WANT_SYS_EXECVE
None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers
of kernel_execve() (which is a trivial wrapper for do_execve() now) left.
Kill the conditionals and make both callers use do_execve().
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"Nothing all that exciting; a new module-from-fd syscall for those who
want to verify the source of the module (ChromeOS) and/or use standard
IMA on it or other security hooks."
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
MODSIGN: Fix kbuild output when using default extra_certificates
MODSIGN: Avoid using .incbin in C source
modules: don't hand 0 to vmalloc.
module: Remove a extra null character at the top of module->strtab.
ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants
ASN.1: Define indefinite length marker constant
moduleparam: use __UNIQUE_ID()
__UNIQUE_ID()
MODSIGN: Add modules_sign make target
powerpc: add finit_module syscall.
ima: support new kernel module syscall
add finit_module syscall to asm-generic
ARM: add finit_module syscall to ARM
security: introduce kernel_module_from_file hook
module: add flags arg to sys_finit_module()
module: add syscall to load module from fd
But the kernel decided to call it "origin" instead. Fix most of the
sites.
Thanks to Michael Kerrisk for keeping us honest. These flags are actually
useful for eliminating the only case where kmod has to mangle a module's
internals: for overriding module versioning.
Acked-by: Lucas De Marchi <lucas.demarchi@profusion.mobi>
As part of the effort to create a stronger boundary between root and
kernel, Chrome OS wants to be able to enforce that kernel modules are
being loaded only from our read-only crypto-hash verified (dm_verity)
root filesystem. Since the init_module syscall hands the kernel a module
as a memory blob, no reasoning about the origin of the blob can be made.
Earlier proposals for appending signatures to kernel modules would not be
useful in Chrome OS, since it would involve adding an additional set of
keys to our kernel and builds for no good reason: we already trust the
contents of our root filesystem. We don't need to verify those kernel
modules a second time. Having to do signature checking on module loading
would slow us down and be redundant. All we need to know is where a
module is coming from so we can say yes/no to loading it.
If a file descriptor is used as the source of a kernel module, many more
things can be reasoned about. In Chrome OS's case, we could enforce that
the module lives on the filesystem we expect it to live on. In the case
of IMA (or other LSMs), it would be possible, for example, to examine
extended attributes that may contain signatures over the contents of
the module.
This introduces a new syscall (on x86), similar to init_module, that has
only two arguments. The first argument is used as a file descriptor to
the module and the second argument is a pointer to the NULL terminated
string of module arguments.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (merge fixes)
now it can be done...
* allow kernel_execve() leave the actual return to userland to
caller (selected by CONFIG_GENERIC_KERNEL_EXECVE). Callers
updated accordingly.
* architecture that does select GENERIC_KERNEL_EXECVE in its
Kconfig should have its ret_from_kernel_thread() do this:
call schedule_tail
call the callback left for it by copy_thread(); if it ever
returns, that's because it has just done successful kernel_execve()
jump to return from syscall
IOW, its only difference from ret_from_fork() is that it does call the
callback.
* such an architecture should also get rid of ret_from_kernel_execve()
and __ARCH_WANT_KERNEL_EXECVE
This is the last part of infrastructure patches in that area - from
that point on work on different architectures can live independently.
While doing the checkpoint-restore in the user space one need to determine
whether various kernel objects (like mm_struct-s of file_struct-s) are
shared between tasks and restore this state.
The 2nd step can be solved by using appropriate CLONE_ flags and the
unshare syscall, while there's currently no ways for solving the 1st one.
One of the ways for checking whether two tasks share e.g. mm_struct is to
provide some mm_struct ID of a task to its proc file, but showing such
info considered to be not that good for security reasons.
Thus after some debates we end up in conclusion that using that named
'comparison' syscall might be the best candidate. So here is it --
__NR_kcmp.
It takes up to 5 arguments - the pids of the two tasks (which
characteristics should be compared), the comparison type and (in case of
comparison of files) two file descriptors.
Lookups for pids are done in the caller's PID namespace only.
At moment only x86 is supported and tested.
[akpm@linux-foundation.org: fix up selftests, warnings]
[akpm@linux-foundation.org: include errno.h]
[akpm@linux-foundation.org: tweak comment text]
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Andrey Vagin <avagin@openvz.org>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Cc: Glauber Costa <glommer@parallels.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Vasiliy Kulikov <segoon@openwall.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Valdis.Kletnieks@vt.edu
Cc: Michal Marek <mmarek@suse.cz>
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
The 'poll()' system call timeout parameter is supposed to be 'int', not
'long'.
Now, the reason this matters is that right now 32-bit compat mode is
broken on at least x86-64, because the 32-bit code just calls
'sys_poll()' directly on x86-64, and the 32-bit argument will have been
zero-extended, turning a signed 'int' into a large unsigned 'long'
value.
We could just introduce a 'compat_sys_poll()' function for this, and
that may eventually be what we have to do, but since the actual standard
poll() semantics is *supposed* to be 'int', and since at least on x86-64
glibc sign-extends the argument before invocing the system call (so
nobody can actually use a 64-bit timeout value in user space _anyway_,
even in 64-bit binaries), the simpler solution would seem to be to just
fix the definition of the system call to match what it should have been
from the very start.
If it turns out that somebody somehow circumvents the user-level libc
64-bit sign extension and actually uses a large unsigned 64-bit timeout
despite that not being how poll() is supposed to work, we will need to
do the compat_sys_poll() approach.
Reported-by: Thomas Meyer <thomas@m3y3r.de>
SYSCALLx magic should take care of things, according to Linus...
The basic idea behind cross memory attach is to allow MPI programs doing
intra-node communication to do a single copy of the message rather than a
double copy of the message via shared memory.
The following patch attempts to achieve this by allowing a destination
process, given an address and size from a source process, to copy memory
directly from the source process into its own address space via a system
call. There is also a symmetrical ability to copy from the current
process's address space into a destination process's address space.
- Use of /proc/pid/mem has been considered, but there are issues with
using it:
- Does not allow for specifying iovecs for both src and dest, assuming
preadv or pwritev was implemented either the area read from or
written to would need to be contiguous.
- Currently mem_read allows only processes who are currently
ptrace'ing the target and are still able to ptrace the target to read
from the target. This check could possibly be moved to the open call,
but its not clear exactly what race this restriction is stopping
(reason appears to have been lost)
- Having to send the fd of /proc/self/mem via SCM_RIGHTS on unix
domain socket is a bit ugly from a userspace point of view,
especially when you may have hundreds if not (eventually) thousands
of processes that all need to do this with each other
- Doesn't allow for some future use of the interface we would like to
consider adding in the future (see below)
- Interestingly reading from /proc/pid/mem currently actually
involves two copies! (But this could be fixed pretty easily)
As mentioned previously use of vmsplice instead was considered, but has
problems. Since you need the reader and writer working co-operatively if
the pipe is not drained then you block. Which requires some wrapping to
do non blocking on the send side or polling on the receive. In all to all
communication it requires ordering otherwise you can deadlock. And in the
example of many MPI tasks writing to one MPI task vmsplice serialises the
copying.
There are some cases of MPI collectives where even a single copy interface
does not get us the performance gain we could. For example in an
MPI_Reduce rather than copy the data from the source we would like to
instead use it directly in a mathops (say the reduce is doing a sum) as
this would save us doing a copy. We don't need to keep a copy of the data
from the source. I haven't implemented this, but I think this interface
could in the future do all this through the use of the flags - eg could
specify the math operation and type and the kernel rather than just
copying the data would apply the specified operation between the source
and destination and store it in the destination.
Although we don't have a "second user" of the interface (though I've had
some nibbles from people who may be interested in using it for intra
process messaging which is not MPI). This interface is something which
hardware vendors are already doing for their custom drivers to implement
fast local communication. And so in addition to this being useful for
OpenMPI it would mean the driver maintainers don't have to fix things up
when the mm changes.
There was some discussion about how much faster a true zero copy would
go. Here's a link back to the email with some testing I did on that:
http://marc.info/?l=linux-mm&m=130105930902915&w=2
There is a basic man page for the proposed interface here:
http://ozlabs.org/~cyeoh/cma/process_vm_readv.txt
This has been implemented for x86 and powerpc, other architecture should
mainly (I think) just need to add syscall numbers for the process_vm_readv
and process_vm_writev. There are 32 bit compatibility versions for
64-bit kernels.
For arch maintainers there are some simple tests to be able to quickly
verify that the syscalls are working correctly here:
http://ozlabs.org/~cyeoh/cma/cma-test-20110718.tgz
Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com>
Cc: <linux-man@vger.kernel.org>
Cc: <linux-arch@vger.kernel.org>
The nfsservctl system call is now gone, so we should remove all
linkage for it.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfd:
net: fix get_net_ns_by_fd for !CONFIG_NET_NS
ns proc: Return -ENOENT for a nonexistent /proc/self/ns/ entry.
ns: Declare sys_setns in syscalls.h
net: Allow setting the network namespace by fd
ns proc: Add support for the ipc namespace
ns proc: Add support for the uts namespace
ns proc: Add support for the network namespace.
ns: Introduce the setns syscall
ns: proc files for namespace naming policy.
Ooops I overlooked this one, and missing it causes compile
errors of the powerpc syscall.
This patch adds a multiple message send syscall and is the send
version of the existing recvmmsg syscall. This is heavily
based on the patch by Arnaldo that added recvmmsg.
I wrote a microbenchmark to test the performance gains of using
this new syscall:
http://ozlabs.org/~anton/junkcode/sendmmsg_test.c
The test was run on a ppc64 box with a 10 Gbit network card. The
benchmark can send both UDP and RAW ethernet packets.
64B UDP
batch pkts/sec
1 804570
2 872800 (+ 8 %)
4 916556 (+14 %)
8 939712 (+17 %)
16 952688 (+18 %)
32 956448 (+19 %)
64 964800 (+20 %)
64B raw socket
batch pkts/sec
1 1201449
2 1350028 (+12 %)
4 1461416 (+22 %)
8 1513080 (+26 %)
16 1541216 (+28 %)
32 1553440 (+29 %)
64 1557888 (+30 %)
We see a 20% improvement in throughput on UDP send and 30%
on raw socket send.
[ Add sparc syscall entries. -DaveM ]
It is frequently useful to sync a single file system, instead of all
mounted file systems via sync(2):
- On machines with many mounts, it is not at all uncommon for some of
them to hang (e.g. unresponsive NFS server). sync(2) will get stuck on
those and may never get to the one you do care about (e.g., /).
- Some applications write lots of data to the file system and then
want to make sure it is flushed to disk. Calling fsync(2) on each
file introduces unnecessary ordering constraints that result in a large
amount of sub-optimal writeback/flush/commit behavior by the file
system.
There are currently two ways (that I know of) to sync a single super_block:
- BLKFLSBUF ioctl on the block device: That also invalidates the bdev
mapping, which isn't usually desirable, and doesn't work for non-block
file systems.
- 'mount -o remount,rw' will call sync_filesystem as an artifact of the
current implemention. Relying on this little-known side effect for
something like data safety sounds foolish.
Both of these approaches require root privileges, which some applications
do not have (nor should they need?) given that sync(2) is an unprivileged
operation.
This patch introduces a new system call syncfs(2) that takes an fd and
syncs only the file system it references. Maybe someday we can
$ sync /some/path
and not get
sync: ignoring all arguments
The syscall is motivated by comments by Al and Christoph at the last LSF.
syncfs(2) seems like an appropriate name given statfs(2).
A similar ioctl was also proposed a while back, see
http://marc.info/?l=linux-fsdevel&m=127970513829285&w=2
Signed-off-by: Sage Weil <sage@newdream.net>
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits)
posix-clocks: Check write permissions in posix syscalls
hrtimer: Remove empty hrtimer_init_hres_timer()
hrtimer: Update hrtimer->state documentation
hrtimer: Update base[CLOCK_BOOTTIME].offset correctly
timers: Export CLOCK_BOOTTIME via the posix timers interface
timers: Add CLOCK_BOOTTIME hrtimer base
time: Extend get_xtime_and_monotonic_offset() to also return sleep
time: Introduce get_monotonic_boottime and ktime_get_boottime
hrtimers: extend hrtimer base code to handle more then 2 clockids
ntp: Remove redundant and incorrect parameter check
mn10300: Switch do_timer() to xtimer_update()
posix clocks: Introduce dynamic clocks
posix-timers: Cleanup namespace
posix-timers: Add support for fd based clocks
x86: Add clock_adjtime for x86
posix-timers: Introduce a syscall for clock tuning.
time: Splitout compat timex accessors
ntp: Add ADJ_SETOFFSET mode bit
time: Introduce timekeeping_inject_offset
posix-timer: Update comment
Fix up new system-call-related conflicts in
arch/x86/ia32/ia32entry.S
arch/x86/include/asm/unistd_32.h
arch/x86/include/asm/unistd_64.h
arch/x86/kernel/syscall_table_32.S
(name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some
due to movement of get_jiffies_64() in:
kernel/time.c
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (184 commits)
perf probe: Clean up probe_point_lazy_walker() return value
tracing: Fix irqoff selftest expanding max buffer
tracing: Align 4 byte ints together in struct tracer
tracing: Export trace_set_clr_event()
tracing: Explain about unstable clock on resume with ring buffer warning
ftrace/graph: Trace function entry before updating index
ftrace: Add .ref.text as one of the safe areas to trace
tracing: Adjust conditional expression latency formatting.
tracing: Fix event alignment: skb:kfree_skb
tracing: Fix event alignment: mce:mce_record
tracing: Fix event alignment: kvm:kvm_hv_hypercall
tracing: Fix event alignment: module:module_request
tracing: Fix event alignment: ftrace:context_switch and ftrace:wakeup
tracing: Remove lock_depth from event entry
perf header: Stop using 'self'
perf session: Use evlist/evsel for managing perf.data attributes
perf top: Don't let events to eat up whole header line
perf top: Fix events overflow in top command
ring-buffer: Remove unused #include <linux/trace_irq.h>
tracing: Add an 'overwrite' trace_option.
[AV: duplicate of open() guts removed; file_open_root() used instead]
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
The syscall also return mount id which can be used
to lookup file system specific information such as uuid
in /proc/<pid>/mountinfo
Compile time initialization is better than runtime initialization.
Remove many early_initcall()s and many trace_init_flags_##name()s.
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <4D3FDFFC.6030304@cn.fujitsu.com>
FTRACE_SYSCALLS would create events for each and every system call, even
if it had failed to map the system call's name with it's number. This
resulted in a number of events being created that would not behave as
expected.
This could happen, for example, on architectures who's symbol names are
unusual and will not match the system call name. It could also happen
with system calls which were mapped to sys_ni_syscall.
This patch changes the default system call number in the metadata to -1.
If the system call name from the metadata is not successfully mapped to
a system call number during boot, than the event initialisation routine
will now return an error, preventing the event from being created.
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
LKML-Reference: <1296703645-18718-2-git-send-email-imunsie@au1.ibm.com>
Currently the syscall_meta structures for the syscall tracepoints are
placed in the __syscall_metadata section, and at link time, the linker
makes one large array of all these syscall metadata structures. On boot
up, this array is read (much like the initcall sections) and the syscall
data is processed.
The problem is that there is no guarantee that gcc will place complex
structures nicely together in an array format. Two structures in the
same file may be placed awkwardly, because gcc has no clue that they
are suppose to be in an array.
A hack was used previous to force the alignment to 4, to pack the
structures together. But this caused alignment issues with other
architectures (sparc).
Instead of packing the structures into an array, the structures' addresses
are now put into the __syscall_metadata section. As pointers are always the
natural alignment, gcc should always pack them tightly together
(otherwise initcall, extable, etc would also fail).
By having the pointers to the structures in the section, we can still
iterate the trace_events without causing unnecessary alignment problems
with other architectures, or depending on the current behaviour of
gcc that will likely change in the future just to tick us kernel developers
off a little more.
The __syscall_metadata section is also moved into the .init.data section
as it is now only needed at boot up.
Suggested-by: David Miller <davem@davemloft.net>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Currently the trace_event structures are placed in the _ftrace_events
section, and at link time, the linker makes one large array of all
the trace_event structures. On boot up, this array is read (much like
the initcall sections) and the events are processed.
are now put into the _ftrace_event section. As pointers are always the
off a little more.
The _ftrace_event section is also moved into the .init.data section
A new syscall is introduced that allows tuning of a POSIX clock. The
new call, clock_adjtime, takes two parameters, the clock ID and a
pointer to a struct timex. Any ADJTIMEX(2) operation may be requested
via this system call, but various POSIX clocks may or may not support
tuning.
[ tglx: Adapted to the posix-timer cleanup series. Avoid copy_to_user
in the error case ]
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
Acked-by: John Stultz <johnstul@us.ibm.com>
LKML-Reference: <20110201134419.869804645@linutronix.de>
It is defined right after, which makes the declaration completely
useless.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Jason Baron <jbaron@redhat.com>
As for the raw syscalls events, individual syscall events won't
leak system wide information on task bound tracing. Allow non
privileged users to use them in such workflow.
Since userspace API of ptrace syscall defines @addr and @data as void
pointers, it would be more appropriate to define them as unsigned long in
kernel. Therefore related functions are changed also.
'unsigned long' is typically used in other places in kernel as an opaque
data type and that using this helps cleaning up a lot of warnings from
sparse.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Roland McGrath <roland@redhat.com>
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
* 'writable_limits' of git://decibel.fi.muni.cz/~xslaby/linux:
unistd: add __NR_prlimit64 syscall numbers
rlimits: implement prlimit64 syscall
rlimits: switch more rlimit syscalls to do_prlimit
rlimits: redo do_setrlimit to more generic do_prlimit
rlimits: add rlimit64 structure
rlimits: do security check under task_lock
rlimits: allow setrlimit to non-current tasks
rlimits: split sys_setrlimit
rlimits: selinux, do rlimits changes under task_lock
rlimits: make sure ->rlim_max never grows in sys_setrlimit
rlimits: add task_struct to update_rlimit_cpu
rlimits: security, add task_struct to setrlimit
Fix up various system call number conflicts. We not only added fanotify
system calls in the meantime, but asm-generic/unistd.h added a wait4
along with a range of reserved per-architecture system calls.
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits)
fanotify: use both marks when possible
fsnotify: pass both the vfsmount mark and inode mark
fsnotify: walk the inode and vfsmount lists simultaneously
fsnotify: rework ignored mark flushing
fsnotify: remove global fsnotify groups lists
fsnotify: remove group->mask
fsnotify: remove the global masks
fsnotify: cleanup should_send_event
fanotify: use the mark in handler functions
audit: use the mark in handler functions
dnotify: use the mark in handler functions
inotify: use the mark in handler functions
fsnotify: send fsnotify_mark to groups in event handling functions
fsnotify: Exchange list heads instead of moving elements
fsnotify: srcu to protect read side of inode and vfsmount locks
fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called
fsnotify: use _rcu functions for mark list traversal
fsnotify: place marks on object in order of group memory address
vfs/fsnotify: fsnotify_close can delay the final work in fput
fsnotify: store struct file not struct path
Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
The priority argument in fanotify is useless. Kill it.
Signed-off-by: Eric Paris <eparis@redhat.com>
This patch simply declares the new sys_fanotify_mark syscall
int fanotify_mark(int fanotify_fd, unsigned int flags, u64_mask,
int dfd const char *pathname)
This patch defines a new syscall fanotify_init() of the form:
int sys_fanotify_init(unsigned int flags, unsigned int event_f_flags,
unsigned int priority)
This syscall is used to create and fanotify group. This is very similar to
the inotify_init() syscall.
