path: root/include/linux/sunrpc
2009-09-23sunrpc: xdr_xcode_hyper helpers cannot presume 64-bit alignmentBenny Halevy
Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-15SUNRPC: Defer the auth_gss upcall when the RPC call is asynchronousTrond Myklebust
Otherwise, the upcall is going to be synchronous, which may not be what the caller wants... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-13nfsd41: sunrpc: add new xprt class for nfsv4.1 backchannelAlexandros Batsakis
[sunrpc: change idle timeout value for the backchannel] Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-11nfsd41: sunrpc: Added rpc server-side backchannel handlingRahul Iyer
When the call direction is a reply, copy the xid and call direction into the req->rq_private_buf.head[0].iov_base otherwise rpc_verify_header returns rpc_garbage. Signed-off-by: Rahul Iyer <iyer@netapp.com> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [get rid of CONFIG_NFSD_V4_1] [sunrpc: refactoring of svc_tcp_recvfrom] [nfsd41: sunrpc: create common send routine for the fore and the back channels] [nfsd41: sunrpc: Use free_page() to free server backchannel pages] [nfsd41: sunrpc: Document server backchannel locking] [nfsd41: sunrpc: remove bc_connect_worker()] [nfsd41: sunrpc: Define xprt_server_backchannel()[ [nfsd41: sunrpc: remove bc_close and bc_init_auto_disconnect dummy functions] [nfsd41: sunrpc: eliminate unneeded switch statement in xs_setup_tcp()] [nfsd41: sunrpc: Don't auto close the server backchannel connection] [nfsd41: sunrpc: Remove unused functions] Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: change bc_sock to bc_xprt] [nfsd41: sunrpc: move struct rpc_buffer def into a common header file] [nfsd41: sunrpc: use rpc_sleep in bc_send_request so not to block on mutex] [removed cosmetic changes] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [sunrpc: add new xprt class for nfsv4.1 backchannel] [sunrpc: v2.1 change handling of auto_close and init_auto_disconnect operations for the nfsv4.1 backchannel] Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> [reverted more cosmetic leftovers] [got rid of xprt_server_backchannel] [separated "nfsd41: sunrpc: add new xprt class for nfsv4.1 backchannel"] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Cc: Trond Myklebust <trond.myklebust@netapp.com> [sunrpc: change idle timeout value for the backchannel] Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Acked-by: Trond Myklebust <trond.myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-21nfsd: populate sin6_scope_id on callback address with scopeid from rq_addr ↵Jeff Layton
on SETCLIENTID call When a SETCLIENTID call comes in, one of the args given is the svc_rqst. This struct contains an rq_addr field which holds the address that sent the call. If this is an IPv6 address, then we can use the sin6_scope_id field in this address to populate the sin6_scope_id field in the callback address. AFAICT, the rq_addr.sin6_scope_id is non-zero if and only if the client mounted the server's link-local address. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-21sunrpc: add common routine for copying address portion of a sockaddrJeff Layton
2009-08-21sunrpc: add routine for comparing addressesJeff Layton
lockd needs these sort of routines, as does the NFSv4 callback code. Move lockd's routines into common code and rename them so that they can be used by others. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-21Merge branch 'nfs-for-2.6.32' of ↵J. Bruce Fields
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 into for-2.6.32-incoming Conflicts: net/sunrpc/cache.c
2009-08-20nfs: fix compile error in rpc_pipefs.hJ. Bruce Fields
This include is needed for the definition of delayed_work. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-19Merge branch 'nfsv4_xdr_cleanups-for-2.6.32' into nfs-for-2.6.32Trond Myklebust
Conflicts: fs/nfs/nfs4xdr.c
2009-08-14sunrpc: ntoh -> be*_to_cpuBenny Halevy
ntohl is already defined as be32_to_cpu. be64_to_cpu has architecture specific optimized implementations. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-14sunrpc: hton -> cpu_to_be*Benny Halevy
htonl is already defined as cpu_to_be32. cpu_to_be64 has architecture specific optimized implementations. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-10Merge branch 'sunrpc_cache-for-2.6.32' into nfs-for-2.6.32Trond Myklebust
2009-08-09SUNRPC: Add an rpc_pipefs front end for the sunrpc cache codeTrond Myklebust
2009-08-09SUNRPC: Move procfs-specific stuff out of the generic sunrpc cache codeTrond Myklebust
2009-08-09SUNRPC: Allow the cache_detail to specify alternative upcall mechanismsTrond Myklebust
For events that are rare, such as referral DNS lookups, it makes limited sense to have a daemon constantly listening for upcalls on a channel. An alternative in those cases might simply be to run the app that fills the cache using call_usermodehelper_exec() and friends. The following patch allows the cache_detail to specify alternative upcall mechanisms for these particular cases. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09NFSD: Clean up the idmapper warning...Trond Myklebust
What part of 'internal use' is so hard to understand? Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: clean up rpc_setup_pipedir()Trond Myklebust
There is still a little wart or two there: Since we've already got a vfsmount, we might as well pass that in to rpc_create_client_dir. Another point is that if we open code __rpc_lookup_path() here, then we can avoid looking up the entire parent directory path over and over again: it doesn't change. Also get rid of rpc_clnt->cl_pathname, since it has no users... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Replace rpc_client->cl_dentry and cl_mnt, with a cl_pathTrond Myklebust
2009-08-09SUNRPC: Rename rpc_mkdir to rpc_create_client_dir()Trond Myklebust
This reflects the fact that rpc_mkdir() as it stands today, can only create a RPC client type directory. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Constify rpc_pipe_ops...Trond Myklebust
2009-08-09SUNRPC: Kill RPC_DISPLAY_ALLChuck Lever
At some point, I recall that rpc_pipe_fs used RPC_DISPLAY_ALL. Currently there are no uses of RPC_DISPLAY_ALL outside the transport modules themselves, so we can safely get rid of it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Remove duplicate universal address generationChuck Lever
RPC universal address generation is currently done in several places: rpcb_clnt.c, nfs4proc.c xprtsock.c, and xprtrdma.c. Remove the redundant cases that convert a socket address to a universal address. The nfs4proc.c case takes a pre-formatted presentation address string, not a socket address, so we'll leave that one. Because the new uaddr constructor uses the recently introduced rpc_ntop(), it now supports proper "::" shorthanding for IPv6 addresses. This allows the kernel to register properly formed universal addresses with the local rpcbind service, in _all_ cases. The kernel can now also send properly formed universal addresses in RPCB_GETADDR requests, and support link-local properly when encoding and decoding IPv6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Provide functions for managing universal addressesChuck Lever
Introduce a set of functions in the kernel's RPC implementation for converting between a socket address and either a standard presentation address string or an RPC universal address. The universal address functions will be used to encode and decode RPCB_FOO and NFSv4 SETCLIENTID arguments. The other functions are part of a previous promise to deliver shared functions that can be used by upper-layer protocols to display and manipulate IP addresses. The kernel's current address printf formatters were designed specifically for kernel to user-space APIs that require a particular string format for socket addresses, thus are somewhat limited for the purposes of sunrpc.ko. The formatter for IPv6 addresses, %pI6, does not support short-handing or scope IDs. Also, these printf formatters are unique per address family, so a separate formatter string is required for printing AF_INET and AF_INET6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Clean up RPCBIND_MAXUADDRLEN definitionsChuck Lever
Clean up: Replace the single-integer definition of RPCBIND_MAXUADDRLEN with a definition that is based on previously defined address string sizes, and document the way this maximum is calculated. Also provide a separate macro for the size of the port number extension. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-07-14nfsd41: use globals for DRC limitsAndy Adamson
The version 4.1 DRC memory limit and tracking variables are server wide and session specific. Replace struct svc_serv fields with globals. Stop using the svc_serv sv_lock. Add a spinlock to serialize access to the DRC limit management variables which change on session creation and deletion (usage counter) or (future) administrative action to adjust the total DRC memory limit. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22Merge branch 'for-2.6.31' of git://fieldses.org/git/linux-nfsdLinus Torvalds
* 'for-2.6.31' of git://fieldses.org/git/linux-nfsd: (60 commits) SUNRPC: Fix the TCP server's send buffer accounting nfsd41: Backchannel: minorversion support for the back channel nfsd41: Backchannel: cleanup nfs4.0 callback encode routines nfsd41: Remove ip address collision detection case nfsd: optimise the starting of zero threads when none are running. nfsd: don't take nfsd_mutex twice when setting number of threads. nfsd41: sanity check client drc maxreqs nfsd41: move channel attributes from nfsd4_session to a nfsd4_channel_attr struct NFS: kill off complicated macro 'PROC' sunrpc: potential memory leak in function rdma_read_xdr nfsd: minor nfsd_vfs_write cleanup nfsd: Pull write-gathering code out of nfsd_vfs_write nfsd: track last inode only in use_wgather case sunrpc: align cache_clean work's timer nfsd: Use write gathering only with NFSv2 NFSv4: kill off complicated macro 'PROC' NFSv4: do exact check about attribute specified knfsd: remove unreported filehandle stats counters knfsd: fix reply cache memory corruption knfsd: reply cache cleanups ...
2009-06-17nfs41: Rename rq_received to rq_reply_bytes_recvdRicardo Labiaga
The 'rq_received' member of 'struct rpc_rqst' is used to track when we have received a reply to our request. With v4.1, the backchannel can now accept callback requests over the existing connection. Rename this field to make it clear that it is only used for tracking reply bytes and not all bytes received on the connection. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: sunrpc: add a struct svc_xprt pointer to struct svc_serv for ↵Andy Adamson
backchannel use This svc_xprt is passed on to the callback service thread to be later used to processes incoming svc_rqst's Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: sunrpc: provide functions to create and destroy a svc_xprt for ↵Benny Halevy
backchannel use For nfs41 callbacks we need an svc_xprt to process requests coming up the backchannel socket as rpc_rqst's that are transformed into svc_rqst's that need a rq_xprt to be processed. The svc_{udp,tcp}_create methods are too heavy for this job as svc_create_socket creates an actual socket to listen on while for nfs41 we're "reusing" the fore channel's socket. Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: Backchannel bc_svc_process()Ricardo Labiaga
Implement the NFSv4.1 backchannel service. Invokes the common callback processing logic svc_process_common() to authenticate the call and dispatch the appropriate NFSv4.1 XDR decoder and operation procedure. It then invokes bc_send() to send the reply over the same connection. bc_send() is implemented in a separate patch. At this time there is no slot validation or reply cache handling. [nfs41: Preallocate rpc_rqst receive buffer for handling callbacks] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Move bc_svc_process() declaration to correct patch] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: Backchannel callback service helper routinesRicardo Labiaga
Executes the backchannel task on the RPC state machine using the existing open connection previously established by the client. Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> nfs41: Add bc_svc.o to sunrpc Makefile. [nfs41: bc_send() does not need to be exported outside RPC module] [nfs41: xprt_free_bc_request() need not be exported outside RPC module] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Update copyright] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: Add backchannel processing support to RPC state machineRicardo Labiaga
Adds rpc_run_bc_task() which is called by the NFS callback service to process backchannel requests. It performs similar work to rpc_run_task() though "schedules" the backchannel task to be executed starting at the call_trasmit state in the RPC state machine. It also introduces some miscellaneous updates to the argument validation, call_transmit, and transport cleanup functions to take into account that there are now forechannel and backchannel tasks. Backchannel requests do not carry an RPC message structure, since the payload has already been XDR encoded using the existing NFSv4 callback mechanism. Introduce a new transmit state for the client to reply on to backchannel requests. This new state simply reserves the transport and issues the reply. In case of a connection related error, disconnects the transport and drops the reply. It requires the forechannel to re-establish the connection and the server to retransmit the request, as stated in NFSv4.1 section 2.9.2 "Client and Server Transport Behavior". Note: There is no need to loop attempting to reserve the transport. If EAGAIN is returned by xprt_prepare_transmit(), return with tk_status == 0, setting tk_action to call_bc_transmit. rpc_execute() will invoke it again after the task is taken off the sleep queue. [nfs41: rpc_run_bc_task() need not be exported outside RPC module] [nfs41: New call_bc_transmit RPC state] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: Backchannel: No need to loop in call_bc_transmit()] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [rpc_count_iostats incorrectly exits early] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Convert rpc_reply_expected() to inline function] [Remove unnecessary BUG_ON()] [Rename variable] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: New include/linux/sunrpc/bc_xprt.hRicardo Labiaga
Contains prototype for backchannel helper routines. Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: xprt_setup_backchannel v4.0 only inline] Fix compile error when CONFIG_NFS_V4_1 is not set. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Update Copyright notice and fix formatting] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: New backchannel helper routinesRicardo Labiaga
This patch introduces support to setup the callback xprt on the client side. It allocates/ destroys the preallocated memory structures used to process backchannel requests. At setup time, xprt_setup_backchannel() is invoked to allocate one or more rpc_rqst structures and substructures. This ensures that they are available when an RPC callback arrives. The rpc_rqst structures are maintained in a linked list attached to the rpc_xprt structure. We keep track of the number of allocations so that they can be correctly removed when the channel is destroyed. When an RPC callback arrives, xprt_alloc_bc_request() is invoked to obtain a preallocated rpc_rqst structure. An rpc_xprt structure is returned, and its RPC_BC_PREALLOC_IN_USE bit is set in rpc_xprt->bc_flags. The structure is removed from the the list since it is now in use, and it will be later added back when its user is done with it. After the RPC callback replies, the rpc_rqst structure is returned by invoking xprt_free_bc_request(). This clears the RPC_BC_PREALLOC_IN_USE bit and adds it back to the list, allowing it to be reused by a subsequent RPC callback request. To be consistent with the reception of RPC messages, the backchannel requests should be placed into the 'struct rpc_rqst' rq_rcv_buf, which is then in turn copied to the 'struct rpc_rqst' rq_private_buf. [nfs41: Preallocate rpc_rqst receive buffer for handling callbacks] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Update copyright notice and explain page allocation] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: client callback structuresRicardo Labiaga
Adds new list of rpc_xprt structures, and a readers/writers lock to protect the list. The list is used to preallocate resources for the backchannel during backchannel requests. Callbacks are not expected to cause significant latency, so only one callback will be allowed at this time. It also adds a pointer to the NFS callback service so that requests can be directed to it for processing. New callback members added to svc_serv. The NFSv4.1 callback service will sleep on the svc_serv->svc_cb_waitq until new callback requests arrive. The request will be queued in svc_serv->svc_cb_list. This patch adds this list, the sleep queue and spinlock to svc_serv. [nfs41: NFSv4.1 callback support] Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: sunrpc: Export the call prepare state for session resetAndy Adamson
Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-15Merge commit 'v2.6.30' into for-2.6.31J. Bruce Fields
2009-05-02SUNRPC: Fix the problem of EADDRNOTAVAIL syslog floods on reconnectTrond Myklebust
See http://bugzilla.kernel.org/show_bug.cgi?id=13034 If the port gets into a TIME_WAIT state, then we cannot reconnect without binding to a new port. Tested-by: Petr Vandrovec <petr@vandrovec.name> Tested-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-28SUNRPC: pass buffer size to svc_sock_names()Chuck Lever
Adjust the synopsis of svc_sock_names() to pass in the size of the output buffer. Add a documenting comment. This is a cosmetic change for now. A subsequent patch will make sure the buffer length is passed to one_sock_name(), where the length will actually be useful. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: pass buffer size to svc_addsock()Chuck Lever
Adjust the synopsis of svc_addsock() to pass in the size of the output buffer. Add a documenting comment. This is a cosmetic change for now. A subsequent patch will make sure the buffer length is passed to one_sock_name(), where the length will actually be useful. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Prevent a buffer overflow in svc_xprt_names()Chuck Lever
The svc_xprt_names() function can overflow its buffer if it's so near the end of the passed in buffer that the "name too long" string still doesn't fit. Of course, it could never tell if it was near the end of the passed in buffer, since its only caller passes in zero as the buffer length. Let's make this API a little safer. Change svc_xprt_names() so it *always* checks for a buffer overflow, and change its only caller to pass in the correct buffer length. If svc_xprt_names() does overflow its buffer, it now fails with an ENAMETOOLONG errno, instead of trying to write a message at the end of the buffer. I don't like this much, but I can't figure out a clean way that's always safe to return some of the names, *and* an indication that the buffer was not long enough. The displayed error when doing a 'cat /proc/fs/nfsd/portlist' is "File name too long". Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: Fix error return value of svc_addr_len()Chuck Lever
The svc_addr_len() helper function returns -EAFNOSUPPORT if it doesn't recognize the address family of the passed-in socket address. However, the return type of this function is size_t, which means -EAFNOSUPPORT is turned into a very large positive value in this case. The check in svc_udp_recvfrom() to see if the return value is less than zero therefore won't work at all. Additionally, handle_connect_req() passes this value directly to memset(). This could cause memset() to clobber a large chunk of memory if svc_addr_len() has returned an error. Currently the address family of these addresses, however, is known to be supported long before handle_connect_req() is called, so this isn't a real risk. Change the error return value of svc_addr_len() to zero, which fits in the range of size_t, and is safer to pass to memset() directly. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-06Merge branch 'for-2.6.30' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.30' of git://linux-nfs.org/~bfields/linux: (81 commits) nfsd41: define nfsd4_set_statp as noop for !CONFIG_NFSD_V4 nfsd41: define NFSD_DRC_SIZE_SHIFT in set_max_drc nfsd41: Documentation/filesystems/nfs41-server.txt nfsd41: CREATE_EXCLUSIVE4_1 nfsd41: SUPPATTR_EXCLCREAT attribute nfsd41: support for 3-word long attribute bitmask nfsd: dynamically skip encoded fattr bitmap in _nfsd4_verify nfsd41: pass writable attrs mask to nfsd4_decode_fattr nfsd41: provide support for minor version 1 at rpc level nfsd41: control nfsv4.1 svc via /proc/fs/nfsd/versions nfsd41: add OPEN4_SHARE_ACCESS_WANT nfs4_stateid bmap nfsd41: access_valid nfsd41: clientid handling nfsd41: check encode size for sessions maxresponse cached nfsd41: stateid handling nfsd: pass nfsd4_compound_state* to nfs4_preprocess_{state,seq}id_op nfsd41: destroy_session operation nfsd41: non-page DRC for solo sequence responses nfsd41: Add a create session replay cache nfsd41: create_session operation ...
2009-04-03nfsd41: hard page limit for DRCAndy Adamson
Use no more than 1/128th of the number of free pages at nfsd startup for the v4.1 DRC. This is an arbitrary default which should probably end up under the control of an administrator. Signed-off-by: Andy Adamson <andros@netapp.com> [moved added fields in struct svc_serv under CONFIG_NFSD_V4_1] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [fix set_max_drc calculation of sv_drc_max_pages] [moved NFSD_DRC_SIZE_SHIFT's declaration up in header file] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-03nfsd: don't use the deferral service, return NFS4ERR_DELAYAndy Adamson
On an NFSv4.1 server cache miss that causes an upcall, NFS4ERR_DELAY will be returned. It is up to the NFSv4.1 client to resend only the operations that have not been processed. Initialize rq_usedeferral to 1 in svc_process(). It sill be turned off in nfsd4_proc_compound() only when NFSv4.1 Sessions are used. Note: this isn't an adequate solution on its own. It's acceptable as a way to get some minimal 4.1 up and working, but we're going to have to find a way to avoid returning DELAY in all common cases before 4.1 can really be considered ready. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: reverse rq_nodeferral negative logic] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [sunrpc: initialize rq_usedeferral] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-03-28SUNRPC: Remove @family argument from svc_create() and svc_create_pooled()Chuck Lever
Since an RPC service listener's protocol family is specified now via svc_create_xprt(), it no longer needs to be passed to svc_create() or svc_create_pooled(). Remove that argument from the synopsis of those functions, and remove the sv_family field from the svc_serv struct. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Change svc_create_xprt() to take a @family argumentChuck Lever
The sv_family field is going away. Pass a protocol family argument to svc_create_xprt() instead of extracting the family from the passed-in svc_serv struct. Again, as this is a listener socket and not an address, we make this new argument an "int" protocol family, instead of an "sa_family_t." Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Pass a family argument to svc_register()Chuck Lever
The sv_family field is going away. Instead of using sv_family, have the svc_register() function take a protocol family argument. Since this argument represents a protocol family, and not an address family, this argument takes an int, as this is what is passed to sock_create_kern(). Also make sure svc_register's helpers are checking for PF_FOO instead of AF_FOO. The value of [AP]F_FOO are equivalent; this is simply a symbolic change to reflect the semantics of the value stored in that variable. sock_create_kern() should return EPFNOSUPPORT if the passed-in protocol family isn't supported, but it uses EAFNOSUPPORT for this case. We will stick with that tradition here, as svc_register() is called by the RPC server in the same path as sock_create_kern(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
