path: root/include/linux/skbuff.h
2005-10-28[IPv4/IPv6]: UFO Scatter-gather approachAnanda Raju
Attached is kernel patch for UDP Fragmentation Offload (UFO) feature. 1. This patch incorporate the review comments by Jeff Garzik. 2. Renamed USO as UFO (UDP Fragmentation Offload) 3. udp sendfile support with UFO This patches uses scatter-gather feature of skb to generate large UDP datagram. Below is a "how-to" on changes required in network device driver to use the UFO interface. UDP Fragmentation Offload (UFO) Interface: ------------------------------------------- UFO is a feature wherein the Linux kernel network stack will offload the IP fragmentation functionality of large UDP datagram to hardware. This will reduce the overhead of stack in fragmenting the large UDP datagram to MTU sized packets 1) Drivers indicate their capability of UFO using dev->features |= NETIF_F_UFO | NETIF_F_HW_CSUM | NETIF_F_SG NETIF_F_HW_CSUM is required for UFO over ipv6. 2) UFO packet will be submitted for transmission using driver xmit routine. UFO packet will have a non-zero value for "skb_shinfo(skb)->ufo_size" skb_shinfo(skb)->ufo_size will indicate the length of data part in each IP fragment going out of the adapter after IP fragmentation by hardware. skb->data will contain MAC/IP/UDP header and skb_shinfo(skb)->frags[] contains the data payload. The skb->ip_summed will be set to CHECKSUM_HW indicating that hardware has to do checksum calculation. Hardware should compute the UDP checksum of complete datagram and also ip header checksum of each fragmented IP packet. For IPV6 the UFO provides the fragment identification-id in skb_shinfo(skb)->ip6_frag_id. The adapter should use this ID for generating IPv6 fragments. Signed-off-by: Ananda Raju <ananda.raju@neterion.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (forwarded) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[SK_BUFF] kernel-doc: fix skbuff warningsRandy Dunlap
Add kernel-doc to skbuff.h, skbuff.c to eliminate kernel-doc warnings. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-03[NET]: Fix packet timestamping.Herbert Xu
I've found the problem in general. It affects any 64-bit architecture. The problem occurs when you change the system time. Suppose that when you boot your system clock is forward by a day. This gets recorded down in skb_tv_base. You then wind the clock back by a day. From that point onwards the offset will be negative which essentially overflows the 32-bit variables they're stored in. In fact, why don't we just store the real time stamp in those 32-bit variables? After all, we're not going to overflow for quite a while yet. When we do overflow, we'll need a better solution of course. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-08[NET]: Optimize pskb_trim_rcsum()Stephen Hemminger
Since packets almost never contain extra garbage at the end, it is worthwhile to optimize for that case. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-06[NET]: skb_get/set_timestamp use constStephen Hemminger
The new timestamp get/set routines should have const attribute on parameters (helps to indicate direction). Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Implement SKB fast cloning.David S. Miller
Protocols that make extensive use of SKB cloning, for example TCP, eat at least 2 allocations per packet sent as a result. To cut the kmalloc() count in half, we implement a pre-allocation scheme wherein we allocate 2 sk_buff objects in advance, then use a simple reference count to free up the memory at the correct time. Based upon an initial patch by Thomas Graf and suggestions from Herbert Xu. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Store skb->timestamp as offset to a base timestampPatrick McHardy
Reduces skb size by 8 bytes on 64-bit. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Reduce tc_index/tc_verd to u16Patrick McHardy
2005-08-29[NET]: Remove HIPPI private from skbuff.hStephen Hemminger
This removes the private element from skbuff, that is only used by HIPPI. Instead it uses skb->cb[] to hold the additional data that is needed in the output path from hard_header to device driver. PS: The only qdisc that might potentially corrupt this cb[] is if netem was used over HIPPI. I will take care of that by fixing netem to use skb->stamp. I don't expect many users of netem over HIPPI Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->tc_classidPatrick McHardy
2005-08-29[NET]: Kill skb->listDavid S. Miller
Remove the "list" member of struct sk_buff, as it is entirely redundant. All SKB list removal callers know which list the SKB is on, so storing this in sk_buff does nothing other than taking up some space. Two tricky bits were SCTP, which I took care of, and two ATM drivers which Francois Romieu <romieu@fr.zoreil.com> fixed up. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-08-29[NETFILTER]: reduce netfilter sk_buff enlargementHarald Welte
As discussed at netconf'05, we're trying to save every bit in sk_buff. The patch below makes sk_buff 8 bytes smaller. I did some basic testing on my notebook and it seems to work. The only real in-tree user of nfcache was IPVS, who only needs a single bit. Unfortunately I couldn't find some other free bit in sk_buff to stuff that bit into, so I introduced a separate field for them. Maybe the IPVS guys can resolve that to further save space. Initially I wanted to shrink pkt_type to three bits (PACKET_HOST and alike are only 6 values defined), but unfortunately the bluetooth code overloads pkt_type :( The conntrack-event-api (out-of-tree) uses nfcache, but Rusty just came up with a way how to do it without any skb fields, so it's safe to remove it. - remove all never-implemented 'nfcache' code - don't have ipvs code abuse 'nfcache' field. currently get's their own compile-conditional skb->ipvs_property field. IPVS maintainers can decide to move this bit elswhere, but nfcache needs to die. - remove skb->nfcache field to save 4 bytes - move skb->nfctinfo into three unused bits to save further 4 bytes Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: convert nfmark and conntrack mark to 32bitHarald Welte
As discussed at netconf'05, we convert nfmark and conntrack-mark to be 32bits even on 64bit architectures. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-11[NET]: Make skb->protocol __be16Alexey Dobriyan
There are many instances of skb->protocol = htons(ETH_P_*); skb->protocol = __constant_htons(ETH_P_*); and skb->protocol = *_type_trans(...); Most of *_type_trans() are already endian-annotated, so, let's shift attention on other warnings. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-18[NET]: Fix "nocast type" warnings in skbuff.hVictor Fusco
From: Victor Fusco <victor@cetuc.puc-rio.br> Fix the sparse warning "implicit cast to nocast type" Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-08[NET]: Fix sparse warningsVictor Fusco
2005-07-05[NET]: Reduce size of sk_buff by 4 bytesThomas Graf
Reduce local_df to a bit field and ip_summed to a 2 bits field thus saving 13 bits. Move bit fields, packet type, and protocol into the spare area between the priority and the destructor. Saves 4 bytes on both, 32bit and 64bit architectures. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-05[NET]: Remove unused security member in sk_buffThomas Graf
2005-07-05[NET]: Fix signedness issues in net/core/filter.cPatrick McHardy
This is the code to load packet data into a register: k = fentry->k; if (k < 0) { ... } else { u32 _tmp, *p; p = skb_header_pointer(skb, k, 4, &_tmp); if (p != NULL) { A = ntohl(*p); continue; } } skb_header_pointer checks if the requested data is within the linear area: int hlen = skb_headlen(skb); if (offset + len <= hlen) return skb->data + offset; When offset is within [INT_MAX-len+1..INT_MAX] the addition will result in a negative number which is <= hlen. I couldn't trigger a crash on my AMD64 with 2GB of memory, but a coworker tried on his x86 machine and it crashed immediately. This patch fixes the check in skb_header_pointer to handle large positive offsets similar to skb_copy_bits. Invalid data can still be accessed using negative offsets (also similar to skb_copy_bits), anyone using negative offsets needs to verify them himself. Thanks to Thomas Vögtle <thomas.voegtle@coreworks.de> for verifying the problem by crashing his machine and providing me with an Oops. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[NET]: skb_find_text() - Find a text pattern in skb dataThomas Graf
Finds a pattern in the skb data according to the specified textsearch configuration. Use textsearch_next() to retrieve subsequent occurrences of the pattern. Returns the offset to the first occurrence or UINT_MAX if no match was found. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[NET]: Zerocopy sequential reading of skb dataThomas Graf
Implements sequential reading for both linear and non-linear skb data at zerocopy cost. The data is returned in chunks of arbitary length, therefore random access is not possible. Usage: from := 0 to := 128 state := undef data := undef len := undef consumed := 0 skb_prepare_seq_read(skb, from, to, &state) while (len = skb_seq_read(consumed, &data, &state)) != 0 do /* do something with 'data' of length 'len' */ if abort then /* abort read if we don't wait for * skb_seq_read() to return 0 */ skb_abort_seq_read(&state) return endif /* not necessary to consume all of 'len' */ consumed += len done Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[NETFILTER]: Kill nf_debugPatrick McHardy
2005-05-01[PATCH] DocBook: fix some descriptionsMartin Waitz
Some KernelDoc descriptions are updated to match the current code. No code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: changes and extensions to the kernel documentationPavel Pisa
I have recompiled Linux kernel 2.6.11.5 documentation for me and our university students again. The documentation could be extended for more sources which are equipped by structured comments for recent 2.6 kernels. I have tried to proceed with that task. I have done that more times from 2.6.0 time and it gets boring to do same changes again and again. Linux kernel compiles after changes for i386 and ARM targets. I have added references to some more files into kernel-api book, I have added some section names as well. So please, check that changes do not break something and that categories are not too much skewed. I have changed kernel-doc to accept "fastcall" and "asmlinkage" words reserved by kernel convention. Most of the other changes are modifications in the comments to make kernel-doc happy, accept some parameters description and do not bail out on errors. Changed <pid> to @pid in the description, moved some #ifdef before comments to correct function to comments bindings, etc. You can see result of the modified documentation build at http://cmp.felk.cvut.cz/~pisa/linux/lkdb-2.6.11.tar.gz Some more sources are ready to be included into kernel-doc generated documentation. Sources has been added into kernel-api for now. Some more section names added and probably some more chaos introduced as result of quick cleanup work. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[NET]: skbuff: remove old NET_CALLER macroStephen Hemminger
Here is a revised alternative that uses BUG_ON/WARN_ON (as suggested by Herbert Xu) to eliminate NET_CALLER. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-19[IPV6]: IPV6_CHECKSUM socket option can corrupt kernel memoryHerbert Xu
So here is a patch that introduces skb_store_bits -- the opposite of skb_copy_bits, and uses them to read/write the csum field in rawv6. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
