path: root/include/linux/smp_lock.h
2008-01-25sched: remove the !PREEMPT_BKL codeIngo Molnar
remove the !PREEMPT_BKL code. this removes 160 lines of legacy code. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-16Remove unnecessary includes of spinlock.h under include/linuxRobert P. J. Day
Remove the obviously unnecessary includes of <linux/spinlock.h> under the include/linux/ directory, and fix the couple errors that are introduced as a result of that. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-11-13[PATCH] m68k: thread_info header cleanupAl Viro
a) in smp_lock.h #include of sched.h and spinlock.h moved under #ifdef CONFIG_LOCK_KERNEL. b) interrupt.h now explicitly pulls sched.h (not via smp_lock.h from hardirq.h as it used to) c) in three more places we need changes to compensate for (a) - one place in arch/sparc needs string.h now, hardirq.h needs forward declaration of task_struct and preempt.h needs direct include of thread_info.h. d) thread_info-related helpers in sched.h and thread_info.h put under ifndef __HAVE_THREAD_FUNCTIONS. Obviously safe. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
