path: root/include/linux/serial_sci.h
2011-01-19serial: sh-sci: Kill off some DMA ifdeffery.Paul Mundt
There's nothing worth hiding under the ifdef in the platform DMA definitions, and we certainly don't want board code adding this in to their platform data definitions, so we always expose the slave rx/tx and device pointer members instead. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-19serial: sh-sci: Provide a helper for muxed IRQs.Paul Mundt
All of the muxed IRQs presently populate the IRQ array verbosely, this simply provides a trivial helper to do it for them. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-19serial: sh-sci: Kill off unused membase kludge.Paul Mundt
All users of the platform port data specify a mapbase where the driver later derives the membase from. Now that UPF flags are taken in to account for generic ioremapping we can kill off the port-specific membase clobbering and simply use the generic paths. This derives from a time when sh64 was not capable of using the generic ioremap implementation and had employed early bolted DTLB mappings for port access, which is no longer an issue. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-19serial: sh-sci: Kill off unused clock string.Paul Mundt
Now that the clock string isn't used by the driver anymore, kill it off from the platform structure. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-13Merge branch 'master' of ↵Paul Mundt
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 into common/serial-rework Conflicts: arch/sh/kernel/cpu/sh2/setup-sh7619.c arch/sh/kernel/cpu/sh2a/setup-mxg.c arch/sh/kernel/cpu/sh2a/setup-sh7201.c arch/sh/kernel/cpu/sh2a/setup-sh7203.c arch/sh/kernel/cpu/sh2a/setup-sh7206.c arch/sh/kernel/cpu/sh3/setup-sh7705.c arch/sh/kernel/cpu/sh3/setup-sh770x.c arch/sh/kernel/cpu/sh3/setup-sh7710.c arch/sh/kernel/cpu/sh3/setup-sh7720.c arch/sh/kernel/cpu/sh4/setup-sh4-202.c arch/sh/kernel/cpu/sh4/setup-sh7750.c arch/sh/kernel/cpu/sh4/setup-sh7760.c arch/sh/kernel/cpu/sh4a/setup-sh7343.c arch/sh/kernel/cpu/sh4a/setup-sh7366.c arch/sh/kernel/cpu/sh4a/setup-sh7722.c arch/sh/kernel/cpu/sh4a/setup-sh7723.c arch/sh/kernel/cpu/sh4a/setup-sh7724.c arch/sh/kernel/cpu/sh4a/setup-sh7763.c arch/sh/kernel/cpu/sh4a/setup-sh7770.c arch/sh/kernel/cpu/sh4a/setup-sh7780.c arch/sh/kernel/cpu/sh4a/setup-sh7785.c arch/sh/kernel/cpu/sh4a/setup-sh7786.c arch/sh/kernel/cpu/sh4a/setup-shx3.c arch/sh/kernel/cpu/sh5/setup-sh5.c drivers/serial/sh-sci.c drivers/serial/sh-sci.h include/linux/serial_sci.h
2010-05-25serial: sh-sci: fix up serial DMA build.Paul Mundt
asm/dmaengine.h no longer exists, update for the shared linux/sh_dma.h header. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-23dmaengine: shdma: Remove sh_dmae_slave_chan_id enumMagnus Damm
This patch replaces the sh_dmae_slave_chan_id enum with an unsigned int. The purpose of this chainge is to make it possible to separate the slave id enums from the dmaengine header. The slave id enums varies with processor model, so in the future it makes sense to put these in the processor specific headers together with the pinmux enums. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-10serial: sh-sci: Fix build failure for non-sh architectures.Peter Huewe
This patch fixes a build failure for various arm based defconfigs [1][2][3] and maybe other architectures/configs. The build failure was introduced by the sh specific patch [4] "serial: sh-sci: Add DMA support" by Guennadi Liakhovetski Patch against linux-next of 20100309 References: [1] http://kisskb.ellerman.id.au/kisskb/buildresult/2248992/ [2] http://kisskb.ellerman.id.au/kisskb/buildresult/2248996/ [3] http://kisskb.ellerman.id.au/kisskb/buildresult/2248998/ [4] http://git.kernel.org/?p=linux/kernel/git/sfr/linux-next.git;a=commit;h=73a19e4c0301908ce6346715fd08a74308451f5a Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-02serial: sh-sci: Add DMA support.Guennadi Liakhovetski
Support using DMA for sending and receiving data over SCI(F) interfaces of various SH SoCs. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-24serial: sh-sci: Move SCBRR calculation algo in to platform data.Paul Mundt
This permits each port to select its own SCBRR calculation algorithm, rather than having it all ifdef'ed in the header. There are presently only 5 different variations that all parts fall under. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-24serial: sh-sci: Move SCSCR_INIT in to platform data.Paul Mundt
This moves all of the SCSCR_INIT definitions in to the platform data, for future consolidation. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-08sh-sci: improve clock framework supportMagnus Damm
Use enable/disable hooks for clock framework integration. Make sure we control the clock for the serial console as well. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-08sh-sci: remove early_sci_setup()Magnus Damm
Remove unused early_sci_setup() function from sh-sci. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-26serial: Move asm-sh/sci.h to linux/serial_sci.h.Paul Mundt
This header is needed on other architectures as well (namely h8300), which currently fails to build without this in place. Rather than duplicating the port definition completely there, just move this to a common location instead. This should get h8300 working again for 2.6.25, in addition to the changes already pushed by Sato-san in -rc2. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
