path: root/include/linux/stop_machine.h
2011-10-31stop_machine.h: fix implicit use of smp.h for smp_processor_idPaul Gortmaker
This will show up on MIPS when we fix all the implicit header presences that are because of module.h being everywhere. In file included from kernel/trace/ftrace.c:16: include/linux/stop_machine.h: In function 'stop_one_cpu': include/linux/stop_machine.h:50: error: implicit declaration of function 'smp_processor_id' include/linux/stop_machine.h: In function 'stop_cpus': include/linux/stop_machine.h:80: error: implicit declaration of function 'raw_smp_processor_id' Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-06-27x86, mtrr: use stop_machine APIs for doing MTRR rendezvousSuresh Siddha
MTRR rendezvous sequence is not implemened using stop_machine() before, as this gets called both from the process context aswell as the cpu online paths (where the cpu has not come online and the interrupts are disabled etc). Now that we have a new stop_machine_from_inactive_cpu() API, use it for rendezvous during mtrr init of a logical processor that is coming online. For the rest (runtime MTRR modification, system boot, resume paths), use stop_machine() to implement the rendezvous sequence. This will consolidate and cleanup the code. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Link: http://lkml.kernel.org/r/20110623182057.076997177@sbsiddha-MOBL3.sc.intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-06-27stop_machine: implement stop_machine_from_inactive_cpu()Tejun Heo
Currently, mtrr wants stop_machine functionality while a CPU is being brought up. As stop_machine() requires the calling CPU to be active, mtrr implements its own stop_machine using stop_one_cpu() on each online CPU. This doesn't only unnecessarily duplicate complex logic but also introduces a possibility of deadlock when it races against the generic stop_machine(). This patch implements stop_machine_from_inactive_cpu() to serve such use cases. Its functionality is basically the same as stop_machine(); however, it should be called from a CPU which isn't active and doesn't depend on working scheduling on the calling CPU. This is achieved by using busy loops for synchronization and open-coding stop_cpus queuing and waiting with direct invocation of fn() for local CPU inbetween. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/20110623182056.982526827@sbsiddha-MOBL3.sc.intel.com Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-06-27x86, mtrr: lock stop machine during MTRR rendezvous sequenceSuresh Siddha
MTRR rendezvous sequence using stop_one_cpu_nowait() can potentially happen in parallel with another system wide rendezvous using stop_machine(). This can lead to deadlock (The order in which works are queued can be different on different cpu's. Some cpu's will be running the first rendezvous handler and others will be running the second rendezvous handler. Each set waiting for the other set to join for the system wide rendezvous, leading to a deadlock). MTRR rendezvous sequence is not implemented using stop_machine() as this gets called both from the process context aswell as the cpu online paths (where the cpu has not come online and the interrupts are disabled etc). stop_machine() works with only online cpus. For now, take the stop_machine mutex in the MTRR rendezvous sequence that gets called from an online cpu (here we are in the process context and can potentially sleep while taking the mutex). And the MTRR rendezvous that gets triggered during cpu online doesn't need to take this stop_machine lock (as the stop_machine() already ensures that there is no cpu hotplug going on in parallel by doing get_online_cpus()) TBD: Pursue a cleaner solution of extending the stop_machine() infrastructure to handle the case where the calling cpu is still not online and use this for MTRR rendezvous sequence. fixes: https://bugzilla.novell.com/show_bug.cgi?id=672008 Reported-by: Vadim Kotelnikov <vadimuzzz@inbox.ru> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Link: http://lkml.kernel.org/r/20110623182056.807230326@sbsiddha-MOBL3.sc.intel.com Cc: stable@kernel.org # 2.6.35+, backport a week or two after this gets more testing in mainline Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-06-20stop_machine.h: "disables preeempt" -> "disables preemption"Jonathan Neuschäfer
Use the noun instead of a misspelled verb. Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-14stopmachine: Define __stop_machine when CONFIG_STOP_MACHINE=nMasami Hiramatsu
Define dummy __stop_machine() function even when CONFIG_STOP_MACHINE=n. This getcpu-required version of stop_machine() will be used from poke_text_smp(). Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20101014031030.4100.34156.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-08cpu_stop: add dummy implementation for UPTejun Heo
When !CONFIG_SMP, cpu_stop functions weren't defined at all which could lead to build failures if UP code uses cpu_stop facility. Add dummy cpu_stop implementation for UP. The waiting variants execute the work function directly with preempt disabled and stop_one_cpu_nowait() schedules a workqueue work. Makefile and ifdefs around stop_machine implementation are updated to accomodate CONFIG_SMP && !CONFIG_STOP_MACHINE case. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Ingo Molnar <mingo@elte.hu>
2010-05-06stop_machine: reimplement using cpu_stopTejun Heo
Reimplement stop_machine using cpu_stop. As cpu stoppers are guaranteed to be available for all online cpus, stop_machine_create/destroy() are no longer necessary and removed. With resource management and synchronization handled by cpu_stop, the new implementation is much simpler. Asking the cpu_stop to execute the stop_cpu() state machine on all online cpus with cpu hotplug disabled is enough. stop_machine itself doesn't need to manage any global resources anymore, so all per-instance information is rolled into struct stop_machine_data and the mutex and all static data variables are removed. The previous implementation created and destroyed RT workqueues as necessary which made stop_machine() calls highly expensive on very large machines. According to Dimitri Sivanich, preventing the dynamic creation/destruction makes booting faster more than twice on very large machines. cpu_stop resources are preallocated for all online cpus and should have the same effect. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2010-05-06cpu_stop: implement stop_cpu[s]()Tejun Heo
Implement a simplistic per-cpu maximum priority cpu monopolization mechanism. A non-sleeping callback can be scheduled to run on one or multiple cpus with maximum priority monopolozing those cpus. This is primarily to replace and unify RT workqueue usage in stop_machine and scheduler migration_thread which currently is serving multiple purposes. Four functions are provided - stop_one_cpu(), stop_one_cpu_nowait(), stop_cpus() and try_stop_cpus(). This is to allow clean sharing of resources among stop_cpu and all the migration thread users. One stopper thread per cpu is created which is currently named "stopper/CPU". This will eventually replace the migration thread and take on its name. * This facility was originally named cpuhog and lived in separate files but Peter Zijlstra nacked the name and thus got renamed to cpu_stop and moved into stop_machine.c. * Better reporting of preemption leak as per Peter's suggestion. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2009-01-05stop_machine: introduce stop_machine_create/destroy.Heiko Carstens
Introduce stop_machine_create/destroy. With this interface subsystems that need a non-failing stop_machine environment can create the stop_machine machine threads before actually calling stop_machine. When the threads aren't needed anymore they can be killed with stop_machine_destroy again. When stop_machine gets called and the threads aren't present they will be created and destroyed automatically. This restores the old behaviour of stop_machine. This patch also converts cpu hotplug to the new interface since it is special: cpu_down calls __stop_machine instead of stop_machine. However the kstop threads will only be created when stop_machine gets called. Changing the code so that the threads would be created automatically on __stop_machine is currently not possible: when __stop_machine gets called we hold cpu_add_remove_lock, which is the same lock that create_rt_workqueue would take. So the workqueue needs to be created before the cpu hotplug code locks cpu_add_remove_lock. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-01cpumask: convert rest of files in kernel/Rusty Russell
Impact: Reduce stack usage, use new cpumask API. Mainly changing cpumask_t to 'struct cpumask' and similar simple API conversion. Two conversions worth mentioning: 1) we use cpumask_any_but to avoid a temporary in kernel/softlockup.c, 2) Use cpumask_var_t in taskstats_user_cmd(). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@redhat.com>
2008-08-26stop_machine: Remove deprecated stop_machine_runRusty Russell
Everyone should be using stop_machine() now. The staged API transition helped life in linux-next. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-28stop_machine(): stop_machine_run() changed to use cpu maskRusty Russell
Instead of a "cpu" arg with magic values NR_CPUS (any cpu) and ~0 (all cpus), pass a cpumask_t. Allow NULL for the common case (where we don't care which CPU the function is run on): temporary cpumask_t's are usually considered bad for stack space. This deprecates stop_machine_run, to be removed soon when all the callers are dead. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-28Simplify stop_machineRusty Russell
stop_machine creates a kthread which creates kernel threads. We can create those threads directly and simplify things a little. Some care must be taken with CPU hotunplug, which has special needs, but that code seems more robust than it was in the past. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
2008-07-28stop_machine: add ALL_CPUS optionJason Baron
-allow stop_mahcine_run() to call a function on all cpus. Calling stop_machine_run() with a 'ALL_CPUS' invokes this new behavior. stop_machine_run() proceeds as normal until the calling cpu has invoked 'fn'. Then, we tell all the other cpus to call 'fn'. Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> CC: Adrian Bunk <bunk@stusta.de> CC: Andi Kleen <andi@firstfloor.org> CC: Alexey Dobriyan <adobriyan@gmail.com> CC: Christoph Hellwig <hch@infradead.org> CC: mingo@elte.hu CC: akpm@osdl.org
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
