path: root/include/linux/rtc.h
2009-01-04rtc: add alarm/update irq interfacesAlessandro Zummo
Add standard interfaces for alarm/update irqs enabling. Drivers are no more required to implement equivalent ioctl code as rtc-dev will provide it. UIE emulation should now be handled correctly and will work even for those RTC drivers who cannot be configured to do both UIE and AIE. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26drivers/char/rtc.c: make 2 functions staticAdrian Bunk
The following functions can now become static: - rtc_interrupt() - rtc_get_rtc_time() Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Bernhard Walle <bwalle@suse.de> Acked-by: Paul Gortmaker <p_gortmaker@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc: remove BKL for ioctl()David Brownell
Remove implicit use of BKL in ioctl() from the RTC framework. Instead, the rtc->ops_lock is used. That's the same lock that already protects the RTC operations when they're issued through the exported rtc_*() calls in drivers/rtc/interface.c ... making this a bugfix, not just a cleanup, since both ioctl calls and set_alarm() need to update IRQ enable flags and that implies a common lock (which RTC drivers as a rule do not provide on their own). A new comment at the declaration of "struct rtc_class_ops" summarizes current locking rules. It's not clear to me that the exceptions listed there should exist ... if not, those are pre-existing problems which can be fixed in a patch that doesn't relate to BKL removal. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jonathan Corbet <corbet@lwn.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29RTC: convert mutex to bitfieldJiri Kosina
RTC code is using mutex to assure exclusive access to /dev/rtc. This is however wrong usage, as it leaves the mutex locked when returning into userspace, which is unacceptable. Convert rtc->char_lock into bit operation. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08revert "rtc: Add rtc_merge_alarm()"Andrew Morton
David says "884b4aaaa242a2db8c8252796f0118164a680ab5 should be reverted. It added an rtc_merge_alarm() call to the 2.6.20 kernel, which hasn't yet been used by any in-tree driver; this patch obviates the need for that call, and uses a more robust approach." Cc: Scott Wood <scottwood@freescale.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove rest of class_deviceDavid Brownell
Finish converting the RTC framework so it no longer uses class_device. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove /sys/class/rtc-dev/*David Brownell
This simplifies the /dev support by removing a superfluous class_device (the /sys/class/rtc-dev stuff) and the class_interface that hooks it into the rtc core. Accordingly, if it's configured then /dev support is now part of the RTC core, and is never a separate module. It's another step towards being able to remove "struct class_device". [bunk@stusta.de: drivers/rtc/rtc-dev.c should #include "rtc-core.h"] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[PATCH] rtc: Add rtc_merge_alarm()Scott Wood
Add rtc_merge_alarm(), which can be used by rtc drivers to turn a partially specified alarm expiry (i.e. most significant fields set to -1, as with the RTC_ALM_SET ioctl()) into a fully specified expiry. If the most significant specified field is earlier than the current time, the least significant unspecified field is incremented. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-01[PATCH] constify rtc_class_ops: update driversDavid Brownell
Update RTC framework so that drivers can constify their method tables, moving them from ".data" to ".rodata". Then update the drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] Correct rtc_wkalrm commentsAndrew Victor
This corrects the comments describing the 'enabled' and 'pending' flags in struct rtc_wkalrm of include/linux/rtc.h. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] RTC: Add rtc_year_days() to calculate tm_ydayAndrew Victor
RTC: Add exported function rtc_year_days() to calculate the tm_yday value. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] rtc subsystem: add capability checksAlessandro Zummo
Centralize CAP_SYS_XXX checks to avoid duplicate code and missing checks in the drivers. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] RTC: rtc-dev UIE emulationAtsushi Nemoto
Import genrtc's RTC UIE emulation (CONFIG_GEN_RTC_X) to rtc-dev driver with slight adjustments/refinements. This makes UIE-less rtc drivers work better with programs doing read/poll on /dev/rtc, such as hwclock. This emulation should not harm rtc drivers with UIE support, since rtc_dev_ioctl() calls underlaying rtc driver's ioctl() first. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: classAlessandro Zummo
Add the basic RTC subsystem infrastructure to the kernel. rtc/class.c - registration facilities for RTC drivers rtc/interface.c - kernel/rtc interface functions rtc/hctosys.c - snippet of code that copies hw clock to sw clock at bootup, if configured to do so. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC Subsystem: library functionsAlessandro Zummo
RTC and date/time related functions. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] rtc.h broke strace(1) buildsJoe Korty
Git patch 52dfa9a64cfb3dd01fa1ee1150d589481e54e28e [PATCH] move rtc_interrupt() prototype to rtc.h broke strace(1) builds. The below moves the kernel-only additions lower, under the already provided #ifdef __KERNEL__ statement. Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] move rtc_interrupt() prototype to rtc.hAdrian Bunk
This patch moves the rtc_interrupt() prototype to rtc.h and removes the prototypes from C files. It also renames static rtc_interrupt() functions in arch/arm/mach-integrator/time.c and arch/sh64/kernel/time.c to avoid compile problems. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Paul Gortmaker <p_gortmaker@yahoo.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
