Those two new SCM calls are needed from qcom-iommu driver in order
to initialize secure iommu page table.
Signed-off-by: Stanimir Varbanov <stanimir.varbanov@linaro.org>
Signed-off-by: Rob Clark <robdclark@gmail.com>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
This patch adds a set remote state SCM API. This will be used by the
Venus and GPU subsystems to set state on the remote processors.
This work was based on two patch sets by Jordan Crouse and Stanimir
Varbanov.
This will help to compile testing drivers which depends on scm
functions with COMPILE_TEST Kconfig option.
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
This adds the Peripheral Authentication Service (PAS) interface to the
Qualcomm SCM interface. The API is used to authenticate and boot a range
of external processors in various Qualcomm platforms.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Signed-off-by: Andy Gross <agross@codeaurora.org>
HDCP driver needs to check if secure environment supports HDCP. If it's
supported, then it requires to program some registers through SCM.
Add qcom_scm_hdcp_available and qcom_scm_hdcp_req to support these
requirements.
Signed-off-by: Jilai Wang <jilaiw@codeaurora.org>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
Support powering down the calling cpu, by trapping into SCM. This
termination function triggers the ARM cpu to execute WFI instruction,
causing the power controller to safely power the cpu down.
Caches may be flushed before powering down the cpu. If cache controller
is set to turn off when the cpu is powered down, then the flags argument
indicates to the secure mode to flush its cache lines before executing
WFI.The warm boot reset address for the cpu should be set before the
calling into this function for the cpu to resume.
The original code for the qcom_scm_call_atomic1() comes from a patch by
Stephen Boyd [1]. The function scm_call_atomic1() has been cherry picked
and renamed to match the convention used in this file. Since there are
no users of scm_call_atomic2(), the function is not included.
[1]. https://lkml.org/lkml/2014/8/4/765
Signed-off-by: Stephen Boyd <sboyd@codeauraro.org>
Signed-off-by: Lina Iyer <lina.iyer@linaro.org>
A core can be powered down for cpuidle or when it is hotplugged off. In
either case, the warmboot return address would be different. Allow
setting the warmboot address for a specific cpu, optimize and write to
the firmware, if the address is different than the previously set
address.
Export qcom_scm_set_warm_boot_addr function move the warm boot flags to
implementation.
We dont need to export the SCM specific cold boot flags to the platform
code. Export only a function to set the cold boot address.
Architectural changes in the ARM Linux kernel tree mandate the eventual
removal of the mach-* directories. Move the scm driver to
drivers/firmware and the scm header to include/linux to support that
removal.
