path: root/include/linux/rcutree.h
2009-09-23rcu: Clean up code to address Ingo's checkpatch feedbackPaul E. McKenney
Move declarations and update storage classes to make checkpatch happy. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12537246441701-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23rcu: Clean up code based on review feedback from Josh Triplett, part 2Paul E. McKenney
These issues identified during an old-fashioned face-to-face code review extending over many hours. o Add comments for tricky parts of code, and correct comments that have passed their sell-by date. o Get rid of the vestiges of rcu_init_sched(), which is no longer needed now that PREEMPT_RCU is gone. o Move the #include of rcutree_plugin.h to the end of rcutree.c, which means that, rather than having a random collection of forward declarations, the new set of forward declarations document the set of plugins. The new home for this #include also allows __rcu_init_preempt() to move into rcutree_plugin.h. o Fix rcu_preempt_check_callbacks() to be static. Suggested-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12537246443924-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu> Peter Zijlstra <peterz@infradead.org>
2009-09-23rcu: Clean up code based on review feedback from Josh TriplettPaul E. McKenney
These issues identified during an old-fashioned face-to-face code review extended over many hours. o Bury various forms of the "rsp->completed == rsp->gpnum" comparison into an rcu_gp_in_progress() function, which has the beneficial side-effect of forcing consistent use of ACCESS_ONCE(). o Replace hand-coded arithmetic with DIV_ROUND_UP(). o Bury several "!list_empty(&rnp->blocked_tasks[rnp->gpnum & 0x01])" instances into an rcu_preempted_readers() function, as this expression indicates that there are no readers blocked within RCU read-side critical sections blocking the current grace period. (Though there might well be similar readers blocking the next grace period.) o Remove a dangling rcu_restart_cpu() declaration that has been dangling for almost 20 minor releases of the kernel. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12537246442687-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19rcu: Fix whitespace inconsistenciesPaul E. McKenney
Fix a number of whitespace ^Ierrors in the include/linux/rcu* and the kernel/rcu* files. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <20090918172819.GA24405@linux.vnet.ibm.com> [ did more checkpatch fixlets ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18rcu: Fix synchronize_rcu() for TREE_PREEMPT_RCUPaul E. McKenney
The redirection of synchronize_sched() to synchronize_rcu() was appropriate for TREE_RCU, but not for TREE_PREEMPT_RCU. Fix this by creating an underlying synchronize_sched(). TREE_RCU then redirects synchronize_rcu() to synchronize_sched(), while TREE_PREEMPT_RCU has its own version of synchronize_rcu(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <12528585111916-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Merge preemptable-RCU functionality into hierarchical RCUPaul E. McKenney
Create a kernel/rcutree_plugin.h file that contains definitions for preemptable RCU (or, under the #else branch of the #ifdef, empty definitions for the classic non-preemptable semantics). These definitions fit into plugins defined in kernel/rcutree.c for this purpose. This variant of preemptable RCU uses a new algorithm whose read-side expense is roughly that of classic hierarchical RCU under CONFIG_PREEMPT. This new algorithm's update-side expense is similar to that of classic hierarchical RCU, and, in absence of read-side preemption or blocking, is exactly that of classic hierarchical RCU. Perhaps more important, this new algorithm has a much simpler implementation, saving well over 1,000 lines of code compared to mainline's implementation of preemptable RCU, which will hopefully be retired in favor of this new algorithm. The simplifications are obtained by maintaining per-task nesting state for running tasks, and using a simple lock-protected algorithm to handle accounting when tasks block within RCU read-side critical sections, making use of lessons learned while creating numerous user-level RCU implementations over the past 18 months. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746134003-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Simplify rcu_pending()/rcu_check_callbacks() APIPaul E. McKenney
All calls from outside RCU are of the form: if (rcu_pending(cpu)) rcu_check_callbacks(cpu, user); This is silly, instead we put a call to rcu_pending() in rcu_check_callbacks(), and then make the outside calls be to rcu_check_callbacks(). This cuts down on the code a bit and also gives the compiler a better chance of optimizing. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <125097461311-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Consolidate sparse and lockdep declarations in include/linux/rcupdate.hPaul E. McKenney
Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746132349-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Renamings to increase RCU clarityPaul E. McKenney
Make RCU-sched, RCU-bh, and RCU-preempt be underlying implementations, with "RCU" defined in terms of one of the three. Update the outdated rcu_qsctr_inc() names, as these functions no longer increment anything. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746132696-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Move private definitions from include/linux/rcutree.h to kernel/rcutree.hPaul E. McKenney
Some information hiding that makes it easier to merge preemptability into rcutree without descending into #include hell. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <1250974613373-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-03rcu: Add synchronize_sched_expedited() primitivePaul E. McKenney
This adds the synchronize_sched_expedited() primitive that implements the "big hammer" expedited RCU grace periods. This primitive is placed in kernel/sched.c rather than kernel/rcupdate.c due to its need to interact closely with the migration_thread() kthread. The idea is to wake up this kthread with req->task set to NULL, in response to which the kthread reports the quiescent state resulting from the kthread having been scheduled. Because this patch needs to fallback to the slow versions of the primitives in response to some races with CPU onlining and offlining, a new synchronize_rcu_bh() primitive is added as well. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Cc: davem@davemloft.net Cc: dada1@cosmosbay.com Cc: zbr@ioremap.net Cc: jeff.chua.linux@gmail.com Cc: paulus@samba.org Cc: laijs@cn.fujitsu.com Cc: jengelh@medozas.de Cc: r000n@r000n.net Cc: benh@kernel.crashing.org Cc: mathieu.desnoyers@polymtl.ca LKML-Reference: <12459460982947-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14rcu: Add __rcu_pending tracing to hierarchical RCUPaul E. McKenney
Add tracing to __rcu_pending() to provide information on why RCU processing was kicked off. This is helpful for debugging hierarchical RCU, and might also be helpful in learning how hierarchical RCU operates. Located-by: Anton Blanchard <anton@au1.ibm.com> Tested-by: Anton Blanchard <anton@au1.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: anton@samba.org Cc: akpm@linux-foundation.org Cc: dipankar@in.ibm.com Cc: manfred@colorfullife.com Cc: cl@linux-foundation.org Cc: josht@linux.vnet.ibm.com Cc: schamp@sgi.com Cc: niv@us.ibm.com Cc: dvhltc@us.ibm.com Cc: ego@in.ibm.com Cc: laijs@cn.fujitsu.com Cc: rostedt@goodmis.org Cc: peterz@infradead.org Cc: penberg@cs.helsinki.fi Cc: andi@firstfloor.org Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> LKML-Reference: <1239683479943-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14rcu: Make hierarchical RCU less IPI-happyPaul E. McKenney
This patch fixes a hierarchical-RCU performance bug located by Anton Blanchard. The problem stems from a misguided attempt to provide a work-around for jiffies-counter failure. This work-around uses a per-CPU n_rcu_pending counter, which is incremented on each call to rcu_pending(), which in turn is called from each scheduling-clock interrupt. Each CPU then treats this counter as a surrogate for the jiffies counter, so that if the jiffies counter fails to advance, the per-CPU n_rcu_pending counter will cause RCU to invoke force_quiescent_state(), which in turn will (among other things) send resched IPIs to CPUs that have thus far failed to pass through an RCU quiescent state. Unfortunately, each CPU resets only its own counter after sending a batch of IPIs. This means that the other CPUs will also (needlessly) send -another- round of IPIs, for a full N-squared set of IPIs in the worst case every three scheduler-clock ticks until the grace period finally ends. It is not reasonable for a given CPU to reset each and every n_rcu_pending for all the other CPUs, so this patch instead simply disables the jiffies-counter "training wheels", thus eliminating the excessive IPIs. Note that the jiffies-counter IPIs do not have this problem due to the fact that the jiffies counter is global, so that the CPU sending the IPIs can easily reset things, thus preventing the other CPUs from sending redundant IPIs. Note also that the n_rcu_pending counter remains, as it will continue to be used for tracing. It may also see use to update the jiffies counter, should an appropriate kick-the-jiffies-counter API appear. Located-by: Anton Blanchard <anton@au1.ibm.com> Tested-by: Anton Blanchard <anton@au1.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: anton@samba.org Cc: akpm@linux-foundation.org Cc: dipankar@in.ibm.com Cc: manfred@colorfullife.com Cc: cl@linux-foundation.org Cc: josht@linux.vnet.ibm.com Cc: schamp@sgi.com Cc: niv@us.ibm.com Cc: dvhltc@us.ibm.com Cc: ego@in.ibm.com Cc: laijs@cn.fujitsu.com Cc: rostedt@goodmis.org Cc: peterz@infradead.org Cc: penberg@cs.helsinki.fi Cc: andi@firstfloor.org Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> LKML-Reference: <12396834793575-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace, rcu: don't include unnecessary headers, allow kmemtrace w/ ↵Eduard - Gabriel Munteanu
tracepoints Impact: cleanup linux/percpu.h includes linux/slab.h, which generates circular inclusion dependencies when trying to switch kmemtrace to use tracepoints instead of markers. This patch allows tracing within slab headers' inline functions. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: paulmck@linux.vnet.ibm.com LKML-Reference: <1237898630.25315.83.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace, rcu: fix linux/rcutree.h and linux/rcuclassic.h dependenciesIngo Molnar
Impact: build fix for all non-x86 architectures We want to remove percpu.h from rcuclassic.h/rcutree.h (for upcoming kmemtrace changes) but that would break the DECLARE_PER_CPU based declarations in these files. Move the quiescent counter management functions to their respective RCU implementation .c files - they were slightly above the inlining limit anyway. Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: paulmck@linux.vnet.ibm.com LKML-Reference: <1237898630.25315.83.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-26rcu: Teach RCU that idle task is not quiscent state at bootPaul E. McKenney
This patch fixes a bug located by Vegard Nossum with the aid of kmemcheck, updated based on review comments from Nick Piggin, Ingo Molnar, and Andrew Morton. And cleans up the variable-name and function-name language. ;-) The boot CPU runs in the context of its idle thread during boot-up. During this time, idle_cpu(0) will always return nonzero, which will fool Classic and Hierarchical RCU into deciding that a large chunk of the boot-up sequence is a big long quiescent state. This in turn causes RCU to prematurely end grace periods during this time. This patch changes the rcutree.c and rcuclassic.c rcu_check_callbacks() function to ignore the idle task as a quiescent state until the system has started up the scheduler in rest_init(), introducing a new non-API function rcu_idle_now_means_idle() to inform RCU of this transition. RCU maintains an internal rcu_idle_cpu_truthful variable to track this state, which is then used by rcu_check_callback() to determine if it should believe idle_cpu(). Because this patch has the effect of disallowing RCU grace periods during long stretches of the boot-up sequence, this patch also introduces Josh Triplett's UP-only optimization that makes synchronize_rcu() be a no-op if num_online_cpus() returns 1. This allows boot-time code that calls synchronize_rcu() to proceed normally. Note, however, that RCU callbacks registered by call_rcu() will likely queue up until later in the boot sequence. Although rcuclassic and rcutree can also use this same optimization after boot completes, rcupreempt must restrict its use of this optimization to the portion of the boot sequence before the scheduler starts up, given that an rcupreempt RCU read-side critical section may be preeempted. In addition, this patch takes Nick Piggin's suggestion to make the system_state global variable be __read_mostly. Changes since v4: o Changes the name of the introduced function and variable to be less emotional. ;-) Changes since v3: o WARN_ON(nr_context_switches() > 0) to verify that RCU switches out of boot-time mode before the first context switch, as suggested by Nick Piggin. Changes since v2: o Created rcu_blocking_is_gp() internal-to-RCU API that determines whether a call to synchronize_rcu() is itself a grace period. o The definition of rcu_blocking_is_gp() for rcuclassic and rcutree checks to see if but a single CPU is online. o The definition of rcu_blocking_is_gp() for rcupreempt checks to see both if but a single CPU is online and if the system is still in early boot. This allows rcupreempt to again work correctly if running on a single CPU after booting is complete. o Added check to rcupreempt's synchronize_sched() for there being but one online CPU. Tested all three variants both SMP and !SMP, booted fine, passed a short rcutorture test on both x86 and Power. Located-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-18"Tree RCU": scalable classic RCU implementationPaul E. McKenney
This patch fixes a long-standing performance bug in classic RCU that results in massive internal-to-RCU lock contention on systems with more than a few hundred CPUs. Although this patch creates a separate flavor of RCU for ease of review and patch maintenance, it is intended to replace classic RCU. This patch still handles stress better than does mainline, so I am still calling it ready for inclusion. This patch is against the -tip tree. Nevertheless, experience on an actual 1000+ CPU machine would still be most welcome. Most of the changes noted below were found while creating an rcutiny (which should permit ejecting the current rcuclassic) and while doing detailed line-by-line documentation. Updates from v9 (http://lkml.org/lkml/2008/12/2/334): o Fixes from remainder of line-by-line code walkthrough, including comment spelling, initialization, undesirable narrowing due to type conversion, removing redundant memory barriers, removing redundant local-variable initialization, and removing redundant local variables. I do not believe that any of these fixes address the CPU-hotplug issues that Andi Kleen was seeing, but please do give it a whirl in case the machine is smarter than I am. A writeup from the walkthrough may be found at the following URL, in case you are suffering from terminal insomnia or masochism: http://www.kernel.org/pub/linux/kernel/people/paulmck/tmp/rcutree-walkthrough.2008.12.16a.pdf o Made rcutree tracing use seq_file, as suggested some time ago by Lai Jiangshan. o Added a .csv variant of the rcudata debugfs trace file, to allow people having thousands of CPUs to drop the data into a spreadsheet. Tested with oocalc and gnumeric. Updated documentation to suit. Updates from v8 (http://lkml.org/lkml/2008/11/15/139): o Fix a theoretical race between grace-period initialization and force_quiescent_state() that could occur if more than three jiffies were required to carry out the grace-period initialization. Which it might, if you had enough CPUs. o Apply Ingo's printk-standardization patch. o Substitute local variables for repeated accesses to global variables. o Fix comment misspellings and redundant (but harmless) increments of ->n_rcu_pending (this latter after having explicitly added it). o Apply checkpatch fixes. Updates from v7 (http://lkml.org/lkml/2008/10/10/291): o Fixed a number of problems noted by Gautham Shenoy, including the cpu-stall-detection bug that he was having difficulty convincing me was real. ;-) o Changed cpu-stall detection to wait for ten seconds rather than three in order to reduce false positive, as suggested by Ingo Molnar. o Produced a design document (http://lwn.net/Articles/305782/). The act of writing this document uncovered a number of both theoretical and "here and now" bugs as noted below. o Fix dynticks_nesting accounting confusion, simplify WARN_ON() condition, fix kerneldoc comments, and add memory barriers in dynticks interface functions. o Add more data to tracing. o Remove unused "rcu_barrier" field from rcu_data structure. o Count calls to rcu_pending() from scheduling-clock interrupt to use as a surrogate timebase should jiffies stop counting. o Fix a theoretical race between force_quiescent_state() and grace-period initialization. Yes, initialization does have to go on for some jiffies for this race to occur, but given enough CPUs... Updates from v6 (http://lkml.org/lkml/2008/9/23/448): o Fix a number of checkpatch.pl complaints. o Apply review comments from Ingo Molnar and Lai Jiangshan on the stall-detection code. o Fix several bugs in !CONFIG_SMP builds. o Fix a misspelled config-parameter name so that RCU now announces at boot time if stall detection is configured. o Run tests on numerous combinations of configurations parameters, which after the fixes above, now build and run correctly. Updates from v5 (http://lkml.org/lkml/2008/9/15/92, bad subject line): o Fix a compiler error in the !CONFIG_FANOUT_EXACT case (blew a changeset some time ago, and finally got around to retesting this option). o Fix some tracing bugs in rcupreempt that caused incorrect totals to be printed. o I now test with a more brutal random-selection online/offline script (attached). Probably more brutal than it needs to be on the people reading it as well, but so it goes. o A number of optimizations and usability improvements: o Make rcu_pending() ignore the grace-period timeout when there is no grace period in progress. o Make force_quiescent_state() avoid going for a global lock in the case where there is no grace period in progress. o Rearrange struct fields to improve struct layout. o Make call_rcu() initiate a grace period if RCU was idle, rather than waiting for the next scheduling clock interrupt. o Invoke rcu_irq_enter() and rcu_irq_exit() only when idle, as suggested by Andi Kleen. I still don't completely trust this change, and might back it out. o Make CONFIG_RCU_TRACE be the single config variable manipulated for all forms of RCU, instead of the prior confusion. o Document tracing files and formats for both rcupreempt and rcutree. Updates from v4 for those missing v5 given its bad subject line: o Separated dynticks interface so that NMIs and irqs call separate functions, greatly simplifying it. In particular, this code no longer requires a proof of correctness. ;-) o Separated dynticks state out into its own per-CPU structure, avoiding the duplicated accounting. o The case where a dynticks-idle CPU runs an irq handler that invokes call_rcu() is now correctly handled, forcing that CPU out of dynticks-idle mode. o Review comments have been applied (thank you all!!!). For but one example, fixed the dynticks-ordering issue that Manfred pointed out, saving me much debugging. ;-) o Adjusted rcuclassic and rcupreempt to handle dynticks changes. Attached is an updated patch to Classic RCU that applies a hierarchy, greatly reducing the contention on the top-level lock for large machines. This passes 10-hour concurrent rcutorture and online-offline testing on 128-CPU ppc64 without dynticks enabled, and exposes some timekeeping bugs in presence of dynticks (exciting working on a system where "sleep 1" hangs until interrupted...), which were fixed in the 2.6.27 kernel. It is getting more reliable than mainline by some measures, so the next version will be against -tip for inclusion. See also Manfred Spraul's recent patches (or his earlier work from 2004 at http://marc.info/?l=linux-kernel&m=108546384711797&w=2). We will converge onto a common patch in the fullness of time, but are currently exploring different regions of the design space. That said, I have already gratefully stolen quite a few of Manfred's ideas. This patch provides CONFIG_RCU_FANOUT, which controls the bushiness of the RCU hierarchy. Defaults to 32 on 32-bit machines and 64 on 64-bit machines. If CONFIG_NR_CPUS is less than CONFIG_RCU_FANOUT, there is no hierarchy. By default, the RCU initialization code will adjust CONFIG_RCU_FANOUT to balance the hierarchy, so strongly NUMA architectures may choose to set CONFIG_RCU_FANOUT_EXACT to disable this balancing, allowing the hierarchy to be exactly aligned to the underlying hardware. Up to two levels of hierarchy are permitted (in addition to the root node), allowing up to 16,384 CPUs on 32-bit systems and up to 262,144 CPUs on 64-bit systems. I just know that I am going to regret saying this, but this seems more than sufficient for the foreseeable future. (Some architectures might wish to set CONFIG_RCU_FANOUT=4, which would limit such architectures to 64 CPUs. If this becomes a real problem, additional levels can be added, but I doubt that it will make a significant difference on real hardware.) In the common case, a given CPU will manipulate its private rcu_data structure and the rcu_node structure that it shares with its immediate neighbors. This can reduce both lock and memory contention by multiple orders of magnitude, which should eliminate the need for the strange manipulations that are reported to be required when running Linux on very large systems. Some shortcomings: o More bugs will probably surface as a result of an ongoing line-by-line code inspection. Patches will be provided as required. o There are probably hangs, rcutorture failures, &c. Seems quite stable on a 128-CPU machine, but that is kind of small compared to 4096 CPUs. However, seems to do better than mainline. Patches will be provided as required. o The memory footprint of this version is several KB larger than rcuclassic. A separate UP-only rcutiny patch will be provided, which will reduce the memory footprint significantly, even compared to the old rcuclassic. One such patch passes light testing, and has a memory footprint smaller even than rcuclassic. Initial reaction from various embedded guys was "it is not worth it", so am putting it aside. Credits: o Manfred Spraul for ideas, review comments, and bugs spotted, as well as some good friendly competition. ;-) o Josh Triplett, Ingo Molnar, Peter Zijlstra, Mathieu Desnoyers, Lai Jiangshan, Andi Kleen, Andy Whitcroft, and Andrew Morton for reviews and comments. o Thomas Gleixner for much-needed help with some timer issues (see patches below). o Jon M. Tollefson, Tim Pepper, Andrew Theurer, Jose R. Santos, Andy Whitcroft, Darrick Wong, Nishanth Aravamudan, Anton Blanchard, Dave Kleikamp, and Nathan Lynch for keeping machines alive despite my heavy abuse^Wtesting. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
