path: root/include/linux/sunrpc
2007-10-15Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (131 commits) NFSv4: Fix a typo in nfs_inode_reclaim_delegation NFS: Add a boot parameter to disable 64 bit inode numbers NFS: nfs_refresh_inode should clear cache_validity flags on success NFS: Fix a connectathon regression in NFSv3 and NFSv4 NFS: Use nfs_refresh_inode() in ops that aren't expected to change the inode SUNRPC: Don't call xprt_release in call refresh SUNRPC: Don't call xprt_release() if call_allocate fails SUNRPC: Fix buggy UDP transmission [23/37] Clean up duplicate includes in [2.6 patch] net/sunrpc/rpcb_clnt.c: make struct rpcb_program static SUNRPC: Use correct type in buffer length calculations SUNRPC: Fix default hostname created in rpc_create() nfs: add server port to rpc_pipe info file NFS: Get rid of some obsolete macros NFS: Simplify filehandle revalidation NFS: Ensure that nfs_link() returns a hashed dentry NFS: Be strict about dentry revalidation when doing exclusive create NFS: Don't zap the readdir caches upon error NFS: Remove the redundant nfs_reval_fsid() NFSv3: Always use directory post-op attributes in nfs3_proc_lookup ... Fix up trivial conflict due to sock_owned_by_user() cleanup manually in net/sunrpc/xprtsock.c
2007-10-09nfsd: remove unused cache_for_each macroJ. Bruce Fields
This macro is unused. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de>
2007-10-09RPCRDMA: rpc rdma transport switch\"Talpey, Thomas\
This implements the configuration and building of the core transport switch implementation of the rpcrdma transport. Stubs are provided for the rpcrdma protocol handling, and the infiniband/iwarp verbs interface. These are provided in following patches. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09RPCRDMA: Kconfig and header file with rpcrdma protocol definitions\"Talpey, Thomas\
This file implements the configuration target, protocol template and constants for the rpcrdma transport framing, for use by the xprtrdma rpc transport implementation. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS/SUNRPC: support transport protocol naming\"Talpey, Thomas\
To prepare for including non-sockets-based RPC transports, select RPC transports by an identifier (to be used in following patches). Signed-off-by: Tom Talpey <tmt@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09SUNRPC: rearrange RPC sockets definitions\"Talpey, Thomas\
To prepare for including non-sockets-based RPC transports, move the sockets-dependent definitions into their own file. Signed-off-by: Tom Talpey <tmt@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09SUNRPC: rename the rpc_xprtsock_create structure\"Talpey, Thomas\
To prepare for including non-sockets-based RPC transports, change the overly suggestive name of the transport creation arguments struct. Signed-off-by: Tom Talpey <tmt@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09SUNRPC: Provide a new API for registering transport implementations\"Talpey, Thomas\
To allow transport capabilities to be loaded dynamically, provide an API for registering and unregistering the transports with the RPC client. Eventually xprt_create_transport() will be changed to search the list of registered transports when initializing a fresh transport. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Tom Talpey <tmt@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09SUNRPC: mark bulk read/write data in xdrbuf\"Talpey, Thomas\
Adds a flag word to the xdrbuf struct which indicates any bulk disposition of the data. This enables RPC transport providers to marshal it efficiently/appropriately, and may enable other optimizations. Signed-off-by: Tom Talpey <tmt@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09SUNRPC: export per-transport rpcbind netid's\"Talpey, Thomas\
The rpcbind (v3+) netid is provided by each RPC client transport. This fixes an omission in IPv6 rpcbind client support, and enables future extension. Signed-off-by: Tom Talpey <tmt@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09SUNRPC: move per-transport rpcbind netid's\"Talpey, Thomas\
Move the TCP/UDP rpcbind netid's from the rpcbind client to a global header. Signed-off-by: Tom Talpey <tmt@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09SUNRPC: fix a signed v. unsigned comparison nit in rpc_bind_new_programChuck Lever
/home/cel/linux/net/sunrpc/clnt.c: In function ‘rpc_bind_new_program’: /home/cel/linux/net/sunrpc/clnt.c:445: warning: comparison between signed and unsigned RPC version numbers are u32, not int. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09SUNRPC: Add support for formatted universal addressesChuck Lever
"Universal addresses" are a string representation of an IP address and port. They are described fully in RFC 3530, section 2.2. Add support for generating them in the RPC client's socket transport module. Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
2007-10-09SUNRPC: Add hex-formatted address support to rpc_peeraddr2str()Chuck Lever
Add support for the NFS client's need to export volume information with IP addresses formatted in hex instead of decimal. This isn't used yet, but subsequent patches (not in this series) will change the NFS client to use this functionality. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-19SUNRPC: move bkl locking and xdr proc invocation into a common helperJ. Bruce Fields
Since every invocation of xdr encode or decode functions takes the BKL now, there's a lot of redundant lock_kernel/unlock_kernel pairs that we can pull out into a common function. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-17knfsd: nfsd4: secinfo handling without secinfo= optionJ. Bruce Fields
We could return some sort of error in the case where someone asks for secinfo on an export without the secinfo= option set--that'd be no worse than what we've been doing. But it's not really correct. So, hack up an approximate secinfo response in that case--it may not be complete, but it'll tell the client at least one acceptable security flavor. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd: set rq_client to ip-address-determined-domainJ. Bruce Fields
We want it to be possible for users to restrict exports both by IP address and by pseudoflavor. The pseudoflavor information has previously been passed using special auth_domains stored in the rq_client field. After the preceding patch that stored the pseudoflavor in rq_pflavor, that's now superfluous; so now we use rq_client for the ip information, as auth_null and auth_unix do. However, we keep around the special auth_domain in the rq_gssclient field for backwards compatibility purposes, so we can still do upcalls using the old "gss/pseudoflavor" auth_domain if upcalls using the unix domain to give us an appropriate export. This allows us to continue supporting old mountd. In fact, for this first patch, we always use the "gss/pseudoflavor" auth_domain (and only it) if it is available; thus rq_client is ignored in the auth_gss case, and this patch on its own makes no change in behavior; that will be left to later patches. Note on idmap: I'm almost tempted to just replace the auth_domain in the idmap upcall by a dummy value--no version of idmapd has ever used it, and it's unlikely anyone really wants to perform idmapping differently depending on the where the client is (they may want to perform *credential* mapping differently, but that's a different matter--the idmapper just handles id's used in getattr and setattr). But I'm updating the idmapd code anyway, just out of general backwards-compatibility paranoia. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd4: store pseudoflavor in requestAndy Adamson
Add a new field to the svc_rqst structure to record the pseudoflavor that the request was made with. For now we record the pseudoflavor but don't use it for anything. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10SUNRPC client: add interface for binding to a local addressFrank van Maarseveen
In addition to binding to a local privileged port the NFS client should allow binding to a specific local address. This is used by the server for callbacks. The patch adds the necessary interface. Signed-off-by: Frank van Maarseveen <frankvm@frankvm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC server: record the destination address of a requestFrank van Maarseveen
Save the destination address of an incoming request over TCP like is done already for UDP. It is necessary later for callbacks by the server. Signed-off-by: Frank van Maarseveen <frankvm@frankvm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: cleanup transport creation argument passingFrank van Maarseveen
Cleanup argument passing to functions for creating an RPC transport. Signed-off-by: Frank van Maarseveen <frankvm@frankvm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Rename rpcb_getport to be consistent with new rpcb_getport_sync nameChuck Lever
Clean up, for consistency. Rename rpcb_getport as rpcb_getport_async, to match the naming scheme of rpcb_getport_sync. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Rename rpcb_getport_external routineChuck Lever
In preparation for handling NFS mount option parsing in the kernel, rename rpcb_getport_external as rpcb_get_port_sync, and make it available always (instead of only when CONFIG_ROOT_NFS is enabled). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Remove the tk_auth macro...Trond Myklebust
We should almost always be deferencing the rpc_auth struct by means of the credential's cr_auth field instead of the rpc_clnt->cl_auth anyway. Fix up that historical mistake, and remove the macro that propagated it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Convert gss_ctx_lock to an RCU lockTrond Myklebust
2007-07-10SUNRPC: Convert the credential garbage collector into a shrinker callbackTrond Myklebust
2007-07-10SUNRPC: Give credential cache a local spinlockTrond Myklebust
2007-07-10SUNRPC: Convert the credcache lookup code to use RCUTrond Myklebust
2007-07-10SUNRPC: cleanup rpc credential cache garbage collectionTrond Myklebust
2007-07-10SUNRPC: Enforce atomic updates of rpc_cred->cr_flagsTrond Myklebust
Convert to the use of atomic bitops... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Clean up rpc credential initialisationTrond Myklebust
Add a helper rpc_cred_init() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Mark auth and cred operation tables as constant.Trond Myklebust
Also do the same for gss_api operation tables. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Rename rpcauth_destroy() to rpcauth_release()Trond Myklebust
2007-07-10SUNRPC: Add the helper function 'rpc_call_null()'Trond Myklebust
Does a NULL RPC call and returns a pointer to the resulting rpc_task. The call may be either synchronous or asynchronous. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Make rpc_ping() staticTrond Myklebust
2007-07-10SUNRPC: Fix a memory leak in the auth credcache codeTrond Myklebust
The leak only affects the RPCSEC_GSS caches, since they are the only ones that are dynamically allocated... Rename the existing rpcauth_free_credcache() to rpcauth_clear_credcache() in order to better describe its role, then add a new function rpcauth_destroy_credcache() that actually frees the cache in addition to clearing it out. Also move the call to destroy the credcache in gss_destroy() to come before the rpc upcall pipe is unlinked. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Add a field to track the number of kernel users of an rpc_pipeTrond Myklebust
This allows us to correctly deduce when we need to remove the pipe. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Add a downcall queue to struct rpc_inodeTrond Myklebust
Currently, the downcall queue is tied to the struct gss_auth, which means that different RPCSEC_GSS pseudoflavours must use different upcall pipes. Add a list to struct rpc_inode that can be used instead. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Add a backpointer from the struct rpc_cred to the rpc_authTrond Myklebust
Cleans up an issue whereby rpcsec_gss uses the rpc_clnt->cl_auth. If we want to be able to add several rpc_auths to a single rpc_clnt, then this abuse must go. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Move rpc_register_client and friends into net/sunrpc/clnt.cTrond Myklebust
2007-07-10SUNRPC: Remove rpc_clnt->cl_countTrond Myklebust
The kref now does most of what cl_count + cl_user used to do. The only remaining role for cl_count is to tell us if we are in a 'shutdown' phase. We can provide that information using a single bit field instead of a full atomic counter. Also rename rpc_destroy_client() to rpc_close_client(), which reflects better what its role is these days. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Kill rpc_clnt->cl_oneshotTrond Myklebust
Replace it with explicit calls to rpc_shutdown_client() or rpc_destroy_client() (for the case of asynchronous calls). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Kill rpc_clnt->cl_deadTrond Myklebust
Its use is at best racy, and there is only one user (lockd), which has additional locking that makes the whole thing redundant. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Convert rpc_clnt->cl_users to a krefTrond Myklebust
2007-07-10SUNRPC: Add a per-rpc_clnt spinlockTrond Myklebust
Use that to protect the rpc_clnt->cl_tasks list instead of using a global lock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Move rpc_task->tk_task list into struct rpc_clntTrond Myklebust
2007-07-10sendfile: convert nfsd to splice_direct_to_actor()Jens Axboe
2007-05-14SUNRPC: Fix sparse warningsTrond Myklebust
- net/sunrpc/xprtsock.c:1635:5: warning: symbol 'init_socket_xprt' was not declared. Should it be static? - net/sunrpc/xprtsock.c:1649:6: warning: symbol 'cleanup_socket_xprt' was not declared. Should it be static? Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09RPC: add wrapper for svc_reserve to account for checksumJeff Layton
When the kernel calls svc_reserve to downsize the expected size of an RPC reply, it fails to account for the possibility of a checksum at the end of the packet. If a client mounts a NFSv2/3 with sec=krb5i/p, and does I/O then you'll generally see messages similar to this in the server's ring buffer: RPC request reserved 164 but used 208 While I was never able to verify it, I suspect that this problem is also the root cause of some oopses I've seen under these conditions: https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=227726 This is probably also a problem for other sec= types and for NFSv4. The large reserved size for NFSv4 compound packets seems to generally paper over the problem, however. This patch adds a wrapper for svc_reserve that accounts for the possibility of a checksum. It also fixes up the appropriate callers of svc_reserve to call the wrapper. For now, it just uses a hardcoded value that I determined via testing. That value may need to be revised upward as things change, or we may want to eventually add a new auth_op that attempts to calculate this somehow. Unfortunately, there doesn't seem to be a good way to reliably determine the expected checksum length prior to actually calculating it, particularly with schemes like spkm3. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09knfsd: rename sk_defer_lock to sk_lockNeilBrown
Now that sk_defer_lock protects two different things, make the name more generic. Also don't bother with disabling _bh as the lock is only ever taken from process context. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
