path: root/include/linux/signal.h
2008-04-30kill_pid_info: don't take now unneeded tasklist_lockOleg Nesterov
Previously handle_stop_signal(SIGCONT) could drop ->siglock. That is why kill_pid_info(SIGCONT) takes tasklist_lock to make sure the target task can't go away after unlock. Not needed now. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08fix group stop with exit raceOleg Nesterov
do_signal_stop() counts all sub-thread and sets ->group_stop_count accordingly. Every thread should decrement ->group_stop_count and stop, the last one should notify the parent. However a sub-thread can exit before it notices the signal_pending(), or it may be somewhere in do_exit() already. In that case the group stop never finishes properly. Note: this is a minimal fix, we can add some optimizations later. Say we can return quickly if thread_group_empty(). Also, we can move some signal related code from exit_notify() to exit_signals(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06proper prototype for signals_init()Adrian Bunk
Add a proper prototype for signals_init() in include/linux/signal.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-22x86: i386-show-unhandled-signals-v3Masoud Asgharifard Sharbiani
This patch makes the i386 behave the same way that x86_64 does when a segfault happens. A line gets printed to the kernel log so that tools that need to check for failures can behave more uniformly between debug.show_unhandled_signals sysctl variable to 0 (or by doing echo 0 > /proc/sys/debug/exception-trace) Also, all of the lines being printed are now using printk_ratelimit() to deny the ability of DoS from a local user with a program like the following: main() { while (1) if (!fork()) *(int *)0 = 0; } This new revision also includes the fix that Andrew did which got rid of new sysctl that was added to the system in earlier versions of this. Also, 'show-unhandled-signals' sysctl has been renamed back to the old 'exception-trace' to avoid breakage of people's scripts. AK: Enabling by default for i386 will be likely controversal, but let's see what happens AK: Really folks, before complaining just fix your segfaults AK: I bet this will find a lot of silent issues Signed-off-by: Masoud Sharbiani <masouds@google.com> Signed-off-by: Andi Kleen <ak@suse.de> [ Personally, I've found the complaints useful on x86-64, so I'm all for this. That said, I wonder if we could do it more prettily.. -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Remove unnecessary includes of spinlock.h under include/linuxRobert P. J. Day
Remove the obviously unnecessary includes of <linux/spinlock.h> under the include/linux/ directory, and fix the couple errors that are introduced as a result of that. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11signal/timer/event: signalfd coreDavide Libenzi
This patch series implements the new signalfd() system call. I took part of the original Linus code (and you know how badly it can be broken :), and I added even more breakage ;) Signals are fetched from the same signal queue used by the process, so signalfd will compete with standard kernel delivery in dequeue_signal(). If you want to reliably fetch signals on the signalfd file, you need to block them with sigprocmask(SIG_BLOCK). This seems to be working fine on my Dual Opteron machine. I made a quick test program for it: http://www.xmailserver.org/signafd-test.c The signalfd() system call implements signal delivery into a file descriptor receiver. The signalfd file descriptor if created with the following API: int signalfd(int ufd, const sigset_t *mask, size_t masksize); The "ufd" parameter allows to change an existing signalfd sigmask, w/out going to close/create cycle (Linus idea). Use "ufd" == -1 if you want a brand new signalfd file. The "mask" allows to specify the signal mask of signals that we are interested in. The "masksize" parameter is the size of "mask". The signalfd fd supports the poll(2) and read(2) system calls. The poll(2) will return POLLIN when signals are available to be dequeued. As a direct consequence of supporting the Linux poll subsystem, the signalfd fd can use used together with epoll(2) too. The read(2) system call will return a "struct signalfd_siginfo" structure in the userspace supplied buffer. The return value is the number of bytes copied in the supplied buffer, or -1 in case of error. The read(2) call can also return 0, in case the sighand structure to which the signalfd was attached, has been orphaned. The O_NONBLOCK flag is also supported, and read(2) will return -EAGAIN in case no signal is available. If the size of the buffer passed to read(2) is lower than sizeof(struct signalfd_siginfo), -EINVAL is returned. A read from the signalfd can also return -ERESTARTSYS in case a signal hits the process. The format of the struct signalfd_siginfo is, and the valid fields depends of the (->code & __SI_MASK) value, in the same way a struct siginfo would: struct signalfd_siginfo { __u32 signo; /* si_signo */ __s32 err; /* si_errno */ __s32 code; /* si_code */ __u32 pid; /* si_pid */ __u32 uid; /* si_uid */ __s32 fd; /* si_fd */ __u32 tid; /* si_fd */ __u32 band; /* si_band */ __u32 overrun; /* si_overrun */ __u32 trapno; /* si_trapno */ __s32 status; /* si_status */ __s32 svint; /* si_int */ __u64 svptr; /* si_ptr */ __u64 utime; /* si_utime */ __u64 stime; /* si_stime */ __u64 addr; /* si_addr */ }; [akpm@linux-foundation.org: fix signalfd_copyinfo() on i386] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Move sig_kernel_* et al macros to linux/signal.hRoland McGrath
This patch moves the sig_kernel_* and related macros from kernel/signal.c to linux/signal.h, and cleans them up slightly. I need the sig_kernel_* macros for default signal behavior in the utrace code, and want to avoid duplication or overhead to share the knowledge. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] Move sighand_cachep to include/signal.hChristoph Lameter
Move sighand_cachep definitioni to linux/signal.h The sighand cache is only used in fs/exec.c and kernel/fork.c. It is defined in kernel/fork.c but only used in fs/exec.c. The sighand_cachep is related to signal processing. So add the definition to signal.h. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: consolidate flags for request_irqThomas Gleixner
The recent interrupt rework introduced bit value conflicts with sparc. Instead of introducing new architecture flags mess, move the interrupt SA_ flags out of the signal namespace and replace them by interrupt related flags. This allows to remove the obsolete SA_INTERRUPT flag and clean up the bit field values. This patch: Move the interrupt related SA_ flags out of linux/signal.h and rename them to IRQF_ . This moves the interrupt related flags out of the signal namespace and allows to remove the architecture dependencies. SA_INTERRUPT is not needed by userspace and glibc so it can be removed safely. The existing SA_ constants are kept for easy transition and will be removed after a 6 month grace period. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Greg KH <greg@kroah.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Jeff Garzik <jeff@garzik.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Karsten Keil <kkeil@suse.de> Cc: Jody McIntyre <scjody@modernduck.com> Cc: Ben Collins <bcollins@debian.org> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Dave Airlie <airlied@linux.ie> Cc: Jens Axboe <axboe@suse.de> Cc: Chris Zankel <chris@zankel.net> Cc: Andi Kleen <ak@muc.de> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: David Howells <dhowells@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6David Woodhouse
2006-04-28[PATCH] request_irq(): remove warnings from irq probingAndrew Morton
- Add new SA_PROBEIRQ which suppresses the new sharing-mismatch warning. Some drivers like to use request_irq() to find an unused interrupt slot. - Use it in i82365.c - Kill unused SA_PROBE. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-25Don't include private headers from user-visible part of linux/signal.hDavid Woodhouse
2006-03-28[PATCH] move __exit_signal() to kernel/exit.cOleg Nesterov
__exit_signal() is private to release_task() now. I think it is better to make it static in kernel/exit.c and export flush_sigqueue() instead - this function is much more simple and straightforward. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] sigaction should clear all signals on SIG_IGN, not just < 32George Anzinger
While rooting aroung in the signal code trying to understand how to fix the SIG_IGN ploy (set sig handler to SIG_IGN and flood system with high speed repeating timers) I came across what, I think, is a problem in sigaction() in that when processing a SIG_IGN request it flushes signals from 1 to SIGRTMIN and leaves the rest. Attempt to fix this. Signed-off-by: George Anzinger <george@mvista.com> Cc: Roland McGrath <roland@redhat.com> Cc: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] IRQ type flagsRussell King
Some ARM platforms have the ability to program the interrupt controller to detect various interrupt edges and/or levels. For some platforms, this is critical to setup correctly, particularly those which the setting is dependent on the device. Currently, ARM drivers do (eg) the following: err = request_irq(irq, ...); set_irq_type(irq, IRQT_RISING); However, if the interrupt has previously been programmed to be level sensitive (for whatever reason) then this will cause an interrupt storm. Hence, if we combine set_irq_type() with request_irq(), we can then safely set the type prior to unmasking the interrupt. The unfortunate problem is that in order to support this, these flags need to be visible outside of the ARM architecture - drivers such as smc91x need these flags and they're cross-architecture. Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the property that the device would like. The IRQ controller code should do its best to select the most appropriate supported mode. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] kill sigqueue->lockOleg Nesterov
This lock is used in sigqueue_free(), but it is always equal to current->sighand->siglock, so we don't need to keep it in the struct sigqueue. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-12[PATCH] Remove obsolete HAVE_ARCH_GET_SIGNAL_TO_DELIVER?Geert Uytterhoeven
Now m68k no longer sets HAVE_ARCH_GET_SIGNAL_TO_DELIVER, can it be removed completely? Or may ARM26 still need it? Note that its usage was removed from kernel/signal.c about 2 months ago. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] new valid_signal() functionJesper Juhl
This patch adds a new function valid_signal() that tests if its argument is a valid signal number. The reasons for adding this new function are: - some code currently testing _NSIG directly has off-by-one errors. Using this function instead avoids such errors. - some code currently tests unsigned signal numbers for <0 which is pointless and generates warnings when building with gcc -W. Using this function instead avoids such warnings. I considered various places to add this function but eventually settled on include/linux/signal.h as the most logical place for it. If there's some reason this is a bad choice then please let me know (hints as to a better location are then welcome of course). Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] move SA_xxx defines to linux/signal.hStas Sergeev
The attached patch moves the IRQ-related SA_xxx flags (namely, SA_PROBE, SA_SAMPLE_RANDOM and SA_SHIRQ) from all the arch-specific headers to linux/signal.h. This looks like a left-over after the irq-handling code was consolidated. The code was moved to kernel/irq/*, but the flags are still left per-arch. Right now, adding a new IRQ flag to the arch-specific header, like this patch does: http://cvs.sourceforge.net/viewcvs.py/*checkout*/alsa/alsa-driver/utils/patches/pcsp-kernel-2.6.10-03.diff?rev=1.1 no longer works, it breaks the compilation for all other arches, unless you add that flag to all the other arch-specific headers too. So I think such a clean-up makes sense. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
