[ Upstream commit 860c8802ace14c646864795e057349c9fb2d60ad ]
Eric Dumazet supplied a KCSAN report of a bug that forces use
of hlist_unhashed_lockless() from sk_unhashed():
BUG: KCSAN: data-race in inet_unhash / inet_unhash
write to 0xffff8880a69a0170 of 8 bytes by interrupt on cpu 1:
__hlist_nulls_del include/linux/list_nulls.h:88 [inline]
hlist_nulls_del_init_rcu include/linux/rculist_nulls.h:36 [inline]
__sk_nulls_del_node_init_rcu include/net/sock.h:676 [inline]
inet_unhash+0x38f/0x4a0 net/ipv4/inet_hashtables.c:612
tcp_set_state+0xfa/0x3e0 net/ipv4/tcp.c:2249
tcp_done+0x93/0x1e0 net/ipv4/tcp.c:3854
tcp_write_err+0x7e/0xc0 net/ipv4/tcp_timer.c:56
tcp_retransmit_timer+0x9b8/0x16d0 net/ipv4/tcp_timer.c:479
tcp_write_timer_handler+0x42d/0x510 net/ipv4/tcp_timer.c:599
tcp_write_timer+0xd1/0xf0 net/ipv4/tcp_timer.c:619
call_timer_fn+0x5f/0x2f0 kernel/time/timer.c:1404
expire_timers kernel/time/timer.c:1449 [inline]
__run_timers kernel/time/timer.c:1773 [inline]
__run_timers kernel/time/timer.c:1740 [inline]
run_timer_softirq+0xc0c/0xcd0 kernel/time/timer.c:1786
__do_softirq+0x115/0x33f kernel/softirq.c:292
invoke_softirq kernel/softirq.c:373 [inline]
irq_exit+0xbb/0xe0 kernel/softirq.c:413
exiting_irq arch/x86/include/asm/apic.h:536 [inline]
smp_apic_timer_interrupt+0xe6/0x280 arch/x86/kernel/apic/apic.c:1137
apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:830
native_safe_halt+0xe/0x10 arch/x86/kernel/paravirt.c:71
arch_cpu_idle+0x1f/0x30 arch/x86/kernel/process.c:571
default_idle_call+0x1e/0x40 kernel/sched/idle.c:94
cpuidle_idle_call kernel/sched/idle.c:154 [inline]
do_idle+0x1af/0x280 kernel/sched/idle.c:263
cpu_startup_entry+0x1b/0x20 kernel/sched/idle.c:355
start_secondary+0x208/0x260 arch/x86/kernel/smpboot.c:264
secondary_startup_64+0xa4/0xb0 arch/x86/kernel/head_64.S:241
read to 0xffff8880a69a0170 of 8 bytes by interrupt on cpu 0:
sk_unhashed include/net/sock.h:607 [inline]
inet_unhash+0x3d/0x4a0 net/ipv4/inet_hashtables.c:592
rest_init+0xec/0xf6 init/main.c:452
arch_call_rest_init+0x17/0x37
start_kernel+0x838/0x85e init/main.c:786
x86_64_start_reservations+0x29/0x2b arch/x86/kernel/head64.c:490
x86_64_start_kernel+0x72/0x76 arch/x86/kernel/head64.c:471
Reported by Kernel Concurrency Sanitizer on:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.0-rc6+ #0
Hardware name: Google Google Compute Engine/Google Compute Engine,
BIOS Google 01/01/2011
This commit therefore replaces C-language assignments with WRITE_ONCE()
in include/linux/list_nulls.h and include/linux/rculist_nulls.h.
Reported-by: Eric Dumazet <edumazet@google.com> # For KCSAN
Signed-off-by: Paul E. McKenney <paulmck@kernel.org>
[ Upstream commit 8dbd76e79a16b45b2ccb01d2f2e08dbf64e71e40 ]
Michal Kubecek and Firo Yang did a very nice analysis of crashes
happening in __inet_lookup_established().
Since a TCP socket can go from TCP_ESTABLISH to TCP_LISTEN
(via a close()/socket()/listen() cycle) without a RCU grace period,
I should not have changed listeners linkage in their hash table.
They must use the nulls protocol (Documentation/RCU/rculist_nulls.txt),
so that a lookup can detect a socket in a hash list was moved in
another one.
Since we added code in commit d296ba60d8e2 ("soreuseport: Resolve
merge conflict for v4/v6 ordering fix"), we have to add
hlist_nulls_add_tail_rcu() helper.
Fixes: 3b24d854cb35 ("tcp/dccp: do not touch listener sk_refcnt under synflood")
Reported-by: Michal Kubecek <mkubecek@suse.cz>
Reported-by: Firo Yang <firo.yang@suse.com>
Reviewed-by: Michal Kubecek <mkubecek@suse.cz>
Link: https://lore.kernel.org/netdev/20191120083919.GH27852@unicorn.suse.cz/
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
As we move stuff around, some doc references are broken. Fix some of
them via this script:
./scripts/documentation-file-ref-check --fix
Manually checked if the produced result is valid, removing a few
false-positives.
Acked-by: Takashi Iwai <tiwai@suse.de>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Stephen Boyd <sboyd@kernel.org>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Acked-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Reviewed-by: Coly Li <colyli@suse.de>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Acked-by: Jonathan Corbet <corbet@lwn.net>
Alexander Potapenko reported use of uninitialized memory [1]
This happens when inserting a request socket into TCP ehash,
in __sk_nulls_add_node_rcu(), since sk_reuseport is not initialized.
Bug was added by commit d894ba18d4e4 ("soreuseport: fix ordering for
mixed v4/v6 sockets")
Note that d296ba60d8e2 ("soreuseport: Resolve merge conflict for v4/v6
ordering fix") missed the opportunity to get rid of
hlist_nulls_add_tail_rcu() :
Both UDP sockets and TCP/DCCP listeners no longer use
__sk_nulls_add_node_rcu() for their hash insertion.
Since all other sockets have unique 4-tuple, the reuseport status
has no special meaning, so we can always use hlist_nulls_add_head_rcu()
for them and save few cycles/instructions.
[1]
BUG: KMSAN: use of uninitialized memory in inet_ehash_insert+0xd40/0x1050
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.13.0+ #3288
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16
dump_stack+0x185/0x1d0 lib/dump_stack.c:52
kmsan_report+0x13f/0x1c0 mm/kmsan/kmsan.c:1016
__msan_warning_32+0x69/0xb0 mm/kmsan/kmsan_instr.c:766
__sk_nulls_add_node_rcu ./include/net/sock.h:684
inet_ehash_insert+0xd40/0x1050 net/ipv4/inet_hashtables.c:413
reqsk_queue_hash_req net/ipv4/inet_connection_sock.c:754
inet_csk_reqsk_queue_hash_add+0x1cc/0x300 net/ipv4/inet_connection_sock.c:765
tcp_conn_request+0x31e7/0x36f0 net/ipv4/tcp_input.c:6414
tcp_v4_conn_request+0x16d/0x220 net/ipv4/tcp_ipv4.c:1314
tcp_rcv_state_process+0x42a/0x7210 net/ipv4/tcp_input.c:5917
tcp_v4_do_rcv+0xa6a/0xcd0 net/ipv4/tcp_ipv4.c:1483
tcp_v4_rcv+0x3de0/0x4ab0 net/ipv4/tcp_ipv4.c:1763
ip_local_deliver_finish+0x6bb/0xcb0 net/ipv4/ip_input.c:216
NF_HOOK ./include/linux/netfilter.h:248
ip_local_deliver+0x3fa/0x480 net/ipv4/ip_input.c:257
dst_input ./include/net/dst.h:477
ip_rcv_finish+0x6fb/0x1540 net/ipv4/ip_input.c:397
ip_rcv+0x10f6/0x15c0 net/ipv4/ip_input.c:488
__netif_receive_skb_core+0x36f6/0x3f60 net/core/dev.c:4298
__netif_receive_skb net/core/dev.c:4336
netif_receive_skb_internal+0x63c/0x19c0 net/core/dev.c:4497
napi_skb_finish net/core/dev.c:4858
napi_gro_receive+0x629/0xa50 net/core/dev.c:4889
e1000_receive_skb drivers/net/ethernet/intel/e1000/e1000_main.c:4018
e1000_clean_rx_irq+0x1492/0x1d30
drivers/net/ethernet/intel/e1000/e1000_main.c:4474
e1000_clean+0x43aa/0x5970 drivers/net/ethernet/intel/e1000/e1000_main.c:3819
napi_poll net/core/dev.c:5500
net_rx_action+0x73c/0x1820 net/core/dev.c:5566
__do_softirq+0x4b4/0x8dd kernel/softirq.c:284
invoke_softirq kernel/softirq.c:364
irq_exit+0x203/0x240 kernel/softirq.c:405
exiting_irq+0xe/0x10 ./arch/x86/include/asm/apic.h:638
do_IRQ+0x15e/0x1a0 arch/x86/kernel/irq.c:263
common_interrupt+0x86/0x86
Fixes: d894ba18d4e4 ("soreuseport: fix ordering for mixed v4/v6 sockets")
Fixes: d296ba60d8e2 ("soreuseport: Resolve merge conflict for v4/v6 ordering fix")
Reported-by: Alexander Potapenko <glider@google.com>
Acked-by: Craig Gallek <kraig@google.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
when all map elements are pre-allocated one cpu can delete and reuse htab_elem
while another cpu is still walking the hlist. In such case the lookup may
miss the element. Convert hlist to hlist_nulls to avoid such scenario.
When bucket lock is taken there is no need to take such precautions,
so only convert map_lookup and map_get_next to nulls.
The race window is extremely small and only reproducible with explicit
udelay() inside lookup_nulls_elem_raw()
Similar to hlist add hlist_nulls_for_each_entry_safe() and
hlist_nulls_entry_safe() helpers.
Fixes: 6c9059817432 ("bpf: pre-allocate hash map elements")
Reported-by: Jonathan Perry <jonperry@fb.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
With the SO_REUSEPORT socket option, it is possible to create sockets
in the AF_INET and AF_INET6 domains which are bound to the same IPv4 address.
This is only possible with SO_REUSEPORT and when not using IPV6_V6ONLY on
the AF_INET6 sockets.
Prior to the commits referenced below, an incoming IPv4 packet would
always be routed to a socket of type AF_INET when this mixed-mode was used.
After those changes, the same packet would be routed to the most recently
bound socket (if this happened to be an AF_INET6 socket, it would
have an IPv4 mapped IPv6 address).
The change in behavior occurred because the recent SO_REUSEPORT optimizations
short-circuit the socket scoring logic as soon as they find a match. They
did not take into account the scoring logic that favors AF_INET sockets
over AF_INET6 sockets in the event of a tie.
To fix this problem, this patch changes the insertion order of AF_INET
and AF_INET6 addresses in the TCP and UDP socket lists when the sockets
have SO_REUSEPORT set. AF_INET sockets will be inserted at the head of the
list and AF_INET6 sockets with SO_REUSEPORT set will always be inserted at
the tail of the list. This will force AF_INET sockets to always be
considered first.
Fixes: e32ea7e74727 ("soreuseport: fast reuseport UDP socket selection")
Fixes: 125e80b88687 ("soreuseport: fast reuseport TCP socket selection")
Reported-by: Maciej Żenczykowski <maze@google.com>
Signed-off-by: Craig Gallek <kraig@google.com>
Roman Gushchin discovered that udp4_lib_lookup2() was not reloading
first item in the rcu protected list, in case the loop was restarted.
This produced soft lockups as in https://lkml.org/lkml/2013/4/16/37
rcu_dereference(X)/ACCESS_ONCE(X) seem to not work as intended if X is
ptr->field :
In some cases, gcc caches the value or ptr->field in a register.
Use a barrier() to disallow such caching, as documented in
Documentation/atomic_ops.txt line 114
Thanks a lot to Roman for providing analysis and numerous patches.
Diagnosed-by: Roman Gushchin <klamm@yandex-team.ru>
Reported-by: Boris Zhmurov <zhmurov@yandex-team.ru>
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
This avoids warnings from missing __rcu annotations
in the rculist implementation, making it possible to
use the same lists in both RCU and non-RCU cases.
We can add rculist annotations later, together with
lockdep support for rculist, which is missing as well,
but that may involve changing all the users.
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The theory is that use of bare rcu_dereference() is more prone
to error than use of the RCU list-traversal primitives.
Therefore, disable lockdep RCU read-side critical-section
checking in these primitives for the time being. Once all of
the rcu_dereference() uses have been dealt with, it may be time
to re-enable lockdep checking for the RCU list-traversal
primitives.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1266887105-1528-4-git-send-email-paulmck@linux.vnet.ibm.com>
Fix a number of whitespace ^Ierrors in the include/linux/rcu*
and the kernel/rcu* files.
Cc: akpm@linux-foundation.org
Cc: niv@us.ibm.com
LKML-Reference: <20090918172819.GA24405@linux.vnet.ibm.com>
[ did more checkpatch fixlets ]
hlist uses NULL value to finish a chain.
hlist_nulls variant use the low order bit set to 1 to signal an end-of-list marker.
This allows to store many different end markers, so that some RCU lockless
algos (used in TCP/UDP stack for example) can save some memory barriers in
fast paths.
Two new files are added :
- mimics hlist part of include/linux/list.h, derived to hlist_nulls variant
- mimics hlist part of include/linux/rculist.h, derived to hlist_nulls variant
Only four helpers are declared for the moment :
hlist_nulls_del_init_rcu(), hlist_nulls_del_rcu(),
hlist_nulls_add_head_rcu() and hlist_nulls_for_each_entry_rcu()
prefetches() were removed, since an end of list is not anymore NULL value.
prefetches() could trigger useless (and possibly dangerous) memory transactions.
Example of use (extracted from __udp4_lib_lookup())
struct sock *sk, *result;
struct hlist_nulls_node *node;
unsigned short hnum = ntohs(dport);
unsigned int hash = udp_hashfn(net, hnum);
struct udp_hslot *hslot = &udptable->hash[hash];
int score, badness;
rcu_read_lock();
begin:
result = NULL;
badness = -1;
sk_nulls_for_each_rcu(sk, node, &hslot->head) {
score = compute_score(sk, net, saddr, hnum, sport,
daddr, dport, dif);
if (score > badness) {
result = sk;
badness = score;
* if the nulls value we got at the end of this lookup is
* not the expected one, we must restart lookup.
* We probably met an item that was moved to another chain.
if (get_nulls_value(node) != hash)
goto begin;
if (result) {
if (unlikely(!atomic_inc_not_zero(&result->sk_refcnt)))
result = NULL;
else if (unlikely(compute_score(result, net, saddr, hnum, sport,
daddr, dport, dif) < badness)) {
sock_put(result);
goto begin;
rcu_read_unlock();
return result;
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
