[ Upstream commit 1fa5cef283420b3dad93cd6ab04d7125bc1562de ]
refcount of rx_buffer page will be added here originally, so prefetchw
is needed, but after commit 1793668c3b8c ("i40e/i40evf: Update code to
better handle incrementing page count"), and refcount is not added
every time, so change prefetchw as prefetch.
Now it mainly services page_address(), but which accesses struct page
only when WANT_PAGE_VIRTUAL or HASHED_PAGE_VIRTUAL is defined otherwise
it returns address based on offset, so we prefetch it conditionally.
Jakub suggested to define prefetch_page_address in a common header.
Reported-by: kernel test robot <lkp@intel.com>
Suggested-by: Jakub Kicinski <kuba@kernel.org>
Signed-off-by: Li RongQing <lirongqing@baidu.com>
Reviewed-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
Signed-off-by: Tony Nguyen <anthony.l.nguyen@intel.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
