path: root/include/linux/skbuff.h
2005-07-08[NET]: Fix sparse warningsVictor Fusco
From: Victor Fusco <victor@cetuc.puc-rio.br> Fix the sparse warning "implicit cast to nocast type" Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-05[NET]: Reduce size of sk_buff by 4 bytesThomas Graf
Reduce local_df to a bit field and ip_summed to a 2 bits field thus saving 13 bits. Move bit fields, packet type, and protocol into the spare area between the priority and the destructor. Saves 4 bytes on both, 32bit and 64bit architectures. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-05[NET]: Remove unused security member in sk_buffThomas Graf
2005-07-05[NET]: Fix signedness issues in net/core/filter.cPatrick McHardy
This is the code to load packet data into a register: k = fentry->k; if (k < 0) { ... } else { u32 _tmp, *p; p = skb_header_pointer(skb, k, 4, &_tmp); if (p != NULL) { A = ntohl(*p); continue; } } skb_header_pointer checks if the requested data is within the linear area: int hlen = skb_headlen(skb); if (offset + len <= hlen) return skb->data + offset; When offset is within [INT_MAX-len+1..INT_MAX] the addition will result in a negative number which is <= hlen. I couldn't trigger a crash on my AMD64 with 2GB of memory, but a coworker tried on his x86 machine and it crashed immediately. This patch fixes the check in skb_header_pointer to handle large positive offsets similar to skb_copy_bits. Invalid data can still be accessed using negative offsets (also similar to skb_copy_bits), anyone using negative offsets needs to verify them himself. Thanks to Thomas Vögtle <thomas.voegtle@coreworks.de> for verifying the problem by crashing his machine and providing me with an Oops. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[NET]: skb_find_text() - Find a text pattern in skb dataThomas Graf
Finds a pattern in the skb data according to the specified textsearch configuration. Use textsearch_next() to retrieve subsequent occurrences of the pattern. Returns the offset to the first occurrence or UINT_MAX if no match was found. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[NET]: Zerocopy sequential reading of skb dataThomas Graf
Implements sequential reading for both linear and non-linear skb data at zerocopy cost. The data is returned in chunks of arbitary length, therefore random access is not possible. Usage: from := 0 to := 128 state := undef data := undef len := undef consumed := 0 skb_prepare_seq_read(skb, from, to, &state) while (len = skb_seq_read(consumed, &data, &state)) != 0 do /* do something with 'data' of length 'len' */ if abort then /* abort read if we don't wait for * skb_seq_read() to return 0 */ skb_abort_seq_read(&state) return endif /* not necessary to consume all of 'len' */ consumed += len done Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[NETFILTER]: Kill nf_debugPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-01[PATCH] DocBook: fix some descriptionsMartin Waitz
Some KernelDoc descriptions are updated to match the current code. No code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: changes and extensions to the kernel documentationPavel Pisa
I have recompiled Linux kernel 2.6.11.5 documentation for me and our university students again. The documentation could be extended for more sources which are equipped by structured comments for recent 2.6 kernels. I have tried to proceed with that task. I have done that more times from 2.6.0 time and it gets boring to do same changes again and again. Linux kernel compiles after changes for i386 and ARM targets. I have added references to some more files into kernel-api book, I have added some section names as well. So please, check that changes do not break something and that categories are not too much skewed. I have changed kernel-doc to accept "fastcall" and "asmlinkage" words reserved by kernel convention. Most of the other changes are modifications in the comments to make kernel-doc happy, accept some parameters description and do not bail out on errors. Changed <pid> to @pid in the description, moved some #ifdef before comments to correct function to comments bindings, etc. You can see result of the modified documentation build at http://cmp.felk.cvut.cz/~pisa/linux/lkdb-2.6.11.tar.gz Some more sources are ready to be included into kernel-doc generated documentation. Sources has been added into kernel-api for now. Some more section names added and probably some more chaos introduced as result of quick cleanup work. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[NET]: skbuff: remove old NET_CALLER macroStephen Hemminger
Here is a revised alternative that uses BUG_ON/WARN_ON (as suggested by Herbert Xu) to eliminate NET_CALLER. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-19[IPV6]: IPV6_CHECKSUM socket option can corrupt kernel memoryHerbert Xu
So here is a patch that introduces skb_store_bits -- the opposite of skb_copy_bits, and uses them to read/write the csum field in rawv6. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
