path: root/include/linux/ring_buffer.h
2011-08-30trace: Add ring buffer stats to measure rate of eventsVaibhav Nagarnaik
The stats file under per_cpu folder provides the number of entries, overruns and other statistics about the CPU ring buffer. However, the numbers do not provide any indication of how full the ring buffer is in bytes compared to the overall size in bytes. Also, it is helpful to know the rate at which the cpu buffer is filling up. This patch adds an entry "bytes: " in printed stats for per_cpu ring buffer which provides the actual bytes consumed in the ring buffer. This field includes the number of bytes used by recorded events and the padding bytes added when moving the tail pointer to next page. It also adds the following time stamps: "oldest event ts:" - the oldest timestamp in the ring buffer "now ts:" - the timestamp at the time of reading The field "now ts" provides a consistent time snapshot to the userspace when being read. This is read from the same trace clock used by tracing event timestamps. Together, these values provide the rate at which the buffer is filling up, from the formula: bytes / (now_ts - oldest_event_ts) Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Cc: Michael Rubin <mrubin@google.com> Cc: David Sharp <dhsharp@google.com> Link: http://lkml.kernel.org/r/1313531179-9323-3-git-send-email-vnagarnaik@google.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing: Use NUMA allocation for per-cpu ring buffer pagesVaibhav Nagarnaik
The tracing ring buffer is a group of per-cpu ring buffers where allocation and logging is done on a per-cpu basis. The events that are generated on a particular CPU are logged in the corresponding buffer. This is to provide wait-free writes between CPUs and good NUMA node locality while accessing the ring buffer. However, the allocation routines consider NUMA locality only for buffer page metadata and not for the actual buffer page. This causes the pages to be allocated on the NUMA node local to the CPU where the allocation routine is running at the time. This patch fixes the problem by using a NUMA node specific allocation routine so that the pages are allocated from a NUMA node local to the logging CPU. I tested with the getuid_microbench from autotest. It is a simple binary that calls getuid() in a loop and measures the average time for the syscall to complete. The following command was used to test: $ getuid_microbench 1000000 Compared the numbers found on kernel with and without this patch and found that logging latency decreases by 30-50 ns/call. tracing with non-NUMA allocation - 569 ns/call tracing with NUMA allocation - 512 ns/call Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Michael Rubin <mrubin@google.com> Cc: David Sharp <dhsharp@google.com> Link: http://lkml.kernel.org/r/1304470602-20366-1-git-send-email-vnagarnaik@google.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-09tracing: Add an 'overwrite' trace_option.David Sharp
Add an "overwrite" trace_option for ftrace to control whether the buffer should be overwritten on overflow or not. The default remains to overwrite old events when the buffer is full. This patch adds the option to instead discard newest events when the buffer is full. This is useful to get a snapshot of traces just after enabling traces. Dropping the current event is also a simpler code path. Signed-off-by: David Sharp <dhsharp@google.com> LKML-Reference: <1291844807-15481-1-git-send-email-dhsharp@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-20ring-buffer: Remove ring_buffer_event_time_delta()Steven Rostedt
The ring_buffer_event_time_delta() static inline function does not have any users. Remove it. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-27ring-buffer: Make non-consuming read less expensive with lots of cpus.David Miller
When performing a non-consuming read, a synchronize_sched() is performed once for every cpu which is actively tracing. This is very expensive, and can make it take several seconds to open up the 'trace' file with lots of cpus. Only one synchronize_sched() call is actually necessary. What is desired is for all cpus to see the disabling state change. So we transform the existing sequence: for_each_cpu() { ring_buffer_read_start(); } where each ring_buffer_start() call performs a synchronize_sched(), into the following: for_each_cpu() { ring_buffer_read_prepare(); } ring_buffer_read_prepare_sync(); for_each_cpu() { ring_buffer_read_start(); } wherein only the single ring_buffer_read_prepare_sync() call needs to do the synchronize_sched(). The first phase, via ring_buffer_read_prepare(), allocates the 'iter' memory and increments ->record_disabled. In the second phase, ring_buffer_read_prepare_sync() makes sure this ->record_disabled state is visible fully to all cpus. And in the final third phase, the ring_buffer_read_start() calls reset the 'iter' objects allocated in the first phase since we now know that none of the cpus are adding trace entries any more. This makes openning the 'trace' file nearly instantaneous on a sparc64 Niagara2 box with 128 cpus tracing. Signed-off-by: David S. Miller <davem@davemloft.net> LKML-Reference: <20100420.154711.11246950.davem@davemloft.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-03-31ring-buffer: Add place holder recording of dropped eventsSteven Rostedt
Currently, when the ring buffer drops events, it does not record the fact that it did so. It does inform the writer that the event was dropped by returning a NULL event, but it does not put in any place holder where the event was dropped. This is not a trivial thing to add because the ring buffer mostly runs in overwrite (flight recorder) mode. That is, when the ring buffer is full, new data will overwrite old data. In a produce/consumer mode, where new data is simply dropped when the ring buffer is full, it is trivial to add the placeholder for dropped events. When there's more room to write new data, then a special event can be added to notify the reader about the dropped events. But in overwrite mode, any new write can overwrite events. A place holder can not be inserted into the ring buffer since there never may be room. A reader could also come in at anytime and miss the placeholder. Luckily, the way the ring buffer works, the read side can find out if events were lost or not, and how many events. Everytime a write takes place, if it overwrites the header page (the next read) it updates a "overrun" variable that keeps track of the number of lost events. When a reader swaps out a page from the ring buffer, it can record this number, perfom the swap, and then check to see if the number changed, and take the diff if it has, which would be the number of events dropped. This can be stored by the reader and returned to callers of the reader. Since the reader page swap will fail if the writer moved the head page since the time the reader page set up the swap, this gives room to record the overruns without worrying about races. If the reader sets up the pages, records the overrun, than performs the swap, if the swap succeeds, then the overrun variable has not been updated since the setup before the swap. For binary readers of the ring buffer, a flag is set in the header of each sub page (sub buffer) of the ring buffer. This flag is embedded in the size field of the data on the sub buffer, in the 31st bit (the size can be 32 or 64 bits depending on the architecture), but only 27 bits needs to be used for the actual size (less actually). We could add a new field in the sub buffer header to also record the number of events dropped since the last read, but this will change the format of the binary ring buffer a bit too much. Perhaps this change can be made if the information on the number of events dropped is considered important enough. Note, the notification of dropped events is only used by consuming reads or peeking at the ring buffer. Iterating over the ring buffer does not keep this information because the necessary data is only available when a page swap is made, and the iterator does not swap out pages. Cc: Robert Richter <robert.richter@amd.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "Luis Claudio R. Goncalves" <lclaudio@uudg.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-04ring-buffer: only enable ring_buffer_swap_cpu when neededSteven Rostedt
Since the ability to swap the cpu buffers adds a small overhead to the recording of a trace, we only want to add it when needed. Only the irqsoff and preemptoff tracers use this feature, and both are not recommended for production kernels. This patch disables its use when neither irqsoff nor preemptoff is configured. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-04ring-buffer: remove ring_buffer_event_discardSteven Rostedt
The function ring_buffer_event_discard can be used on any item in the ring buffer, even after the item was committed. This function provides no safety nets and is very race prone. An item may be safely removed from the ring buffer before it is committed with the ring_buffer_discard_commit. Since there are currently no users of this function, and because this function is racey and error prone, this patch removes it altogether. Note, removing this function also allows the counters to ignore all discarded events (patches will follow). Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-07-07ring-buffer: make locklessSteven Rostedt
This patch converts the ring buffers into a completely lockless buffer recording system. The read side still takes locks since we still serialize readers. But the writers are the ones that must be lockless (those can happen in NMIs). The main change is to the "head_page" pointer. We write to the tail, and read from the head. The "head_page" pointer in the cpu buffer is now just a reference to where to look. The real head page is now kept in the head_page->list->prev->next pointer. That is, in the list head of the previous page we set flags. The list pages are allocated to be aligned such that the lowest significant bits are always zero pointing to the list. This gives us play to put in flags to their pointers. bit 0: set when the page is a head page bit 1: set when the writer is moving the page (for overwrite mode) cmpxchg is used to update the pointer. When the writer wraps the buffer and the tail meets the head, in overwrite mode, the writer must move the head page forward. It first uses cmpxchg to change the pointer flag from 1 to 2. Once this is done, the reader on another CPU will not take the page from the buffer. The writers need to protect against interrupts (we don't bother with disabling interrupts because NMIs are allowed to write too). After the writer sets the pointer flag to 2, it takes care to manage interrupts coming in. This is discribed in detail within the comments of the code. Changes in version 2: - Let reader reset entries value of header page. - Fix tail page passing commit page on reader page test. - Always increment entries and write counter in rb_tail_page_update - Add safety check in rb_set_commit_to_write to break out of infinite loop - add mask in rb_is_reader_page [ Impact: lock free writing to the ring buffer ] Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-06-15trace: annotate bitfields in struct ring_buffer_eventVegard Nossum
This gets rid of a heap of false-positive warnings from the tracer code due to the use of bitfields. [rebased for mainline inclusion] Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-08ring-buffer: pass in lockdep class key for reader_lockPeter Zijlstra
On Sun, 7 Jun 2009, Ingo Molnar wrote: > Testing tracer sched_switch: <6>Starting ring buffer hammer > PASSED > Testing tracer sysprof: PASSED > Testing tracer function: PASSED > Testing tracer irqsoff: > ============================================= > PASSED > Testing tracer preemptoff: PASSED > Testing tracer preemptirqsoff: [ INFO: possible recursive locking detected ] > PASSED > Testing tracer branch: 2.6.30-rc8-tip-01972-ge5b9078-dirty #5760 > --------------------------------------------- > rb_consumer/431 is trying to acquire lock: > (&cpu_buffer->reader_lock){......}, at: [<c109eef7>] ring_buffer_reset_cpu+0x37/0x70 > > but task is already holding lock: > (&cpu_buffer->reader_lock){......}, at: [<c10a019e>] ring_buffer_consume+0x7e/0xc0 > > other info that might help us debug this: > 1 lock held by rb_consumer/431: > #0: (&cpu_buffer->reader_lock){......}, at: [<c10a019e>] ring_buffer_consume+0x7e/0xc0 The ring buffer is a generic structure, and can be used outside of ftrace. If ftrace traces within the use of the ring buffer, it can produce false positives with lockdep. This patch passes in a static lock key into the allocation of the ring buffer, so that different ring buffers will have their own lock class. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1244477919.13761.9042.camel@twins> [ store key in ring buffer descriptor ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-05-05ring-buffer: add counters for commit overrun and nmi dropped entriesSteven Rostedt
The WARN_ON in the ring buffer when a commit is preempted and the buffer is filled by preceding writes can happen in normal operations. The WARN_ON makes it look like a bug, not to mention, because it does not stop tracing and calls printk which can also recurse, this is prone to deadlock (the WARN_ON is not in a position to recurse). This patch removes the WARN_ON and replaces it with a counter that can be retrieved by a tracer. This counter is called commit_overrun. While at it, I added a nmi_dropped counter to count any time an NMI entry is dropped because the NMI could not take the spinlock. [ Impact: prevent deadlock by printing normal case warning ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-24ring_buffer: compressed event headerLai Jiangshan
RB_MAX_SMALL_DATA = 28bytes is too small for most tracers, it wastes an 'u32' to save the actually length for events which data size > 28. This fix uses compressed event header and enlarges RB_MAX_SMALL_DATA. [ Impact: saves about 0%-12.5%(depends on tracer) memory in ring_buffer ] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <49F13189.3090000@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-17tracing/events/ring-buffer: expose format of ring buffer headers to usersSteven Rostedt
Currently, every thing needed to read the binary output from the ring buffers is available, with the exception of the way the ring buffers handles itself internally. This patch creates two special files in the debugfs/tracing/events directory: # cat /debug/tracing/events/header_page field: u64 timestamp; offset:0; size:8; field: local_t commit; offset:8; size:8; field: char data; offset:16; size:4080; # cat /debug/tracing/events/header_event type : 2 bits len : 3 bits time_delta : 27 bits array : 32 bits padding : type == 0 time_extend : type == 1 data : type == 3 This is to allow a userspace app to see if the ring buffer format changes or not. [ Impact: allow userspace apps to know of ringbuffer format changes ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14ring-buffer: add ring_buffer_discard_commitSteven Rostedt
The ring_buffer_discard_commit is similar to ring_buffer_event_discard but it can only be done on an event that has yet to be commited. Unpredictable results can happen otherwise. The main difference between ring_buffer_discard_commit and ring_buffer_event_discard is that ring_buffer_discard_commit will try to free the data in the ring buffer if nothing has addded data after the reserved event. If something did, then it acts almost the same as ring_buffer_event_discard followed by a ring_buffer_unlock_commit. Note, either ring_buffer_commit_discard and ring_buffer_unlock_commit can be called on an event, not both. This commit also exports both discard functions to be usable by GPL modules. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-22tracing: add ring_buffer_event_discard() to ring bufferTom Zanussi
This patch overloads RINGBUF_TYPE_PADDING to provide a way to discard events from the ring buffer, for the event-filtering mechanism introduced in a subsequent patch. I did the initial version but thanks to Steven Rostedt for adding the parts that actually made it work. ;-) Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-17ring-buffer: add api to allow a tracer to change clock sourceSteven Rostedt
This patch adds a new function called ring_buffer_set_clock that allows a tracer to assign its own clock source to the buffer. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-05tracing: add tracing_on/tracing_off to kernel.hSteven Rostedt
Impact: cleanup The functions tracing_start/tracing_stop have been moved to kernel.h. These are not the functions a developer most likely wants to use when they want to insert a place to stop tracing and restart it from user space. tracing_start/tracing_stop was created to work with things like suspend to ram, where even calling smp_processor_id() can crash the system. The tracing_start/tracing_stop was used to stop the tracer from doing anything. These are still light weight functions, but add a bit more overhead to be able to stop the tracers. They also have no interface back to userland. That is, if the kernel calls tracing_stop, userland can not start tracing. What a developer most likely wants to use is tracing_on/tracing_off. These are very light weight functions (simply sets or clears a bit). These functions just stop recording into the ring buffer. The tracers don't even know that this happens except that they would receive NULL from the ring_buffer_lock_reserve function. Also, there's a way for the user land to enable or disable this bit. In debugfs/tracing/tracing_on, a user may echo "0" (same as tracing_off()) or echo "1" (same as tracing_on()) into this file. This becomes handy when a kernel developer is debugging and wants tracing to turn off when it hits an anomaly. Then the developer can examine the trace, and restart tracing if they want to try again (echo 1 > tracing_on). This patch moves the prototypes for tracing_on/tracing_off to kernel.h and comments their use, so that a kernel developer will know how to use them. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-03ring-buffer: fix ring_buffer_read_pageSteven Rostedt
The ring_buffer_read_page was broken if it were to only copy part of the page. This patch fixes that up as well as adds a parameter to allow a length field, in order to only copy part of the buffer page. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-16ring-buffer: add tracing_is_on to test if ring buffer is enabledSteven Rostedt
This patch adds the tracing_is_on() interface to tell if the ring buffer is turned on or not. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-10tracing: fix typos in commentsWenji Huang
Impact: clean up. Fix typos in the comments. Signed-off-by: Wenji Huang <wenji.huang@oracle.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-09Merge branch 'tip/tracing/core/devel' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into tracing/ftrace Conflicts: kernel/trace/trace_hw_branches.c
2009-02-07ring-buffer: allow tracing_off to be used in core kernel codeSteven Rostedt
tracing_off() is the fastest way to stop recording to the ring buffers. This may be used in places like panic and die, just before the ftrace_dump is called. This patch adds the appropriate CPP conditionals to make it a stub function when the ring buffer is not configured it. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-06ring_buffer: remove unused flags parameterArnaldo Carvalho de Melo
Impact: API change, cleanup >From ring_buffer_{lock_reserve,unlock_commit}. $ codiff /tmp/vmlinux.before /tmp/vmlinux.after linux-2.6-tip/kernel/trace/trace.c: trace_vprintk | -14 trace_graph_return | -14 trace_graph_entry | -10 trace_function | -8 __ftrace_trace_stack | -8 ftrace_trace_userstack | -8 tracing_sched_switch_trace | -8 ftrace_trace_special | -12 tracing_sched_wakeup_trace | -8 9 functions changed, 90 bytes removed, diff: -90 linux-2.6-tip/block/blktrace.c: __blk_add_trace | -1 1 function changed, 1 bytes removed, diff: -1 /tmp/vmlinux.after: 10 functions changed, 91 bytes removed, diff: -91 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Frédéric Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-30Merge branch 'oprofile-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'oprofile-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: oprofile: select RING_BUFFER ring_buffer: adding EXPORT_SYMBOLs oprofile: fix lost sample counter oprofile: remove nr_available_slots() oprofile: port to the new ring_buffer ring_buffer: add remaining cpu functions to ring_buffer.h oprofile: moving cpu_buffer_reset() to cpu_buffer.h oprofile: adding cpu_buffer_entries() oprofile: adding cpu_buffer_write_commit() oprofile: adding cpu buffer r/w access functions ftrace: remove unused function arg in trace_iterator_increment() ring_buffer: update description for ring_buffer_alloc() oprofile: set values to default when creating oprofilefs oprofile: implement switch/case in buffer_sync.c x86/oprofile: cleanup IBS init/exit functions in op_model_amd.c x86/oprofile: reordering IBS code in op_model_amd.c oprofile: fix typo oprofile: whitspace changes only oprofile: update comment for oprofile_add_sample() oprofile: comment cleanup
2008-12-10ring_buffer: add remaining cpu functions to ring_buffer.hRobert Richter
These functions are not yet in ring_buffer.h though they seems to be part of the API. Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Robert Richter <robert.richter@amd.com>
2008-12-08ring_buffer: fix commentsLai Jiangshan
Impact: comments cleanup fix incorrect comments for enum ring_buffer_type Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-03ring-buffer: read page interfaceSteven Rostedt
Impact: new API to ring buffer This patch adds a new interface into the ring buffer that allows a page to be read from the ring buffer on a given CPU. For every page read, one must also be given to allow for a "swap" of the pages. rpage = ring_buffer_alloc_read_page(buffer); if (!rpage) goto err; ret = ring_buffer_read_page(buffer, &rpage, cpu, full); if (!ret) goto empty; process_page(rpage); ring_buffer_free_read_page(rpage); The caller of these functions must handle any waits that are needed to wait for new data. The ring_buffer_read_page will simply return 0 if there is no data, or if "full" is set and the writer is still on the current page. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-23ring-buffer: add tracing_off_permanentSteven Rostedt
Impact: feature to permanently disable ring buffer This patch adds a API to the ring buffer code that will permanently disable the ring buffer from ever recording. This should only be called when some serious anomaly is detected, and the system may be in an unstable state. When that happens, shutting down the recording to the ring buffers may be appropriate. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-11ring-buffer: buffer record on/off switchSteven Rostedt
Impact: enable/disable ring buffer recording API added Several kernel developers have requested that there be a way to stop recording into the ring buffers with a simple switch that can also be enabled from userspace. This patch addes a new kernel API to the ring buffers called: tracing_on() tracing_off() When tracing_off() is called, all ring buffers will not be able to record into their buffers. tracing_on() will enable the ring buffers again. These two act like an on/off switch. That is, there is no counting of the number of times tracing_off or tracing_on has been called. A new file is added to the debugfs/tracing directory called tracing_on This allows for userspace applications to also flip the switch. echo 0 > debugfs/tracing/tracing_on disables the tracing. echo 1 > /debugfs/tracing/tracing_on enables it. Note, this does not disable or enable any tracers. It only sets or clears a flag that needs to be set in order for the ring buffers to write to their buffers. It is a global flag, and affects all ring buffers. The buffers start out with tracing_on enabled. There are now three flags that control recording into the buffers: tracing_on: which affects all ring buffer tracers. buffer->record_disabled: which affects an allocated buffer, which may be set if an anomaly is detected, and tracing is disabled. cpu_buffer->record_disabled: which is set by tracing_stop() or if an anomaly is detected. tracing_start can not reenable this if an anomaly occurred. The userspace debugfs/tracing/tracing_enabled is implemented with tracing_stop() but the user space code can not enable it if the kernel called tracing_stop(). Userspace can enable the tracing_on even if the kernel disabled it. It is just a switch used to stop tracing if a condition was hit. tracing_on is not for protecting critical areas in the kernel nor is it for stopping tracing if an anomaly occurred. This is because userspace can reenable it at any time. Side effect: With this patch, I discovered a dead variable in ftrace.c called tracing_on. This patch removes it. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2008-10-14ring_buffer: implement new lockingSteven Rostedt
The old "lock always" scheme had issues with lockdep, and was not very efficient anyways. This patch does a new design to be partially lockless on writes. Writes will add new entries to the per cpu pages by simply disabling interrupts. When a write needs to go to another page than it will grab the lock. A new "read page" has been added so that the reader can pull out a page from the ring buffer to read without worrying about the writer writing over it. This allows us to not take the lock for all reads. The lock is now only taken when a read needs to go to a new page. This is far from lockless, and interrupts still need to be disabled, but it is a step towards a more lockless solution, and it also solves a lot of the issues that were noticed by the first conversion of ftrace to the ring buffers. Note: the ring_buffer_{un}lock API has been removed. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14tracing: unified trace bufferSteven Rostedt
This is a unified tracing buffer that implements a ring buffer that hopefully everyone will eventually be able to use. The events recorded into the buffer have the following structure: struct ring_buffer_event { u32 type:2, len:3, time_delta:27; u32 array[]; }; The minimum size of an event is 8 bytes. All events are 4 byte aligned inside the buffer. There are 4 types (all internal use for the ring buffer, only the data type is exported to the interface users). RINGBUF_TYPE_PADDING: this type is used to note extra space at the end of a buffer page. RINGBUF_TYPE_TIME_EXTENT: This type is used when the time between events is greater than the 27 bit delta can hold. We add another 32 bits, and record that in its own event (8 byte size). RINGBUF_TYPE_TIME_STAMP: (Not implemented yet). This will hold data to help keep the buffer timestamps in sync. RINGBUF_TYPE_DATA: The event actually holds user data. The "len" field is only three bits. Since the data must be 4 byte aligned, this field is shifted left by 2, giving a max length of 28 bytes. If the data load is greater than 28 bytes, the first array field holds the full length of the data load and the len field is set to zero. Example, data size of 7 bytes: type = RINGBUF_TYPE_DATA len = 2 time_delta: <time-stamp> - <prev_event-time-stamp> array[0..1]: <7 bytes of data> <1 byte empty> This event is saved in 12 bytes of the buffer. An event with 82 bytes of data: type = RINGBUF_TYPE_DATA len = 0 time_delta: <time-stamp> - <prev_event-time-stamp> array[0]: 84 (Note the alignment) array[1..14]: <82 bytes of data> <2 bytes empty> The above event is saved in 92 bytes (if my math is correct). 82 bytes of data, 2 bytes empty, 4 byte header, 4 byte length. Do not reference the above event struct directly. Use the following functions to gain access to the event table, since the ring_buffer_event structure may change in the future. ring_buffer_event_length(event): get the length of the event. This is the size of the memory used to record this event, and not the size of the data pay load. ring_buffer_time_delta(event): get the time delta of the event This returns the delta time stamp since the last event. Note: Even though this is in the header, there should be no reason to access this directly, accept for debugging. ring_buffer_event_data(event): get the data from the event This is the function to use to get the actual data from the event. Note, it is only a pointer to the data inside the buffer. This data must be copied to another location otherwise you risk it being written over in the buffer. ring_buffer_lock: A way to lock the entire buffer. ring_buffer_unlock: unlock the buffer. ring_buffer_alloc: create a new ring buffer. Can choose between overwrite or consumer/producer mode. Overwrite will overwrite old data, where as consumer producer will throw away new data if the consumer catches up with the producer. The consumer/producer is the default. ring_buffer_free: free the ring buffer. ring_buffer_resize: resize the buffer. Changes the size of each cpu buffer. Note, it is up to the caller to provide that the buffer is not being used while this is happening. This requirement may go away but do not count on it. ring_buffer_lock_reserve: locks the ring buffer and allocates an entry on the buffer to write to. ring_buffer_unlock_commit: unlocks the ring buffer and commits it to the buffer. ring_buffer_write: writes some data into the ring buffer. ring_buffer_peek: Look at a next item in the cpu buffer. ring_buffer_consume: get the next item in the cpu buffer and consume it. That is, this function increments the head pointer. ring_buffer_read_start: Start an iterator of a cpu buffer. For now, this disables the cpu buffer, until you issue a finish. This is just because we do not want the iterator to be overwritten. This restriction may change in the future. But note, this is used for static reading of a buffer which is usually done "after" a trace. Live readings would want to use the ring_buffer_consume above, which will not disable the ring buffer. ring_buffer_read_finish: Finishes the read iterator and reenables the ring buffer. ring_buffer_iter_peek: Look at the next item in the cpu iterator. ring_buffer_read: Read the iterator and increment it. ring_buffer_iter_reset: Reset the iterator to point to the beginning of the cpu buffer. ring_buffer_iter_empty: Returns true if the iterator is at the end of the cpu buffer. ring_buffer_size: returns the size in bytes of each cpu buffer. Note, the real size is this times the number of CPUs. ring_buffer_reset_cpu: Sets the cpu buffer to empty ring_buffer_reset: sets all cpu buffers to empty ring_buffer_swap_cpu: swaps a cpu buffer from one buffer with a cpu buffer of another buffer. This is handy when you want to take a snap shot of a running trace on just one cpu. Having a backup buffer, to swap with facilitates this. Ftrace max latencies use this. ring_buffer_empty: Returns true if the ring buffer is empty. ring_buffer_empty_cpu: Returns true if the cpu buffer is empty. ring_buffer_record_disable: disable all cpu buffers (read only) ring_buffer_record_disable_cpu: disable a single cpu buffer (read only) ring_buffer_record_enable: enable all cpu buffers. ring_buffer_record_enabl_cpu: enable a single cpu buffer. ring_buffer_entries: The number of entries in a ring buffer. ring_buffer_overruns: The number of entries removed due to writing wrap. ring_buffer_time_stamp: Get the time stamp used by the ring buffer ring_buffer_normalize_time_stamp: normalize the ring buffer time stamp into nanosecs. I still need to implement the GTOD feature. But we need support from the cpu frequency infrastructure. But this can be done at a later time without affecting the ring buffer interface. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
