path: root/include/linux/sht15.h
2012-09-23hwmon: (sht15) move header to linux/platform_data/Vivien Didelot
This patch moves the sht15.h header from include/linux to include/linux/platform_data, and update existing support (stargate2 platform) accordingly. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2011-05-19hwmon: (sht15) add support for CRC validationJerome Oufella
The sht15 sensor allows validating exchanges to and from the device using a crc8 function. An utility function to reverse a byte has also been added. Signed-off-by: Jerome Oufella <jerome.oufella@savoirfairelinux.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-05-19hwmon: (sht15) add support for the status registerVivien Didelot
* Add support for: - Heater. - End of battery notice. - Ability not to reload from OTP. - Low resolution (12bit temp, 8bit humidity). * Add an utility function to read individual bytes from the device. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-05-19hwmon: (sht15) general code clean-upVivien Didelot
* Add a documentation file for the device. * Respect a bit more the kernel-doc syntax. * Rename some variables for clarity. * Use bool type for flags. * Use an enum for states (actions being done). Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2009-04-13hwmon: sht15 humidity sensor driverJonathan Cameron
Data sheet at: http://www.sensirion.ch/en/pdf/product_information/Datasheet-humidity-sensor-SHT1x.pdf These sensors communicate over a 2 wire bus running a device specific protocol. The complexity of the driver is mainly due to handling the substantial delays between requesting a reading and the device pulling the data line low to indicate that the data is available. This is handled by an interrupt that is disabled under all other conditions. I wasn't terribly clear on the best way to handle this, so comments on that aspect would be particularly welcome! Interpretation of the temperature depends on knowing the supply voltage. If configured in a board config as a regulator consumer this is obtained from the regulator subsystem. If not it should be provided in the platform data. I've placed this driver in the hwmon subsystem as it is definitely a device that may be used for hardware monitoring and with it's relatively slow response times (up to 120 millisecs to get a reading) a caching strategy certainly seems to make sense! Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
