As explained in 1407814240-4275-1-git-send-email-decui@microsoft.com we
have a hard load dependency between i8042 and atkbd which prevents
keyboard from working on Gen2 Hyper-V VMs.
> hyperv_keyboard invokes serio_interrupt(), which needs a valid serio
> driver like atkbd.c. atkbd.c depends on libps2.c because it invokes
> ps2_command(). libps2.c depends on i8042.c because it invokes
> i8042_check_port_owner(). As a result, hyperv_keyboard actually
> depends on i8042.c.
> For a Generation 2 Hyper-V VM (meaning no i8042 device emulated), if a
> Linux VM (like Arch Linux) happens to configure CONFIG_SERIO_I8042=m
> rather than =y, atkbd.ko can't load because i8042.ko can't load(due to
> no i8042 device emulated) and finally hyperv_keyboard can't work and
> the user can't input: https://bugs.archlinux.org/task/39820
> (Ubuntu/RHEL/SUSE aren't affected since they use CONFIG_SERIO_I8042=y)
To break the dependency we move away from using i8042_check_port_owner()
and instead allow serio port owner specify a mutex that clients should use
to serialize PS/2 command stream.
Reported-by: Mark Laws <mdl@60hz.org>
Tested-by: Mark Laws <mdl@60hz.org>
Cc: stable@vger.kernel.org
A big problem with the current i8042 debugging option is that it outputs
data going to and from the keyboard by default. As a result, many dmesg
logs uploaded by users will unintentionally contain sensitive information
such as their password, as such it's probably a good idea not to output
data coming from the keyboard unless specifically enabled by the user.
Signed-off-by: Stephen Chandler Paul <cpaul@redhat.com>
Reviewed-by: Andreas Mohr <andim2@users.sf.net>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
serio devices exposed via platform firmware interfaces such as ACPI may
provide additional identifying information of use to userspace.
We don't associate the serio devices with the firmware device (we don't
set it as parent), so there's no way for userspace to make use of this
information.
We cannot change the parent for serio devices instantiated though a
firmware interface as that would break suspend / resume ordering.
Therefore this patch adds a new firmware_id sysfs attribute so that
userspace can get a string from there with any additional identifying
information the firmware interface may provide.
Acked-by: Peter Hutterer <peter.hutterer@who-t.net>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
This patch introduces the module_serio_driver macro which is a
convenience macro for serio driver modules similar to
module_platform_driver. It is intended to be used by drivers
which init/exit section does nothing but registers/unregisters
the serio driver. By using this macro it is possible to eliminate
a few lines of boilerplate code per serio driver.
Based on work done by Lars-Peter Clausen <lars@metafoo.de> for
other buses (i2c and spi).
The original implementations reference THIS_MODULE in an inline.
We could include <linux/export.h>, but it is better to avoid chaining.
Fortunately someone else already thought of this, and made a similar
inline into a #define in <linux/device.h> for device_schedule_callback(),
[see commit 523ded71de0] so follow that precedent here.
Also bubble up any __must_check that were used on the prev. wrapper inline
functions up one to the real __register functions, to preserve any prev.
sanity checks that were used in those instances.
This patch adds the TSC-40 serial touchscreen driver and should be
compatible with TSC-10 and TSC-25.
The driver was written by Linutronix on behalf of Bachmann electronic GmbH.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
PS2Mult is a simple serial protocol used for multiplexing several PS/2
streams into one serial data stream. It's used e.g. on TQM85xx series
of boards.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Some (rare) serio devices need to have multiple serio children. One of
the examples is PS/2 multiplexer present on several TQC STKxxx boards,
which connect PS/2 keyboard and mouse to single tty port.
Nobody uses it anymore.
Memory pointed to by these fields is not supposed to change.
Adds support for Hampshire TSHARC serial touchscreens. Implements
Hampshire's 4-byte communication protocol.
Signed-off-by: Adam Bennett <abennett72@gmail.com>
No need to keep track of it by ourselves.
sysfs_remove_group() waits for sysfs attributes to be removed, therefore
we do not need to worry about driver-specific attributes being accessed
after driver has been detached from the device. In fact, attempts to take
serio->drv_mutex in attribute methods may lead to the following deadlock:
sysfs_read_file()
fill_read_buffer()
sysfs_get_active_two()
psmouse_attr_show_helper()
serio_pin_driver()
serio_disconnect_driver()
mutex_lock(&serio->drv_mutex);
<--------> mutex_lock(&serio_drv_mutex);
psmouse_disconnect()
sysfs_remove_group(... psmouse_attr_group);
sysfs_deactivate();
wait_for_completion();
Fix this by removing calls to serio_[un]pin_driver() and functions themselves
and using driver-private mutexes to serialize access to attribute's set()
methods that may change device state.
This is a driver for Dynapro serial touchscreen, which used to be
supported in Xorg. The driver needs updated inputattach utility to
initialize serial port and create proper serio device before the
driver will be bound to it.
Signed-off-by: Tias Guns <tias@ulyssis.org>
Protocol 0x37 has been reserved for iNexio devices and Sahara
was supposed to get 0x38.
Reported-by: Claudio Nieder <private@claudio.ch>
The Wacom W8001 sensor is a sensor device (uses electromagnetic
resonance) and it is interfaced via its serial microcontroller
to the host.
Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com>
Also remove extra declaration of serio_register_driver().
In include/linux/serio.h two different define-series are documented as
"Serio types". However the second series contains defines for the
different protocols.
Signed-off-by: Niels de Vos <niels.devos@wincor-nixdorf.com>
Signed-off-by: Claudio Nieder <private@claudio.ch>
Signed-off-by: Richard Lemon <richard@codelemon.com>
This is a driver for Zhen Hua PPM-4CH RC transmitter (commonly used in cheap
Ready To Fly RC helicopters by Walkera) which using "Zhen Hua 5-byte protocol"
for using them as a four axis joystick via serial port. Transmitter connected
to serial port (19200 8N1) sending periodically 5 bytes where first byte is for
synchronization and next four bytes are values of axis.
Signed-off-by: Martin Kebert <gkmarty@gmail.com>
These serial touchscreens are found on some Fujitsu lifebook
P-series laptops, and the B6210. Using this requires a new
version of inputattach and doing:
inputattach -fjt /dev/ttyS0
Big thanks to Stephen Hemminger for testing it and making it
work on his B6210 laptop.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This is a new I2C bus driver for the TAOS evaluation modules. Developped
and tested on the TAOS TSL2550 EVM.
Let serio subsystem take care of suspending the ports; concentrate
on suspending/resuming the controller itself.
This adds the module name to all SERIO drivers, if they are built into
the kernel or not. It will show up in /sys/modules/MODULE_NAME/drivers/
Cc: Kay Sievers <kay.sievers@suse.de>
Perform actual driver registration right in serio_register_driver()
instead of offloading it to kseriod and return proper error code to
callers if driver registration fails.
Note that driver <-> port matching is still done by kseriod to
speed up boot process since probing for PS/2 mice and keyboards
is pretty slow.
Now that i8042 reserves IRQs early there are no more users of this
function and it should be removed.
Signed-off-by: Jiri Kosina <jikos@jikos.cz>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Signed-off-by: Rick Koch <n1gp@hotmail.com>
arch/powerpc/kernel/setup-common.c
drivers/input/keyboard/hil_kbd.c
drivers/input/mouse/hil_ptr.c
s/fucntion/function/ typo fixes
Signed-off-by: Akinobu Mita <mita@miraclelinux.com>
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
to allow easy switching at run-time.
infrastructure for it.
Let it rip!
